The thread discusses upgrading an older MCP6PB M2+ 6.0 motherboard with an AMD Phenom II x4 CPU and 4 GB RAM to a compatible graphics card for Windows 10. The original poster seeks advice on how to choose a suitable GPU. A responder recommends matching the motherboard's PCIe slot and verifying compatibility, noting that most modern GPUs support Windows 10 and should specify this on their packaging. The overall tone is helpful, providing practical advice for hardware upgrades.
grover7030
Good morning, I have a MCP6PB M2+ 6.0 mother board. running a AMD Phenom ii x4 with 4 gb ram. I've upgraded to windows 10 and would like to install a graphics card compatible with this board and windows 10.
What should I do?
Match the slot such as PCIx and verify the board has the correct port. Any modern GPU out should support Windows 10 and should mention that on the box specification page.
Neemobeer
Windows Forum Team
