Rtkvac.sys is the driver left-over. You may need to use Link Removed.
1. Disable your Antivirus/Security software
2. Uninstall your Realtek sound driver
3. Reboot
4. Disable your Antivirus/Security software
5. Control Panel > System > Device Manasger
6. Locate your Realtek HD audio device, right-click it and completely remove it
7. Reboot
8. Download and install the right driver for your audio device, I understand it is Link Removed.
9. Reboot your pc now
3. Reboot
7. Reboot
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,626
It is FREE trial version, you are probably supposed to click on something to proceed.
+ try this:
|MG| EVEREST Free Edition 2.20 Download
Don't you have your motherboard manual ?
+ try this:
- Thread Author
- #45
--------[ EVEREST Home Edition (c) 2003-2005 Lavalys, Inc. ]------------------------------------------------------------
Version EVEREST v2.20.405/se
Hemsida Lavalys - Comprehensive IT Security and Management
Rapporttyp Rapportassistenten
Dator TIMMYGAME (XilitoN's Comp)
Skapad av Timmy
Operativsystem Windows 7 Ultimate Media Center Edition 6.1.7600
Datum 2010-02-20
Tid 21:58
--------[ Sammanställning ]---------------------------------------------------------------------------------------------
Dator:
OS Servicepaket -
DirectX 4.09.00.0904 (DirectX 9.0c)
Datornamn TIMMYGAME (XilitoN's Comp)
Användarnamn Timmy
Moderkort:
CPU typ Intel Pentium 4 630, 3000 MHz (15 x 200)
Moderkortsnamn Okänd
Moderkortschipset Intel Grantsdale i915P
Systemminne 2560 MB (PC3200 DDR SDRAM)
BIOS typ AMI (10/26/04)
Kommunikationsport Communications Port (COM1)
Kommunikationsport Standard Serial over Bluetooth link (COM10)
Kommunikationsport Standard Serial over Bluetooth link (COM11)
Kommunikationsport Standard Serial over Bluetooth link (COM12)
Kommunikationsport Communications Port (COM2)
Kommunikationsport Standard Serial over Bluetooth link (COM9)
Kommunikationsport Printer Port (LPT1)
Bildskärm:
Grafikkort NVIDIA GeForce 6500
3D accelerator nVIDIA NV44
Bildskärm Compaq TFT7020 [17" LCD] (12162516226137)
Multimedia:
Ljudkort Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Lagring:
IDE Kontroller Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
IDE Kontroller Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
SCSI/RAID Kontroller Microsoft iSCSI Initiator
Diskettenhet Floppy disk drive
Hårddisk WDC WD1001FALS-00J7B1 ATA Device (931 GB, IDE)
Hårddisk Maxtor 6Y080M0 ATA Device (80 GB, 7200 RPM, SATA)
Hårddisk ST3120827AS ATA Device (120 GB, 7200 RPM, SATA)
Optisk enhet BENQ DVD LS DW1655 ATA Device
Optisk enhet TSSTcorp DVD-ROM SH-D162C ATA Device (16x/48x DVD-ROM)
SMART Hårddiskstatus OK
Partitioner:
C: (NTFS) 953866 MB (814805 MB ledigt)
F: (NTFS) 76316 MB (38384 MB ledigt)
G: (NTFS) 37997 MB (24122 MB ledigt)
H: (NTFS) 76465 MB (16325 MB ledigt)
Total storlek 1117.8 GB (872.7 GB ledigt)
Inmatningsenheter:
Tangentbord HID Keyboard Device
Mus HID-compliant mouse
Nätverk:
Nätverkskort Realtek RTL8139/810x Family Fast Ethernet NIC (192.168.0.100)
Modem Standard Modem over Bluetooth link #3
Modem Standard Modem over Bluetooth link #4
Kringutrustning:
Skrivare Adobe PDF
Skrivare Fax
Skrivare HP LaserJet P2015 PCL6
Skrivare Microsoft XPS Document Writer
USB1 Kontroller Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
USB2 Kontroller Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
USB enhet CSR Bluetooth Radio
USB enhet USB Composite Device
USB enhet USB Input Device
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS egenskaper:
Försäljare American Megatrends Inc.
Version 080011
Publiceringsdatum 10/26/2004
Storlek 512 kB
Bootenheter Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Funktioner Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
Standarder som stöds DMI, APM, ACPI, ESCD, PnP
Expansionsmöjligheter ISA, PCI, USB
[ System ]
Systemegenskaper:
Tillverkare To Be Filled By O.E.M.
Produkt To Be Filled By O.E.M.
Version To Be Filled By O.E.M.
Serienummer To Be Filled By O.E.M.
Universellt Unikt ID 00020003-00040005-00060007-00080009
Wake-Up typ Strömkontakt
[ Moderkort ]
Moderkortsegenskaper:
Tillverkare To be filled by O.E.M.
Produkt To be filled by O.E.M.
Version To be filled by O.E.M.
Serienummer To be filled by O.E.M.
[ Chassi ]
Chassiegenskaper:
Tillgångsmärkning To Be Filled By O.E.M.
Chassityp Skrivbordmodell
Uppstartsstatus Säkert
Strömaggregatsstatus Säkert
Temperaturstatus Säkert
Säkerhetsstatus Ingen
[ Minneskontroller ]
Egenskaper för minneskontroller:
Felsökningsmetod 64-bit ECC
Felkorrigeringsmetod Ingen
Stödd minnesinterfoliering 1-Way
Aktiverad minnesinterfoliering 1-Way
Stödd minnestyp DIMM, SDRAM
Stödd minnesströmstyrka 3.3V
Maximal minnesmodulstorlek 4096 MB
Minnesplatser 4
[ Processorer / Intel(R) Pentium(R) 4 CPU 3.00GHz ]
Processoregenskaper:
Tillverkare Intel
Version Intel(R) Pentium(R) 4 CPU 3.00GHz
Reservdelsnummer To Be Filled By O.E.M.
Extern klockhastighet 800 MHz
Maximal klockhastighet 3000 MHz
Nuvarande klockhastighet 3000 MHz
Typ Central Processor
Volt 3.3 V, 2.9 V
Status Aktiverad
Socketbenämning CPU 1
[ Cache / L1-Cache ]
Cacheegenskaper:
Typ Internt
Status Aktiverad
Körläge Varies with Memory Address
Maximal storlek 16 kB
Installerad storlek 16 kB
Stödd SRAM typ Pipeline Burst
Aktiv SRAM typ Pipeline Burst
Felkorrigeringsmetod Single-bit ECC
Socketbenämning L1-Cache
[ Cache / L2-Cache ]
Cacheegenskaper:
Typ Internt
Status Avaktiverad
Maximal storlek 0 kB
Installerad storlek 0 kB
Socketbenämning L2-Cache
[ Cache / L3-Cache ]
Cacheegenskaper:
Typ Internt
Status Avaktiverad
Socketbenämning L3-Cache
[ Minnesmoduler / DIMM0 ]
Minnesmodulsegenskaper:
Socketbenämning DIMM0
Typ DIMM, SDRAM
Installerad storlek 512 MB
Aktiverad storlek 512 MB
[ Minnesmoduler / DIMM1 ]
Socketbenämning DIMM1
Typ DIMM, SDRAM
Installerad storlek 256 MB
Aktiverad storlek 256 MB
[ Minnesmoduler / DIMM2 ]
Socketbenämning DIMM2
Typ DIMM, SDRAM
[ Minnesmoduler / DIMM3 ]
Socketbenämning DIMM3
Typ DIMM, SDRAM
[ Minnesenheter / DIMM0 ]
Minnesenhetsegenskaper:
Moderkortstyp DIMM
Typ SDRAM
Detaljer Synchronous
Storlek 512 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM0
Bankplacerare BANK0
Tillverkare Manufacturer0
Serienummer SerNum0
Tillgångsmärkning AssetTagNum0
Reservdelsnummer PartNum0
[ Minnesenheter / DIMM1 ]
Moderkortstyp DIMM
Typ SDRAM
Storlek 256 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM1
Bankplacerare BANK1
Tillverkare Manufacturer1
Serienummer SerNum1
Tillgångsmärkning AssetTagNum1
Reservdelsnummer PartNum1
[ Minnesenheter / DIMM2 ]
Moderkortstyp DIMM
Typ SDRAM
Storlek 512 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM2
Bankplacerare BANK2
Tillverkare Manufacturer2
Serienummer SerNum2
Tillgångsmärkning AssetTagNum2
Reservdelsnummer PartNum2
[ Minnesenheter / DIMM3 ]
Moderkortstyp DIMM
Typ SDRAM
Storlek 256 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM3
Bankplacerare BANK3
Tillverkare Manufacturer3
Serienummer SerNum3
Tillgångsmärkning AssetTagNum3
Reservdelsnummer PartNum3
--------[ Överklockning ]-----------------------------------------------------------------------------------------------
CPU egenskaper:
CPU alias Prescott-2M
CPU stegning N0
Engineering Sample Nej
CPUID CPU namn Intel(R) Pentium(R) 4 CPU 3.00GHz
CPUID revision 00000F43h
CPU hastighet:
CPU Hastighet 2995.14 MHz (orginal: 3000 MHz)
CPU multiplikator 15.0x
CPU FSB 199.68 MHz (orginal: 200 MHz)
Minnesbuss 166.40 MHz
CPU cache:
L1 spårningscache 12K Instructions
L1 datacache 16 kB
L2 cache 2 MB (On-Die, ECC, ATC, Full-Speed)
Moderkorts ID 63-0100-009999-00101111-102604-GrantsD$I501000_BIOS DATE: 10/26/04 18:56:58 VER: 08.00.11 P5I915P(G) BIOS V1.3 OCT.26,2004
Chipsets egenskaper:
Minnes synkning 2.5-4-4-7 (CL-RCD-RP-RAS)
SPD minnes moduler:
DIMM1: Team Group YMD512 646A8J-D43 1 GB PC3200 DDR SDRAM (2.5-4-4-8 @ 200 MHz)
DIMM2: Team Group YMD512 646A8J-D43 1 GB PC3200 DDR SDRAM (2.5-4-4-8 @ 200 MHz)
DIMM3: Samsung M3 68L3223FTN-CCC 256 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM5: Samsung M3 68L3223FTN-CCC 256 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
BIOS egenskaper:
System BIOS datum 10/26/04
Video BIOS datum 08/30/05
DMI BIOS version 080011
Egenskaper för grafikprocessor:
Grafikkort nVIDIA NV44
GPU kodnamn NV44 (PCI Express x16 10DE / 0160, Rev A1)
GPU klockhastighet 398 MHz
Minnes klocka 334 MHz
--------[ Energialternativ ]--------------------------------------------------------------------------------------------
Egenskaper för energialternativ:
Aktuell strömkälla AC nät
Batteritillstånd Inget Batteri
Full batterilivstid Okänd
Återstående batterilivstid Okänd
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensoregenskaper:
Sensortyp HDD
Temperaturer:
WDC WD1001FALS-00J7B1 39 °C (102 °F)
Maxtor 6Y080M0 41 °C (106 °F)
Seagate ST3120827AS 36 °C (97 °F)
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU egenskaper:
CPU stegning N0
Instruktions uppsättning x86, x86-64, MMX, SSE, SSE2, SSE3
Ursprunglig klockhastighet 3000 MHz
Min / Max CPU multiplicerare 14x / 15x
L1 datacache 16 kB
Multi CPU:
Moderkorts ID Intel Grantsdale
CPU #0 Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 MHz
CPU #1 Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 MHz
CPU fysisk information:
Paketeringstyp 775 Contact LGA
Paketeringsstorlek 3.75 cm x 3.75 cm
Transistorer 169 miljoner
Processorteknologi 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Kretskortsstorlek 135 mm2
Kärnvolts tal 1.3 V
I/O volt 1.3 V
Typisk strömstyrka 84 - 115 W (beroende av klockhastighet)
Maximal strömstyrka 101 - 155 W (beroende av klockhastighet)
CPU Tillverkare:
Företagsnamn Intel Corporation
Produktinformation Link Removed
CPU användning:
CPU 1 / HTT 1 enheter 0 %
CPU 1 / HTT 2 enheter 100 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID egenskaper:
CPUID tillverkare GenuineIntel
IA märkes ID 00h (Okänd)
Plattforms ID 13h (Socket 775)
IA CPU serienummer Okänd
Microcode Update Revision 5
HTT / CMP Enheter 2 / 1
Instruktions uppsättning:
64 bitars x86-utökning (AMD64, EM64T) Stöds
Alternate Instruction Set Inget Stöd
AMD 3DNow! Inget Stöd
AMD 3DNow! Professional Inget Stöd
AMD Enhanced 3DNow! Inget Stöd
AMD Extended MMX Inget Stöd
Cyrix Extended MMX Inget Stöd
IA-64 Inget Stöd
IA MMX Stöds
IA SSE Stöds
IA SSE 2 Stöds
IA SSE 3 Stöds
CLFLUSH Instruktion Stöds
CMPXCHG8B Instruktion Stöds
CMPXCHG16B Instruktion Stöds
Conditional Move Instruktion Stöds
MONITOR / MWAIT Instruktion Stöds
RDTSCP Instruktion Inget Stöd
SYSCALL / SYSRET Instruktion Inget Stöd
SYSENTER / SYSEXIT Instruktion Stöds
VIA FEMMS Instruktion Inget Stöd
Säkerhet funktioner:
Advanced Cryptography Engine (ACE) Inget Stöd
Förhindrande av data exekvering (DEP, NX, EDB) Inget Stöd
Hardware Random Number Generator (RNG) Inget Stöd
Montgomery Multiplier & Hash Engine Inget Stöd
Processor Serial Number (PSN) Inget Stöd
Energispar funktioner:
Automatic Clock Control Stöds
Enhanced Halt State (C1E) Stöds, Avaktiverad
Enhanced SpeedStep Technology (EIST, ESS) Stöds, Avaktiverad
Frequency ID Control Inget Stöd
LongRun Inget Stöd
LongRun Table Interface Inget Stöd
PowerSaver 1.0 Inget Stöd
PowerSaver 2.0 Inget Stöd
PowerSaver 3.0 Inget Stöd
Processor Duty Cycle Control Stöds
Software Thermal Control Inget Stöd
Temperature Sensing Diode Inget Stöd
Thermal Monitor 1 Stöds
Thermal Monitor 2 Inget Stöd
Thermal Monitoring Inget Stöd
Thermal Trip Inget Stöd
Voltage ID Control Inget Stöd
CPUID funktioner:
36-bit Page Size Extension Stöds
Address Region Registers (ARR) Inget Stöd
CPL Qualified Debug Store Stöds
Debug Trace Store Stöds
Debugging Extension Stöds
Fast Save & Restore Stöds
Hyper-Threading Technology (HTT) Stöds, Aktiverad
L1 Context ID Stöds
Local APIC On Chip Stöds
Machine Check Architecture (MCA) Stöds
Machine Check Exception (MCE) Stöds
Memory Configuration Registers (MCR) Inget Stöd
Memory Type Range Registers (MTRR) Stöds
Model Specific Registers (MSR) Stöds
Page Attribute Table (PAT) Stöds
Page Global Extension Stöds
Page Size Extension (PSE) Stöds
Pending Break Event Stöds
Physical Address Extension (PAE) Stöds
Secure Virtual Machine Extensions (Pacifica) Inget Stöd
Self-Snoop Stöds
Time Stamp Counter (TSC) Stöds
Virtual Machine Extensions (Vanderpool) Inget Stöd
Virtual Mode Extension Stöds
CPUID Registers (CPU #1):
CPUID 00000000 00000005-756E6547-6C65746E-49656E69
CPUID 00000001 00000F43-00020800-0000649D-BFEBFBFF
CPUID 00000002 605B5001-00000000-00000000-007D7040
CPUID 00000003 00000000-00000000-00000000-00000000
CPUID 00000004 00004121-01C0003F-0000001F-00000000
CPUID 00000005 00000040-00000040-00000000-00000000
CPUID 80000000 80000008-00000000-00000000-00000000
CPUID 80000001 00000000-00000000-00000000-20000000
CPUID 80000002 20202020-20202020-20202020-6E492020
CPUID 80000003 286C6574-50202952-69746E65-52286D75
CPUID 80000004 20342029-20555043-30302E33-007A4847
CPUID 80000005 00000000-00000000-00000000-00000000
CPUID 80000006 00000000-00000000-08006040-00000000
CPUID 80000007 00000000-00000000-00000000-00000000
CPUID 80000008 00003024-00000000-00000000-00000000
CPUID Registers (CPU #2 Virtual):
CPUID 00000001 00000F43-01020800-0000649D-BFEBFBFF
MSR Registers:
MSR 00000017 0012-0000-0000-0000
MSR 0000002A 0000-0000-0000-0000
MSR 0000002C 0000-0000-0F12-010F
MSR 0000008B 0000-0005-0000-0000
MSR 00000198 0000-0F2D-0000-0F2D
MSR 00000199 0000-0000-0000-0F2D
MSR 0000019A 0000-0000-0000-0002
MSR 0000019B 0000-0000-0000-0000
MSR 0000019C 0000-0000-0000-0000
MSR 000001A0 0000-0004-208C-0289
--------[ Moderkort ]---------------------------------------------------------------------------------------------------
Front Side Bus egenskaper:
Busstyp Intel NetBurst
Busbredd 64-bit
Realtidsklocka 200 MHz (QDR)
Effektiv klocka 800 MHz
Bandbredd 6400 MB/s
Minnesbussegenskaper:
Busstyp Dual DDR SDRAM
Busbredd 128-bit
Realtidsklocka 167 MHz (DDR)
Effektiv klocka 333 MHz
Bandbredd 5333 MB/s
Chipsetbussegenskaper:
Busstyp Intel Direct Media Interface
--------[ Minne ]-------------------------------------------------------------------------------------------------------
Fysiskt minne:
Totalt 2559 MB
Använt 959 MB
Ledigt 1600 MB
Utnyttjande 37 %
Växlingsfil:
Totalt 5115 MB
Använt 1929 MB
Ledigt 3185 MB
Utnyttjande 38 %
Virtuellt minne:
Totalt 7674 MB
Använt 2888 MB
Ledigt 4785 MB
Utnyttjande 38 %
Physical Address Extension (PAE):
Stöds av operativsystemet Ja
Stöds av processorn Ja
Aktiv Nej
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Team Group YMD512 646A8J-D43 ]
Modulnamn Team Group YMD512 646A8J-D43
Serienummer Ingen
Tillverkningsdatum Vecka 28 / 2006
Modulstorlek 1024 MB (2 ranks, 4 banks)
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulhastighet PC3200 (200 MHz)
Modulbredd 64 bit
Modulvolt SSTL 2.5
Felsökningsmetod Ingen
Uppdateringsfrekvens Reducerad (7.8 us), Self-Refresh
Minnes synkning:
@ 200 MHz 2.5-4-4-8 (CL-RCD-RP-RAS)
Minnesmodulsfunktioner:
Early RAS# Precharge Inget Stöd
Auto-Precharge Inget Stöd
Precharge All Inget Stöd
Write1/Read Burst Inget Stöd
Buffered Address/Control Inputs Inget Stöd
Registered Address/Control Inputs Inget Stöd
On-Card PLL (Clock) Inget Stöd
Buffered DQMB Inputs Inget Stöd
Registered DQMB Inputs Inget Stöd
Differential Clock Input Stöds
Redundant Row Address Inget Stöd
[ DIMM2: Team Group YMD512 646A8J-D43 ]
Serienummer Ingen
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulbredd 64 bit
Modulvolt SSTL 2.5
Minnes synkning:
[ DIMM3: Samsung M3 68L3223FTN-CCC ]
Modulnamn Samsung M3 68L3223FTN-CCC
Serienummer F1035DE8h
Modulstorlek 256 MB (1 rank, 4 banks)
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulbredd 64 bit
Modulvolt SSTL 2.5
Minnes synkning:
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS)
Minnesmodulstillverkare:
Företagsnamn Samsung
[ DIMM5: Samsung M3 68L3223FTN-CCC ]
Serienummer F1035E28h
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulbredd 64 bit
Modulvolt SSTL 2.5
Minnes synkning:
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: Intel Grantsdale i915P ]
North Bridge egenskaper:
North Bridge Intel Grantsdale i915P
Inventering / Stepping 04 / B1
Paketeringstyp 1210 Pin FC-BGA
Kärnvolts tal 1.5 V
In-Order Queue Depth 12
Minneskontroller:
Typ Dual Channel (128-bit)
Aktiv Mode Dual Channel (128-bit)
Minnes synkning:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 4T
RAS Precharge (tRP) 4T
RAS Active Time (tRAS) 7T
Felkorrigeringsmetod:
ECC Inget Stöd
ChipKill ECC Inget Stöd
RAID Inget Stöd
ECC Scrubbing Inget Stöd
Minnesplatser:
DRAM plats #1 1024 MB (PC3200 DDR SDRAM)
DRAM plats #2 256 MB (PC3200 DDR SDRAM)
DRAM plats #3 1024 MB (PC3200 DDR SDRAM)
DRAM plats #4 256 MB (PC3200 DDR SDRAM)
PCI Express Kontroller:
PCI-E x16 port #2 Används @ x16 (nVIDIA NV44 Video Adapter)
Chipsettillverkare:
Nedladdning av drivrutin Link Removed
[ South Bridge: Intel 82801FB ICH6 ]
South Bridge Egenskaper:
South Bridge Intel 82801FB ICH6
Inventering / Stepping D3 / B1
Paketeringstyp 609 Pin mBGA
Paketeringsstorlek 3.1 cm x 3.1 cm
Kärnvolts tal 1.5 V
High Definition Audio:
Ljudkortstyp Intel 82801FB(M) ICH6
Codec namn Okänd
Codec ID FFFFFFFFh
Codec Revision FFFFFFFFh
Chipsettillverkare:
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS egenskaper:
BIOS typ AMI
BIOS tillverkare:
Företagsnamn American Megatrends Inc.
Produktinformation Link Removed - Invalid URL
BIOS uppgradering Link Removed - Invalid URL
Problem och förslag:
Förslag Are you looking for a BIOS Upgrade? Contact eSupport Today!
Förslag System BIOS är mer än 2 år gammalt. Uppdatera om nödvändigt.
Förslag Grafikkortets BIOS är mer än 2 år gammalt. Uppdatera om nödvändigt.
