When deleted files do not appear in the Recycle Bin, Windows is usually doing exactly what it was configured to do—just not what you expected. A delete can bypass the Bin because of a per-drive setting, because the item came from a network location, because it was too large for the space allocated to the Bin, or because the Recycle Bin’s underlying folder has become damaged.
The important distinction is this: fixing the Recycle Bin can restore future deletes, but resetting it permanently removes anything currently inside it. Do not reset first if the missing files matter.
Windows 11 shows Recycle Bin properties with a custom 48,828 MB size limit and delete confirmation enabled. First, confirm the files were eligible for the Recycle Bin​
Open the Recycle Bin from the desktop and check that it is not simply filtered or sorted in an unexpected way. Then test it safely:
Quick walkthrough
  • Create a small text file on the Desktop.
  • Delete it normally with the Delete key or the right-click Delete command.
  • Open Recycle Bin.
The Recycle Bin folder is open in File Explorer and displays deleted items if any are currently present.
If that test file appears, the Bin itself is working. The original missing files were probably deleted in a way that bypassed it.
Deletes that normally skip the Bin​
A file may not appear in Recycle Bin if it was:
  • Deleted with Shift + Delete
  • Deleted from Command Prompt, PowerShell, or a script
  • Deleted from a network share or another non-local location
  • Deleted from removable media, depending on the device and its configuration
  • Larger than the maximum Recycle Bin size configured for that drive
  • Removed by an application that performs its own cleanup
Microsoft notes that files deleted from network resources do not go to the local Recycle Bin. In other words, a shared-folder deletion can be more like dropping a file through a trapdoor than tossing it into Windows’ safety net.
Check whether Recycle Bin has been disabled for a drive​
Recycle Bin settings are configured separately for each local drive. A PC with both C: and D: can have a perfectly healthy Bin on one drive and instant deletion on the other.
  • Right-click Recycle Bin on the desktop.
  • Select Properties.
  • Select the drive where the files were stored.
  • Make sure Don’t move files to the Recycle Bin. Remove files immediately when deleted is not selected.
  • Review the Custom size setting.
If the custom size is extremely small, Windows may discard older deleted files—or skip storing a large deletion—to make room. Increase the allocation if you routinely delete large project folders, videos, virtual machines, or game files.
Click Apply, then OK. Repeat the small text-file test.
What success looks like​
A normally deleted small file from that drive should now appear in Recycle Bin. Its original location should be shown in the Original Location column, and right-clicking it should offer Restore.
Show hidden files—but treat $Recycle.Bin as diagnostic territory​
Windows stores deleted items on each local NTFS drive in a protected system folder named $Recycle.Bin. The Recycle Bin interface uses that data along with metadata to show the original filename and location.
Showing hidden files can confirm that the folder exists, but it is not a reliable way to manually restore files. The contents may use altered names, and manually moving or deleting items there can make recovery harder.
In Windows 11:
  • Open File Explorer.
  • Select View > Show > Hidden items.
  • Browse to the root of the affected drive, such as C:\.
In Windows 10:
  • Select the View tab.
  • Enable Hidden items.
To see protected operating-system folders as well:
  • In File Explorer, open Options.
  • Clear Hide protected operating system files (Recommended).
  • Accept the warning only if you understand that these files should not be edited or removed.
  • Look for $Recycle.Bin at the root of the drive.
The View tab of File Explorer Options with the Folder views buttons and the Advanced settings list of file and folder options.
When finished, restore the protected-files setting. This is one of those Windows areas where curiosity is healthy, but enthusiasm with the Delete key is not.
Reset a damaged Recycle Bin​
Use this only after checking the earlier settings and only after accepting that it empties the Bin on the selected drive.
A reset deletes that drive’s $Recycle.Bin folder. Windows automatically builds a new one when the PC restarts or when you delete another file. Microsoft’s rd command documentation confirms that the /s switch removes a directory tree and its contents, while /q suppresses the confirmation prompt—so this command deserves its ominous little moment of silence.
  • Save and close your work.
  • Search for Command Prompt.
  • Right-click it and select Run as administrator.
  • For the system drive, enter:
rd /s /q C:\$Recycle.Bin
  • Press Enter.
  • If affected files were deleted from another local drive, repeat the command with its drive letter. For example:
rd /s /q D:\$Recycle.Bin
  • Restart Windows.
  • Create and delete a small test file to confirm that Recycle Bin has been recreated and is receiving deleted files.
Do not run the command against a drive until you are certain you no longer need anything currently stored in that drive’s Recycle Bin.
If the missing files were never in the Bin​
Resetting the Recycle Bin will not resurrect a file that was deleted permanently. Stop writing new data to the affected drive as much as possible, especially if the data is important. New files, browser caches, updates, and downloads can overwrite the disk space once occupied by deleted data.
For locally stored files that cannot be restored from Recycle Bin or a backup, Microsoft provides Windows File Recovery for Windows 10 and Windows 11. It is a command-line recovery tool, and its source and destination must be different drives. It does not support recovery from cloud storage or network file shares, so check services such as OneDrive’s own Recycle Bin separately if the files were synchronized.
The quick diagnosis​
  • New test files appear in Recycle Bin: the original deletion bypassed the Bin or came from an unsupported location.
  • New test files disappear immediately: check Recycle Bin Properties for that specific drive.
  • Recycle Bin will not display or accept files consistently: reset the affected drive’s $Recycle.Bin only after accepting that its current contents will be erased.
  • Important files are already missing: avoid using the drive unnecessarily and move to backups or recovery tools rather than repeatedly resetting Windows features.
The Recycle Bin is a helpful buffer, not a time machine. A few minutes spent checking its per-drive settings can turn it back into the safety net it was meant to be—before the next accidental deletion becomes an afternoon-long archaeology project.
