XilitoN
So... I just downloaded Realtek AC'97 Driver. But then I try to install it it says "Rtkvac.sys missing".
I run Windows 7 Ultimate Build 7600 please help!:frown:
Rtkvac.sys is the driver left-over. You may need to use Link Removed.
1. Disable your Antivirus/Security software
2. Uninstall your Realtek sound driver
3. Reboot
4. Disable your Antivirus/Security software
5. Control Panel > System > Device Manasger
6. Locate your Realtek HD audio device, right-click it and completely remove it
7. Reboot
8. Download and install the right driver for your audio device, I understand it is Link Removed.
9. Reboot your pc now
Hmm.. I just gone over this thread again and cannot see your system stats. Could you post them please as something else is occurring here other than just a sticky driver..
What's the name and make of your pc? Try and post as much information as possible as it's always a help.
Oh this might help if your stuck: Link Removed
I think you can create a report of your system with the above app but if not it will give you all the information you need (hopefully)
XilitoN
System Information
Time of this report: 2/19/2010, 14:09:34
Machine name: TIMMYCOMP
Operating System: Windows 7 Ultimate 32-bit (6.1, Build 7600) (7600.win7_gdr.091207-1941)
Language: Swedish (Regional Setting: Swedish)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 10/26/04 18:56:58 Ver: 08.00.11
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs), ~3.0GHz
Memory: 2560MB RAM
Available OS Memory: 2560MB RAM
Page File: 2146MB used, 2968MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6500
Manufacturer: NVIDIA
Chip type: GeForce 6500
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0160&SUBSYS_00000000&REV_A1
Display Memory: 1129 MB
Dedicated Memory: 121 MB
Shared Memory: 1007 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor Name: Generic PnP Monitor
Monitor Model: COMPAQ 7020
Monitor Id: CPQ1435
Native Mode: 1280 x 1024(p) (60.020Hz)
Output Type: HD15
Driver Name: nvd3dum.dll
Driver File Version: 8.17.0011.9562 (English)
Driver Version: 8.17.11.9562
DDI Version: 9Ex
Driver Model: WDDM 1.0
Driver Attributes: Final Retail
Driver Date/Size: 11/21/2009 03:34:54, 9333352 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71E3E-4220-11CF-EA46-0B201FC2C535}
Vendor ID: 0x10DE
Device ID: 0x0160
SubSys ID: 0x00000000
Revision ID: 0x00A1
Driver Strong Name: oem9.inf:NVIDIA_SetB_Devices.NTx86.6.0:Section001:8.17.11.9562:pci\ven_10de&dev_0160
Rank Of Driver: 00F60003
Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_B ModeWMV9_B ModeVC1_A ModeWMV9_A
Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
D3D9 Overlay: Not Supported
DXVA-HD: Not Supported
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Saitek Eclipse Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x06A3, 0x8020
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x2659
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/14/2009 00:52:09, 258560 bytes
| Driver: usbd.sys, 7/14/2009 00:51:05, 5888 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 7/14/2009 00:45:09, 28160 bytes
| Driver: kbdclass.sys, 7/14/2009 02:20:36, 42576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: i8042prt.sys, 7/14/2009 00:11:24, 80896 bytes
+ HID-compliant mouse
| Vendor/Product ID: 0x04FC, 0x0013
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouhid.sys, 7/14/2009 00:45:08, 26112 bytes
| Driver: mouclass.sys, 7/14/2009 02:20:44, 41552 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 7/14/2009 02:19:10, 51776 bytes
| Driver: sermouse.sys, 7/14/2009 00:45:08, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 815.1 GB
Total Space: 953.9 GB
File System: NTFS
Model: WDC WD1001FALS-00J7B1 ATA Device
Drive: F:
Free Space: 38.4 GB
Total Space: 76.3 GB
File System: NTFS
Model: Maxtor 6Y080M0 ATA Device
Drive: G:
Free Space: 24.1 GB
Total Space: 38.0 GB
File System: NTFS
Model: ST3120827AS ATA Device
Drive: H:
Free Space: 16.3 GB
Total Space: 76.5 GB
File System: NTFS
Drive: E:
Model: TSSTcorp DVD-ROM SH-D162C ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7600.16385 (Swedish), 7/14/2009 00:11:26, 108544 bytes
Drive: D:
Model: BENQ DVD LS DW1655 ATA Device
System Devices
Name: Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
Device ID: PCI\VEN_8086&DEV_266F&SUBSYS_266F8086&REV_03\3&11583659&0&F9
Driver: C:\Windows\system32\DRIVERS\intelide.sys, 6.01.7600.16385 (English), 7/14/2009 02:20:36, 15424 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (Swedish), 7/14/2009 02:19:03, 42560 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 02:26:15, 21584 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7600.16385 (Swedish), 7/14/2009 02:26:15, 133200 bytes