--------[ Windows video ]-----------------------------------------------------------------------------------------------
[ NVIDIA GeForce 6500 ]
Grafikkortsegenskaper:
Enhetsbeskrivning NVIDIA GeForce 6500
Kortsträng GeForce 6500
BIOS sträng Version 5.44.2.41.1
Chiptyp GeForce 6500
DAC typ Integrated RAMDAC
Installerade drivrutiner nvd3dum (8.17.11.9562)
Grafikkortstillverkare:
Företagsnamn NVIDIA Corporation
Nedladdning av drivrutin Drivers - Download NVIDIA Drivers
--------[ PCI / AGP video ]---------------------------------------------------------------------------------------------
nVIDIA NV44 Grafikkort
nVIDIA NV44 3D accelerator
--------[ GPU ]---------------------------------------------------------------------------------------------------------
[ PCI Express x16: nVIDIA NV44 ]
GPU kodnamn NV44
PCI enhet 10DE / 0160
Transistorer 77 miljoner
Processorteknologi 0.11u
Kretskortsstorlek 110 mm2
Busstyp PCI Express x16 @ x16
Minnesstorlek 128 MB
RAMDAC klockhastighet 400 MHz
Pixel pipelines 4
TMU per pipeline 1
Vertex shaders 3 (v3.0)
Pixel shaders 1 (v3.0)
DirectX hårdvarustöd DirectX v9.0c
Pixel Fillrate 1592 MPixel/s
Texel Fillrate 1592 MTexel/s
Busstyp DDR
Busbredd 64-bit
Realtidsklocka 334 MHz (DDR)
Effektiv klocka 668 MHz
Bandbredd 5344 MB/s
Grafikprocessortillverkare:
nVIDIA GPU Registers:
nv-000000 044000A2
nv-100000 00000000
nv-100200 43003E00
nv-10020C 08000000
nv-101000 2342CE8B
nv-680500 00000000
nv-680504 00000000
nv-680570 00000000
nv-680574 00000000
nv-68057C 80000802
nv-001540 7FFF0703
nv-004000 8000011C
nv-004004 011F3B04
nv-004008 C000001C
nv-004020 E041001C
nv-004024 16020902
nv-004028 80000AA8
nv-00C040 3C0BC003
--------[ Bildskärm ]---------------------------------------------------------------------------------------------------
[ Compaq TFT7020 ]
Bildskärmsegenskaper:
Bildskärmsnamn Compaq TFT7020
Bildskärms ID CPQ1435
Modell COMPAQ 7020
Bildskärmstyp 17" LCD
Tillverkningsdatum Vecka 16 / 2002
Serienummer 12162516226137
Max. synlig visningsstorlek 33 cm x 27 cm (16.8")
Betraktningsförhållande 5:4
Horisontell frekvens 32 - 61 kHz
Vertikal frekvens 56 - 75 Hz
Maximal upplösning 1280 x 1024
Gamma 2.31
DPMS formatstöd Standby, Suspend, Active-Off
Stödda videolägen:
640 x 480 75 Hz
800 x 600 75 Hz
1024 x 768 75 Hz
1152 x 864 65 Hz
1280 x 1024 55 Hz
Bildskärmstillverkare:
Företagsnamn Hewlett-Packard Company
Nedladdning av drivrutin 24/7 Online support for HP's Home and Home Office Products - HP Customer Care (United States - English)
--------[ Skrivbord ]---------------------------------------------------------------------------------------------------
Skrivbordsegenskaper:
Enhetsteknologi Raster display
Upplösning 1280 x 1024
Färgdjup 32-bit
Färgplan 1
Typsnittsupplösning 96 dpi
Pixel bredd / höjd 36 / 36
Pixel diagonal 51
Vertikal uppdateringsfrekvens 60 Hz
Skrivbordsbakgrund C:\Users\Timmy\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
Skrivbordseffekter:
Animering av kombinationsrutor Avaktiverad
Skuggningseffekter Avaktiverad
Platta menyer effekt Aktiverad
Kantutjämning av teckensnitt Aktiverad
Visa innehåll i fönster vid drag och släpp Aktiverad
Tonövergång för programlister Aktiverad
Dölj tangenter för menyåtkomst Aktiverad
Hot tracking effekt Aktiverad
Radbrytning på ikontitlar Aktiverad
Mjuk rullning för listrutor Avaktiverad
Menyanimationer Avaktiverad
Menytoningseffekter Aktiverad
Animera fönster vid minimering/återställning Avaktiverad
Skuggning av muspekare Avaktiverad
Toning av aktivt val effekt Avaktiverad
ShowSounds hjälpmedelsfunktion Avaktiverad
Verktygstips animeringar Avaktiverad
Verktygstips toningseffekter Aktiverad
Windows Plus! tillägg Avaktiverad
Problem Minst 85 Hz vertikal uppdateringsfrekvens rekommenderas på konventionella (CRT) skärmar.
--------[ Multibildskärm ]----------------------------------------------------------------------------------------------
\\.\DISPLAY1 Ja (0,0) (1280,1024)
--------[ Windows ljud ]------------------------------------------------------------------------------------------------
midi-out.0 0001 001B Microsoft GS Wavetable Synth
--------[ PCI / PnP ljud ]----------------------------------------------------------------------------------------------
Intel 82801FB ICH6 - High Definition Audio Controller [B-1] PCI
--------[ Windows lagring ]---------------------------------------------------------------------------------------------
[ Floppy disk drive ]
Enhetsegenskaper:
Drivrutinsbeskrivning Floppy disk drive
Drivrutinsdatum 2006-06-21
Drivrutinsversion 6.1.7600.16385
Drivrutinstillverkare Microsoft
INF Fil flpydisk.inf
[ Maxtor 6Y080M0 ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Maxtor 6Y080M0 ATA Device
INF Fil disk.inf
Disk enhetens fysiska info:
Tillverkare Maxtor
Hårddiskfamilj DiamondMax Plus 9
Moderkortstyp 3.5"
Formaterad kapacitet 80 GB
Hårddiskar 1
inspelningsytor 2
Fysiska dimensioner 146.1 x 101.6 x 26.1 mm
Max. vikt 630 g
Medelrotationslatens 4.17 ms
Rotationshastighet 7200 RPM
Interface SATA
Buffer-till-värd datahastighet 150 MB/s
Bufferstorlek 8 MB
Enhetstillverkare:
Företagsnamn Maxtor Corporation
Produktinformation Maxtor is now Seagate
[ ST3120827AS ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning ST3120827AS ATA Device
INF Fil disk.inf
Tillverkare Seagate
Hårddisknamn Barracuda 7200.7 SATA NCQ 120827
Moderkortstyp 3.5"
Formaterad kapacitet 120 GB
Hårddiskar 2
inspelningsytor 3
Fysiska dimensioner 146.56 x 101.85 x 26.1 mm
Max. vikt 635 g
Medelrotationslatens 4.16 ms
Max. intern datahastighet 683 Mbit/s
Medelsöktid 8.5 ms
Interface SATA
Bufferstorlek 8 MB
Uppvarvningstid 10 sekunder
Enhetstillverkare:
Företagsnamn Seagate Technology LLC
Produktinformation Redirect
[ WDC WD1001FALS-00J7B1 ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning WDC WD1001FALS-00J7B1 ATA Device
INF Fil disk.inf
Enhetstillverkare:
Företagsnamn Western Digital Corporation
Produktinformation Welcome westerndigital.comen - Hostmonster.com
[ BENQ DVD LS DW1655 ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning BENQ DVD LS DW1655 ATA Device
INF Fil cdrom.inf
Enhetstillverkare:
Företagsnamn BenQ Corp.
Produktinformation Link Removed due to 404 Error
Firmware Download Link Removed due to 404 Error
[ TSSTcorp DVD-ROM SH-D162C ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning TSSTcorp DVD-ROM SH-D162C ATA Device
INF Fil cdrom.inf
Egenskaper för optisk enhet:
Tillverkare Toshiba-Samsung
Enhetstyp DVD-ROM
Interface ATAPI
Reading Speeds:
DVD-ROM 16x
CD-ROM 48x
Enhetstillverkare:
Företagsnamn Toshiba Samsung Storage Technology
Firmware Download http://www.samsungodd.com/eng/LiveUpdate/LiveUpdate.asp
[ ATA Channel 0 ]
Enhetsegenskaper:
Drivrutinsbeskrivning ATA Channel 0
INF Fil mshdc.inf
Enhetsresurser:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
[ ATA Channel 0 ]
Enhetsegenskaper:
INF Fil mshdc.inf
[ ATA Channel 1 ]
Enhetsegenskaper:
Drivrutinsbeskrivning ATA Channel 1
INF Fil mshdc.inf
Enhetsresurser:
IRQ 15
Port 0170-0177
Port 0376-0376
[ ATA Channel 1 ]
Enhetsegenskaper:
INF Fil mshdc.inf
[ Intel(R) 82801FB Ultra ATA Storage Controllers - 2651 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
INF Fil mshdc.inf
Enhetsresurser:
IRQ 19
Port C880-C88F
Port CC00-CC03
Port D000-D007
Port D080-D083
Port D400-D407
[ Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INF Fil mshdc.inf
Enhetsresurser:
Port FFA0-FFAF
[ Standard floppy disk controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard floppy disk controller
INF Fil fdc.inf
Enhetsresurser:
DMA 02
IRQ 06
Port 03F0-03F5
Port 03F7-03F7
[ Microsoft iSCSI Initiator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft iSCSI Initiator
INF Fil iscsi.inf
--------[ Logiska enheter ]---------------------------------------------------------------------------------------------
A: Flyttbar disk
C: (Timmy) Lokal disk NTFS 953866 MB 139061 MB 814805 MB 85 % 08B2-A367
D: Optisk enhet
E: Optisk enhet
F: (EXTRA) Lokal disk NTFS 76316 MB 37931 MB 38384 MB 50 % C495-A630
G: Lokal disk NTFS 37997 MB 13874 MB 24122 MB 63 % 0496-F990
H: (DATA) Lokal disk NTFS 76465 MB 60139 MB 16325 MB 21 % 0C9F-420F
--------[ Fysiska enheter ]---------------------------------------------------------------------------------------------
[ Enhet #1 - WDC WD1001FALS-00J7B1 ATA Device (931 GB) ]
#1 (Aktiv) NTFS C: (Timmy) 1 MB 953867 MB
[ Enhet #2 - Maxtor 6Y080M0 ATA Device (74 GB) ]
#1 NTFS F: (EXTRA) 0 MB 76316 MB
[ Enhet #3 - ST3120827AS ATA Device (111 GB) ]
#1 (Aktiv) NTFS G: 0 MB 37997 MB
#2 NTFS H: (DATA) 37997 MB 76465 MB
--------[ Optiska enheter ]---------------------------------------------------------------------------------------------
Enhetsbeskrivning BENQ DVD LS DW1655 ATA Device
Enhetsbeskrivning TSSTcorp DVD-ROM SH-D162C ATA Device
Enhetstyp DVD-ROM
Interface ATAPI
Reading Speeds:
DVD-ROM 16x
CD-ROM 48x
Enhetstillverkare:
--------[ ATA ]---------------------------------------------------------------------------------------------------------
[ WDC WD1001FALS-00J7B1 (WD-WMATV2952215) ]
ATA enhetsegenskaper:
Modell ID WDC WD1001FALS-00J7B1
Serienummer WD-WMATV2952215
Inventering 05.00K05
Parametrar 1938021 cylindrar, 16 huvuden, 63 sektorer per spår, 512 bytes per sektor
LBA sektorer 1953525168
Bufferstorlek 32767 kB
Multipla sektorer 16
ECC bytes 50
Max. PIO överföringsläge PIO 4
Max. UDMA överföringsläge UDMA 6 (ATA-133)
Aktiv UDMA överföringsläge UDMA 5 (ATA-100)
Oformaterad kapacitet 953870 MB
ATA enhetsfunktioner:
SMART Stöds
Säkerhetsläge Stöds
Energialternativ Stöds
Avancerade energialternativ Inget Stöd
Skrivcache Stöds
Host Protected Area Stöds
Power-Up In Standby Stöds
Automatic Acoustic Management Stöds
48-bit LBA Stöds
Device Configuration Overlay Stöds
ATA enhetstillverkare:
[ Maxtor 6Y080M0 (Y2BBVBKE) ]
Modell ID Maxtor 6Y080M0
Serienummer Y2BBVBKE
Inventering YAR51HW0
Parametrar 155072 cylindrar, 16 huvuden, 63 sektorer per spår, 512 bytes per sektor
LBA sektorer 156312576
Bufferstorlek 7936 kB (Dual Ported, Read Ahead)
ECC bytes 4
Oformaterad kapacitet 76324 MB
SMART Stöds
Säkerhetsläge Stöds
Avancerade energialternativ Stöds
Skrivcache Stöds
Power-Up In Standby Inget Stöd
48-bit LBA Inget Stöd
ATA enhetens fysiska info:
Tillverkare Maxtor
Moderkortstyp 3.5"
Hårddiskar 1
inspelningsytor 2
Max. vikt 630 g
Interface SATA
Bufferstorlek 8 MB
[ ST3120827AS (4MS01P2S) ]
Modell ID ST3120827AS
Serienummer 4MS01P2S
Inventering 3.42
Parametrar 232581 cylindrar, 16 huvuden, 63 sektorer per spår, 512 bytes per sektor
LBA sektorer 234441648
Bufferstorlek 8 MB
ECC bytes 4
Oformaterad kapacitet 114473 MB
SMART Stöds
Säkerhetsläge Stöds
Skrivcache Stöds
Automatic Acoustic Management Inget Stöd
48-bit LBA Stöds
Tillverkare Seagate
Moderkortstyp 3.5"
Hårddiskar 2
inspelningsytor 3
Max. vikt 635 g
Medelsöktid 8.5 ms
Interface SATA
Bufferstorlek 8 MB
--------[ SMART ]-------------------------------------------------------------------------------------------------------
01 Raw Read Error Rate 51 200 200 0 OK: Värdet är normalt
03 Spin Up Time 21 232 231 8366 OK: Värdet är normalt
04 Start/Stop Count 0 100 100 144 OK: Alltid godkänd
05 Reallocated Sector Count 140 200 200 0 OK: Värdet är normalt
07 Seek Error Rate 0 200 200 0 OK: Alltid godkänd
09 Power-On Time Count 0 100 100 620 OK: Alltid godkänd
0A Spin Retry Count 0 100 100 0 OK: Alltid godkänd
0B Calibration Retry Count 0 100 100 0 OK: Alltid godkänd
0C Power Cycle Count 0 100 100 140 OK: Alltid godkänd
C0 Power-Off Retract Count 0 200 200 13 OK: Alltid godkänd
C1 Load/Unload Cycle Count 0 200 200 144 OK: Alltid godkänd
C2 Temperature 0 111 106 39 OK: Alltid godkänd
C4 Reallocation Event Count 0 200 200 0 OK: Alltid godkänd
C5 Current Pending Sector Count 0 200 200 0 OK: Alltid godkänd
C6 Off-Line Uncorrectable Sector Count 0 100 253 0 OK: Alltid godkänd
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Alltid godkänd
C8 Write Error Rate 0 100 253 0 OK: Alltid godkänd
03 Spin Up Time 63 225 224 10048 OK: Värdet är normalt
04 Start/Stop Count 0 253 253 1736 OK: Alltid godkänd
05 Reallocated Sector Count 63 253 253 0 OK: Värdet är normalt
06 Read Channel Margin 100 253 253 0 OK: Värdet är normalt
07 Seek Error Rate 0 253 252 0 OK: Alltid godkänd
08 Seek Time Performance 187 253 241 49819 OK: Värdet är normalt
09 Power-On Time Count 0 245 245 37292 OK: Alltid godkänd
0A Spin Retry Count 157 253 252 0 OK: Värdet är normalt
0B Calibration Retry Count 223 253 252 0 OK: Värdet är normalt
0C Power Cycle Count 0 251 251 1112 OK: Alltid godkänd
C0 Power-Off Retract Count 0 253 253 0 OK: Alltid godkänd
C1 Load/Unload Cycle Count 0 253 253 0 OK: Alltid godkänd
C2 Temperature 0 253 253 42 OK: Alltid godkänd
C3 Hardware ECC Recovered 0 253 252 20833 OK: Alltid godkänd
C4 Reallocation Event Count 0 253 253 0 OK: Alltid godkänd
C5 Current Pending Sector Count 0 253 253 0 OK: Alltid godkänd
C6 Off-Line Uncorrectable Sector Count 0 253 253 0 OK: Alltid godkänd
C7 Ultra ATA CRC Error Rate 0 199 199 0 OK: Alltid godkänd
C8 Write Error Rate 0 253 252 0 OK: Alltid godkänd
C9 <Försäljarspecifik> 0 253 252 3 OK: Alltid godkänd
CA <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
CB <Försäljarspecifik> 180 253 252 0 OK: Värdet är normalt
CC <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
CD <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
CF <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
D0 <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
D1 <Försäljarspecifik> 0 191 191 0 OK: Alltid godkänd
63 <Försäljarspecifik> 0 253 253 0 OK: Alltid godkänd
64 <Försäljarspecifik> 0 253 253 0 OK: Alltid godkänd
65 <Försäljarspecifik> 0 253 253 0 OK: Alltid godkänd
01 Raw Read Error Rate 6 57 47 233942539 OK: Värdet är normalt
03 Spin Up Time 0 96 96 0 OK: Alltid godkänd
04 Start/Stop Count 20 98 98 2050 OK: Värdet är normalt
05 Reallocated Sector Count 36 100 100 0 OK: Värdet är normalt
07 Seek Error Rate 30 86 60 432046543 OK: Värdet är normalt
09 Power-On Time Count 0 91 91 8279 OK: Alltid godkänd
0A Spin Retry Count 97 100 100 0 OK: Värdet är normalt
0C Power Cycle Count 20 99 99 1176 OK: Värdet är normalt
C2 Temperature 0 37 46 37 OK: Alltid godkänd
C3 Hardware ECC Recovered 0 57 47 233942539 OK: Alltid godkänd
C5 Current Pending Sector Count 0 100 100 0 OK: Alltid godkänd
C6 Off-Line Uncorrectable Sector Count 0 100 100 0 OK: Alltid godkänd
CA <Försäljarspecifik> 0 100 253 0 OK: Alltid godkänd
--------[ Windows nätverk ]---------------------------------------------------------------------------------------------
[ Realtek RTL8139/810x Family Fast Ethernet NIC ]
Egenskaper för nätverkskort:
Interfacetyp Ethernet
Hårdvaruadress 00-10-5C-FE-A7-02
Anslutningsnamn Local Area Connection
Anslutningshastighet 100 Mbps
MTU 1500 bytes
DHCP lånet erhölls 2010-02-20 07:44:43
DHCP lånet upphör 2010-02-27 07:44:43
Bytes mottagna 1020046865 (972.8 MB)
Bytes skickade 167315878 (159.6 MB)
Nätverskortsadress:
IP / nätmask 192.168.0.100 / 255.255.255.0
Gateway 192.168.0.1
DHCP 192.168.0.1
DNS 148.160.16.66
DNS 192.168.0.1
Nätverkskortstillverkare:
Företagsnamn Realtek Semiconductor Corp.
--------[ PCI / PnP nätverk ]-------------------------------------------------------------------------------------------
Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C] PCI
--------[ DirectX video ]-----------------------------------------------------------------------------------------------
[ Primary Display Driver ]
DirectDraw enhetsegenskaper:
DirectDraw drivrutinsnamn display
DirectDraw drivrutinsbeskrivning Primary Display Driver
Hårdvarudrivrutin nvd3dum.dll
Hårdvarubeskrivning NVIDIA GeForce 6500
Direct3D enhetsegenskaper:
Tillgängligt lokalt videominne 124916 kB
Tillgängligt icke-lokalt videominne (AGP) 1031616 kB
Renderingsbitdjup 16, 32
Z-buffer Bitdjup 16, 24, 32
Min texturstorlek 1 x 1
Max texturstorlek 4096 x 4096
Vertex Shader version 3.0
Pixel shader version 3.0
Direct3D enhetsfunktioner:
Additive Texture Blending Stöds
AGP Texturing Stöds
Anisotropic Filtering Stöds
Bilinear Filtering Stöds
Cubic Environment Mapping Stöds
Cubic Filtering Inget Stöd
Decal-Alpha Texture Blending Stöds
Decal Texture Blending Stöds
Directional Lights Inget Stöd
DirectX Texture Compression Inget Stöd
DirectX Volumetric Texture Compression Inget Stöd
Dithering Stöds
Dot3 Texture Blending Stöds
Dynamic Textures Stöds
Edge Antialiasing Stöds
Environmental Bump Mapping Stöds
Environmental Bump Mapping + Luminance Stöds
Factor Alpha Blending Stöds
Geometric Hidden-Surface Removal Inget Stöd
Guard Band Stöds
Hardware Scene Rasterization Stöds
Hardware Transform & Lighting Stöds
Legacy Depth Bias Inget Stöd
Mipmap LOD Bias Adjustments Stöds
Mipmapped Cube Textures Stöds
Mipmapped Volume Textures Stöds
Modulate-Alpha Texture Blending Stöds
Modulate Texture Blending Stöds
Non-Square Textures Stöds
N-Patches Inget Stöd
Perspective Texture Correction Stöds
Point Lights Inget Stöd
Point Sampling Stöds
Projective Textures Stöds
Quintic Bezier Curves & B-Splines Inget Stöd
Range-Based Fog Stöds
Rectangular & Triangular Patches Inget Stöd
Rendering In Windowed Mode Stöds
Scissor Test Inget Stöd
Slope-Scale Based Depth Bias Inget Stöd
Specular Flat Shading Stöds
Specular Gouraud Shading Stöds
Specular Phong Shading Inget Stöd
Spherical Mapping Stöds
Spot Lights Inget Stöd
Stencil Buffers Stöds
Sub-Pixel Accuracy Stöds
Table Fog Stöds
Texture Alpha Blending Stöds
Texture Clamping Stöds
Texture Mirroring Stöds
Texture Transparency Stöds
Texture Wrapping Stöds
Triangle Culling Inget Stöd
Trilinear Filtering Stöds
Two-Sided Stencil Test Stöds
Vertex Alpha Blending Stöds
Vertex Fog Stöds
Vertex Tweening Inget Stöd
W-Based Fog Stöds
W-Buffering Inget Stöd
Z-Based Fog Stöds
Z-Bias Stöds
Z-Test Stöds
Supporterade FourCC Koder:
AI44 Stöds
AIP8 Stöds
ATOC Stöds
AV12 Stöds
AYUV Stöds
NV12 Stöds
NVDB Stöds
NVDP Stöds
NVMD Stöds
PLFF Stöds
R2VB Stöds
SSAA Stöds
UYVY Stöds
YUY2 Stöds
YV12 Stöds
--------[ DirectX ljud ]------------------------------------------------------------------------------------------------
[ Primary Sound Driver ]
DirectSound enhetsegenskaper:
Enhetsbeskrivning Primary Sound Driver
Drivrutinsmodul
Primära buffrar 0
Min / Max sekundära bufferfrekvenser 0 / 0 Hz
Primära bufferns ljudformat Ingen
Sekundära bufferns ljudformat Ingen
Totala / Fria ljudbuffers 0 / 0
Totala / Fria statiska ljudbuffers 0 / 0
Totala / Fria strömmande ljudbuffers 0 / 0
Totala / Fria 3D ljudbuffers 0 / 0
Totalt / Fria 3D statiska ljudbuffers 0 / 0
Totala / Fria 3D strömmande ljudbuffers 0 / 0
DirectSound enhetsfunktioner:
Certifierad drivrutin Nej
Emulerad enhet Nej
Precis samplingfrekvens Inget Stöd
DirectSound3D Inget Stöd
Creative EAX 1.0 Inget Stöd
Creative EAX 2.0 Inget Stöd
Creative EAX 3.0 Inget Stöd
--------[ DirectX musik ]-----------------------------------------------------------------------------------------------
[ Microsoft MIDI Mapper [Emulated] ]
DirectMusic enhetsegenskaper:
Enhetsbeskrivning Microsoft MIDI Mapper [Emulated]
Synthesizertyp Hårdvara
Enhetsklass Utgående Port
Enhetstyp Windows Multimedia
MIDI kanaler 16
DirectMusic enhetsfunktioner:
Inbyggda GM instrument Nej
Inbyggda Roland GS ljuduppsättningar Nej
DirectSound Inget Stöd
DLS L1 samplingssamling Inget Stöd
DLS L2 samplingssamling Inget Stöd
Extern MIDI port Nej
Låst DLS Minnesstorlek Nej
Portdelning Stöds
Köreffekt Inget Stöd
Fördröjningseffekt Inget Stöd
Genljudseffekt Inget Stöd
[ Microsoft GS Wavetable Synth [Emulated] ]
Enhetsbeskrivning Microsoft GS Wavetable Synth [Emulated]
MIDI kanaler 16
Portdelning Stöds
[ Microsoft Synthesizer ]
Enhetsbeskrivning Microsoft Synthesizer
Synthesizertyp Mjukvara
Enhetstyp User-Mode Synthesizer
Ljudkanaler 2
MIDI kanaler 16000
Röster 1000
Tillgängligt minne Systemminne
DirectSound Stöds
DLS L1 samplingssamling Stöds
DLS L2 samplingssamling Stöds
Portdelning Inget Stöd
Genljudseffekt Stöds
--------[ DirectX indata ]----------------------------------------------------------------------------------------------
[ Mus ]
DirectInput enhetsegenskaper:
Enhetsbeskrivning Mus
Enhetstyp Okänd
Enhetsundertyp Okänd
Antal axlar 3
Antal knappar 3
DirectInput enhetsfunktioner:
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Polled Data Format Nej
Attack Force Feedback Inget Stöd
Deadband Force Feedback Inget Stöd
Fade Force Feedback Inget Stöd
Saturation Force Feedback Inget Stöd
+/- Force Feedback Coefficients Inget Stöd
+/- Force Feedback Saturation Inget Stöd
[ Tangentbord ]
Enhetsbeskrivning Tangentbord
Enhetstyp Okänd
Antal knappar 128
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
[ Bluetooth Remote Control Device ]
Enhetsbeskrivning Bluetooth Remote Control Device
Enhetstyp Okänd
Antal knappar 255
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Antal knappar 255
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
[ Saitek Eclipse Keyboard ]
Enhetsbeskrivning Saitek Eclipse Keyboard
Enhetstyp Okänd
Antal knappar 16
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Antal knappar 3
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
--------[ Windows enheter ]---------------------------------------------------------------------------------------------
[ Enheter ]
Bluetooth Radios:
CSR Bluetooth Radio 3.0.0.159
Microsoft Bluetooth Enumerator 6.1.7600.16385
Computer:
ACPI x86-based PC 6.1.7600.16385
Disk drives:
Maxtor 6Y080M0 ATA Device 6.1.7600.16385
ST3120827AS ATA Device 6.1.7600.16385
WDC WD1001FALS-00J7B1 ATA Device 6.1.7600.16385
Display adapters:
NVIDIA GeForce 6500 8.17.11.9562
DVD/CD-ROM drives:
BENQ DVD LS DW1655 ATA Device 6.1.7600.16385
TSSTcorp DVD-ROM SH-D162C ATA Device 6.1.7600.16385
Floppy disk drives:
Floppy disk drive 6.1.7600.16385
Floppy drive controllers:
Standard floppy disk controller 6.1.7600.16385
Human Interface Devices:
Bluetooth HID Device 6.1.7600.16385
Heej!!!! :'D (Remote Control) 3.0.0.183
HID-compliant consumer control device 6.1.7600.16385
HID-compliant device 6.1.7600.16385
Misa ^^ (Remote Control) 3.0.0.183
USB Input Device 6.1.7600.16385
IDE ATA/ATAPI controllers:
ATA Channel 0 6.1.7600.16385
ATA Channel 1 6.1.7600.16385
Intel(R) 82801FB Ultra ATA Storage Controllers - 26516.1.7600.16385
Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F6.1.7600.16385
IEEE 1394 Bus host controllers:
Texas Instruments 1394 OHCI Compliant Host Controller6.1.7600.16385
Keyboards:
HID Keyboard Device 6.1.7600.16385
Mice and other pointing devices:
HID-compliant mouse 6.1.7600.16385
Modems:
Standard Modem over Bluetooth link #3 6.1.7600.16385
Standard Modem over Bluetooth link #4 6.1.7600.16385
Monitors:
Generic PnP Monitor 6.1.7600.16385
Network adapters:
Bluetooth Device (Personal Area Network) #2 6.1.7600.16385
Bluetooth Device (RFCOMM Protocol TDI) #2 6.1.7600.16385
Microsoft ISATAP Adapter #2 6.1.7600.16385
Microsoft ISATAP Adapter #3 6.1.7600.16385
Realtek RTL8139/810x Family Fast Ethernet NIC 6.108.331.2008
Teredo Tunneling Pseudo-Interface 6.1.7600.16385
WAN Miniport (IKEv2) 6.1.7600.16385
WAN Miniport (IP) 6.1.7600.16385
WAN Miniport (IPv6) 6.1.7600.16385
WAN Miniport (L2TP) 6.1.7600.16385
WAN Miniport (Network Monitor) 6.1.7600.16385
WAN Miniport (PPPOE) 6.1.7600.16385
WAN Miniport (PPTP) 6.1.7600.16385
WAN Miniport (SSTP) 6.1.7600.16385
Non-Plug and Play Drivers:
adfs
Ancillary Function Driver for Winsock
AppID Driver
AVG Free AVI Loader Driver x86
AVG Free Network Redirector
Beep
Bitlocker Drive Encryption Filter Driver
CNG
Common Log (CLFS)
Disk Virtual Machine Bus Acceleration Filter Driver
Dynamic Volume Manager
EagleNT
Hardware Policy Driver
HTTP
Kernel Mode Driver Frameworks service
KSecDD
KSecPkg
LDDM Graphics Subsystem
Link-Layer Topology Discovery Mapper I/O Driver
Link-Layer Topology Discovery Responder
Mount Point Manager
msisadrv
NativeWiFi Filter
NDIS System Driver
NDIS Usermode I/O Protocol
NDProxy
NETBT
NetIO Legacy TDI Support Driver
npkcrypt
NSI proxy service driver.
