The thread discusses a user’s annoyance with on-screen notifications for Caps Lock, Num Lock, and Scroll Lock on Windows, which they find distracting. Several contributors suggest disabling toggle keys through the Control Panel’s Ease of Access settings, but the original poster points out that their system lacks the relevant options due to being on a laptop. The thread ends with the user asking if they can lock or turn off the thread, as they resolved their original issue by reinstalling the OS.
Thread Author
I have a problem,
I understand that I am a junior member, but the only reason I created an account is because of this problem, even though I have been browsing this site for a while now.
Anyways, whenever I press Capslock/numlock/scroll lock, I get a small box at the bottom right of my screen that says for example "numlock: ON." This does not create any problems, but it does get very annoying! If you have any ideas on how to fix this, please let me know.
Thanks
Val Samsonov
cybercore
Hi and welcome to the forums. : )
There is absolutely no problem with being a 'junior' at this forum, everyone is welcome.
Control Panel --> Keyboard --> Key settings tab --> scroll down to Caps lock and double click it --> uncheck the box marked 'Displays CAPS Lock status on screen'.
vsams14
Thread Author #3
I have seen that reply to similar problems, and have tried it, but I don't have a key settings tab in the keyboard settings menu!
I just have a speed tab (general) and a hardware tab. Maybe because I have a laptop the built in keyboard does not offer this?
either way, thanks for trying but this wont work, heres a screenshot of the problem, and the keyboard settings menu:
Joe S
Mine doesn't have those tabs either It looks like his screen shot.
Joe
andreal
t I don't have a key settings tab in the keyboard settings menu either. and that caps lock image in the corner is ridiculous and annoying. help!
cybercore
Is Control Panel >> Ease of Access >> Make the keyboard easier to use>>Turn on toggle keys >> On or Off?
vsams14
Thread Author #7
Is there any way to turn off/lock a thread, because my computer was having some other problems, and I got bored, and re-installed the os from a recovery disk that I had created earlier. Everything is fine now!
