The thread discusses a Lenovo 300 workstation experiencing random Blue Screen of Death (BSOD) errors, including "Unexpected Store Exception" and "Critical Process Died," with the original poster seeking help after initial troubleshooting and driver updates. Contributors recommend running system scans (sfc and dism) and adjusting settings to generate dump files for further diagnosis, but no dump files have yet been produced. Overall, the user is actively seeking solutions, and helpers are providing troubleshooting steps, awaiting further error data.
Ed Otero
Hi I'm a newbie and I have a Lenovo 300 workstation PC. It has been working fine for 2 years, then last week while surfing in Chrome I get to a certain random point, the PC slows to a halt, and I get the BSOD, followed bt the sorry your PC is now dead (sort of) message, and the look up Unexpected Store Exception.
I was able to get a dump file, but have no clue how to read it. I will place here in hopes that somebody can tell me what is wrong.
So far I have the lasted updates to Windows 10, I have updated all my drivers, scanned my harddrive, with no errors found.
Please help, and thank you Ed
Hi Ed,
whilst i debug your dump files can you run these scans please:
File scans
Right click on the Start menu icon and from the revealed list choose 'admin command prompt'. Type:
sfc /scannow
press enter and await results
I'll post back shortly.
Ed Otero
Thread Author #2
Lenovo did it again with BSOD this time the message was "Critical Process Died" I got the dump for it.
Hi Ed,
File scans
sfc /scannow
Hi Ed,
I check your folders and no dump files are contained within. Please change your settings so that dump files will be produced when a bsod occurs.
Open the run application.
Type sysdm.cpl in the run box and click ok.
Look across the top of the system properties box for 'Advanced' and click that.
Look for 'Startup and Recovery' near the bottom and click 'settings'.
Near the bottom you'll see a drop down menu under the heading 'write debugging information'.
In the drop down menu choose ' small memory dump (256KB)'
Under 'small dump directory' make sure it says %SystemRoot%\Minidump.
Click ok and your good to go.
You will of course need to have another BSOD before a dump file is created.
Another reason for no dump file can be when the page file has been turned off.
Please post as soon as you have a dump file. You'll find them in a folder marked minidump in the main windows folder.
Ed Otero
Thread Author #5
Hi Kemical thanks for the help... I checked my setting and they are setup as you say to say them up, I checked my page file, and its on, its being managed by Windows. I dud not find anything in the minidump folder either.
I ran sfc/scannow and dism /online /cleanup-image /restorehealth, and got this...
Microsoft Windows [Version 10.0.10586]
(c) 2015 Microsoft Corporation. All rights reserved.
C:\WINDOWS\system32>sfc/scannow
Beginning system scan. This process will take some time.
Beginning verification phase of system scan.
Verification 100% complete.
Windows Resource Protection did not find any integrity violations.
C:\WINDOWS\system32>dism /online /cleanup-image /restorehealth
Deployment Image Servicing and Management tool
Version: 10.0.10586.0
Image Version: 10.0.10586.0
[==========================100.0%==========================]
The restore operation completed successfully.
The operation completed successfully.
Waiting for the next BSOD
Thanks
ED
Much thanks for the update Ed. The scans went well which is at least something and hope it isn't too long before we have the dump file.. Good luck!