Null
Offline Files Driver
Parvdm
PEAUTH
Performance Counters for Windows Driver
QoS Packet Scheduler
QWAVE driver
RDP Encoder Mirror Driver
RDPCDD
Reflector Display Driver used to gain access to graphics data
Remote Access IPv6 ARP Driver
Security Driver
Security Processor Loader Driver
sptd
Storage volumes
System Attribute Cache
TCP/IP Protocol Driver
TCP/IP Registry Compatibility
TPkd
User Mode Driver Frameworks Platform Driver
WFP Lightweight Filter
VgaSave
Windows Firewall Authorization Driver
Virtual WiFi Filter Driver
Ports (COM & LPT):
Communications Port (COM1) 6.1.7600.16385
Communications Port (COM2) 6.1.7600.16385
Printer Port (LPT1) 6.1.7600.16385
Standard Serial over Bluetooth link (COM10) 6.1.7600.16385
Standard Serial over Bluetooth link (COM11) 6.1.7600.16385
Standard Serial over Bluetooth link (COM12) 6.1.7600.16385
Standard Serial over Bluetooth link (COM9) 6.1.7600.16385
Processors:
Intel(R) Pentium(R) 4 CPU 3.00GHz 6.1.7600.16385
Sound, video and game controllers:
High Definition Audio Device 6.1.7600.16385
Storage controllers:
Microsoft iSCSI Initiator 6.1.7600.16385
Storage volume shadow copies:
Generic volume shadow copy 6.1.7600.16385
Storage Volumes:
Generic volume 6.1.7600.16385
System devices:
ACPI Fixed Feature Button 6.1.7600.16385
ACPI Power Button 6.1.7600.16385
Composite Bus Enumerator 6.1.7600.16385
Direct memory access controller 6.1.7600.16385
Extended IO Bus 6.1.7600.16385
File as Volume Driver 6.1.7600.16385
High Definition Audio Controller 6.1.7600.16385
Intel(R) 82801 PCI Bridge - 244E 6.1.7600.16385
Intel(R) 82801FB LPC Interface Controller - 2640 6.1.7600.16385
Intel(R) 82801FB/FBM SMBus Controller - 266A 6.1.7600.16385
Intel(R) 82802 Firmware Hub Device 6.1.7600.16385
Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 25816.1.7600.16385
Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 25806.1.7600.16385
IPBusEnum Root Enumerator 6.1.7600.16385
Microsoft ACPI-Compliant System 6.1.7600.16385
Microsoft System Management BIOS Driver 6.1.7600.16385
Microsoft Virtual Drive Enumerator Driver 6.1.7600.16385
Motherboard resources 6.1.7600.16385
Numeric data processor 6.1.7600.16385
PCI bus 6.1.7600.16385
Plug and Play Software Device Enumerator 6.1.7600.16385
Printer Port Logical Interface 6.1.7600.16385
Programmable interrupt controller 6.1.7600.16385
Remote Desktop Device Redirector Bus 6.1.7600.16385
System board 6.1.7600.16385
System CMOS/real time clock 6.1.7600.16385
System speaker 6.1.7600.16385
System timer 6.1.7600.16385
Terminal Server Keyboard Driver 6.1.7600.16385
Terminal Server Mouse Driver 6.1.7600.16385
UMBus Enumerator 6.1.7600.16385
UMBus Root Bus Enumerator 6.1.7600.16385
Volume Manager 6.1.7600.16385
Universal Serial Bus controllers:
Intel(R) 82801FB/FBM USB Universal Host Controller - 26586.1.7600.16385
Intel(R) 82801FB/FBM USB Universal Host Controller - 26596.1.7600.16385
Intel(R) 82801FB/FBM USB Universal Host Controller - 265A6.1.7600.16385
Intel(R) 82801FB/FBM USB Universal Host Controller - 265B6.1.7600.16385
Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C6.1.7600.16385
USB Composite Device 6.1.7600.16385
USB Root Hub 6.1.7600.16385
Unknown:
Bluetooth Peripheral Device
[ Bluetooth Radios / CSR Bluetooth Radio ]
Enhetsegenskaper:
Drivrutinsbeskrivning CSR Bluetooth Radio
Drivrutinsdatum 2008-05-19
Drivrutinsversion 3.0.0.159
Drivrutinstillverkare CSR plc
INF Fil oem5.inf
Hårdvaru ID USB\VID_0A12&PID_0001&REV_0525
Location Information Port_#0001.Hub_#0002
[ Bluetooth Radios / Microsoft Bluetooth Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft Bluetooth Enumerator
INF Fil bth.inf
Hårdvaru ID BTH\MS_BTHBRB
[ Computer / ACPI x86-based PC ]
Enhetsegenskaper:
Drivrutinsbeskrivning ACPI x86-based PC
INF Fil hal.inf
Hårdvaru ID acpiapic
[ Disk drives / Maxtor 6Y080M0 ATA Device ]
Enhetsegenskaper:
INF Fil disk.inf
Hårdvaru ID IDE\DiskMaxtor_6Y080M0__________________________YAR51HW0
Location Information Channel 1, Target 1, Lun 0
[ Disk drives / ST3120827AS ATA Device ]
Enhetsegenskaper:
INF Fil disk.inf
Hårdvaru ID IDE\DiskST3120827AS_____________________________3.42____
Location Information Channel 0, Target 1, Lun 0
[ Disk drives / WDC WD1001FALS-00J7B1 ATA Device ]
Enhetsegenskaper:
INF Fil disk.inf
Hårdvaru ID IDE\DiskWDC_WD1001FALS-00J7B1___________________05.00K05
Location Information Channel 1, Target 0, Lun 0
[ Display adapters / NVIDIA GeForce 6500 ]
Enhetsegenskaper:
Drivrutinsbeskrivning NVIDIA GeForce 6500
Drivrutinsdatum 2009-11-20
Drivrutinsversion 8.17.11.9562
Drivrutinstillverkare NVIDIA
INF Fil oem9.inf
Hårdvaru ID PCI\VEN_10DE&DEV_0160&SUBSYS_00000000&REV_A1
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(1,0,0)
PCI enhet nVIDIA NV44 Video Adapter
Enhetsresurser:
IRQ 16
Minne 000A0000-000BFFFF
Minne D0000000-DFFFFFFF
Minne F9000000-F9FFFFFF
Minne FA000000-FAFFFFFF
Port 03B0-03BB
Port 03C0-03DF
[ DVD/CD-ROM drives / BENQ DVD LS DW1655 ATA Device ]
Enhetsegenskaper:
INF Fil cdrom.inf
Hårdvaru ID IDE\CdRomBENQ_DVD_LS_DW1655______________________BCHB____
Location Information Channel 0, Target 0, Lun 0
[ DVD/CD-ROM drives / TSSTcorp DVD-ROM SH-D162C ATA Device ]
Enhetsegenskaper:
INF Fil cdrom.inf
Hårdvaru ID IDE\CdRomTSSTcorp_DVD-ROM_SH-D162C_______________TS02____
[ Floppy disk drives / Floppy disk drive ]
Enhetsegenskaper:
Hårdvaru ID FDC\GENERIC_FLOPPY_DRIVE
[ Floppy drive controllers / Standard floppy disk controller ]
Enhetsegenskaper:
INF Fil fdc.inf
Hårdvaru ID ACPI\PNP0700
PnP enhet Floppy Disk Controller
Enhetsresurser:
DMA 02
IRQ 06
Port 03F0-03F5
Port 03F7-03F7
[ Human Interface Devices / Bluetooth HID Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth HID Device
INF Fil hidbth.inf
Hårdvaru ID BTHENUM\{00001124-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Human Interface Devices / Heej!!!! :'D (Remote Control) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Heej!!!! :'D (Remote Control)
Drivrutinsdatum 2008-07-10
Drivrutinsversion 3.0.0.183
INF Fil oem6.inf
Hårdvaru ID BTHENUM\{0000110e-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Human Interface Devices / HID-compliant consumer control device ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID-compliant consumer control device
INF Fil hidserv.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_01&Col01
Enhetsegenskaper:
INF Fil hidserv.inf
Hårdvaru ID HID\BthAvrcpDevice&Col01
Enhetsegenskaper:
INF Fil hidserv.inf
[ Human Interface Devices / HID-compliant device ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID-compliant device
INF Fil input.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_01&Col03
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_01&Col02
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID HID\BthAvrcpDevice&Col02
Enhetsegenskaper:
INF Fil input.inf
[ Human Interface Devices / Misa ^^ (Remote Control) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Misa ^^ (Remote Control)
INF Fil oem6.inf
Hårdvaru ID BTHENUM\{0000110e-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
[ Human Interface Devices / USB Input Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning USB Input Device
INF Fil input.inf
Hårdvaru ID USB\VID_06A3&PID_8020&REV_0130&MI_00
Location Information 0000.001d.0000.002.000.000.000.000.000
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID USB\VID_06A3&PID_8020&REV_0130&MI_01
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID USB\VID_04FC&PID_0013&REV_06;0
Location Information Port_#0001.Hub_#0001
[ IDE ATA/ATAPI controllers / ATA Channel 0 ]
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID Intel-266f
Enhetsresurser:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID Intel-2651
[ IDE ATA/ATAPI controllers / ATA Channel 1 ]
Enhetsegenskaper:
INF Fil mshdc.inf
Enhetsresurser:
IRQ 15
Port 0170-0177
Port 0376-0376
Enhetsegenskaper:
INF Fil mshdc.inf
[ IDE ATA/ATAPI controllers / Intel(R) 82801FB Ultra ATA Storage Controllers - 2651 ]
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID PCI\VEN_8086&DEV_2651&SUBSYS_26518086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,2)
PCI enhet Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Enhetsresurser:
IRQ 19
Port C880-C88F
Port CC00-CC03
Port D000-D007
Port D080-D083
Port D400-D407
[ IDE ATA/ATAPI controllers / Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F ]
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID PCI\VEN_8086&DEV_266F&SUBSYS_266F8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,1)
PCI enhet Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Enhetsresurser:
Port FFA0-FFAF
[ IEEE 1394 Bus host controllers / Texas Instruments 1394 OHCI Compliant Host Controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Texas Instruments 1394 OHCI Compliant Host Controller
INF Fil 1394.inf
Hårdvaru ID PCI\VEN_104C&DEV_8023&SUBSYS_8026104C&REV_00
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(2,7,0)
PCI enhet Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
Enhetsresurser:
IRQ 19
Minne FBFF8000-FBFFBFFF
Minne FBFFF800-FBFFFFFF
[ Keyboards / HID Keyboard Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID Keyboard Device
INF Fil keyboard.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_00
[ Mice and other pointing devices / HID-compliant mouse ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID-compliant mouse
INF Fil msmouse.inf
Hårdvaru ID HID\VID_04FC&PID_0013&REV_06;0
[ Modems / Standard Modem over Bluetooth link #3 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Modem over Bluetooth link #3
INF Fil mdmbtmdm.inf
Hårdvaru ID BTHENUM\{00001103-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Modems / Standard Modem over Bluetooth link #4 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Modem over Bluetooth link #4
Hårdvaru ID BTHENUM\{00001103-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
[ Monitors / Generic PnP Monitor ]
Enhetsegenskaper:
Drivrutinsbeskrivning Generic PnP Monitor
INF Fil monitor.inf
Hårdvaru ID MONITOR\CPQ1435
[ Network adapters / Bluetooth Device (Personal Area Network) #2 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth Device (Personal Area Network) #2
INF Fil bthpan.inf
Hårdvaru ID BTH\MS_BTHPAN
[ Network adapters / Bluetooth Device (RFCOMM Protocol TDI) #2 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth Device (RFCOMM Protocol TDI) #2
INF Fil tdibth.inf
Hårdvaru ID BTH\MS_RFCOMM
[ Network adapters / Microsoft ISATAP Adapter #2 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft ISATAP Adapter #2
INF Fil nettun.inf
Hårdvaru ID *ISATAP
[ Network adapters / Microsoft ISATAP Adapter #3 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft ISATAP Adapter #3
INF Fil nettun.inf
Hårdvaru ID *ISATAP
[ Network adapters / Realtek RTL8139/810x Family Fast Ethernet NIC ]
Enhetsegenskaper:
Drivrutinsbeskrivning Realtek RTL8139/810x Family Fast Ethernet NIC
Drivrutinsdatum 2008-03-31
Drivrutinsversion 6.108.331.2008
Drivrutinstillverkare Realtek Semiconductor Corp.
INF Fil oem8.inf
Hårdvaru ID PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(2,14,0)
PCI enhet Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Enhetsresurser:
IRQ 18
Minne FBFFF400-FBFFF4FF
Port E800-E8FF
[ Network adapters / Teredo Tunneling Pseudo-Interface ]
Enhetsegenskaper:
Drivrutinsbeskrivning Teredo Tunneling Pseudo-Interface
INF Fil nettun.inf
Hårdvaru ID *TEREDO
[ Network adapters / WAN Miniport (IKEv2) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (IKEv2)
INF Fil netavpna.inf
Hårdvaru ID ms_agilevpnminiport
[ Network adapters / WAN Miniport (IP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (IP)
INF Fil netrasa.inf
Hårdvaru ID ms_ndiswanip
[ Network adapters / WAN Miniport (IPv6) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (IPv6)
INF Fil netrasa.inf
Hårdvaru ID ms_ndiswanipv6
[ Network adapters / WAN Miniport (L2TP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (L2TP)
INF Fil netrasa.inf
Hårdvaru ID ms_l2tpminiport
[ Network adapters / WAN Miniport (Network Monitor) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (Network Monitor)
INF Fil netrasa.inf
Hårdvaru ID ms_ndiswanbh
[ Network adapters / WAN Miniport (PPPOE) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (PPPOE)
INF Fil netrasa.inf
Hårdvaru ID ms_pppoeminiport
[ Network adapters / WAN Miniport (PPTP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (PPTP)
INF Fil netrasa.inf
Hårdvaru ID ms_pptpminiport
[ Network adapters / WAN Miniport (SSTP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (SSTP)
INF Fil netsstpa.inf
Hårdvaru ID ms_sstpminiport
[ Non-Plug and Play Drivers / adfs ]
Enhetsegenskaper:
Drivrutinsbeskrivning adfs
[ Non-Plug and Play Drivers / Ancillary Function Driver for Winsock ]
Enhetsegenskaper:
Drivrutinsbeskrivning Ancillary Function Driver for Winsock
[ Non-Plug and Play Drivers / AppID Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning AppID Driver
[ Non-Plug and Play Drivers / AVG Free AVI Loader Driver x86 ]
Enhetsegenskaper:
Drivrutinsbeskrivning AVG Free AVI Loader Driver x86
[ Non-Plug and Play Drivers / AVG Free Network Redirector ]
Enhetsegenskaper:
Drivrutinsbeskrivning AVG Free Network Redirector
[ Non-Plug and Play Drivers / Beep ]
Enhetsegenskaper:
Drivrutinsbeskrivning Beep
[ Non-Plug and Play Drivers / Bitlocker Drive Encryption Filter Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bitlocker Drive Encryption Filter Driver
[ Non-Plug and Play Drivers / CNG ]
Enhetsegenskaper:
Drivrutinsbeskrivning CNG
[ Non-Plug and Play Drivers / Common Log (CLFS) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Common Log (CLFS)
[ Non-Plug and Play Drivers / Disk Virtual Machine Bus Acceleration Filter Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Disk Virtual Machine Bus Acceleration Filter Driver
[ Non-Plug and Play Drivers / Dynamic Volume Manager ]
Enhetsegenskaper:
Drivrutinsbeskrivning Dynamic Volume Manager
[ Non-Plug and Play Drivers / EagleNT ]
Enhetsegenskaper:
Drivrutinsbeskrivning EagleNT
[ Non-Plug and Play Drivers / Hardware Policy Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Hardware Policy Driver
[ Non-Plug and Play Drivers / HTTP ]
Enhetsegenskaper:
Drivrutinsbeskrivning HTTP
[ Non-Plug and Play Drivers / Kernel Mode Driver Frameworks service ]
Enhetsegenskaper:
Drivrutinsbeskrivning Kernel Mode Driver Frameworks service
[ Non-Plug and Play Drivers / KSecDD ]
Enhetsegenskaper:
Drivrutinsbeskrivning KSecDD
[ Non-Plug and Play Drivers / KSecPkg ]
Enhetsegenskaper:
Drivrutinsbeskrivning KSecPkg
[ Non-Plug and Play Drivers / LDDM Graphics Subsystem ]
Enhetsegenskaper:
Drivrutinsbeskrivning LDDM Graphics Subsystem
[ Non-Plug and Play Drivers / Link-Layer Topology Discovery Mapper I/O Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Link-Layer Topology Discovery Mapper I/O Driver
[ Non-Plug and Play Drivers / Link-Layer Topology Discovery Responder ]
Enhetsegenskaper:
Drivrutinsbeskrivning Link-Layer Topology Discovery Responder
[ Non-Plug and Play Drivers / Mount Point Manager ]
Enhetsegenskaper:
Drivrutinsbeskrivning Mount Point Manager
[ Non-Plug and Play Drivers / msisadrv ]
Enhetsegenskaper:
Drivrutinsbeskrivning msisadrv
[ Non-Plug and Play Drivers / NativeWiFi Filter ]
Enhetsegenskaper:
Drivrutinsbeskrivning NativeWiFi Filter
[ Non-Plug and Play Drivers / NDIS System Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning NDIS System Driver
[ Non-Plug and Play Drivers / NDIS Usermode I/O Protocol ]
Enhetsegenskaper:
Drivrutinsbeskrivning NDIS Usermode I/O Protocol
[ Non-Plug and Play Drivers / NDProxy ]
Enhetsegenskaper:
Drivrutinsbeskrivning NDProxy
[ Non-Plug and Play Drivers / NETBT ]
Enhetsegenskaper:
Drivrutinsbeskrivning NETBT
[ Non-Plug and Play Drivers / NetIO Legacy TDI Support Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning NetIO Legacy TDI Support Driver
[ Non-Plug and Play Drivers / npkcrypt ]
Enhetsegenskaper:
Drivrutinsbeskrivning npkcrypt
[ Non-Plug and Play Drivers / NSI proxy service driver. ]
Enhetsegenskaper:
Drivrutinsbeskrivning NSI proxy service driver.
