Windows 7 Xbox wired controller on PC help
Justin Becker
I am having a problem with my Xbox wired controller connecting to some of my games. It works fine on Assassins Creed Black Flag, but other games don't seem to recognize it at all. I have all the drivers and software installed and it connected to my PC just fine but the games don't seem to recognize it at all. I know this controller works too because it works on all the other games on my laptop which is running windows 8. I have looked at a lot of help forums but nothing is helping me, does anyone know the fix?
To address the issue with your Xbox wired controller not being recognized by certain games on your PC, here are some troubleshooting steps you can follow to try and resolve the problem:
Troubleshooting Steps:​
  • Driver Reinstallation:
  • Confirm that you have the latest driver for your Xbox wired controller. Sometimes, a fresh installation can resolve compatibility issues.
  • Controller Setup:
  • Check in the game settings if there is an option to select the controller. Some games need manual configuration to recognize specific controllers.
  • Compatibility Mode:
  • Try running the games in compatibility mode by right-clicking on the game executable, selecting Properties, going to the Compatibility tab, and...
  • Controller Setup:
  • Try running the games in compatibility mode by right-clicking on the game executable, selecting Properties, going to the Compatibility tab, and adjusting settings.
  • Update Game Versions:
  • Ensure that the games where the controller does not work are up to date. A game update might include controller compatibility features.
  • Run as Administrator:
  • Try running the games as an administrator. Right-click on the game executable and choose "Run as administrator."
  • Controller Configuration Software:
  • Some games may require additional software or configurations to recognize specific controllers. Check the game's documentation or support for guidance.
  • DirectX and Visual C++:
  • Make sure you have the latest version of DirectX and Visual C++ Redistributable Packages installed.
  • Check Game Controller Settings:
  • Look in the game settings for specific controller configurations or options related to input devices.
  • USB Port:
  • Try using a different USB port on your PC. Sometimes, connectivity issues can arise from faulty USB ports.
  • Game Controller Settings (Windows):
  • In Windows, navigate to Control Panel > Devices and Printers > right-click on your controller > Game controller settings > Properties > Test to ensure the controller is recognized.
Additional Suggestions:​
  • Game Developer Support: Contact the support for the specific games in which your controller is not recognized. They might provide tailored solutions for controller compatibility issues.
  • Controller Testing: Verify that the controller works on another system to rule out any hardware issues with the controller itself. By following these steps and ensuring game compatibility with your Xbox wired controller, you can increase the chances of resolving the recognition issues in the games where your controller is not being detected.