Name: Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Device ID: PCI\VEN_8086&DEV_2651&SUBSYS_26518086&REV_03\3&11583659&0&FA
Name: NVIDIA GeForce 6500
Device ID: PCI\VEN_10DE&DEV_0160&SUBSYS_00000000&REV_A1\4&1A5F293&0&0008
Driver: C:\Windows\System32\DriverStore\FileRepository\nv_disp.inf_x86_neutral_41aad7f8b629e0a1\NvCplSetupEng.exe, 14.00.0000.0162 (English), 11/21/2009 03:34:54, 16933624 bytes
Driver: C:\Windows\system32\DRIVERS\nvBridge.kmd, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 10920 bytes
Driver: C:\Windows\system32\DRIVERS\nvlddmkm.sys, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 11515752 bytes
Driver: C:\Windows\system32\OpenCL.dll, 1.00.0000.0000 (English), 11/21/2009 03:34:54, 76392 bytes
Driver: C:\Windows\system32\dpinst.exe, 2.01.0000.0000 (English), 9/27/2009 23:12:22, 795104 bytes
Driver: C:\Windows\system32\nvapi.dll, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 1249896 bytes
Driver: C:\Windows\system32\nvcompiler.dll, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 11381352 bytes
Driver: C:\Windows\system32\nvcuda.dll, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 4001384 bytes
Driver: C:\Windows\system32\nvcuvenc.dll, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 1989224 bytes
Driver: C:\Windows\system32\nvcuvid.dll, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 2243176 bytes
Driver: C:\Windows\system32\nvd3dum.dll, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 9333352 bytes
Driver: C:\Windows\system32\nvinfo.pb, 11/21/2009 03:34:54, 7133 bytes
Driver: C:\Windows\system32\nvoglv32.dll, 8.17.0011.9562 (English), 11/21/2009 03:34:54, 14064232 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvdisp.nvu, 11/21/2009 03:34:54, 19077 bytes
Driver: C:\Program Files\NVIDIA Corporation\Uninstall\nvudisp.exe, 1.10.0052.0030 (English), 11/21/2009 03:34:54, 592488 bytes
Driver: C:\Windows\system32\nvcod.dll, 1.07.0008.0073 (English), 11/21/2009 03:34:54, 182888 bytes
Driver: C:\Windows\system32\nvcod178.dll, 1.07.0008.0073 (English), 11/21/2009 03:34:54, 182888 bytes
Name: Intel(R) 82801FB/FBM SMBus Controller - 266A
Device ID: PCI\VEN_8086&DEV_266A&SUBSYS_266A8086&REV_03\3&11583659&0&FB
Driver: n/a
Name: Intel(R) 82801FB LPC Interface Controller - 2640
Device ID: PCI\VEN_8086&DEV_2640&SUBSYS_26408086&REV_03\3&11583659&0&F8
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 02:20:43, 13888 bytes
Name: Texas Instruments 1394 OHCI Compliant Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_8026104C&REV_00\4&1E7851E3&0&38F0
Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7600.16385 (English), 7/14/2009 00:52:00, 163328 bytes
Name: High Definition Audio Controller
Device ID: PCI\VEN_8086&DEV_2668&SUBSYS_58263411&REV_03\3&11583659&0&D8
Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7600.16385 (English), 7/14/2009 00:50:56, 108544 bytes
Name: Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Device ID: PCI\VEN_8086&DEV_2581&SUBSYS_00008086&REV_04\3&11583659&0&08
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7600.16385 (English), 7/14/2009 02:20:45, 153680 bytes
Name: Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Device ID: PCI\VEN_8086&DEV_265C&SUBSYS_265C8086&REV_03\3&11583659&0&EF
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7600.16385 (English), 7/14/2009 00:51:14, 41472 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7600.16385 (English), 7/14/2009 00:51:15, 284160 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7600.16385 (English), 7/14/2009 00:52:09, 258560 bytes
Name: Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 2580
Device ID: PCI\VEN_8086&DEV_2580&SUBSYS_25808086&REV_04\3&11583659&0&00
Driver: n/a
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
Device ID: PCI\VEN_8086&DEV_265B&SUBSYS_265B8086&REV_03\3&11583659&0&EB
Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7600.16385 (English), 7/14/2009 00:51:10, 24064 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_244E8086&REV_D3\3&11583659&0&F0
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
Device ID: PCI\VEN_8086&DEV_265A&SUBSYS_265A8086&REV_03\3&11583659&0&EA
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
Device ID: PCI\VEN_8086&DEV_2659&SUBSYS_26598086&REV_03\3&11583659&0&E9
Name: Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
Device ID: PCI\VEN_8086&DEV_2658&SUBSYS_26588086&REV_03\3&11583659&0&E8
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\4&1E7851E3&0&70F0