[ Non-Plug and Play Drivers / Null ]
Enhetsegenskaper:
Drivrutinsbeskrivning Null
[ Non-Plug and Play Drivers / Offline Files Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Offline Files Driver
[ Non-Plug and Play Drivers / Parvdm ]
Enhetsegenskaper:
Drivrutinsbeskrivning Parvdm
[ Non-Plug and Play Drivers / PEAUTH ]
Enhetsegenskaper:
Drivrutinsbeskrivning PEAUTH
[ Non-Plug and Play Drivers / Performance Counters for Windows Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Performance Counters for Windows Driver
[ Non-Plug and Play Drivers / QoS Packet Scheduler ]
Enhetsegenskaper:
Drivrutinsbeskrivning QoS Packet Scheduler
[ Non-Plug and Play Drivers / QWAVE driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning QWAVE driver
[ Non-Plug and Play Drivers / RDP Encoder Mirror Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning RDP Encoder Mirror Driver
[ Non-Plug and Play Drivers / RDPCDD ]
Enhetsegenskaper:
Drivrutinsbeskrivning RDPCDD
[ Non-Plug and Play Drivers / Reflector Display Driver used to gain access to graphics data ]
Enhetsegenskaper:
Drivrutinsbeskrivning Reflector Display Driver used to gain access to graphics data
[ Non-Plug and Play Drivers / Remote Access IPv6 ARP Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Remote Access IPv6 ARP Driver
[ Non-Plug and Play Drivers / Security Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Security Driver
[ Non-Plug and Play Drivers / Security Processor Loader Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Security Processor Loader Driver
[ Non-Plug and Play Drivers / sptd ]
Enhetsegenskaper:
Drivrutinsbeskrivning sptd
[ Non-Plug and Play Drivers / Storage volumes ]
Enhetsegenskaper:
Drivrutinsbeskrivning Storage volumes
[ Non-Plug and Play Drivers / System Attribute Cache ]
Enhetsegenskaper:
Drivrutinsbeskrivning System Attribute Cache
[ Non-Plug and Play Drivers / TCP/IP Protocol Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning TCP/IP Protocol Driver
[ Non-Plug and Play Drivers / TCP/IP Registry Compatibility ]
Enhetsegenskaper:
Drivrutinsbeskrivning TCP/IP Registry Compatibility
[ Non-Plug and Play Drivers / TPkd ]
Enhetsegenskaper:
Drivrutinsbeskrivning TPkd
[ Non-Plug and Play Drivers / User Mode Driver Frameworks Platform Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning User Mode Driver Frameworks Platform Driver
[ Non-Plug and Play Drivers / WFP Lightweight Filter ]
Enhetsegenskaper:
Drivrutinsbeskrivning WFP Lightweight Filter
[ Non-Plug and Play Drivers / VgaSave ]
Enhetsegenskaper:
Drivrutinsbeskrivning VgaSave
[ Non-Plug and Play Drivers / Windows Firewall Authorization Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Windows Firewall Authorization Driver
[ Non-Plug and Play Drivers / Virtual WiFi Filter Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Virtual WiFi Filter Driver
[ Ports (COM & LPT) / Communications Port (COM1) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Communications Port (COM1)
INF Fil msports.inf
Hårdvaru ID ACPI\PNP0501
PnP enhet 16550A-compatible UART Serial Port
Enhetsresurser:
IRQ 04
Port 03F8-03FF
[ Ports (COM & LPT) / Communications Port (COM2) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Communications Port (COM2)
INF Fil msports.inf
Enhetsresurser:
IRQ 03
Port 02F8-02FF
[ Ports (COM & LPT) / Printer Port (LPT1) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Printer Port (LPT1)
INF Fil msports.inf
Hårdvaru ID ACPI\PNP0400
PnP enhet Parallel Port
Enhetsresurser:
Port 0378-037F
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM10) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM10)
INF Fil bthspp.inf
Hårdvaru ID BTHENUM\{00001101-0000-1000-8000-00805f9b34fb}_LOCALMFG&0000
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM11) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM11)
INF Fil bthspp.inf
Hårdvaru ID BTHENUM\{00001101-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM12) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM12)
INF Fil bthspp.inf
Hårdvaru ID BTHENUM\{00001101-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM9) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM9)
INF Fil bthspp.inf
[ Processors / Intel(R) Pentium(R) 4 CPU 3.00GHz ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) Pentium(R) 4 CPU 3.00GHz
INF Fil cpu.inf
Hårdvaru ID ACPI\GenuineIntel_-_x86_Family_15_Model_4
Enhetsegenskaper:
INF Fil cpu.inf
[ Sound, video and game controllers / High Definition Audio Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning High Definition Audio Device
Drivrutinsdatum 2009-07-13
INF Fil hdaudio.inf
Hårdvaru ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_08800000&REV_0905
Location Information Internal High Definition Audio Bus
[ Storage controllers / Microsoft iSCSI Initiator ]
Enhetsegenskaper:
INF Fil iscsi.inf
Hårdvaru ID ROOT\ISCSIPRT
[ Storage volume shadow copies / Generic volume shadow copy ]
Enhetsegenskaper:
Drivrutinsbeskrivning Generic volume shadow copy
INF Fil volsnap.inf
Hårdvaru ID STORAGE\VolumeSnapshot
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
[ Storage Volumes / Generic volume ]
Enhetsegenskaper:
INF Fil volume.inf
Enhetsegenskaper:
INF Fil volume.inf
Enhetsegenskaper:
INF Fil volume.inf
Enhetsegenskaper:
INF Fil volume.inf
[ System devices / ACPI Fixed Feature Button ]
Enhetsegenskaper:
Drivrutinsbeskrivning ACPI Fixed Feature Button
INF Fil machine.inf
Hårdvaru ID ACPI\FixedButton
[ System devices / ACPI Power Button ]
Enhetsegenskaper:
Drivrutinsbeskrivning ACPI Power Button
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C0C
PnP enhet Power Button
[ System devices / Composite Bus Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Composite Bus Enumerator
INF Fil compositebus.inf
Hårdvaru ID ROOT\CompositeBus
[ System devices / Direct memory access controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Direct memory access controller
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0200
PnP enhet DMA Controller
Enhetsresurser:
DMA 04
Port 0000-000F
Port 0081-0083
Port 0087-0087
Port 0089-008B
Port 008F-008F
Port 00C0-00DF
[ System devices / Extended IO Bus ]
Enhetsegenskaper:
Drivrutinsbeskrivning Extended IO Bus
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0A06
PnP enhet Extended IO Bus
[ System devices / File as Volume Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning File as Volume Driver
INF Fil blbdrive.inf
Hårdvaru ID ROOT\BLBDRIVE
[ System devices / High Definition Audio Controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning High Definition Audio Controller
INF Fil hdaudbus.inf
Hårdvaru ID PCI\VEN_8086&DEV_2668&SUBSYS_58263411&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,27,0)
PCI enhet Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Enhetsresurser:
IRQ 16
Minne F8FFC000-F8FFFFFF
[ System devices / Intel(R) 82801 PCI Bridge - 244E ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801 PCI Bridge - 244E
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_244E&SUBSYS_244E8086&REV_D3
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,30,0)
PCI enhet Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Enhetsresurser:
Minne FBF00000-FBFFFFFF
Port E000-EFFF
[ System devices / Intel(R) 82801FB LPC Interface Controller - 2640 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB LPC Interface Controller - 2640
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_2640&SUBSYS_26408086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,0)
PCI enhet Intel 82801FB ICH6 - LPC Bridge [B-1]
[ System devices / Intel(R) 82801FB/FBM SMBus Controller - 266A ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM SMBus Controller - 266A
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_266A&SUBSYS_266A8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,3)
PCI enhet Intel 82801FB ICH6 - SMBus Controller [B-1]
Enhetsresurser:
IRQ 10
Port 0400-041F
[ System devices / Intel(R) 82802 Firmware Hub Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82802 Firmware Hub Device
INF Fil machine.inf
Hårdvaru ID ACPI\INT0800
PnP enhet Intel Flash EEPROM
Enhetsresurser:
Minne FFB80000-FFBFFFFF
Minne FFF80000-FFFFFFFF
[ System devices / Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_2581&SUBSYS_00008086&REV_04
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,1,0)
PCI enhet Intel 82915P PCI Express Root Port [B-1]
Enhetsresurser:
IRQ 16
Minne B8000000-DFFFFFFF
Minne F9000000-FBEFFFFF
Port 03B0-03BB
Port 03C0-03DF
[ System devices / Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 2580 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 2580
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_2580&SUBSYS_25808086&REV_04
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,0,0)
PCI enhet Intel 82915P Memory Controller Hub [B-1]
[ System devices / IPBusEnum Root Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning IPBusEnum Root Enumerator
INF Fil umbus.inf
Hårdvaru ID UMB\UMBUS
[ System devices / Microsoft ACPI-Compliant System ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft ACPI-Compliant System
INF Fil acpi.inf
Hårdvaru ID ACPI_HAL\PNP0C08
PnP enhet ACPI Driver/BIOS
Enhetsresurser:
IRQ 100
IRQ 101
IRQ 102
IRQ 103
IRQ 104
IRQ 105
IRQ 106
IRQ 107
IRQ 108
IRQ 109
IRQ 110
IRQ 111
IRQ 112
IRQ 113
IRQ 114
IRQ 115
IRQ 116
IRQ 117
IRQ 118
IRQ 119
IRQ 120
IRQ 121
IRQ 122
IRQ 123
IRQ 124
IRQ 125
IRQ 126
IRQ 127
IRQ 128
IRQ 129
IRQ 130
IRQ 131
IRQ 132
IRQ 133
IRQ 134
IRQ 135
IRQ 136
IRQ 137
IRQ 138
IRQ 139
IRQ 140
IRQ 141
IRQ 142
IRQ 143
IRQ 144
IRQ 145
IRQ 146
IRQ 147
IRQ 148
IRQ 149
IRQ 150
IRQ 151
IRQ 152
IRQ 153
IRQ 154
IRQ 155
IRQ 156
IRQ 157
IRQ 158
IRQ 159
IRQ 160
IRQ 161
IRQ 162
IRQ 163
IRQ 164
IRQ 165
IRQ 166
IRQ 167
IRQ 168
IRQ 169
IRQ 170
IRQ 171
IRQ 172
IRQ 173
IRQ 174
IRQ 175
IRQ 176
IRQ 177
IRQ 178
IRQ 179
IRQ 180
IRQ 181
IRQ 182
IRQ 183
IRQ 184
IRQ 185
IRQ 186
IRQ 187
IRQ 188
IRQ 189
IRQ 190
IRQ 81
IRQ 82
IRQ 83
IRQ 84
IRQ 85
IRQ 86
IRQ 87
IRQ 88
IRQ 89
IRQ 90
IRQ 91
IRQ 92
IRQ 93
IRQ 94
IRQ 95
IRQ 96
IRQ 97
IRQ 98
IRQ 99
[ System devices / Microsoft System Management BIOS Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft System Management BIOS Driver
INF Fil machine.inf
Hårdvaru ID ROOT\mssmbios
[ System devices / Microsoft Virtual Drive Enumerator Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft Virtual Drive Enumerator Driver
INF Fil machine.inf
Hårdvaru ID ROOT\vdrvroot
[ System devices / Motherboard resources ]
Enhetsegenskaper:
Drivrutinsbeskrivning Motherboard resources
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C02
PnP enhet Motherboard Resources
Enhetsresurser:
Minne E0000000-EFFFFFFF
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FEC00000-FEC00FFF
Minne FEE00000-FEE00FFF
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FED1C000-FED1FFFF
Minne FED20000-FED8FFFF
Port 0010-001F
Port 0022-003F
Port 0044-005F
Port 0062-0063
Port 0065-006F
Port 0072-007F
Port 0080-0080
Port 0084-0086
Port 0088-0088
Port 008C-008E
Port 0090-009F
Port 00A2-00BF
Port 00E0-00EF
Port 0480-04BF
Port 04D0-04D1
Port 0800-087F
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Port 0290-0297
Port 0680-06FF
Port 0A00-0A7F
Port 0D00-0D7F
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FFC00000-FFF7FFFF
[ System devices / Numeric data processor ]
Enhetsegenskaper:
Drivrutinsbeskrivning Numeric data processor
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C04
PnP enhet Numeric Data Processor
Enhetsresurser:
IRQ 13
Port 00F0-00FF
[ System devices / PCI bus ]
Enhetsegenskaper:
Drivrutinsbeskrivning PCI bus
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0A08
PnP enhet ACPI Three-wire Device Bus
Enhetsresurser:
Minne 000C0000-000DFFFF
Minne A0000000-FFFFFFFF
Port 0000-0CF7
Port 0D00-FFFF
[ System devices / Plug and Play Software Device Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Plug and Play Software Device Enumerator
INF Fil machine.inf
Hårdvaru ID root\swenum
[ System devices / Printer Port Logical Interface ]
Enhetsegenskaper:
Drivrutinsbeskrivning Printer Port Logical Interface
INF Fil machine.inf
Hårdvaru ID LPTENUM\MicrosoftRawPort958A
Location Information LPT1
[ System devices / Programmable interrupt controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Programmable interrupt controller
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0000
PnP enhet Programmable Interrupt Controller
Enhetsresurser:
Port 0020-0021
Port 00A0-00A1
[ System devices / Remote Desktop Device Redirector Bus ]
Enhetsegenskaper:
Drivrutinsbeskrivning Remote Desktop Device Redirector Bus
INF Fil rdpbus.inf
Hårdvaru ID ROOT\RDPBUS
[ System devices / System board ]
Enhetsegenskaper:
Drivrutinsbeskrivning System board
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C01
PnP enhet System Board Extension
Enhetsresurser:
Minne 00000000-0009FFFF
Minne 000E0000-000FFFFF
Minne 00100000-9FFFFFFF
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FED13000-FED19FFF
[ System devices / System CMOS/real time clock ]
Enhetsegenskaper:
Drivrutinsbeskrivning System CMOS/real time clock
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0B00
PnP enhet Real-Time Clock
Enhetsresurser:
IRQ 08
Port 0070-0071
[ System devices / System speaker ]
Enhetsegenskaper:
Drivrutinsbeskrivning System speaker
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0800
PnP enhet PC Speaker
Enhetsresurser:
Port 0061-0061
[ System devices / System timer ]
Enhetsegenskaper:
Drivrutinsbeskrivning System timer
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0100
PnP enhet System Timer
Enhetsresurser:
IRQ 00
Port 0040-0043
[ System devices / Terminal Server Keyboard Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Terminal Server Keyboard Driver
INF Fil machine.inf
Hårdvaru ID ROOT\RDP_KBD
[ System devices / Terminal Server Mouse Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Terminal Server Mouse Driver
INF Fil machine.inf
Hårdvaru ID ROOT\RDP_MOU
[ System devices / UMBus Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning UMBus Enumerator
INF Fil umbus.inf
[ System devices / UMBus Root Bus Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning UMBus Root Bus Enumerator
INF Fil umbus.inf
Hårdvaru ID root\umbus
[ System devices / Volume Manager ]
Enhetsegenskaper:
Drivrutinsbeskrivning Volume Manager
INF Fil machine.inf
Hårdvaru ID ROOT\VOLMGR
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 2658 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_2658&SUBSYS_26588086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,0)
PCI enhet Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Enhetsresurser:
IRQ 23
Port DC00-DC1F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 2659 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_2659&SUBSYS_26598086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,1)
Enhetsresurser:
IRQ 19
Port D880-D89F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 265A ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_265A&SUBSYS_265A8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,2)
Enhetsresurser:
IRQ 18
Port D800-D81F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 265B ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_265B&SUBSYS_265B8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,3)
Enhetsresurser:
IRQ 16
Port D480-D49F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_265C&SUBSYS_265C8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,7)
PCI enhet Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Enhetsresurser:
IRQ 23
Minne F8FFBC00-F8FFBFFF
[ Universal Serial Bus controllers / USB Composite Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning USB Composite Device
INF Fil usb.inf
Location Information Port_#0002.Hub_#0001
[ Universal Serial Bus controllers / USB Root Hub ]
Enhetsegenskaper:
Drivrutinsbeskrivning USB Root Hub
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID2659&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID265B&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID2658&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID265A&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB20&VID8086&PID265C&REV0003
[ Unknown / Bluetooth Peripheral Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth Peripheral Device
Hårdvaru ID BTHENUM\{00000002-0000-1000-8000-0002ee000002}_VID&00010000_PID&c0f3
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{00000002-0000-1000-8000-0002ee000002}_VID&00010000_PID&c0f5
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771301-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771301-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771401-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771401-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
PCI enheter:
Buss 0, Enhet 30, Funktion 0 Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Buss 0, Enhet 31, Funktion 1 Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Buss 0, Enhet 29, Funktion 7 Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Buss 0, Enhet 27, Funktion 0 Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Buss 0, Enhet 31, Funktion 0 Intel 82801FB ICH6 - LPC Bridge [B-1]
Buss 0, Enhet 31, Funktion 2 Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Buss 0, Enhet 31, Funktion 3 Intel 82801FB ICH6 - SMBus Controller [B-1]
Buss 0, Enhet 29, Funktion 0 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 29, Funktion 1 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 29, Funktion 2 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 29, Funktion 3 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 0, Funktion 0 Intel 82915P Memory Controller Hub [B-1]
Buss 0, Enhet 1, Funktion 0 Intel 82915P PCI Express Root Port [B-1]
Buss 1, Enhet 0, Funktion 0 nVIDIA NV44 Video Adapter
Buss 2, Enhet 14, Funktion 0 Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Buss 2, Enhet 7, Funktion 0 Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
PnP enheter:
PNP0501 16550A-compatible UART Serial Port
PNP0C08 ACPI Driver/BIOS
FIXEDBUTTON ACPI Fixed Feature Button
PNP0A08 ACPI Three-wire Device Bus
PNP0200 DMA Controller
PNP0A06 Extended IO Bus
PNP0700 Floppy Disk Controller
INT0800 Intel Flash EEPROM
GENUINEINTEL_-_X86_FAMILY_15_MODEL_4_-_______________INTEL(R)_PENTIUM(R)_4_CPU_3.00GHZIntel(R) Pentium(R) 4 CPU 3.00GHz
ISATAP Microsoft ISATAP Adapter #2
ISATAP Microsoft ISATAP Adapter #3
PNP0C02 Motherboard Resources
PNP0C04 Numeric Data Processor
PNP0400 Parallel Port
PNP0800 PC Speaker
PNP0C0C Power Button
PNP0000 Programmable Interrupt Controller
PNP0B00 Real-Time Clock
PNP0C01 System Board Extension
PNP0100 System Timer
TEREDO Teredo Tunneling Pseudo-Interface
LPT PnP enheter:
MICROSOFTRAWPORT Printer Port Logical Interface
USB enheter:
0A12 0001 CSR Bluetooth Radio
06A3 8020 USB Composite Device
04FC 0013 USB Input Device
06A3 8020 USB Input Device
Portar:
COM1 Communications Port (COM1)
COM10 Standard Serial over Bluetooth link (COM10)
COM11 Standard Serial over Bluetooth link (COM11)
COM12 Standard Serial over Bluetooth link (COM12)
COM2 Communications Port (COM2)
COM9 Standard Serial over Bluetooth link (COM9)
LPT1 Printer Port (LPT1)
--------[ PCI enheter ]-------------------------------------------------------------------------------------------------
[ Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 30 / 0
Enhets ID 8086-244E
Delsystems ID 0000-0000
Enhetsklass 0604 (PCI/PCI Bridge)
Inventering D3
Fast Back-to-Back Transactions Inget Stöd
