aaronsp
Hello
For the last couple of months my laptop has been freezing, by this i mean i cant do anything and i have to restart the computer using the power button. Recently it has got worse and worse to the point where it freezes on the windows screen meaning i cant even access my desktop at times and also as soon as i insert a USB stick. I feel its a hardware problem as ive completely formatted the laptop numerous times and the problem is still persisting.I had a blue screen about a week ago and it said at the top "USB Faulty" so i feel that one of the usb ports is not working right.
Is there anyway i can eradicate this problem my self or is the best way to get it repaired at a computer store. Also how do i identify that its definitly the usb drive because it also freezes when a pen drive is not inserted, it does it at random times.
these are my laptop specs
OS Version: Microsoft Windows 7 Home Premium, 64 bit
Processor: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz, Intel64 Family 6 Model 37 Stepping 2
Processor Count: 4
RAM: 1909 Mb
Graphics Card: Intel(R) Graphics Media Accelerator HD, 730 Mb
Hard Drives: C: Total - 225255 MB, Free - 182524 MB; D: Total - 12914 MB, Free - 2143 MB; E: Total - 99 MB, Free - 95 MB;
Motherboard: Hewlett-Packard, 1425
It sounds like you are experiencing quite a frustrating issue with your laptop freezing, possibly due to a USB-related problem. Here are some steps you can take to troubleshoot the issue:
Troubleshooting Steps:​
  • Update Drivers:
  • Make sure all your drivers are up to date, especially the USB drivers. Outdated drivers can cause various issues, including freezing.
  • Check USB Devices:
  • Try using different USB devices and ports to see if the freezing persists. This can help determine if the issue is with a specific USB device or port.
  • Check for Malware:
  • Run a full antivirus scan to rule out any malware causing the freezes.
  • Check Event Viewer:
  • Check the Windows Event Viewer for any error...
  • Update Drivers:
  • Check the Windows Event Viewer for any error messages or warnings related to USB devices that might give more insight into the issue.
  • Hardware Diagnostics:
  • Use built-in hardware diagnostic tools to check the health of your hardware components, including USB ports.
  • BIOS Update:
  • Consider updating your BIOS to the latest version as outdated BIOS can sometimes cause hardware-related issues.
  • Heat Management:
  • Ensure your laptop is not overheating as overheating can cause freezes. Clean out any dust from the vents and use a cooling pad if needed.
    Identifying Hardware Issues:​
    It's important to confirm whether the problem is indeed hardware-related. If the freezing occurs even when no USB devices are connected, it might suggest a broader hardware issue. To help identify the problem:
  • Monitor the temperature of your CPU and GPU to ensure they are not overheating.
  • Test your RAM for any potential faults.
  • Use diagnostic tools to check the health of your hard drive.
    Seeking Repair:​
    If the issue persists after trying these troubleshooting steps, it might be best to have a professional technician inspect your laptop. They can perform more in-depth hardware diagnostics to pinpoint and resolve the issue effectively. Your laptop specifications are as follows:
  • OS Version: Microsoft Windows 7 Home Premium, 64 bit
  • Processor: Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz
  • RAM: 1909 Mb
  • Graphics Card: Intel(R) Graphics Media Accelerator HD, 730 Mb
  • Hard Drives: C: Total - 225255 MB, Free - 182524 MB; D: Total - 12914 MB, Free - 2143 MB; E: Total - 99 MB, Free - 95 MB;
  • Motherboard: Hewlett-Packard, 1425 If you need further assistance or clarification on any of these steps, feel free to ask!