Driver: C:\Windows\system32\DRIVERS\Rtnicxp.sys, 6.108.0331.2008 (English), 7/22/2008 07:42:58, 51200 bytes
Driver: C:\Windows\system32\RtNicProp32.dll, 1.01.0716.2008 (English), 7/21/2008 05:08:40, 9728 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7600.16385
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7600.16385
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7600.16385
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7600.16385
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7600.16385
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.0000
WMT VIH2 Fix,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
Record Queue,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Switch Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Virtual Renderer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
WMT DV Extract,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
WMT Virtual Source,0x00200000,0,1,WLXVAFilt.dll,14.00.8081.0709
WMT Sample Information Filter,0x00200000,1,1,WLXVAFilt.dll,14.00.8081.0709
DV Muxer,0x00400000,0,0,qdv.dll,6.06.7600.16385
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7600.16490
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7600.16385
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7600.16385
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7600.16490
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7600.16490
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
"MainConcept (Adobe2) AAC Decoder",0x00600000,1,1,ad2daac.ax",
MPC - RealVideo Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.02.0908.0000
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7600.16385
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7600.16490
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7600.16385
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7600.16385
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7600.16385
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7600.16385
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7600.16490
DV Splitter,0x00600000,1,2,qdv.dll,6.06.7600.16385
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7600.16490
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7600.16385
RadLight OptimFROG DirectShow Filter,0x00600000,0,1,RLOFRDec.ax,1.00.0000.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7600.16490
Video Renderer,0x00800001,1,0,quartz.dll,6.06.7600.16490
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7600.16385
MPC - Ogg Source,0x00600001,0,0,OggSplitter.ax,1.02.0908.0000
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.06.7600.16385
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7600.16490
DivX H.264 Decoder,0x00800000,1,1,DivXDecH264.ax,8.02.0000.0026
Video Renderer,0x00400000,1,0,quartz.dll,6.06.7600.16490
MPC - RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.02.0908.0000
File Writer,0x00200000,1,0,WLXVAFilt.dll,14.00.8081.0709
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.03.0000.0085
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7600.16385
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7600.16385
Sony Wave Hammer Surround,0x00200000,1,1,mchammer.dll,1.00.0000.1440
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7600.16385
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.06.7600.16385
"MainConcept (Adobe2) AAC Encoder",0x00100000,1,1,ad2eaac.ax",
iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7600.16385
iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7600.16385
MPC - AVI<->AC3/DTS,0x00600000,1,1,avi2ac3filter.ax,1.02.0908.0000
MPC - RealAudio Decoder,0x00600000,1,1,RealMediaSplitter.ax,1.02.0908.0000
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7600.16385
Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7600.16385
MPC - Ogg Splitter,0x00400000,1,1,OggSplitter.ax,1.02.0908.0000
Overlay Mixer2,0x00200000,1,1,qdvd.dll,6.06.7600.16385
AVI Draw,0x00600064,9,1,quartz.dll,6.06.7600.16490
RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7600.16385
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7600.16385
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7600.16385
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7600.16385
MPC - DTS/AC3/DD+ Source,0x00600000,0,1,dtsac3source.ax,1.02.0908.0000
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
rgc:audio z3ta+,0x00200000,1,1,z3ta+.dll,1.05.0003.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7600.16385
Null Renderer,0x00200000,1,0,qedit.dll,6.06.7600.16385
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7600.16385