Enhetens finesser:
66 MHz operation Inget Stöd
Bus Mastering Aktiverad
[ Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 1
Enhets ID 8086-266F
Delsystems ID 8086-266F
Enhetsklass 0101 (IDE Controller)
Inventering 03
Fast Back-to-Back Transactions Stöds, Avaktiverad
Enhetens finesser:
[ Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 7
Enhets ID 8086-265C
Delsystems ID 8086-265C
Enhetsklass 0C03 (USB Controller)
Inventering 03
Enhetens finesser:
[ Intel 82801FB ICH6 - High Definition Audio Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Busstyp PCI Express
Buss / Enhet / Funktioner 0 / 27 / 0
Enhets ID 8086-2668
Delsystems ID 3411-5826
Enhetsklass 0403 (High Definition Audio)
Inventering 03
Enhetens finesser:
[ Intel 82801FB ICH6 - LPC Bridge [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - LPC Bridge [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 0
Enhets ID 8086-2640
Delsystems ID 8086-2640
Enhetsklass 0601 (PCI/ISA Bridge)
Inventering 03
Enhetens finesser:
[ Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 2
Enhets ID 8086-2651
Delsystems ID 8086-2651
Inventering 03
Enhetens finesser:
66 MHz operation Stöds
[ Intel 82801FB ICH6 - SMBus Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - SMBus Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 3
Enhets ID 8086-266A
Delsystems ID 8086-266A
Enhetsklass 0C05 (Serial Bus Controller)
Inventering 03
Enhetens finesser:
Bus Mastering Avaktiverad
[ Intel 82801FB ICH6 - USB Universal Host Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 0
Enhets ID 8086-2658
Delsystems ID 8086-2658
Inventering 03
Enhetens finesser:
Enhetsegenskaper:
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 1
Enhets ID 8086-2659
Delsystems ID 8086-2659
Inventering 03
Enhetens finesser:
Enhetsegenskaper:
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 2
Enhets ID 8086-265A
Delsystems ID 8086-265A
Inventering 03
Enhetens finesser:
Enhetsegenskaper:
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 3
Enhets ID 8086-265B
Delsystems ID 8086-265B
Inventering 03
Enhetens finesser:
[ Intel 82915P Memory Controller Hub [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82915P Memory Controller Hub [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 0 / 0
Enhets ID 8086-2580
Delsystems ID 8086-2580
Enhetsklass 0600 (Host/PCI Bridge)
Inventering 04
Enhetens finesser:
[ Intel 82915P PCI Express Root Port [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82915P PCI Express Root Port [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 1 / 0
Enhets ID 8086-2581
Inventering 04
Enhetens finesser:
[ nVIDIA NV44 Video Adapter ]
Enhetsegenskaper:
Enhetsbeskrivning nVIDIA NV44 Video Adapter
Busstyp PCI Express x16
Buss / Enhet / Funktioner 1 / 0 / 0
Enhets ID 10DE-0160
Enhetsklass 0300 (VGA Display Controller)
Inventering A1
Enhetens finesser:
[ Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C] ]
Enhetsegenskaper:
Enhetsbeskrivning Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Busstyp PCI
Buss / Enhet / Funktioner 2 / 14 / 0
Enhets ID 10EC-8139
Delsystems ID 10EC-8139
Enhetsklass 0200 (Ethernet Controller)
Inventering 10
Enhetens finesser:
[ Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller ]
Enhetsegenskaper:
Enhetsbeskrivning Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
Busstyp PCI
Buss / Enhet / Funktioner 2 / 7 / 0
Enhets ID 104C-8023
Delsystems ID 104C-8026
Enhetsklass 0C00 (Firewire Controller)
Inventering 00
Enhetens finesser:
--------[ Enhetsresurser ]----------------------------------------------------------------------------------------------
DMA 02 Exklusiv Standard floppy disk controller
DMA 04 Exklusiv Direct memory access controller
IRQ 00 Exklusiv System timer
IRQ 03 Exklusiv Communications Port (COM2)
IRQ 04 Exklusiv Communications Port (COM1)
IRQ 06 Exklusiv Standard floppy disk controller
IRQ 08 Exklusiv System CMOS/real time clock
IRQ 10 Delad Intel(R) 82801FB/FBM SMBus Controller - 266A
IRQ 100 Exklusiv Microsoft ACPI-Compliant System
IRQ 101 Exklusiv Microsoft ACPI-Compliant System
IRQ 102 Exklusiv Microsoft ACPI-Compliant System
IRQ 103 Exklusiv Microsoft ACPI-Compliant System
IRQ 104 Exklusiv Microsoft ACPI-Compliant System
IRQ 105 Exklusiv Microsoft ACPI-Compliant System
IRQ 106 Exklusiv Microsoft ACPI-Compliant System
IRQ 107 Exklusiv Microsoft ACPI-Compliant System
IRQ 108 Exklusiv Microsoft ACPI-Compliant System
IRQ 109 Exklusiv Microsoft ACPI-Compliant System
IRQ 110 Exklusiv Microsoft ACPI-Compliant System
IRQ 111 Exklusiv Microsoft ACPI-Compliant System
IRQ 112 Exklusiv Microsoft ACPI-Compliant System
IRQ 113 Exklusiv Microsoft ACPI-Compliant System
IRQ 114 Exklusiv Microsoft ACPI-Compliant System
IRQ 115 Exklusiv Microsoft ACPI-Compliant System
IRQ 116 Exklusiv Microsoft ACPI-Compliant System
IRQ 117 Exklusiv Microsoft ACPI-Compliant System
IRQ 118 Exklusiv Microsoft ACPI-Compliant System
IRQ 119 Exklusiv Microsoft ACPI-Compliant System
IRQ 120 Exklusiv Microsoft ACPI-Compliant System
IRQ 121 Exklusiv Microsoft ACPI-Compliant System
IRQ 122 Exklusiv Microsoft ACPI-Compliant System
IRQ 123 Exklusiv Microsoft ACPI-Compliant System
IRQ 124 Exklusiv Microsoft ACPI-Compliant System
IRQ 125 Exklusiv Microsoft ACPI-Compliant System
IRQ 126 Exklusiv Microsoft ACPI-Compliant System
IRQ 127 Exklusiv Microsoft ACPI-Compliant System
IRQ 128 Exklusiv Microsoft ACPI-Compliant System
IRQ 129 Exklusiv Microsoft ACPI-Compliant System
IRQ 13 Exklusiv Numeric data processor
IRQ 130 Exklusiv Microsoft ACPI-Compliant System
IRQ 131 Exklusiv Microsoft ACPI-Compliant System
IRQ 132 Exklusiv Microsoft ACPI-Compliant System
IRQ 133 Exklusiv Microsoft ACPI-Compliant System
IRQ 134 Exklusiv Microsoft ACPI-Compliant System
IRQ 135 Exklusiv Microsoft ACPI-Compliant System
IRQ 136 Exklusiv Microsoft ACPI-Compliant System
IRQ 137 Exklusiv Microsoft ACPI-Compliant System
IRQ 138 Exklusiv Microsoft ACPI-Compliant System
IRQ 139 Exklusiv Microsoft ACPI-Compliant System
IRQ 14 Exklusiv ATA Channel 0
IRQ 140 Exklusiv Microsoft ACPI-Compliant System
IRQ 141 Exklusiv Microsoft ACPI-Compliant System
IRQ 142 Exklusiv Microsoft ACPI-Compliant System
IRQ 143 Exklusiv Microsoft ACPI-Compliant System
IRQ 144 Exklusiv Microsoft ACPI-Compliant System
IRQ 145 Exklusiv Microsoft ACPI-Compliant System
IRQ 146 Exklusiv Microsoft ACPI-Compliant System
IRQ 147 Exklusiv Microsoft ACPI-Compliant System
IRQ 148 Exklusiv Microsoft ACPI-Compliant System
IRQ 149 Exklusiv Microsoft ACPI-Compliant System
IRQ 15 Exklusiv ATA Channel 1
IRQ 150 Exklusiv Microsoft ACPI-Compliant System
IRQ 151 Exklusiv Microsoft ACPI-Compliant System
IRQ 152 Exklusiv Microsoft ACPI-Compliant System
IRQ 153 Exklusiv Microsoft ACPI-Compliant System
IRQ 154 Exklusiv Microsoft ACPI-Compliant System
IRQ 155 Exklusiv Microsoft ACPI-Compliant System
IRQ 156 Exklusiv Microsoft ACPI-Compliant System
IRQ 157 Exklusiv Microsoft ACPI-Compliant System
IRQ 158 Exklusiv Microsoft ACPI-Compliant System
IRQ 159 Exklusiv Microsoft ACPI-Compliant System
IRQ 16 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
IRQ 16 Delad High Definition Audio Controller
IRQ 16 Delad Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
IRQ 16 Delad NVIDIA GeForce 6500
IRQ 160 Exklusiv Microsoft ACPI-Compliant System
IRQ 161 Exklusiv Microsoft ACPI-Compliant System
IRQ 162 Exklusiv Microsoft ACPI-Compliant System
IRQ 163 Exklusiv Microsoft ACPI-Compliant System
IRQ 164 Exklusiv Microsoft ACPI-Compliant System
IRQ 165 Exklusiv Microsoft ACPI-Compliant System
IRQ 166 Exklusiv Microsoft ACPI-Compliant System
IRQ 167 Exklusiv Microsoft ACPI-Compliant System
IRQ 168 Exklusiv Microsoft ACPI-Compliant System
IRQ 169 Exklusiv Microsoft ACPI-Compliant System
IRQ 170 Exklusiv Microsoft ACPI-Compliant System
IRQ 171 Exklusiv Microsoft ACPI-Compliant System
IRQ 172 Exklusiv Microsoft ACPI-Compliant System
IRQ 173 Exklusiv Microsoft ACPI-Compliant System
IRQ 174 Exklusiv Microsoft ACPI-Compliant System
IRQ 175 Exklusiv Microsoft ACPI-Compliant System
IRQ 176 Exklusiv Microsoft ACPI-Compliant System
IRQ 177 Exklusiv Microsoft ACPI-Compliant System
IRQ 178 Exklusiv Microsoft ACPI-Compliant System
IRQ 179 Exklusiv Microsoft ACPI-Compliant System
IRQ 18 Delad Realtek RTL8139/810x Family Fast Ethernet NIC
IRQ 18 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
IRQ 180 Exklusiv Microsoft ACPI-Compliant System
IRQ 181 Exklusiv Microsoft ACPI-Compliant System
IRQ 182 Exklusiv Microsoft ACPI-Compliant System
IRQ 183 Exklusiv Microsoft ACPI-Compliant System
IRQ 184 Exklusiv Microsoft ACPI-Compliant System
IRQ 185 Exklusiv Microsoft ACPI-Compliant System
IRQ 186 Exklusiv Microsoft ACPI-Compliant System
IRQ 187 Exklusiv Microsoft ACPI-Compliant System
IRQ 188 Exklusiv Microsoft ACPI-Compliant System
IRQ 189 Exklusiv Microsoft ACPI-Compliant System
IRQ 19 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
IRQ 19 Delad Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
IRQ 19 Delad Texas Instruments 1394 OHCI Compliant Host Controller
IRQ 190 Exklusiv Microsoft ACPI-Compliant System
IRQ 23 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
IRQ 23 Delad Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
IRQ 81 Exklusiv Microsoft ACPI-Compliant System
IRQ 82 Exklusiv Microsoft ACPI-Compliant System
IRQ 83 Exklusiv Microsoft ACPI-Compliant System
IRQ 84 Exklusiv Microsoft ACPI-Compliant System
IRQ 85 Exklusiv Microsoft ACPI-Compliant System
IRQ 86 Exklusiv Microsoft ACPI-Compliant System
IRQ 87 Exklusiv Microsoft ACPI-Compliant System
IRQ 88 Exklusiv Microsoft ACPI-Compliant System
IRQ 89 Exklusiv Microsoft ACPI-Compliant System
IRQ 90 Exklusiv Microsoft ACPI-Compliant System
IRQ 91 Exklusiv Microsoft ACPI-Compliant System
IRQ 92 Exklusiv Microsoft ACPI-Compliant System
IRQ 93 Exklusiv Microsoft ACPI-Compliant System
IRQ 94 Exklusiv Microsoft ACPI-Compliant System
IRQ 95 Exklusiv Microsoft ACPI-Compliant System
IRQ 96 Exklusiv Microsoft ACPI-Compliant System
IRQ 97 Exklusiv Microsoft ACPI-Compliant System
IRQ 98 Exklusiv Microsoft ACPI-Compliant System
IRQ 99 Exklusiv Microsoft ACPI-Compliant System
Minne 00000000-0009FFFF Exklusiv System board
Minne 000A0000-000BFFFF Delad PCI bus
Minne 000A0000-000BFFFF Delad NVIDIA GeForce 6500
Minne 000A0000-000BFFFF Ej fastställd Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Minne 000C0000-000DFFFF Delad PCI bus
Minne 000E0000-000FFFFF Exklusiv System board
Minne 00100000-9FFFFFFF Exklusiv System board
Minne A0000000-FFFFFFFF Delad PCI bus
Minne B8000000-DFFFFFFF Exklusiv Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Minne D0000000-DFFFFFFF Exklusiv NVIDIA GeForce 6500
Minne E0000000-EFFFFFFF Exklusiv Motherboard resources
Minne F8FFBC00-F8FFBFFF Exklusiv Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Minne F8FFC000-F8FFFFFF Exklusiv High Definition Audio Controller
Minne F9000000-F9FFFFFF Exklusiv NVIDIA GeForce 6500
Minne F9000000-FBEFFFFF Exklusiv Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Minne FA000000-FAFFFFFF Exklusiv NVIDIA GeForce 6500
Minne FBF00000-FBFFFFFF Exklusiv Intel(R) 82801 PCI Bridge - 244E
Minne FBFF8000-FBFFBFFF Exklusiv Texas Instruments 1394 OHCI Compliant Host Controller
Minne FBFFF400-FBFFF4FF Exklusiv Realtek RTL8139/810x Family Fast Ethernet NIC
Minne FBFFF800-FBFFFFFF Exklusiv Texas Instruments 1394 OHCI Compliant Host Controller
Minne FEC00000-FEC00FFF Exklusiv Motherboard resources
Minne FED13000-FED19FFF Exklusiv System board
Minne FED1C000-FED1FFFF Exklusiv Motherboard resources
Minne FED20000-FED8FFFF Exklusiv Motherboard resources
Minne FEE00000-FEE00FFF Exklusiv Motherboard resources
Minne FFB80000-FFBFFFFF Exklusiv Intel(R) 82802 Firmware Hub Device
Minne FFC00000-FFF7FFFF Exklusiv Motherboard resources
Minne FFF80000-FFFFFFFF Exklusiv Intel(R) 82802 Firmware Hub Device
Port 0000-000F Exklusiv Direct memory access controller
Port 0000-0CF7 Delad PCI bus
Port 0010-001F Exklusiv Motherboard resources
Port 0020-0021 Exklusiv Programmable interrupt controller
Port 0022-003F Exklusiv Motherboard resources
Port 0040-0043 Exklusiv System timer
Port 0044-005F Exklusiv Motherboard resources
Port 0061-0061 Exklusiv System speaker
Port 0062-0063 Exklusiv Motherboard resources
Port 0065-006F Exklusiv Motherboard resources
Port 0070-0071 Exklusiv System CMOS/real time clock
Port 0072-007F Exklusiv Motherboard resources
Port 0080-0080 Exklusiv Motherboard resources
Port 0081-0083 Exklusiv Direct memory access controller
Port 0084-0086 Exklusiv Motherboard resources
Port 0087-0087 Exklusiv Direct memory access controller
Port 0088-0088 Exklusiv Motherboard resources
Port 0089-008B Exklusiv Direct memory access controller
Port 008C-008E Exklusiv Motherboard resources
Port 008F-008F Exklusiv Direct memory access controller
Port 0090-009F Exklusiv Motherboard resources
Port 00A0-00A1 Exklusiv Programmable interrupt controller
Port 00A2-00BF Exklusiv Motherboard resources
Port 00C0-00DF Exklusiv Direct memory access controller
Port 00E0-00EF Exklusiv Motherboard resources
Port 00F0-00FF Exklusiv Numeric data processor
Port 0170-0177 Exklusiv ATA Channel 1
Port 01F0-01F7 Exklusiv ATA Channel 0
Port 0290-0297 Exklusiv Motherboard resources
Port 02F8-02FF Exklusiv Communications Port (COM2)
Port 0376-0376 Exklusiv ATA Channel 1
Port 0378-037F Exklusiv Printer Port (LPT1)
Port 03B0-03BB Delad NVIDIA GeForce 6500
Port 03B0-03BB Ej fastställd Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Port 03C0-03DF Delad NVIDIA GeForce 6500
Port 03C0-03DF Ej fastställd Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Port 03F0-03F5 Exklusiv Standard floppy disk controller
Port 03F6-03F6 Exklusiv ATA Channel 0
Port 03F7-03F7 Exklusiv Standard floppy disk controller
Port 03F8-03FF Exklusiv Communications Port (COM1)
Port 0400-041F Exklusiv Intel(R) 82801FB/FBM SMBus Controller - 266A
Port 0480-04BF Exklusiv Motherboard resources
Port 04D0-04D1 Exklusiv Motherboard resources
Port 0680-06FF Exklusiv Motherboard resources
Port 0800-087F Exklusiv Motherboard resources
Port 0A00-0A7F Exklusiv Motherboard resources
Port 0D00-0D7F Exklusiv Motherboard resources
Port 0D00-FFFF Delad PCI bus
Port C880-C88F Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port CC00-CC03 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D000-D007 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D080-D083 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D400-D407 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D480-D49F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
Port D800-D81F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
Port D880-D89F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
Port DC00-DC1F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
Port E000-EFFF Exklusiv Intel(R) 82801 PCI Bridge - 244E
Port E800-E8FF Exklusiv Realtek RTL8139/810x Family Fast Ethernet NIC
Port FFA0-FFAF Exklusiv Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
--------[ Inmatningsenheter ]-------------------------------------------------------------------------------------------
[ HID Keyboard Device ]
Tangentbordsegenskaper:
Tangentbordsnamn HID Keyboard Device
Tangentbordstyp IBM enhanced (101- or 102-key) keyboard
Tangentbordslayout Swedish
ANSI koder 1252 - @%SystemRoot%\system32\mlang.dll,-4612
OEM koder 850
Repetitionsfördröjning 1
Repetitionshastighet 31
[ HID-compliant mouse ]
Musegenskaper:
Musnamn HID-compliant mouse
Musknappar 3
Mushand Höger
Pekarhastighet 1
Dubbelklickningshastighet 500 msec
X / Y tröskelvärde 6 / 10
Antal rader för hjulrullning 3
Musfunktioner:
Spårning av aktivt fönster Avaktiverad
Klicklås Avaktiverad
Göm pekare vid skrivning Aktiverad
Mushjul Närvarande
Flytta pekare till aktiv knapp Avaktiverad
Eftersläpande pekarspår Avaktiverad
Sonar Avaktiverad
--------[ Skrivare ]----------------------------------------------------------------------------------------------------
[ Adobe PDF ]
Skrivaregenskaper:
Skrivarnamn Adobe PDF
Standardskrivare Nej
Delad som Ej delad
Skrivarport Documents\*.pdf
Skrivardrivrutin Adobe PDF Converter (v6.00)
Enhetsnamn Adobe PDF
Skrivarprocessor winprint
Skiljeblad Ingen
Tillgänglighet Alltid
Prioritet 1
Skrivarjobb i kö 0
Status Okänd
Pappersegenskaper:
Pappersstorlek A4, 210 x 297 mm
Orientering Porträtt
Utskriftskvalitet 1200 x 1200 dpi Color
[ Fax ]
Skrivaregenskaper:
Skrivarnamn Fax
Delad som Ej delad
Skrivarport SHRFAX:
Skrivardrivrutin Microsoft Shared Fax Driver (v4.00)
Enhetsnamn Fax
Skiljeblad Ingen
Tillgänglighet 02:00 - 02:00
Prioritet 1
Skrivarjobb i kö 0
Status Okänd
Pappersegenskaper:
Pappersstorlek Letter, 8.5 x 11 in
Utskriftskvalitet 200 x 200 dpi Mono
[ HP LaserJet P2015 PCL6 (Standard) ]
Skrivaregenskaper:
Skrivarnamn HP LaserJet P2015 PCL6
Standardskrivare Ja
Delad som HP LaserJet P2015 PCL6
Skrivarport 192.168.0.105
Skrivardrivrutin HP LaserJet P2015 PCL6 (v6.00)
Enhetsnamn HP LaserJet P2015 PCL6
Skrivarprocessor hpzppwn7
Skiljeblad Ingen
Prioritet 1
Skrivarjobb i kö 0
Status Offline
Pappersegenskaper:
Utskriftskvalitet 600 x 600 dpi Color
Skrivartillverkare:
Företagsnamn Hewlett-Packard Company
Produktinformation Link Removed
[ Microsoft XPS Document Writer ]
Skrivaregenskaper:
Skrivarnamn Microsoft XPS Document Writer
Delad som Ej delad
Skrivarport XPSPort:
Skrivardrivrutin Microsoft XPS Document Writer (v6.00)
Enhetsnamn Microsoft XPS Document Writer
Skiljeblad Ingen
Prioritet 1
Skrivarjobb i kö 0
Status Okänd
Pappersegenskaper:
--------[ Minneshastighet läs ]-----------------------------------------------------------------------------------------
P4EE 3733 MHz MSI P4N Diamond nForce4-SLI-Intel Dual DDR2-667 7630 MB/s
P4EE 3733 MHz Dell Dimension XPS i925XE Dual DDR2-533 6920 MB/s
Pentium EE 840 3200 MHz Intel D955XBK i955X Dual DDR2-667 6100 MB/s
Athlon64 3500+ 2200 MHz MSI K8N Neo2 Platinum nForce3-Ultra Dual PC3200 DDR 6030 MB/s
P4 540 3200 MHz Abit IC7-MAX3 i875P Dual PC3200 DDR 5780 MB/s
P4 560 3600 MHz Intel D925XCV i925X Dual DDR2-533 5570 MB/s
P4 560 3600 MHz Foxconn 915A01-P i915P Dual DDR2-533 5420 MB/s
Athlon64 FX-51 2200 MHz Asus SK8N nForce3Pro-150 Dual PC3200R DDR 5400 MB/s
P4 520 2800 MHz Soltek SL-PT880E-RL PT880 Dual PC3200 DDR 5370 MB/s
Athlon64 X2 4800+ 2400 MHz Asus A8N-SLI Deluxe nForce4-SLI Dual PC3200 DDR 5100 MB/s
P4 3000 MHz Intel D875PBZ i875P Dual PC3200 DDR 4880 MB/s
P4EE 3400 MHz Intel D925XCV i925X Dual DDR2-533 4480 MB/s
P4 2800 MHz Gigabyte GA-8S655TX Ultra SiS655TX Dual PC3200 DDR 4370 MB/s
P4 3000 MHz Intel D865PERL i865PE Dual PC3200 DDR 4070 MB/s
P4 3200 MHz Gigabyte GA-8TRS350MT RS350 Ext. Dual PC3200 DDR 3830 MB/s
Xeon 2800 MHz Asus PC-DL i875P Dual PC2700 DDR 3660 MB/s
P4 2400 MHz Iwill P4GB iE7205 Dual PC2100 DDR 3560 MB/s
P4 2400 MHz Intel D850EMV2 i850E Dual PC1066 RDRAM 3240 MB/s
Athlon64 3000+ 2000 MHz Gigabyte GA-K8N Pro nForce3-150 PC3200 DDR SDRAM 3050 MB/s
Athlon64 3200+ 2000 MHz MSI K8T Neo-FIS2R K8T800 PC3200 DDR SDRAM 2980 MB/s
P4 630 3000 MHz Unknown i915P Dual PC2700 DDR 2897 MB/s
Pentium M 730J 1600 MHz Acer TravelMate 4150 i915PM Dual DDR2-400 2880 MB/s
AthlonXP 3200+ 2200 MHz Shuttle FN45 nForce2-U400 PC3200 DDR SDRAM 2790 MB/s
AthlonXP 3200+ 2200 MHz Asus A7V880 KT880 Dual PC3200 DDR 2590 MB/s
P4 2533 MHz DFI NT72-SC i850E Dual PC800 RDRAM 2560 MB/s
AthlonXP 2700+ 2166 MHz Chaintech 7NJL1 nForce2-SPP Dual PC2700 DDR 2500 MB/s
Pentium M 1500 MHz Acer TravelMate 4500 i855GME Ext. PC2700 DDR SDRAM 2470 MB/s
AthlonXP 2700+ 2166 MHz Asus A7N8X nForce2-SPP Dual PC2700 DDR 2450 MB/s
P4 2533 MHz Gigabyte GA-8PE667 Ultra i845PE PC2700 DDR SDRAM 2450 MB/s
