lennylion
Iam using win7 32bit with a logitech extrme 3d pro joystick .
having a problem with flight sim x I have no control of direction or speed when taxing aircaft,
they just go to the right
The issue you are facing with your Logitech Extreme 3D Pro joystick in Flight Simulator X where the aircraft always veers to the right can be due to calibration or configuration problems. Here are some steps you can take to troubleshoot and potentially resolve this issue:
Calibration of Logitech Extreme 3D Pro Joystick:​
  • Windows Calibration:
  • Go to the Windows Control Panel.
  • Navigate to "Devices and Printers."
  • Right-click on your Logitech Extreme 3D Pro joystick and select "Game controller settings."
  • Choose the Logitech joystick and click on "Properties."
  • Go to the "Settings" tab and click on "Calibrate" to run the calibration wizard.
  • Follow the on-screen instructions to calibrate your joystick...
  • Flight Simulator X Calibration:
  • Open Flight Simulator X.
  • Go to "Settings" or "Options" in the game menu.
  • Look for the "Controls" section.
  • Locate the joystick settings and ensure they are configured correctly.
  • Calibrate your joystick within the Flight Simulator X settings if needed.
Adjusting Sensitivity and Deadzones:​
  • Windows Joystick Settings:
  • You can adjust sensitivity and deadzones in the Windows calibration settings mentioned above.
  • Setting a deadzone can help prevent small joystick movements from affecting the aircraft.
  • Flight Simulator X Settings:
  • Within Flight Simulator X, check the sensitivity settings for the joystick axis.
  • Increase the deadzone or reduce sensitivity if the aircraft veers too sharply.
Troubleshooting Tips:​
  • Ensure that your joystick drivers are up to date. Visit the Logitech website to download the latest drivers for your joystick model.
  • Check the physical connection of your joystick to the computer to make sure it's securely plugged in.
  • Try using a different USB port for your joystick to rule out any port-related issues. By following these steps and ensuring proper calibration, sensitivity adjustments, and driver updates, you should be able to resolve the issue of the aircraft veering to the right in Flight Simulator X with your Logitech Extreme 3D Pro joystick. If the issue persists, further troubleshooting or adjustments may be necessary.