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7600.16385
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7600.16385
Smart Tee,0x00200000,1,2,qcap.dll,6.06.7600.16385
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.06.7600.16385
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7600.16490
NetBridge,0x00200000,2,0,netbridge.dll,6.01.7600.16385
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7600.16490
MPC - CDXA Reader,0x00600000,0,1,cdxareader.ax,1.02.0908.0000
Wave Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7600.16490
File stream renderer,0x00400000,1,1,quartz.dll,6.06.7600.16490
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
MPC - RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.02.0908.0000
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7600.16385
AVI Mux,0x00200000,1,0,qcap.dll,6.06.7600.16385
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7600.16490
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7600.16490
File Source (URL),0x00400000,0,1,quartz.dll,6.06.7600.16490
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7600.16385
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7600.16385
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7600.16385
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7600.16385
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7600.16490
"MainConcept (Adobe2) H.264/AVC Decoder",0x00600000,1,1,ad2dsh264.ax",
"MainConcept (Adobe2) H.264 Encoder",0x00200000,2,1,ad2esh264.ax",
"MainConcept (Adobe2) H.264/AVC Video Encoder",0x00200000,1,1,ad2evh264.ax",
Sony ExpressFX Chorus,0x00200000,1,1,sfxpfx2.dll,1.00.0000.1436
Sony ExpressFX Delay,0x00200000,1,1,sfxpfx2.dll,1.00.0000.1436
Sony ExpressFX Distortion,0x00200000,1,1,sfxpfx1.dll,1.00.0000.1436
Sony ExpressFX Equalization,0x00200000,1,1,sfxpfx2.dll,1.00.0000.1436
Sony ExpressFX Flange/Wah-Wah,0x00200000,1,1,sfxpfx1.dll,1.00.0000.1436
Sony ExpressFX Amplitude Modulation,0x00200000,1,1,sfxpfx2.dll,1.00.0000.1436
Sony ExpressFX Reverb,0x00200000,1,1,sfxpfx1.dll,1.00.0000.1436
Sony ExpressFX Stutter,0x00200000,1,1,sfxpfx1.dll,1.00.0000.1436
Sony ExpressFX Dynamics,0x00200000,1,1,sfxpfx3.dll,1.00.0000.1436
Sony ExpressFX Graphic EQ,0x00200000,1,1,sfxpfx3.dll,1.00.0000.1436
Sony ExpressFX Noise Gate,0x00200000,1,1,sfxpfx3.dll,1.00.0000.1436
Sony ExpressFX Time Stretch,0x00200000,1,1,sfxpfx3.dll,1.00.0000.1436
Sony ExpressFX Audio Restoration,0x00200000,1,1,xpvinyl.dll,1.00.0000.1920
Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2.dll,1.00.0000.1436
IL FL Studio DXi,0x00200000,1,1,FLSTUD~2.DLL,1.00.0012.0000
Sony Track Compressor,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1441
NI Pro-53 Demo,0x00200000,1,1,Pro53DXi.dll,1.05.0000.0000
Sony Dither,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1441
Sony Chorus,0x00200000,1,1,sfppack1.dll,1.00.0000.1436
Sonik Synth 2 Free,0x00200000,1,1,Sonik Synth 2 Free.ax,1.00.0000.0001
Sony Distortion,0x00200000,1,1,sfppack3.dll,1.00.0000.1436
Sony Gapper/Snipper,0x00200000,1,1,sfppack3.dll,1.00.0000.1436
IL Multi FL Studio DXi,0x00200000,1,1,FLSTUD~1.DLL,1.00.0012.0000
Sony Simple Delay,0x00200000,1,1,sfppack1.dll,1.00.0000.1436
Sony Reverb,0x00200000,1,1,sfppack1.dll,1.00.0000.1436
Sony Multi-Tap Delay,0x00200000,1,1,sfppack1.dll,1.00.0000.1436
Sony Track Noise Gate,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1441
Sony Graphic EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.1436
Sony Track EQ,0x00200000,1,1,sftrkfx1.dll,1.00.0000.1441
Sony Smooth/Enhance,0x00200000,1,1,sfppack3.dll,1.00.0000.1436
Sony Resonant Filter,0x00200000,1,1,sfresfilter.dll,1.00.0000.1440
Sony Parametric EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.1436
Sony Time Stretch,0x00200000,1,1,sfppack1.dll,1.00.0000.1436
Sony Noise Gate,0x00200000,1,1,sfppack2.dll,1.00.0000.1436
Sony Paragraphic EQ,0x00200000,1,1,sfppack2.dll,1.00.0000.1436
Sony Vibrato,0x00200000,1,1,sfppack3.dll,1.00.0000.1436
Sony Pan,0x00200000,1,1,sffrgpnv.dll,1.00.0000.1440
Sony Pitch Shift,0x00200000,1,1,sfppack1.dll,1.00.0000.1436
Sony Volume,0x00200000,1,1,sffrgpnv.dll,1.00.0000.1440
Sony Flange/Wah-wah,0x00200000,1,1,sfppack3.dll,1.00.0000.1436
Sony Graphic Dynamics,0x00200000,1,1,sfppack2.dll,1.00.0000.1436
Sony Amplitude Modulation,0x00200000,1,1,sfppack3.dll,1.00.0000.1436
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7600.16385
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7600.16385
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7600.16490
CamStudio Lossless Codec v1.4,0x00200000,1,1,qcap.dll,6.06.7600.16385