P4 3066 MHz Asus P4PE i845PE PC2700 DDR SDRAM 2400 MB/s
AthlonXP 3200+ 2200 MHz ASRock K7S8XE+ SiS748 PC3200 DDR SDRAM 2370 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2700 DDR SDRAM 2330 MB/s
AthlonXP 2600+ 2100 MHz MSI KT4V KT400 PC2700 DDR SDRAM 2270 MB/s
P4 2400 MHz Gigabyte GA-8GE667 Pro i845GE Int. PC2700 DDR SDRAM 2240 MB/s
Sempron 2600+ 1833 MHz ASRock K7VT4A+ KT400A PC2700 DDR SDRAM 2150 MB/s
P4 1300 MHz Dell Dimension 8100 i850 Dual PC600 RDRAM 2040 MB/s
Celeron 1700 MHz DFI PE21-EC P4X400 PC2100 DDR SDRAM 2020 MB/s
Celeron 2000 MHz Gigabyte GA-8PEMT4 i845PE PC2100 DDR SDRAM 2000 MB/s
AthlonXP 2100+ 1733 MHz Abit NF7 nForce2-SPP Dual PC2100 DDR 1990 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2100 DDR SDRAM 1960 MB/s
P4 1600 MHz Asus P4B266 i845D PC2100 DDR SDRAM 1940 MB/s
P4 1800 MHz MSI 845E Max i845E PC2100 DDR SDRAM 1940 MB/s
P4 2000 MHz Shuttle AV40 P4X266 PC2100 DDR SDRAM 1920 MB/s
AthlonXP 2200+ 1800 MHz Chaintech 7NJL1 nForce2-SPP PC2100 DDR SDRAM 1900 MB/s
Celeron 1700 MHz Asus P4S333-VM SiS650 Ext. PC2100 DDR SDRAM 1870 MB/s
Celeron 1800 MHz TriGem Imperial i845GL Int. PC2100 DDR SDRAM 1870 MB/s
AthlonXP 2000+ 1666 MHz Epox EP-8KHA+ KT266A PC2100 DDR SDRAM 1850 MB/s
P4 1700 MHz ASRock PE Pro SiS645 PC2100 DDR SDRAM 1810 MB/s
AthlonXP 1800+ 1533 MHz Abit AT7-MAX2 KT400 PC2100 DDR SDRAM 1790 MB/s
AthlonXP 2000+ 1666 MHz MSI KT3 Ultra-ARU KT333 PC2100 DDR SDRAM 1770 MB/s
AthlonXP 1800+ 1533 MHz ECS K7S5A SiS735 PC2100 DDR SDRAM 1710 MB/s
Athlon 1200 MHz Abit KG7 AMD760 PC2100 DDR SDRAM 1700 MB/s
Athlon 1200 MHz Asus A7M266 AMD760 PC2100 DDR SDRAM 1560 MB/s
AthlonXP 1500+ 1333 MHz Asus A7V266 KT266 PC2100 DDR SDRAM 1500 MB/s
Celeron 1700 MHz ECS P4S5A/DX+ SiS645DX PC133 SDRAM 1040 MB/s
AthlonXP 1700+ 1466 MHz AOpen AK73A KT133A PC133 SDRAM 990 MB/s
PIII-E 866 MHz Asus CUSL2 i815E Ext. PC133 SDRAM 980 MB/s
P4 1600 MHz Dell Dimension 4300 i845 PC133 SDRAM 950 MB/s
PIII-E 866 MHz ECS P6VAP-A+ ApolloPro133A PC133 SDRAM 840 MB/s
PIII-E 600 MHz Acorp 6V8633A ApolloPro266 PC2100 DDR SDRAM 770 MB/s
PIII-E 866 MHz Intel CC820 i820 PC100 SDRAM 760 MB/s
AthlonXP 1700+ 1466 MHz PCChips M810LR SiS730S Ext. PC133 SDRAM 740 MB/s
Athlon 600 MHz Asus K7M AMD-750 PC100 SDRAM 730 MB/s
Celeron 900 MHz MSI 815EP Pro i815EP PC100 SDRAM 710 MB/s
PIII 600 MHz Asus P2B i440BX PC133 SDRAM 670 MB/s
C3 1333 MHz VIA EPIA SP CN400 Int. PC3200 DDR SDRAM 550 MB/s
Duron 850 MHz Gigabyte GA-7IXE4 AMD750 PC100 SDRAM 460 MB/s
Celeron 466 MHz IBM 628848U i810 Int. PC66 SDRAM 390 MB/s
PII 266 MHz Intel DK440LX i440LX PC66 SDRAM 350 MB/s
K6-III 450 MHz Asus P5A ALADDiN5 PC100 SDRAM 290 MB/s
K6-III 400 MHz Epox EP-MVP3G-M MVP3 PC100 SDRAM 260 MB/s
K6-2 450 MHz Gigabyte GA-5AX ALADDiN5 PC100 SDRAM 260 MB/s
C3 800 MHz VIA EPIA PLE133 PC133 SDRAM 210 MB/s
PentiumMMX 166 MHz Asus TX97-E i430TX PC66 SDRAM 190 MB/s
PentiumPro 200 MHz Intel AP440FX i440FX 66 MHz FPM RAM 160 MB/s
C6 200 MHz M Technology R525 i430FX 66 MHz EDO RAM 60 MB/s
K6 266 MHz Asus SP97-V SiS5598 Int. 66 MHz EDO RAM 60 MB/s
Am5x86 133 MHz Gigabyte GA-5486AL ALi1489 EDO RAM 50 MB/s
--------[ Minneshastighet skriv ]---------------------------------------------------------------------------------------
P4EE 3733 MHz MSI P4N Diamond nForce4-SLI-Intel Dual DDR2-667 2980 MB/s
Athlon64 3500+ 2200 MHz MSI K8N Neo2 Platinum nForce3-Ultra Dual PC3200 DDR 2600 MB/s
Pentium EE 840 3200 MHz Intel D955XBK i955X Dual DDR2-667 2280 MB/s
P4 560 3600 MHz Intel D925XCV i925X Dual DDR2-533 2280 MB/s
P4 560 3600 MHz Foxconn 915A01-P i915P Dual DDR2-533 2200 MB/s
P4EE 3733 MHz Dell Dimension XPS i925XE Dual DDR2-533 2040 MB/s
Athlon64 FX-51 2200 MHz Asus SK8N nForce3Pro-150 Dual PC3200R DDR 1750 MB/s
P4 3000 MHz Intel D875PBZ i875P Dual PC3200 DDR 1750 MB/s
P4 540 3200 MHz Abit IC7-MAX3 i875P Dual PC3200 DDR 1740 MB/s
Athlon64 X2 4800+ 2400 MHz Asus A8N-SLI Deluxe nForce4-SLI Dual PC3200 DDR 1650 MB/s
P4EE 3400 MHz Intel D925XCV i925X Dual DDR2-533 1640 MB/s
P4 520 2800 MHz Soltek SL-PT880E-RL PT880 Dual PC3200 DDR 1550 MB/s
Xeon 2800 MHz Asus PC-DL i875P Dual PC2700 DDR 1540 MB/s
P4 2800 MHz Gigabyte GA-8S655TX Ultra SiS655TX Dual PC3200 DDR 1480 MB/s
P4 3000 MHz Intel D865PERL i865PE Dual PC3200 DDR 1440 MB/s
P4 2400 MHz Intel D850EMV2 i850E Dual PC1066 RDRAM 1330 MB/s
P4 630 3000 MHz Unknown i915P Dual PC2700 DDR 1267 MB/s
Athlon64 3200+ 2000 MHz MSI K8T Neo-FIS2R K8T800 PC3200 DDR SDRAM 1220 MB/s
AthlonXP 3200+ 2200 MHz Shuttle FN45 nForce2-U400 PC3200 DDR SDRAM 1120 MB/s
Athlon64 3000+ 2000 MHz Gigabyte GA-K8N Pro nForce3-150 PC3200 DDR SDRAM 1110 MB/s
P4 2533 MHz DFI NT72-SC i850E Dual PC800 RDRAM 1110 MB/s
AthlonXP 2700+ 2166 MHz Chaintech 7NJL1 nForce2-SPP Dual PC2700 DDR 1000 MB/s
AthlonXP 2700+ 2166 MHz Asus A7N8X nForce2-SPP Dual PC2700 DDR 980 MB/s
P4 3200 MHz Gigabyte GA-8TRS350MT RS350 Ext. Dual PC3200 DDR 970 MB/s
P4 2400 MHz Iwill P4GB iE7205 Dual PC2100 DDR 900 MB/s
AthlonXP 3200+ 2200 MHz Asus A7V880 KT880 Dual PC3200 DDR 880 MB/s
P4 2533 MHz Gigabyte GA-8PE667 Ultra i845PE PC2700 DDR SDRAM 860 MB/s
AthlonXP 2100+ 1733 MHz Abit NF7 nForce2-SPP Dual PC2100 DDR 810 MB/s
Pentium M 730J 1600 MHz Acer TravelMate 4150 i915PM Dual DDR2-400 780 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2700 DDR SDRAM 780 MB/s
AthlonXP 2200+ 1800 MHz Chaintech 7NJL1 nForce2-SPP PC2100 DDR SDRAM 760 MB/s
AthlonXP 3200+ 2200 MHz ASRock K7S8XE+ SiS748 PC3200 DDR SDRAM 750 MB/s
Celeron 1700 MHz DFI PE21-EC P4X400 PC2100 DDR SDRAM 750 MB/s
P4 1600 MHz Asus P4B266 i845D PC2100 DDR SDRAM 740 MB/s
AthlonXP 2600+ 2100 MHz MSI KT4V KT400 PC2700 DDR SDRAM 730 MB/s
P4 3066 MHz Asus P4PE i845PE PC2700 DDR SDRAM 700 MB/s
Celeron 1700 MHz Asus P4S333-VM SiS650 Ext. PC2100 DDR SDRAM 700 MB/s
P4 2400 MHz Gigabyte GA-8GE667 Pro i845GE Int. PC2700 DDR SDRAM 690 MB/s
P4 1700 MHz ASRock PE Pro SiS645 PC2100 DDR SDRAM 690 MB/s
Pentium M 1500 MHz Acer TravelMate 4500 i855GME Ext. PC2700 DDR SDRAM 680 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2100 DDR SDRAM 680 MB/s
P4 1800 MHz MSI 845E Max i845E PC2100 DDR SDRAM 660 MB/s
P4 1300 MHz Dell Dimension 8100 i850 Dual PC600 RDRAM 650 MB/s
P4 2000 MHz Shuttle AV40 P4X266 PC2100 DDR SDRAM 650 MB/s
Celeron 1800 MHz TriGem Imperial i845GL Int. PC2100 DDR SDRAM 650 MB/s
Celeron 2000 MHz Gigabyte GA-8PEMT4 i845PE PC2100 DDR SDRAM 640 MB/s
Sempron 2600+ 1833 MHz ASRock K7VT4A+ KT400A PC2700 DDR SDRAM 630 MB/s
AthlonXP 2000+ 1666 MHz MSI KT3 Ultra-ARU KT333 PC2100 DDR SDRAM 590 MB/s
AthlonXP 1800+ 1533 MHz Abit AT7-MAX2 KT400 PC2100 DDR SDRAM 560 MB/s
AthlonXP 2000+ 1666 MHz Epox EP-8KHA+ KT266A PC2100 DDR SDRAM 510 MB/s
AthlonXP 1800+ 1533 MHz ECS K7S5A SiS735 PC2100 DDR SDRAM 510 MB/s
Athlon 1200 MHz Abit KG7 AMD760 PC2100 DDR SDRAM 500 MB/s
Celeron 1700 MHz ECS P4S5A/DX+ SiS645DX PC133 SDRAM 490 MB/s
Athlon 1200 MHz Asus A7M266 AMD760 PC2100 DDR SDRAM 470 MB/s
AthlonXP 1500+ 1333 MHz Asus A7V266 KT266 PC2100 DDR SDRAM 430 MB/s
P4 1600 MHz Dell Dimension 4300 i845 PC133 SDRAM 350 MB/s
AthlonXP 1700+ 1466 MHz PCChips M810LR SiS730S Ext. PC133 SDRAM 350 MB/s
AthlonXP 1700+ 1466 MHz AOpen AK73A KT133A PC133 SDRAM 310 MB/s
Athlon 600 MHz Asus K7M AMD-750 PC100 SDRAM 300 MB/s
PIII 600 MHz Asus P2B i440BX PC133 SDRAM 260 MB/s
PIII-E 866 MHz Asus CUSL2 i815E Ext. PC133 SDRAM 240 MB/s
C3 1333 MHz VIA EPIA SP CN400 Int. PC3200 DDR SDRAM 200 MB/s
Duron 850 MHz Gigabyte GA-7IXE4 AMD750 PC100 SDRAM 200 MB/s
PIII-E 866 MHz ECS P6VAP-A+ ApolloPro133A PC133 SDRAM 190 MB/s
PIII-E 600 MHz Acorp 6V8633A ApolloPro266 PC2100 DDR SDRAM 190 MB/s
Celeron 900 MHz MSI 815EP Pro i815EP PC100 SDRAM 180 MB/s
PIII-E 866 MHz Intel CC820 i820 PC100 SDRAM 140 MB/s
Celeron 466 MHz IBM 628848U i810 Int. PC66 SDRAM 140 MB/s
C3 800 MHz VIA EPIA PLE133 PC133 SDRAM 130 MB/s
PII 266 MHz Intel DK440LX i440LX PC66 SDRAM 120 MB/s
K6-III 450 MHz Asus P5A ALADDiN5 PC100 SDRAM 120 MB/s
K6-III 400 MHz Epox EP-MVP3G-M MVP3 PC100 SDRAM 120 MB/s
PentiumMMX 166 MHz Asus TX97-E i430TX PC66 SDRAM 90 MB/s
K6-2 450 MHz Gigabyte GA-5AX ALADDiN5 PC100 SDRAM 80 MB/s
PentiumPro 200 MHz Intel AP440FX i440FX 66 MHz FPM RAM 80 MB/s
K6 266 MHz Asus SP97-V SiS5598 Int. 66 MHz EDO RAM 40 MB/s
Am5x86 133 MHz Gigabyte GA-5486AL ALi1489 EDO RAM 30 MB/s
--------[ Minnesfördröjning ]-------------------------------------------------------------------------------------------
Athlon64 3500+ 2200 MHz MSI K8N Neo2 Platinum nForce3-Ultra Dual PC3200 DDR 2-2-2-5 45.6 ns
Athlon64 3400+ 2200 MHz Chaintech VNF3-250 nForce3-250 PC3200 DDR SDRAM 2-2-2-5 48.4 ns
Athlon64 3500+ 2200 MHz Asus A8V K8T800Pro Dual PC3200 DDR 2.5-3-3-7 58.8 ns
Athlon64 X2 4800+ 2400 MHz Asus A8N-SLI Deluxe nForce4-SLI Dual PC3200 DDR 2.5-3-3-8 62.2 ns
Athlon64 3800+ 2400 MHz Gigabyte GA-K8NSNXP-939 nForce3-Ultra Dual PC2700 DDR 2-3-3-7 67.8 ns
Opteron 246 2000 MHz Iwill DK8N nForce3Pro-250 Dual PC3200R DDR 2.5-3-3-8 68.0 ns
P4EE 3733 MHz MSI P4N Diamond nForce4-SLI-Intel Dual DDR2-667 4-4-4-15 76.3 ns
P4 3000 MHz Epox EP-4PCA3+ i875P + PAT Dual PC3200 DDR 2.5-3-3-8 78.9 ns
P4 2600 MHz Asus P4P800 i865PE + PAT Dual PC3200 DDR 2.5-3-3-6 79.7 ns
Opteron 248 2200 MHz MSI K8T Master1-FAR K8T800 Dual PC2100R DDR 2-3-3-6 83.1 ns
P4 540 3200 MHz Abit AA8-DuraMAX i925X Dual DDR2-533 3-3-3-8 84.5 ns
Pentium EE 840 3200 MHz Intel D955XBK i955X Dual DDR2-667 4-4-4-11 85.6 ns
P4 540 3200 MHz Epox EP-5EGA+ i915G Ext. Dual PC3200 DDR 2-2-2-5 86.7 ns
Xeon 2800 MHz Asus PC-DL i875P + PAT Dual PC2700 DDR 2-3-3-5 94.9 ns
Pentium M 1500 MHz Acer TravelMate 4500 i855GME Ext. PC2700 DDR SDRAM 2.5-3-3-7 101.0 ns
P4 3000 MHz Intel D865PERL i865PE Dual PC3200 DDR 3-3-3-8 101.4 ns
Pentium M 730J 1600 MHz Acer TravelMate 4150 i915PM Dual DDR2-400 3-3-3-8 101.9 ns
AthlonXP 3100+ 2200 MHz ASRock K7S8XE SiS748 PC3200 DDR SDRAM 2.5-3-3-5 102.2 ns
AthlonXP 2500+ 1833 MHz Asus A7N8X-E nForce2-U400 PC2700 DDR SDRAM 2.5-3-3-7 105.4 ns
P4 3066 MHz MSI 848P Neo-S i848P PC2700 DDR SDRAM 2.5-3-3-7 115.1 ns
P4 2600 MHz Asus P4P800 i865PE Dual PC3200 DDR 2.5-4-4-7 117.8 ns
P4 630 3000 MHz Unknown i915P Dual PC2700 DDR 2.5-4-4-7 119.3 ns
P4 2400 MHz Asus P4T533 i850E Dual PC1066 RDRAM - 121.8 ns
P4 3200 MHz Gigabyte GA-8TRS350MT RS350 Int. Dual PC3200 DDR 3-3-3-8 125.2 ns
Sempron 2600+ 1833 MHz ASRock K7VT4A+ KT400A PC2700 DDR SDRAM 2.5-3-3-7 131.5 ns
P4 2533 MHz DFI NT72-SC i850E Dual PC800 RDRAM - 150.8 ns
C3 1333 MHz VIA EPIA SP CN400 Int. PC3200 DDR SDRAM 2.5-3-3-8 161.3 ns
PIII-E 600 MHz Acorp 6V8633A ApolloPro266 PC2100 DDR SDRAM 2.5-3-3-6 166.8 ns
Celeron 2400 MHz Gigabyte GA-8TRS350MT RS350 Int. Dual PC3200 DDR 3-3-3-8 169.2 ns
C3 800 MHz VIA EPIA PLE133 PC133 SDRAM 3-3-3-6 178.5 ns
Duron 1300 MHz Asus A7V KT133 PC133 SDRAM 3-3-3-6 182.6 ns
AthlonXP 1800+ 1533 MHz Gigabyte GA-7DXE AMD760 PC2100 DDR SDRAM 2.5-3-3-7 191.3 ns
Celeron 2000 MHz Abit TH7II i850 Dual PC600 RDRAM - 191.8 ns
PIII 450 MHz Intel VC820 i820 PC600 RDRAM - 209.0 ns
PIII Xeon 550 MHz IBM Netfinity 8500R Profusion PC100R SDRAM - 221.0 ns
K6-III 400 MHz Epox EP-MVP3G-M MVP3 PC100 SDRAM 2-2-2-5 248.5 ns
PII 266 MHz Intel DK440LX i440LX PC66 SDRAM 3-2-2-6 272.9 ns
K6-2 500 MHz PCChips M577 MVP3 PC100 SDRAM 2-3-3-6 286.8 ns
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: Intel 82915P Memory Controller Hub [B-1]
Offset 00: 86 80 80 25 06 00 90 30 04 00 00 06 00 00 00 00
Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 80 25
Offset 30: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 90 D1 FE 00 40 D1 FE 00 00 00 E0 00 80 D1 FE
Offset 50: 00 00 00 00 03 00 00 B8 00 00 00 00 00 00 00 00
Offset 60: 01 30 D1 FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 10 11 11 00 00 33 33 00 00 00 00 00 A0 0A 38 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
Offset E0: 09 00 09 21 42 B3 9B 88 02 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
B00 D01 F00: Intel 82915P PCI Express Root Port [B-1]
Offset 00: 86 80 81 25 07 01 10 00 04 00 04 06 08 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 00
Offset 20: 00 F9 E0 FB 00 B8 F0 DF 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 88 00 00 00 00 00 00 00 10 01 1A 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
Offset 80: 01 90 02 C8 00 00 00 00 0D 80 00 00 86 80 00 00
Offset 90: 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 10 00 41 01 00 00 00 00 00 00 00 00 01 2D 01 02
Offset B0: 40 00 01 11 80 25 80 00 C0 01 48 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 01 00 00 00 00 00 00 00 04 00 00 00 00 00
B00 D1B F00: Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Offset 00: 86 80 68 26 06 00 10 00 03 00 03 04 08 00 00 00
Offset 10: 04 C0 FF F8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 11 34 26 58
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
Offset 40: 03 00 00 00 07 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 10 00 91 00 00 00 00 00 00 08 10 00 00 00 00 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 80 0F 03 00 00 00 00 00
B00 D1D F00: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 58 26 05 00 80 02 03 00 03 0C 00 00 80 00
Offset 20: 01 DC 00 00 00 00 00 00 00 00 00 00 86 80 58 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 17 01 00 00
Offset 60: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1D F01: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 59 26 05 00 80 02 03 00 03 0C 00 00 00 00
Offset 20: 81 D8 00 00 00 00 00 00 00 00 00 00 86 80 59 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
B00 D1D F02: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 5A 26 05 00 80 02 03 00 03 0C 00 00 00 00
Offset 20: 01 D8 00 00 00 00 00 00 00 00 00 00 86 80 5A 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
B00 D1D F03: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 5B 26 05 00 80 02 03 00 03 0C 00 00 00 00
Offset 20: 81 D4 00 00 00 00 00 00 00 00 00 00 86 80 5B 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 10 04 00 00
B00 D1D F07: Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Offset 00: 86 80 5C 26 06 00 90 02 03 20 03 0C 00 00 00 00
Offset 10: 00 BC FF F8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 5C 26
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Offset 50: 01 58 C2 C9 00 80 00 00 0A 00 A0 20 00 00 00 00
Offset 60: 20 20 FF 01 00 00 00 00 01 00 00 00 00 00 00 C0
Offset 70: 00 00 FF 3F 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 AA FF 00 55 55 FF 00 20 00 00 00
Offset F0: 00 80 00 09 88 8C 40 00 80 0F 03 00 86 17 00 00
B00 D1E F00: Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Offset 00: 86 80 4E 24 07 01 10 48 D3 01 04 06 00 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 02 02 20 E0 E0 80 F2
Offset 20: F0 FB F0 FB F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 06 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00
Offset 50: 0D 00 00 00 86 80 4E 24 00 00 00 00 00 00 00 00
B00 D1F F00: Intel 82801FB ICH6 - LPC Bridge [B-1]
Offset 00: 86 80 40 26 07 00 00 02 03 00 01 06 00 00 80 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 40 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 01 08 00 00 80 00 00 00 81 04 00 00 10 00 00 00
Offset 60: 8A 8A 85 8B D0 00 00 00 80 80 80 85 00 00 00 00
Offset 80: 10 00 0F 14 01 0A 00 00 01 0D 00 00 00 00 00 00
Offset A0: 20 02 00 00 39 00 00 00 00 00 00 00 00 03 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 01 08 00 00 00 00
Offset D0: 33 22 11 00 67 45 00 00 C0 80 00 00 00 00 00 00
Offset F0: 01 C0 D1 FE 00 00 00 00 80 0F 03 00 00 00 00 00
B00 D1F F01: Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Offset 00: 86 80 6F 26 05 00 80 02 03 8A 01 01 00 00 00 00
Offset 10: 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
Offset 20: A1 FF 00 00 00 00 00 00 00 00 00 00 86 80 6F 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
Offset 40: 33 E3 00 80 0B 00 00 00 03 00 22 00 00 00 00 00
Offset C0: 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F02: Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Offset 00: 86 80 51 26 05 00 B0 02 03 8F 01 01 00 00 00 00
Offset 10: 01 D4 00 00 81 D0 00 00 01 D0 00 00 01 CC 00 00
Offset 20: 81 C8 00 00 00 00 00 00 00 00 00 00 86 80 51 26
Offset 30: 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
Offset 40: 70 C0 77 E3 BB 00 00 00 0E 00 10 11 00 00 00 00
Offset 50: 00 00 00 00 F0 E0 00 00 00 00 00 00 00 00 00 00
Offset 70: 01 00 02 40 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 EF 00 82 01 80 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F03: Intel 82801FB ICH6 - SMBus Controller [B-1]
Offset 00: 86 80 6A 26 01 00 80 02 03 00 05 0C 00 00 00 00
Offset 20: 01 04 00 00 00 00 00 00 00 00 00 00 86 80 6A 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 0A 02 00 00
Offset 40: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B01 D00 F00: nVIDIA NV44 Video Adapter
Offset 00: DE 10 60 01 07 00 10 00 A1 00 00 03 08 00 00 00
Offset 10: 00 00 00 FA 0C 00 00 D0 00 00 00 00 04 00 00 F9
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
Offset 50: 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
Offset 60: 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 10 00 01 00 C0 04 2C 01
Offset 80: 10 28 00 00 01 2D 01 00 48 00 01 11 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B02 D07 F00: Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
Offset 00: 4C 10 23 80 16 00 10 02 00 10 00 0C 08 40 00 00
Offset 10: 00 F8 FF FB 00 80 FF FB 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 4C 10 26 80
Offset 30: 00 00 00 00 44 00 00 00 00 00 00 00 13 01 02 04
Offset 40: 00 00 00 00 01 00 02 7E 00 80 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 88 00 00 00
Offset F0: 10 00 00 00 82 10 00 00 4C 10 26 80 00 00 00 00
B02 D0E F00: Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Offset 00: EC 10 39 81 07 00 90 02 10 00 00 02 00 40 00 00
Offset 10: 01 E8 00 00 00 F4 FF FB 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 12 01 20 40
Offset 50: 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00
PCI-8086-2580: Intel i910/915/925/945/955/E7221/E7230 MMR
Offset 100: 10 20 28 28 00 00 00 00 44 03 00 00 3F 00 00 00
Offset 110: E8 20 54 86 22 69 70 01 FF 03 00 00 FF 01 FF 03
Offset 120: 05 2A 00 40 00 05 00 C2 F0 01 00 00 00 00 00 00
Offset 130: C4 06 00 00 6D 06 1A 87 10 00 01 02 04 08 00 00
Offset 140: 00 00 00 00 00 00 00 00 01 01 02 06 03 00 00 00
Offset 150: 32 9E 35 D2 76 B6 AB EA 00 25 00 00 00 00 00 00
Offset 160: 00 00 00 00 20 00 00 00 55 AA 00 22 98 87 20 20
Offset 170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 180: 10 20 28 28 00 00 00 00 44 03 00 00 3F 00 00 00
Offset 190: E8 20 54 86 22 69 70 01 FF 03 00 00 FF 01 FF 03
Offset 1A0: 05 2A 00 40 00 00 00 00 00 00 00 00 00 00 00 00
Offset 200: 02 02 0F 00 00 00 00 00 20 01 02 04 18 00 00 00
Offset 210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C00: 12 00 00 20 01 01 01 01 00 00 00 00 00 00 00 00
Offset C10: 00 00 00 00 03 00 80 00 00 00 00 00 5A 5A 00 00
Offset C20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C30: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CA0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CB0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CC0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CD0: 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00
Offset CE0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CF0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.w.K7400.L.w.VIDEO ......W...IBM VGA Compatible........08/30/05
C000:0040 .......................................".........PMIDl.o.......
