Sturm
Long-time reader; first-time poster.
I just purchased a Link Removed to replace my older Pinnacle remote. I use it primarily in Windows Media Center (with PowerDVD 9 added on) and I really liked the fact that this remote is so versatile. It also appears to be just about the only PC remote with those four colored buttons that Blu-ray discs take advantage of.
At any rate, I have a custom-built PC with Windows 7 RC 64-bit installed. I tried installing the Vista drivers that came with the remote (which is also the latest version available on Streamzap's web site), but after the software installs and I plug in the receiver, Windows cannot install the drivers for the device.
Does anyone know if there are some (probably underground) drivers available for the Streamzap to get it working on Win7RC64? Or maybe a workaround to get the Vista drivers (which are 32-bit, I believe) to work in Win7?
I would appreciate any help at all. Thanks!
It seems like you are facing compatibility issues with the Streamzap remote on Windows 7 RC 64-bit. While the Vista drivers provided with the remote are not working, there might still be a way to get the remote functioning on your system. Here are a few steps and suggestions you can try to address this issue:
Steps to Get Streamzap Remote Working on Windows 7 RC 64-bit:​
  • Compatibility Mode: Try installing the Vista drivers in compatibility mode. Here's how:
  • Right-click on the driver setup file and select "Properties."
  • Go to the "Compatibility" tab and check the box next to "Run this program in compatibility mode for."
  • Choose "Windows Vista" from the drop-down menu.
  • Click on "Apply" and then try running the...
  • Click on "Apply" and then try running the installation again.
  • Check Device Manager:
  • After attempting to install the drivers, check the Device Manager to see if the Streamzap remote is recognized but lacks proper drivers.
  • If it's listed with a warning symbol, right-click on it, select "Update Driver Software," and try to manually install the driver.
  • Community Solutions:
  • Look for community forums or websites where other users might have found solutions or alternative drivers for the Streamzap remote on Windows 7 RC 64-bit.
  • Contact Support:
  • Reach out to Streamzap's support for assistance. They may have additional information or updated drivers that could work with Windows 7 RC 64-bit.
  • Third-Party Software:
  • Consider exploring third-party software that offers remote control support for media centers. Some applications might provide compatibility with a wider range of remotes.
  • Driver Update Tools:
  • Use driver update tools like "Driver Booster" or "Driver Easy" to scan your system for outdated drivers, including the Streamzap remote, and attempt to update them.
  • Windows Update:
  • Ensure that your Windows 7 RC is up to date with the latest patches and updates. Sometimes, Windows updates include drivers for certain devices.
Additional Information:​
  • Make sure to back up your system before making any significant changes or installations.
  • Keep in mind that using unofficial or third-party drivers carries some risk and should be done cautiously. Give these suggestions a try, and hopefully, you'll find a solution to get your Streamzap remote working with Windows 7 RC 64-bit. Let me know if you need further assistance!
