seekermeister
Honorable Member
- Joined
- May 29, 2009
- Messages
- 1,492
- Thread Author
- #1
It took about 6 tries to boot to Windows a little while ago. First try - couldn't get the login field to open for a password. second try - got the password entered, but after a prolong period, it popped an error simply saying access denied. third try - booted into safe mode okay. fourth and fifth tries got no cursor response from the mouse, and couldn't login from the keyboard. Sixth time, reached desktop, but still no mouse.
I changed the battery and swapped it around between the 2 front USB 3 connectors...no joy. The same happened when I connected using the back 2 USB 3 connectors. Finally got it to work using the USB 2 connectors on the motherboard.
Don't really know if the boot problem was due to the mouse problem or if it was just a coincidence. Checked the Device Manager and it says that both of my 2 USB 3 host controllers and both USB 3 root hubs are okay and have no conflicts.
Anyone with any idea of how this kind of problem comes about and how to fix it?