C000:0080 [email protected]...........@...........J!............
C000:00C0 ................................................................
C000:0100 ....PCIR..`.........w.......NVIDIA GeForce 6500 VGA BIOS...VGA B
C000:0140 IOS..........................................Version 5.44.02.41T
C000:0180 3H1....Copyright (C) 1996-2004 NVIDIA Corp......................
C000:01C0 .................................nv44 Board - p280h6 ..........
C000:0200 ....Chip Rev ...........BIT......G2.....B.....C.....D.....I...
C000:0240 ..L.....t.....M.....N.....P.....S.....T.....U.....V.....c.....i.
C000:0280 $.......A.D.........00/00/00..\\.........[X/y\0...(]:]B]b].].]:]
C000:02C0 T................. ..]....f.......I.......BQ.....Pm....(./.!/#..
C000:0300 #.....\.e5H5..A.D..`.6q..>D.]08/05/05..............1.....#.....
C000:0340 E...E.c.I...........Z.......>.......E...j...Z...H.........a.....
C000:0380 .Ye.H.B.B.B.......B.n.4...q.B.B.t.......x.4...T.f`...(].........
C000:03C0 .......u..fa....f`3....fa....C.>....4.......u.........8...t.....
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
Motherboard 63-0100-009999-00101111-102604-GrantsD$I501000_BIOS DATE: 10/26/04 18:56:58 VER: 08.00.11 P5I915P(G) BIOS V1.3 OCT.26,2004
Motherboard DMIMOBO: To be filled by O.E.M. To be filled by O.E.M.
Motherboard DMISYS: To Be Filled By O.E.M. To Be Filled By O.E.M.
Motherboard Unknown
Optical BENQ DVD LS DW1655 ATA Device
Those this help?
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
Version EVEREST v2.20.405/se
Hemsida Lavalys - Comprehensive IT Security and Management
Rapporttyp Rapportassistenten
Dator TIMMYGAME (XilitoN's Comp)
Skapad av Timmy
Operativsystem Windows 7 Ultimate Media Center Edition 6.1.7600
Datum 2010-02-20
Tid 21:58
--------[ Sammanställning ]---------------------------------------------------------------------------------------------
Dator:
OS Servicepaket -
DirectX 4.09.00.0904 (DirectX 9.0c)
Datornamn TIMMYGAME (XilitoN's Comp)
Användarnamn Timmy
Moderkort:
CPU typ Intel Pentium 4 630, 3000 MHz (15 x 200)
Moderkortsnamn Okänd
Moderkortschipset Intel Grantsdale i915P
Systemminne 2560 MB (PC3200 DDR SDRAM)
BIOS typ AMI (10/26/04)
Kommunikationsport Communications Port (COM1)
Kommunikationsport Standard Serial over Bluetooth link (COM10)
Kommunikationsport Standard Serial over Bluetooth link (COM11)
Kommunikationsport Standard Serial over Bluetooth link (COM12)
Kommunikationsport Communications Port (COM2)
Kommunikationsport Standard Serial over Bluetooth link (COM9)
Kommunikationsport Printer Port (LPT1)
Bildskärm:
Grafikkort NVIDIA GeForce 6500
3D accelerator nVIDIA NV44
Bildskärm Compaq TFT7020 [17" LCD] (12162516226137)
Multimedia:
Ljudkort Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Lagring:
IDE Kontroller Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
IDE Kontroller Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
SCSI/RAID Kontroller Microsoft iSCSI Initiator
Diskettenhet Floppy disk drive
Hårddisk WDC WD1001FALS-00J7B1 ATA Device (931 GB, IDE)
Hårddisk Maxtor 6Y080M0 ATA Device (80 GB, 7200 RPM, SATA)
Hårddisk ST3120827AS ATA Device (120 GB, 7200 RPM, SATA)
Optisk enhet BENQ DVD LS DW1655 ATA Device
Optisk enhet TSSTcorp DVD-ROM SH-D162C ATA Device (16x/48x DVD-ROM)
SMART Hårddiskstatus OK
Partitioner:
C: (NTFS) 953866 MB (814805 MB ledigt)
F: (NTFS) 76316 MB (38384 MB ledigt)
G: (NTFS) 37997 MB (24122 MB ledigt)
H: (NTFS) 76465 MB (16325 MB ledigt)
Total storlek 1117.8 GB (872.7 GB ledigt)
Inmatningsenheter:
Tangentbord HID Keyboard Device
Mus HID-compliant mouse
Nätverk:
Nätverkskort Realtek RTL8139/810x Family Fast Ethernet NIC (192.168.0.100)
Modem Standard Modem over Bluetooth link #3
Modem Standard Modem over Bluetooth link #4
Kringutrustning:
Skrivare Adobe PDF
Skrivare Fax
Skrivare HP LaserJet P2015 PCL6
Skrivare Microsoft XPS Document Writer
USB1 Kontroller Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
USB2 Kontroller Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
USB enhet CSR Bluetooth Radio
USB enhet USB Composite Device
USB enhet USB Input Device
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS egenskaper:
Försäljare American Megatrends Inc.
Version 080011
Publiceringsdatum 10/26/2004
Storlek 512 kB
Bootenheter Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
Funktioner Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
Standarder som stöds DMI, APM, ACPI, ESCD, PnP
Expansionsmöjligheter ISA, PCI, USB
[ System ]
Systemegenskaper:
Tillverkare To Be Filled By O.E.M.
Produkt To Be Filled By O.E.M.
Version To Be Filled By O.E.M.
Serienummer To Be Filled By O.E.M.
Universellt Unikt ID 00020003-00040005-00060007-00080009
Wake-Up typ Strömkontakt
[ Moderkort ]
Moderkortsegenskaper:
Tillverkare To be filled by O.E.M.
Produkt To be filled by O.E.M.
Version To be filled by O.E.M.
Serienummer To be filled by O.E.M.
[ Chassi ]
Chassiegenskaper:
Tillgångsmärkning To Be Filled By O.E.M.
Chassityp Skrivbordmodell
Uppstartsstatus Säkert
Strömaggregatsstatus Säkert
Temperaturstatus Säkert
Säkerhetsstatus Ingen
[ Minneskontroller ]
Egenskaper för minneskontroller:
Felsökningsmetod 64-bit ECC
Felkorrigeringsmetod Ingen
Stödd minnesinterfoliering 1-Way
Aktiverad minnesinterfoliering 1-Way
Stödd minnestyp DIMM, SDRAM
Stödd minnesströmstyrka 3.3V
Maximal minnesmodulstorlek 4096 MB
Minnesplatser 4
[ Processorer / Intel(R) Pentium(R) 4 CPU 3.00GHz ]
Processoregenskaper:
Tillverkare Intel
Version Intel(R) Pentium(R) 4 CPU 3.00GHz
Reservdelsnummer To Be Filled By O.E.M.
Extern klockhastighet 800 MHz
Maximal klockhastighet 3000 MHz
Nuvarande klockhastighet 3000 MHz
Typ Central Processor
Volt 3.3 V, 2.9 V
Status Aktiverad
Socketbenämning CPU 1
[ Cache / L1-Cache ]
Cacheegenskaper:
Typ Internt
Status Aktiverad
Körläge Varies with Memory Address
Maximal storlek 16 kB
Installerad storlek 16 kB
Stödd SRAM typ Pipeline Burst
Aktiv SRAM typ Pipeline Burst
Felkorrigeringsmetod Single-bit ECC
Socketbenämning L1-Cache
[ Cache / L2-Cache ]
Cacheegenskaper:
Typ Internt
Status Avaktiverad
Maximal storlek 0 kB
Installerad storlek 0 kB
Socketbenämning L2-Cache
[ Cache / L3-Cache ]
Cacheegenskaper:
Typ Internt
Status Avaktiverad
Socketbenämning L3-Cache
[ Minnesmoduler / DIMM0 ]
Minnesmodulsegenskaper:
Socketbenämning DIMM0
Typ DIMM, SDRAM
Installerad storlek 512 MB
Aktiverad storlek 512 MB
[ Minnesmoduler / DIMM1 ]
Socketbenämning DIMM1
Typ DIMM, SDRAM
Installerad storlek 256 MB
Aktiverad storlek 256 MB
[ Minnesmoduler / DIMM2 ]
Socketbenämning DIMM2
Typ DIMM, SDRAM
[ Minnesmoduler / DIMM3 ]
Socketbenämning DIMM3
Typ DIMM, SDRAM
[ Minnesenheter / DIMM0 ]
Minnesenhetsegenskaper:
Moderkortstyp DIMM
Typ SDRAM
Detaljer Synchronous
Storlek 512 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM0
Bankplacerare BANK0
Tillverkare Manufacturer0
Serienummer SerNum0
Tillgångsmärkning AssetTagNum0
Reservdelsnummer PartNum0
[ Minnesenheter / DIMM1 ]
Moderkortstyp DIMM
Typ SDRAM
Storlek 256 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM1
Bankplacerare BANK1
Tillverkare Manufacturer1
Serienummer SerNum1
Tillgångsmärkning AssetTagNum1
Reservdelsnummer PartNum1
[ Minnesenheter / DIMM2 ]
Moderkortstyp DIMM
Typ SDRAM
Storlek 512 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM2
Bankplacerare BANK2
Tillverkare Manufacturer2
Serienummer SerNum2
Tillgångsmärkning AssetTagNum2
Reservdelsnummer PartNum2
[ Minnesenheter / DIMM3 ]
Moderkortstyp DIMM
Typ SDRAM
Storlek 256 MB
Total bredd 64-bit
Data bredd 64-bit
Enhetsplacerare DIMM3
Bankplacerare BANK3
Tillverkare Manufacturer3
Serienummer SerNum3
Tillgångsmärkning AssetTagNum3
Reservdelsnummer PartNum3
--------[ Överklockning ]-----------------------------------------------------------------------------------------------
CPU egenskaper:
CPU alias Prescott-2M
CPU stegning N0
Engineering Sample Nej
CPUID CPU namn Intel(R) Pentium(R) 4 CPU 3.00GHz
CPUID revision 00000F43h
CPU hastighet:
CPU Hastighet 2995.14 MHz (orginal: 3000 MHz)
CPU multiplikator 15.0x
CPU FSB 199.68 MHz (orginal: 200 MHz)
Minnesbuss 166.40 MHz
CPU cache:
L1 spårningscache 12K Instructions
L1 datacache 16 kB
L2 cache 2 MB (On-Die, ECC, ATC, Full-Speed)
Moderkorts ID 63-0100-009999-00101111-102604-GrantsD$I501000_BIOS DATE: 10/26/04 18:56:58 VER: 08.00.11 P5I915P(G) BIOS V1.3 OCT.26,2004
Chipsets egenskaper:
Minnes synkning 2.5-4-4-7 (CL-RCD-RP-RAS)
SPD minnes moduler:
DIMM1: Team Group YMD512 646A8J-D43 1 GB PC3200 DDR SDRAM (2.5-4-4-8 @ 200 MHz)
DIMM2: Team Group YMD512 646A8J-D43 1 GB PC3200 DDR SDRAM (2.5-4-4-8 @ 200 MHz)
DIMM3: Samsung M3 68L3223FTN-CCC 256 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
DIMM5: Samsung M3 68L3223FTN-CCC 256 MB PC3200 DDR SDRAM (3.0-3-3-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz)
BIOS egenskaper:
System BIOS datum 10/26/04
Video BIOS datum 08/30/05
DMI BIOS version 080011
Egenskaper för grafikprocessor:
Grafikkort nVIDIA NV44
GPU kodnamn NV44 (PCI Express x16 10DE / 0160, Rev A1)
GPU klockhastighet 398 MHz
Minnes klocka 334 MHz
--------[ Energialternativ ]--------------------------------------------------------------------------------------------
Egenskaper för energialternativ:
Aktuell strömkälla AC nät
Batteritillstånd Inget Batteri
Full batterilivstid Okänd
Återstående batterilivstid Okänd
--------[ Sensor ]------------------------------------------------------------------------------------------------------
Sensoregenskaper:
Sensortyp HDD
Temperaturer:
WDC WD1001FALS-00J7B1 39 °C (102 °F)
Maxtor 6Y080M0 41 °C (106 °F)
Seagate ST3120827AS 36 °C (97 °F)
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU egenskaper:
CPU stegning N0
Instruktions uppsättning x86, x86-64, MMX, SSE, SSE2, SSE3
Ursprunglig klockhastighet 3000 MHz
Min / Max CPU multiplicerare 14x / 15x
L1 datacache 16 kB
Multi CPU:
Moderkorts ID Intel Grantsdale
CPU #0 Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 MHz
CPU #1 Intel(R) Pentium(R) 4 CPU 3.00GHz, 2992 MHz
CPU fysisk information:
Paketeringstyp 775 Contact LGA
Paketeringsstorlek 3.75 cm x 3.75 cm
Transistorer 169 miljoner
Processorteknologi 7M, 90 nm, CMOS, Cu, Low-K Inter-Layer, High-K Gate, Strained Si
Kretskortsstorlek 135 mm2
Kärnvolts tal 1.3 V
I/O volt 1.3 V
Typisk strömstyrka 84 - 115 W (beroende av klockhastighet)
Maximal strömstyrka 101 - 155 W (beroende av klockhastighet)
CPU Tillverkare:
Företagsnamn Intel Corporation
CPU användning:
CPU 1 / HTT 1 enheter 0 %
CPU 1 / HTT 2 enheter 100 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID egenskaper:
CPUID tillverkare GenuineIntel
IA märkes ID 00h (Okänd)
Plattforms ID 13h (Socket 775)
IA CPU serienummer Okänd
Microcode Update Revision 5
HTT / CMP Enheter 2 / 1
Instruktions uppsättning:
64 bitars x86-utökning (AMD64, EM64T) Stöds
Alternate Instruction Set Inget Stöd
AMD 3DNow! Inget Stöd
AMD 3DNow! Professional Inget Stöd
AMD Enhanced 3DNow! Inget Stöd
AMD Extended MMX Inget Stöd
Cyrix Extended MMX Inget Stöd
IA-64 Inget Stöd
IA MMX Stöds
IA SSE Stöds
IA SSE 2 Stöds
IA SSE 3 Stöds
CLFLUSH Instruktion Stöds
CMPXCHG8B Instruktion Stöds
CMPXCHG16B Instruktion Stöds
Conditional Move Instruktion Stöds
MONITOR / MWAIT Instruktion Stöds
RDTSCP Instruktion Inget Stöd
SYSCALL / SYSRET Instruktion Inget Stöd
SYSENTER / SYSEXIT Instruktion Stöds
VIA FEMMS Instruktion Inget Stöd
Säkerhet funktioner:
Advanced Cryptography Engine (ACE) Inget Stöd
Förhindrande av data exekvering (DEP, NX, EDB) Inget Stöd
Hardware Random Number Generator (RNG) Inget Stöd
Montgomery Multiplier & Hash Engine Inget Stöd
Processor Serial Number (PSN) Inget Stöd
Energispar funktioner:
Automatic Clock Control Stöds
Enhanced Halt State (C1E) Stöds, Avaktiverad
Enhanced SpeedStep Technology (EIST, ESS) Stöds, Avaktiverad
Frequency ID Control Inget Stöd
LongRun Inget Stöd
LongRun Table Interface Inget Stöd
PowerSaver 1.0 Inget Stöd
PowerSaver 2.0 Inget Stöd
PowerSaver 3.0 Inget Stöd
Processor Duty Cycle Control Stöds
Software Thermal Control Inget Stöd
Temperature Sensing Diode Inget Stöd
Thermal Monitor 1 Stöds
Thermal Monitor 2 Inget Stöd
Thermal Monitoring Inget Stöd
Thermal Trip Inget Stöd
Voltage ID Control Inget Stöd
CPUID funktioner:
36-bit Page Size Extension Stöds
Address Region Registers (ARR) Inget Stöd
CPL Qualified Debug Store Stöds
Debug Trace Store Stöds
Debugging Extension Stöds
Fast Save & Restore Stöds
Hyper-Threading Technology (HTT) Stöds, Aktiverad
L1 Context ID Stöds
Local APIC On Chip Stöds
Machine Check Architecture (MCA) Stöds
Machine Check Exception (MCE) Stöds
Memory Configuration Registers (MCR) Inget Stöd
Memory Type Range Registers (MTRR) Stöds
Model Specific Registers (MSR) Stöds
Page Attribute Table (PAT) Stöds
Page Global Extension Stöds
Page Size Extension (PSE) Stöds
Pending Break Event Stöds
Physical Address Extension (PAE) Stöds
Secure Virtual Machine Extensions (Pacifica) Inget Stöd
Self-Snoop Stöds
Time Stamp Counter (TSC) Stöds
Virtual Machine Extensions (Vanderpool) Inget Stöd
Virtual Mode Extension Stöds
CPUID Registers (CPU #1):
CPUID 00000000 00000005-756E6547-6C65746E-49656E69
CPUID 00000001 00000F43-00020800-0000649D-BFEBFBFF
CPUID 00000002 605B5001-00000000-00000000-007D7040
CPUID 00000003 00000000-00000000-00000000-00000000
CPUID 00000004 00004121-01C0003F-0000001F-00000000
CPUID 00000005 00000040-00000040-00000000-00000000
CPUID 80000000 80000008-00000000-00000000-00000000
CPUID 80000001 00000000-00000000-00000000-20000000
CPUID 80000002 20202020-20202020-20202020-6E492020
CPUID 80000003 286C6574-50202952-69746E65-52286D75
CPUID 80000004 20342029-20555043-30302E33-007A4847
CPUID 80000005 00000000-00000000-00000000-00000000
CPUID 80000006 00000000-00000000-08006040-00000000
CPUID 80000007 00000000-00000000-00000000-00000000
CPUID 80000008 00003024-00000000-00000000-00000000
CPUID Registers (CPU #2 Virtual):
CPUID 00000001 00000F43-01020800-0000649D-BFEBFBFF
MSR Registers:
MSR 00000017 0012-0000-0000-0000
MSR 0000002A 0000-0000-0000-0000
MSR 0000002C 0000-0000-0F12-010F
MSR 0000008B 0000-0005-0000-0000
MSR 00000198 0000-0F2D-0000-0F2D
MSR 00000199 0000-0000-0000-0F2D
MSR 0000019A 0000-0000-0000-0002
MSR 0000019B 0000-0000-0000-0000
MSR 0000019C 0000-0000-0000-0000
MSR 000001A0 0000-0004-208C-0289
--------[ Moderkort ]---------------------------------------------------------------------------------------------------
Front Side Bus egenskaper:
Busstyp Intel NetBurst
Busbredd 64-bit
Realtidsklocka 200 MHz (QDR)
Effektiv klocka 800 MHz
Bandbredd 6400 MB/s
Minnesbussegenskaper:
Busstyp Dual DDR SDRAM
Busbredd 128-bit
Realtidsklocka 167 MHz (DDR)
Effektiv klocka 333 MHz
Bandbredd 5333 MB/s
Chipsetbussegenskaper:
Busstyp Intel Direct Media Interface
--------[ Minne ]-------------------------------------------------------------------------------------------------------
Fysiskt minne:
Totalt 2559 MB
Använt 959 MB
Ledigt 1600 MB
Utnyttjande 37 %
Växlingsfil:
Totalt 5115 MB
Använt 1929 MB
Ledigt 3185 MB
Utnyttjande 38 %
Virtuellt minne:
Totalt 7674 MB
Använt 2888 MB
Ledigt 4785 MB
Utnyttjande 38 %
Physical Address Extension (PAE):
Stöds av operativsystemet Ja
Stöds av processorn Ja
Aktiv Nej
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Team Group YMD512 646A8J-D43 ]
Modulnamn Team Group YMD512 646A8J-D43
Serienummer Ingen
Tillverkningsdatum Vecka 28 / 2006
Modulstorlek 1024 MB (2 ranks, 4 banks)
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulhastighet PC3200 (200 MHz)
Modulbredd 64 bit
Modulvolt SSTL 2.5
Felsökningsmetod Ingen
Uppdateringsfrekvens Reducerad (7.8 us), Self-Refresh
Minnes synkning:
@ 200 MHz 2.5-4-4-8 (CL-RCD-RP-RAS)
Minnesmodulsfunktioner:
Early RAS# Precharge Inget Stöd
Auto-Precharge Inget Stöd
Precharge All Inget Stöd
Write1/Read Burst Inget Stöd
Buffered Address/Control Inputs Inget Stöd
Registered Address/Control Inputs Inget Stöd
On-Card PLL (Clock) Inget Stöd
Buffered DQMB Inputs Inget Stöd
Registered DQMB Inputs Inget Stöd
Differential Clock Input Stöds
Redundant Row Address Inget Stöd
[ DIMM2: Team Group YMD512 646A8J-D43 ]
Serienummer Ingen
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulbredd 64 bit
Modulvolt SSTL 2.5
Minnes synkning:
[ DIMM3: Samsung M3 68L3223FTN-CCC ]
Modulnamn Samsung M3 68L3223FTN-CCC
Serienummer F1035DE8h
Modulstorlek 256 MB (1 rank, 4 banks)
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulbredd 64 bit
Modulvolt SSTL 2.5
Minnes synkning:
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS)
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS)
Minnesmodulstillverkare:
Företagsnamn Samsung
[ DIMM5: Samsung M3 68L3223FTN-CCC ]
Serienummer F1035E28h
Modultyp Unbuffered
Minnestyp DDR SDRAM
Modulbredd 64 bit
Modulvolt SSTL 2.5
Minnes synkning:
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: Intel Grantsdale i915P ]
North Bridge egenskaper:
North Bridge Intel Grantsdale i915P
Inventering / Stepping 04 / B1
Paketeringstyp 1210 Pin FC-BGA
Kärnvolts tal 1.5 V
In-Order Queue Depth 12
Minneskontroller:
Typ Dual Channel (128-bit)
Aktiv Mode Dual Channel (128-bit)
Minnes synkning:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 4T
RAS Precharge (tRP) 4T
RAS Active Time (tRAS) 7T
Felkorrigeringsmetod:
ECC Inget Stöd
ChipKill ECC Inget Stöd
RAID Inget Stöd
ECC Scrubbing Inget Stöd
Minnesplatser:
DRAM plats #1 1024 MB (PC3200 DDR SDRAM)
DRAM plats #2 256 MB (PC3200 DDR SDRAM)
DRAM plats #3 1024 MB (PC3200 DDR SDRAM)
DRAM plats #4 256 MB (PC3200 DDR SDRAM)
PCI Express Kontroller:
PCI-E x16 port #2 Används @ x16 (nVIDIA NV44 Video Adapter)
Chipsettillverkare:
Nedladdning av drivrutin Link Removed
[ South Bridge: Intel 82801FB ICH6 ]
South Bridge Egenskaper:
South Bridge Intel 82801FB ICH6
Inventering / Stepping D3 / B1
Paketeringstyp 609 Pin mBGA
Paketeringsstorlek 3.1 cm x 3.1 cm
Kärnvolts tal 1.5 V
High Definition Audio:
Ljudkortstyp Intel 82801FB(M) ICH6
Codec namn Okänd
Codec ID FFFFFFFFh
Codec Revision FFFFFFFFh
Chipsettillverkare:
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS egenskaper:
BIOS typ AMI
BIOS tillverkare:
Företagsnamn American Megatrends Inc.
