- Thread Author
- #1
Solution for Windows 7 (32-bit, will try the same with 64-bit later)
Required (I found these on the manufacturers' CD):-
Driver Date: 15/05/2003
Driver Version: 1.63.515.2003 (or 1.63.0515.2003)
Driver details ... WS01UPH.BIN & ZD1201U.sys
Steps
a) do not install the driver via supplier CD Installation program. If it's already been installed, it won't work with Wimndows 7, so uninstall it.
b) insert the supplier CD, select "Open folder to view files"
c) browse to the lowest-level folder that contains the actual driver (in my case it was called ...EW-7117U\WinXP. Reason? W7 doesn't (yet) seem to work properly with searching for drivers in sub-directories - or at least it didn't work for me and I spent hours on this.
d) Note the name of the folder
e) Start Device Manager
f) in Network Adapters right-click on the problem device, then Properties
g) in the Driver tab click on Update Driver
h) Click on Browse my computer for driver software
i) Type in the name of the folder containing the driver (...EW-7117U\WinXP)
j) follow the on-screen prompts.
HTH, Ray
Steps
HTH, Ray
