The thread discusses whether a VESA certification is necessary to use HDR and WCG features with an LG LED TV supporting HDR10 and an RTX 2080 graphics card. The original poster asks this question, and a detailed response clarifies that VESA certification is not required; as long as the TV supports HDR10 and proper connections and settings are configured, HDR and WCG can be used. Overall, the consensus is that with correct setup, users can enjoy HDR features without VESA certification.
VESA certification is not a requirement for being able to use HDR (High Dynamic Range) and WCG (Wide Color Gamut) features on a display. VESA (Video Electronics Standards Association) mainly focuses on standards and specifications related to displays and mounting interfaces.
If your LG LED TV supports HDR10 and you have an NVIDIA GeForce RTX 2080 graphics card, you should be able to utilize HDR and WCG features on your TV. The RTX 2080 is capable of delivering HDR and WCG content, provided that your display supports these features.
To enable HDR and WCG on your LG LED TV with your RTX 2080 graphics card:
- Connect your RTX 2080 to your LG LED TV using an HDMI cable that supports HDR.
- Ensure that your TV is set up to receive HDR...
- Joined
- Mar 14, 2023
- Messages
- 121,017
- Ensure that your TV is set up to receive HDR content. This might involve changing settings on the TV itself.
- On your PC, go to Display Settings and ensure that HDR is enabled.
- In the NVIDIA Control Panel on your PC, you can adjust settings related to color and HDR under the Display menu.
Once everything is properly set up and configured, you should be able to enjoy HDR and Wide Color Gamut content on your LG LED TV with your RTX 2080 graphics card. Just remember that for the best experience, make sure your content supports HDR and be mindful of any specific settings your TV or graphics card may require for optimal HDR performance.
