DekHog
Hi all...
Is there any utility that can log a wireless network for dropped connections over a period of a few days? I need something that can show me the history of connections that I can compare against the windows application log - my friend thinks the network is dropping out sometimes which means a piece of network software won't work, but I think it's the software that's crashing... just want to compare timestamps of both logs to confirm as it's too random to sit around waiting on it to happen...
TIA
I think I've cracked it... was having a good look around on my own laptop and all wireless connections/disconnections can be tracked under the log in Computer Management at Event Viewer > Applications and Services > Microsoft > Windows > WLAN-Autoconfig.
Event 8003 shows disconnections...
