Rebop
- Joined
- Apr 23, 2016
- Messages
- 91
Seems to be several opinions on this as I Google, so thought to ask you all here as well for your thoughts.
Lenovo P51S with Ultradock. Two USB hard drives attached to the dock. Both set for "Quick Removal" in Device Manager.
Do I need to "safely remove" these drives before hot undocking and docking?
Update: I am finding even a bit stranger. Unless i am missing something, to safely remove when docked you still need to disconnect the USB 3.0 cable and do one at a time. Its not as easy as a direct connection to the computer. If I could "safely remove" without physically detaching cables I would try. For now, I think I have to test an undock and redock without and hope I don't lose any data. Drives are usually idle and I am aware when they are being used.
Appreciate your thoughts.
