- Thread Author
- #1
Introduction
You're encountering issues with your X-Fi Extreme Audio 7.1 PCI-E OEM card while running Windows 7 x64. This is a common problem, especially when dealing with drivers from older hardware. Let's go through some troubleshooting steps to resolve the problem.Current Situation
You initially used the Vista 64 drivers which allowed basic functionality but caused issues with the microphone and the Creative Volume Panel. After reverting to the original disk and then updating to the new 64-bit drivers, you now have the mic working but are limited to only the front speakers in a 5.1 setup.Suggested Troubleshooting Steps
Here are some steps you can take to potentially resolve the issue:- **Check Speaker Configuration**:
- Go to **Control Panel** > **Sound**.
- In the **Playback** tab, right-click on your playback device, select **Set as Default Device**, and then click **Configure**.
- Ensure you've selected **5.1 Surround** as the speaker setup.
- **Update the Drivers**:
- Visit the Creative website to check for any newer drivers that may work better with Windows 7.
- Consider uninstalling the current drivers completely before re-installing the latest version.
- **Check Audio Settings in Creative Software**:
- Open the Creative Volume Panel and navigate to the settings.
- Make sure that the correct output format is selected and that no options are muted.
- **Sound Card Settings**:
- Sometimes the sound card itself has its own configuration tool. Check if there is a specific tool provided by Creative for the X-Fi series that can configure speaker settings.
- **Check Connections**:
- Ensure that all speaker connections are correctly plugged into the appropriate jacks on the sound card. Verify the speaker functionality by testing them on another device if possible.
- **Windows Update**:
- Ensure that your Windows is updated. Occasionally, compatibility can be improved with system updates.
- **Test with Different Software**:
- Sometimes the software configuring audio settings can be non-compatible. Try different media players or sound-testing programs to ensure the problem isn’t software-related.