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.06.7600.16385
DivX 6.8.5 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.06.7600.16385
Helix I420 YUV Codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft RLE,0x00200000,1,1,qcap.dll,6.06.7600.16385
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.06.7600.16385
VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.06.7600.16385
VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.06.7600.16385
VP62® Heightened Sharpness Profile,0x00200000,1,1,qcap.dll,6.06.7600.16385
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
Ogg Vorbis (mode1),0x00200000,1,1,quartz.dll,6.06.7600.16490
Ogg Vorbis (mode2),0x00200000,1,1,quartz.dll,6.06.7600.16490
Ogg Vorbis (mode3),0x00200000,1,1,quartz.dll,6.06.7600.16490
Ogg Vorbis (mode1+),0x00200000,1,1,quartz.dll,6.06.7600.16490
Ogg Vorbis (mode2+),0x00200000,1,1,quartz.dll,6.06.7600.16490
Ogg Vorbis (mode3+),0x00200000,1,1,quartz.dll,6.06.7600.16490
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7600.16490
{6A08CF80-0E18-11CF-A24D-0020AFD79767},0x00200000,1,1,quartz.dll,6.06.7600.16490
DivX ;-) Audio,0x00200000,1,1,quartz.dll,6.06.7600.16490
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7600.16490
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7600.16490
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7600.16490
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7600.16385
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7600.16385
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7600.16490
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7600.16385
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7600.16385
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7600.16385
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7600.16385
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7600.16385
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7600.16385
PTFilter,0x00200000,0,0,EncDec.dll,6.06.7600.16385
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7600.16385
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7600.16490
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7600.16490
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
This?
cybercore
The System Information states:
Well the problem is that when i'm going to check that it's empty...
What do you mean it's empty ? If there is no audio in Sound, Video, and Game controllers then perhaps it is hardware related - malfunctioning or disabled in bios ? Or perhaps you don't have a sound card installed ?
XilitoN
There is a driver in Sound, Video, Game controllers with a yellow sign on it. When i double click it it says "Driver Could Not Start (Code 10)".
Hmm...thanks for posting that although unfortunately it doesn't get us any closer to a solution. Is this a machine that you've built yourself or bought whole? If you bought off a dealer is there a system name or model number? Also would you mind posting a screenshot of device manager?
XilitoN
I have built my computer my self.
dm..webp here's a pic...
cybercore
Your device manager says Hi Definition Audio, which very often refers to Realtek BUT not always. This is what my Realtek HD looks like:
Try searching Link Removed.
What we are still missing is the exact model name of your audio device, and I'm not sure that EVEREST can detect it if the audio driver is not installed.
I suggest you right-click it in device manager => Properties => Driver => Update driver software, and let the system search for suitable driver in the internet.
Also, look if there is a Hi Definition audio driver on the Microsoft list of standard drivers.
XilitoN
Well i tried to update the driver but it's up-to-date so i try to find Intel driver :)
cybercore
You can look for a high definition driver Link Removed, but again: you need to know exactly what your audio device is.
the exclamation mark means theres a conflict :o
Error code 10 means that the device cannot start because there is no driver installed, or because the device is broken or conflicting with something.
Delete this device, then reboot, then let the system find a driver, or choose HI DEF audio driver from Microsoft standard drivers list.
What is your motherboard name exactly ?
cybercore
No it doesn't, it won't show your sound card even if you click on the sound tab. Find out the (exact) name of your motherboard, and then let's move on.
Without knowing what your sound card/motherboard is, it is almost impossible to find the right driver.
Do you have support CD's for your motherboard and one for your sound card ? Do you have motherboard manual ?
