Windows 7 windows 7 sp 1 wireless networking problem
sadeghol
hi,when i update my windows 7 to sp 1 doesn't show other computers in my wireless network and can't ping other PCs but when i connect to wired lan every thing work fine
firewall is off,network discovery is on,no antiviruses has installed and microsoft security essentials is fully disable
sadeghol;
First off, if you are only using the built-in Windows Firewall and Microsoft Security Essentials then turn them both back on as neither should have any impact on your ability to network. As proof of concept turn them on and test with the wired adapter, if it works then so will the wireless. If you are currently using or have in the past, have installed on your computer any other third party AntiVirus/Internet Security Suite like Symantec/Norton, McAfee, AVG, etc. and or any software firewall products like Comodo, ZoneAlarm, etc., even if you have uninstalled them please google their respective vendor specific removal/uninstaller utility and use it to be sure all remnants are gone from your...
sadeghol;
First off, if you are only using the built-in Windows Firewall and Microsoft Security Essentials then turn them both back on as neither should have any impact on your ability to network. As proof of concept turn them on and test with the wired adapter, if it works then so will the wireless. If you are currently using or have in the past, have installed on your computer any other third party AntiVirus/Internet Security Suite like Symantec/Norton, McAfee, AVG, etc. and or any software firewall products like Comodo, ZoneAlarm, etc., even if you have uninstalled them please google their respective vendor specific removal/uninstaller utility and use it to be sure all remnants are gone from your computer (since the wired connection seems to work OK, I don't suspect that this is the issue)
Second open device manager
expand network adapters
select then right click the problem adapter and choose properties
Select the "Driver" tab and
click the button to "Roll Back Driver"
answer any subsequent prompts in the affirmative and reboot.
If that doesn't help, determine the manufacturer and model name, model number and revision number of your wireless adapter and use the manufacturer's website to get the latest driver available for your specific device. If you need some help with that post the information here and someone may be able to locate a driver for you. It might help if you fill out the information regarding your system specs in your user profile area of the site as well as let us know which version of Windows 7 you are using 32 or 64 bit.
when you first connected to wireless have you choose "home network"? If not go to Network options to change it.
thanks
all networking items is enable,internet is shared and work.i using acces point in ad-hoc every thing work fine.do sp1 of windows 7 have new configuration for routers?
thanks
No not in so far as I know. I believe if my understanding is correct that Service Pack 1 for Windows 7, was just one big rollup of all the security updates, patches and hotfixes that had come before. My suspicions were that during that or another update process you had acquired a driver update for your network adapter from Microsoft. Not generally the best source for obtaining hardware driver updates and can sometimes result in a problem.
