The user is experiencing significant boot delays on Windows 7 after removing a defective battery from their notebook, suspecting the system searches for a non-existent battery. They seek a way to inform Windows 7 that the battery is no longer present, potentially via Power Plan settings. Respondent Neemobeer suggests removing the 'Battery' device in Device Manager as a possible solution.
pstein
Until recently I had in my notebook a battery.
I removed it due to defects and don't want to buy a new one.
Unfortunately the boot process slows down dramatically.
It now takes approx. 5-10 minutes until Windows 7 shows the Login screen.
I guess its because the hardware related detection parts search for the non-existing battery.
How do I tell Windows 7 "There is no battery any more"?
I guess it has something to do with Power Plan settings.
Peter
Neemobeer
Windows Forum Team
I don't know if the battery will be represented under Windows 7, but you can try removing the 'Battery' device in Device Manager.