Produktinformation Link Removed - Invalid URL
BIOS uppgradering Link Removed - Invalid URL
Problem och förslag:
Förslag Are you looking for a BIOS Upgrade? Contact eSupport Today!
Förslag System BIOS är mer än 2 år gammalt. Uppdatera om nödvändigt.
Förslag Grafikkortets BIOS är mer än 2 år gammalt. Uppdatera om nödvändigt.
--------[ Windows video ]-----------------------------------------------------------------------------------------------
[ NVIDIA GeForce 6500 ]
Grafikkortsegenskaper:
Enhetsbeskrivning NVIDIA GeForce 6500
Kortsträng GeForce 6500
BIOS sträng Version 5.44.2.41.1
Chiptyp GeForce 6500
DAC typ Integrated RAMDAC
Installerade drivrutiner nvd3dum (8.17.11.9562)
Grafikkortstillverkare:
Företagsnamn NVIDIA Corporation
Nedladdning av drivrutin Drivers - Download NVIDIA Drivers
--------[ PCI / AGP video ]---------------------------------------------------------------------------------------------
nVIDIA NV44 Grafikkort
nVIDIA NV44 3D accelerator
--------[ GPU ]---------------------------------------------------------------------------------------------------------
[ PCI Express x16: nVIDIA NV44 ]
GPU kodnamn NV44
PCI enhet 10DE / 0160
Transistorer 77 miljoner
Processorteknologi 0.11u
Kretskortsstorlek 110 mm2
Busstyp PCI Express x16 @ x16
Minnesstorlek 128 MB
RAMDAC klockhastighet 400 MHz
Pixel pipelines 4
TMU per pipeline 1
Vertex shaders 3 (v3.0)
Pixel shaders 1 (v3.0)
DirectX hårdvarustöd DirectX v9.0c
Pixel Fillrate 1592 MPixel/s
Texel Fillrate 1592 MTexel/s
Busstyp DDR
Busbredd 64-bit
Realtidsklocka 334 MHz (DDR)
Effektiv klocka 668 MHz
Bandbredd 5344 MB/s
Grafikprocessortillverkare:
nVIDIA GPU Registers:
nv-000000 044000A2
nv-100000 00000000
nv-100200 43003E00
nv-10020C 08000000
nv-101000 2342CE8B
nv-680500 00000000
nv-680504 00000000
nv-680570 00000000
nv-680574 00000000
nv-68057C 80000802
nv-001540 7FFF0703
nv-004000 8000011C
nv-004004 011F3B04
nv-004008 C000001C
nv-004020 E041001C
nv-004024 16020902
nv-004028 80000AA8
nv-00C040 3C0BC003
--------[ Bildskärm ]---------------------------------------------------------------------------------------------------
[ Compaq TFT7020 ]
Bildskärmsegenskaper:
Bildskärmsnamn Compaq TFT7020
Bildskärms ID CPQ1435
Modell COMPAQ 7020
Bildskärmstyp 17" LCD
Tillverkningsdatum Vecka 16 / 2002
Serienummer 12162516226137
Max. synlig visningsstorlek 33 cm x 27 cm (16.8")
Betraktningsförhållande 5:4
Horisontell frekvens 32 - 61 kHz
Vertikal frekvens 56 - 75 Hz
Maximal upplösning 1280 x 1024
Gamma 2.31
DPMS formatstöd Standby, Suspend, Active-Off
Stödda videolägen:
640 x 480 75 Hz
800 x 600 75 Hz
1024 x 768 75 Hz
1152 x 864 65 Hz
1280 x 1024 55 Hz
Bildskärmstillverkare:
Nedladdning av drivrutin 24/7 Online support for HP's Home and Home Office Products - HP Customer Care (United States - English)
--------[ Skrivbord ]---------------------------------------------------------------------------------------------------
Skrivbordsegenskaper:
Enhetsteknologi Raster display
Upplösning 1280 x 1024
Färgdjup 32-bit
Färgplan 1
Typsnittsupplösning 96 dpi
Pixel bredd / höjd 36 / 36
Pixel diagonal 51
Vertikal uppdateringsfrekvens 60 Hz
Skrivbordsbakgrund C:\Users\Timmy\AppData\Roaming\Microsoft\Windows\Themes\TranscodedWallpaper.jpg
Skrivbordseffekter:
Animering av kombinationsrutor Avaktiverad
Skuggningseffekter Avaktiverad
Platta menyer effekt Aktiverad
Kantutjämning av teckensnitt Aktiverad
Visa innehåll i fönster vid drag och släpp Aktiverad
Tonövergång för programlister Aktiverad
Dölj tangenter för menyåtkomst Aktiverad
Hot tracking effekt Aktiverad
Radbrytning på ikontitlar Aktiverad
Mjuk rullning för listrutor Avaktiverad
Menyanimationer Avaktiverad
Menytoningseffekter Aktiverad
Animera fönster vid minimering/återställning Avaktiverad
Skuggning av muspekare Avaktiverad
Toning av aktivt val effekt Avaktiverad
ShowSounds hjälpmedelsfunktion Avaktiverad
Verktygstips animeringar Avaktiverad
Verktygstips toningseffekter Aktiverad
Windows Plus! tillägg Avaktiverad
Problem Minst 85 Hz vertikal uppdateringsfrekvens rekommenderas på konventionella (CRT) skärmar.
--------[ Multibildskärm ]----------------------------------------------------------------------------------------------
\\.\DISPLAY1 Ja (0,0) (1280,1024)
--------[ Windows ljud ]------------------------------------------------------------------------------------------------
midi-out.0 0001 001B Microsoft GS Wavetable Synth
--------[ PCI / PnP ljud ]----------------------------------------------------------------------------------------------
Intel 82801FB ICH6 - High Definition Audio Controller [B-1] PCI
--------[ Windows lagring ]---------------------------------------------------------------------------------------------
[ Floppy disk drive ]
Enhetsegenskaper:
Drivrutinsbeskrivning Floppy disk drive
Drivrutinsdatum 2006-06-21
Drivrutinsversion 6.1.7600.16385
Drivrutinstillverkare Microsoft
INF Fil flpydisk.inf
[ Maxtor 6Y080M0 ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Maxtor 6Y080M0 ATA Device
INF Fil disk.inf
Disk enhetens fysiska info:
Tillverkare Maxtor
Hårddiskfamilj DiamondMax Plus 9
Moderkortstyp 3.5"
Formaterad kapacitet 80 GB
Hårddiskar 1
inspelningsytor 2
Fysiska dimensioner 146.1 x 101.6 x 26.1 mm
Max. vikt 630 g
Medelrotationslatens 4.17 ms
Rotationshastighet 7200 RPM
Interface SATA
Buffer-till-värd datahastighet 150 MB/s
Bufferstorlek 8 MB
Enhetstillverkare:
Företagsnamn Maxtor Corporation
Produktinformation Maxtor is now Seagate
[ ST3120827AS ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning ST3120827AS ATA Device
INF Fil disk.inf
Tillverkare Seagate
Hårddisknamn Barracuda 7200.7 SATA NCQ 120827
Moderkortstyp 3.5"
Formaterad kapacitet 120 GB
Hårddiskar 2
inspelningsytor 3
Fysiska dimensioner 146.56 x 101.85 x 26.1 mm
Max. vikt 635 g
Medelrotationslatens 4.16 ms
Max. intern datahastighet 683 Mbit/s
Medelsöktid 8.5 ms
Interface SATA
Bufferstorlek 8 MB
Uppvarvningstid 10 sekunder
Enhetstillverkare:
Företagsnamn Seagate Technology LLC
Produktinformation Redirect
[ WDC WD1001FALS-00J7B1 ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning WDC WD1001FALS-00J7B1 ATA Device
INF Fil disk.inf
Enhetstillverkare:
Företagsnamn Western Digital Corporation
Produktinformation Welcome westerndigital.comen - Hostmonster.com
[ BENQ DVD LS DW1655 ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning BENQ DVD LS DW1655 ATA Device
INF Fil cdrom.inf
Enhetstillverkare:
Företagsnamn BenQ Corp.
Produktinformation Link Removed due to 404 Error
Firmware Download Link Removed due to 404 Error
[ TSSTcorp DVD-ROM SH-D162C ATA Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning TSSTcorp DVD-ROM SH-D162C ATA Device
INF Fil cdrom.inf
Egenskaper för optisk enhet:
Tillverkare Toshiba-Samsung
Enhetstyp DVD-ROM
Interface ATAPI
Reading Speeds:
DVD-ROM 16x
CD-ROM 48x
Enhetstillverkare:
Företagsnamn Toshiba Samsung Storage Technology
Firmware Download http://www.samsungodd.com/eng/LiveUpdate/LiveUpdate.asp
[ ATA Channel 0 ]
Enhetsegenskaper:
Drivrutinsbeskrivning ATA Channel 0
INF Fil mshdc.inf
Enhetsresurser:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
[ ATA Channel 0 ]
Enhetsegenskaper:
INF Fil mshdc.inf
[ ATA Channel 1 ]
Enhetsegenskaper:
Drivrutinsbeskrivning ATA Channel 1
INF Fil mshdc.inf
Enhetsresurser:
IRQ 15
Port 0170-0177
Port 0376-0376
[ ATA Channel 1 ]
Enhetsegenskaper:
INF Fil mshdc.inf
[ Intel(R) 82801FB Ultra ATA Storage Controllers - 2651 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
INF Fil mshdc.inf
Enhetsresurser:
IRQ 19
Port C880-C88F
Port CC00-CC03
Port D000-D007
Port D080-D083
Port D400-D407
[ Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
INF Fil mshdc.inf
Enhetsresurser:
Port FFA0-FFAF
[ Standard floppy disk controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard floppy disk controller
INF Fil fdc.inf
Enhetsresurser:
DMA 02
IRQ 06
Port 03F0-03F5
Port 03F7-03F7
[ Microsoft iSCSI Initiator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft iSCSI Initiator
INF Fil iscsi.inf
--------[ Logiska enheter ]---------------------------------------------------------------------------------------------
A: Flyttbar disk
C: (Timmy) Lokal disk NTFS 953866 MB 139061 MB 814805 MB 85 % 08B2-A367
D: Optisk enhet
E: Optisk enhet
F: (EXTRA) Lokal disk NTFS 76316 MB 37931 MB 38384 MB 50 % C495-A630
G: Lokal disk NTFS 37997 MB 13874 MB 24122 MB 63 % 0496-F990
H: (DATA) Lokal disk NTFS 76465 MB 60139 MB 16325 MB 21 % 0C9F-420F
--------[ Fysiska enheter ]---------------------------------------------------------------------------------------------
[ Enhet #1 - WDC WD1001FALS-00J7B1 ATA Device (931 GB) ]
#1 (Aktiv) NTFS C: (Timmy) 1 MB 953867 MB
[ Enhet #2 - Maxtor 6Y080M0 ATA Device (74 GB) ]
#1 NTFS F: (EXTRA) 0 MB 76316 MB
[ Enhet #3 - ST3120827AS ATA Device (111 GB) ]
#1 (Aktiv) NTFS G: 0 MB 37997 MB
#2 NTFS H: (DATA) 37997 MB 76465 MB
--------[ Optiska enheter ]---------------------------------------------------------------------------------------------
Enhetsbeskrivning BENQ DVD LS DW1655 ATA Device
Enhetsbeskrivning TSSTcorp DVD-ROM SH-D162C ATA Device
Enhetstyp DVD-ROM
Interface ATAPI
Reading Speeds:
DVD-ROM 16x
CD-ROM 48x
Enhetstillverkare:
--------[ ATA ]---------------------------------------------------------------------------------------------------------
[ WDC WD1001FALS-00J7B1 (WD-WMATV2952215) ]
ATA enhetsegenskaper:
Modell ID WDC WD1001FALS-00J7B1
Serienummer WD-WMATV2952215
Inventering 05.00K05
Parametrar 1938021 cylindrar, 16 huvuden, 63 sektorer per spår, 512 bytes per sektor
LBA sektorer 1953525168
Bufferstorlek 32767 kB
Multipla sektorer 16
ECC bytes 50
Max. PIO överföringsläge PIO 4
Max. UDMA överföringsläge UDMA 6 (ATA-133)
Aktiv UDMA överföringsläge UDMA 5 (ATA-100)
Oformaterad kapacitet 953870 MB
ATA enhetsfunktioner:
SMART Stöds
Säkerhetsläge Stöds
Energialternativ Stöds
Avancerade energialternativ Inget Stöd
Skrivcache Stöds
Host Protected Area Stöds
Power-Up In Standby Stöds
Automatic Acoustic Management Stöds
48-bit LBA Stöds
Device Configuration Overlay Stöds
ATA enhetstillverkare:
[ Maxtor 6Y080M0 (Y2BBVBKE) ]
Modell ID Maxtor 6Y080M0
Serienummer Y2BBVBKE
Inventering YAR51HW0
Parametrar 155072 cylindrar, 16 huvuden, 63 sektorer per spår, 512 bytes per sektor
LBA sektorer 156312576
Bufferstorlek 7936 kB (Dual Ported, Read Ahead)
ECC bytes 4
Oformaterad kapacitet 76324 MB
SMART Stöds
Säkerhetsläge Stöds
Avancerade energialternativ Stöds
Skrivcache Stöds
Power-Up In Standby Inget Stöd
48-bit LBA Inget Stöd
ATA enhetens fysiska info:
Tillverkare Maxtor
Moderkortstyp 3.5"
Hårddiskar 1
inspelningsytor 2
Max. vikt 630 g
Interface SATA
Bufferstorlek 8 MB
[ ST3120827AS (4MS01P2S) ]
Modell ID ST3120827AS
Serienummer 4MS01P2S
Inventering 3.42
Parametrar 232581 cylindrar, 16 huvuden, 63 sektorer per spår, 512 bytes per sektor
LBA sektorer 234441648
Bufferstorlek 8 MB
ECC bytes 4
Oformaterad kapacitet 114473 MB
SMART Stöds
Säkerhetsläge Stöds
Skrivcache Stöds
Automatic Acoustic Management Inget Stöd
48-bit LBA Stöds
Tillverkare Seagate
Moderkortstyp 3.5"
Hårddiskar 2
inspelningsytor 3
Max. vikt 635 g
Medelsöktid 8.5 ms
Interface SATA
Bufferstorlek 8 MB
--------[ SMART ]-------------------------------------------------------------------------------------------------------
01 Raw Read Error Rate 51 200 200 0 OK: Värdet är normalt
03 Spin Up Time 21 232 231 8366 OK: Värdet är normalt
04 Start/Stop Count 0 100 100 144 OK: Alltid godkänd
05 Reallocated Sector Count 140 200 200 0 OK: Värdet är normalt
07 Seek Error Rate 0 200 200 0 OK: Alltid godkänd
09 Power-On Time Count 0 100 100 620 OK: Alltid godkänd
0A Spin Retry Count 0 100 100 0 OK: Alltid godkänd
0B Calibration Retry Count 0 100 100 0 OK: Alltid godkänd
0C Power Cycle Count 0 100 100 140 OK: Alltid godkänd
C0 Power-Off Retract Count 0 200 200 13 OK: Alltid godkänd
C1 Load/Unload Cycle Count 0 200 200 144 OK: Alltid godkänd
C2 Temperature 0 111 106 39 OK: Alltid godkänd
C4 Reallocation Event Count 0 200 200 0 OK: Alltid godkänd
C5 Current Pending Sector Count 0 200 200 0 OK: Alltid godkänd
C6 Off-Line Uncorrectable Sector Count 0 100 253 0 OK: Alltid godkänd
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Alltid godkänd
C8 Write Error Rate 0 100 253 0 OK: Alltid godkänd
03 Spin Up Time 63 225 224 10048 OK: Värdet är normalt
04 Start/Stop Count 0 253 253 1736 OK: Alltid godkänd
05 Reallocated Sector Count 63 253 253 0 OK: Värdet är normalt
06 Read Channel Margin 100 253 253 0 OK: Värdet är normalt
07 Seek Error Rate 0 253 252 0 OK: Alltid godkänd
08 Seek Time Performance 187 253 241 49819 OK: Värdet är normalt
09 Power-On Time Count 0 245 245 37292 OK: Alltid godkänd
0A Spin Retry Count 157 253 252 0 OK: Värdet är normalt
0B Calibration Retry Count 223 253 252 0 OK: Värdet är normalt
0C Power Cycle Count 0 251 251 1112 OK: Alltid godkänd
C0 Power-Off Retract Count 0 253 253 0 OK: Alltid godkänd
C1 Load/Unload Cycle Count 0 253 253 0 OK: Alltid godkänd
C2 Temperature 0 253 253 42 OK: Alltid godkänd
C3 Hardware ECC Recovered 0 253 252 20833 OK: Alltid godkänd
C4 Reallocation Event Count 0 253 253 0 OK: Alltid godkänd
C5 Current Pending Sector Count 0 253 253 0 OK: Alltid godkänd
C6 Off-Line Uncorrectable Sector Count 0 253 253 0 OK: Alltid godkänd
C7 Ultra ATA CRC Error Rate 0 199 199 0 OK: Alltid godkänd
C8 Write Error Rate 0 253 252 0 OK: Alltid godkänd
C9 <Försäljarspecifik> 0 253 252 3 OK: Alltid godkänd
CA <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
CB <Försäljarspecifik> 180 253 252 0 OK: Värdet är normalt
CC <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
CD <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
CF <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
D0 <Försäljarspecifik> 0 253 252 0 OK: Alltid godkänd
D1 <Försäljarspecifik> 0 191 191 0 OK: Alltid godkänd
63 <Försäljarspecifik> 0 253 253 0 OK: Alltid godkänd
64 <Försäljarspecifik> 0 253 253 0 OK: Alltid godkänd
65 <Försäljarspecifik> 0 253 253 0 OK: Alltid godkänd
01 Raw Read Error Rate 6 57 47 233942539 OK: Värdet är normalt
03 Spin Up Time 0 96 96 0 OK: Alltid godkänd
04 Start/Stop Count 20 98 98 2050 OK: Värdet är normalt
05 Reallocated Sector Count 36 100 100 0 OK: Värdet är normalt
07 Seek Error Rate 30 86 60 432046543 OK: Värdet är normalt
09 Power-On Time Count 0 91 91 8279 OK: Alltid godkänd
0A Spin Retry Count 97 100 100 0 OK: Värdet är normalt
0C Power Cycle Count 20 99 99 1176 OK: Värdet är normalt
C2 Temperature 0 37 46 37 OK: Alltid godkänd
C3 Hardware ECC Recovered 0 57 47 233942539 OK: Alltid godkänd
C5 Current Pending Sector Count 0 100 100 0 OK: Alltid godkänd
C6 Off-Line Uncorrectable Sector Count 0 100 100 0 OK: Alltid godkänd
CA <Försäljarspecifik> 0 100 253 0 OK: Alltid godkänd
--------[ Windows nätverk ]---------------------------------------------------------------------------------------------
[ Realtek RTL8139/810x Family Fast Ethernet NIC ]
Egenskaper för nätverkskort:
Interfacetyp Ethernet
Hårdvaruadress 00-10-5C-FE-A7-02
Anslutningsnamn Local Area Connection
Anslutningshastighet 100 Mbps
MTU 1500 bytes
DHCP lånet erhölls 2010-02-20 07:44:43
DHCP lånet upphör 2010-02-27 07:44:43
Bytes mottagna 1020046865 (972.8 MB)
Bytes skickade 167315878 (159.6 MB)
Nätverskortsadress:
IP / nätmask 192.168.0.100 / 255.255.255.0
Gateway 192.168.0.1
DHCP 192.168.0.1
DNS 148.160.16.66
DNS 192.168.0.1
Nätverkskortstillverkare:
Företagsnamn Realtek Semiconductor Corp.
--------[ PCI / PnP nätverk ]-------------------------------------------------------------------------------------------
Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C] PCI
--------[ DirectX video ]-----------------------------------------------------------------------------------------------
[ Primary Display Driver ]
DirectDraw enhetsegenskaper:
DirectDraw drivrutinsnamn display
DirectDraw drivrutinsbeskrivning Primary Display Driver
Hårdvarudrivrutin nvd3dum.dll
Hårdvarubeskrivning NVIDIA GeForce 6500
Direct3D enhetsegenskaper:
Tillgängligt lokalt videominne 124916 kB
Tillgängligt icke-lokalt videominne (AGP) 1031616 kB
Renderingsbitdjup 16, 32
Z-buffer Bitdjup 16, 24, 32
Min texturstorlek 1 x 1
Max texturstorlek 4096 x 4096
Vertex Shader version 3.0
Pixel shader version 3.0
Direct3D enhetsfunktioner:
Additive Texture Blending Stöds
AGP Texturing Stöds
Anisotropic Filtering Stöds
Bilinear Filtering Stöds
Cubic Environment Mapping Stöds
Cubic Filtering Inget Stöd
Decal-Alpha Texture Blending Stöds
Decal Texture Blending Stöds
Directional Lights Inget Stöd
DirectX Texture Compression Inget Stöd
DirectX Volumetric Texture Compression Inget Stöd
Dithering Stöds
Dot3 Texture Blending Stöds
Dynamic Textures Stöds
Edge Antialiasing Stöds
Environmental Bump Mapping Stöds
Environmental Bump Mapping + Luminance Stöds
Factor Alpha Blending Stöds
Geometric Hidden-Surface Removal Inget Stöd
Guard Band Stöds
Hardware Scene Rasterization Stöds
Hardware Transform & Lighting Stöds
Legacy Depth Bias Inget Stöd
Mipmap LOD Bias Adjustments Stöds
Mipmapped Cube Textures Stöds
Mipmapped Volume Textures Stöds
Modulate-Alpha Texture Blending Stöds
Modulate Texture Blending Stöds
Non-Square Textures Stöds
N-Patches Inget Stöd
Perspective Texture Correction Stöds
Point Lights Inget Stöd
Point Sampling Stöds
Projective Textures Stöds
Quintic Bezier Curves & B-Splines Inget Stöd
Range-Based Fog Stöds
Rectangular & Triangular Patches Inget Stöd
Rendering In Windowed Mode Stöds
Scissor Test Inget Stöd
Slope-Scale Based Depth Bias Inget Stöd
Specular Flat Shading Stöds
Specular Gouraud Shading Stöds
Specular Phong Shading Inget Stöd
Spherical Mapping Stöds
Spot Lights Inget Stöd
Stencil Buffers Stöds
Sub-Pixel Accuracy Stöds
Table Fog Stöds
Texture Alpha Blending Stöds
Texture Clamping Stöds
Texture Mirroring Stöds
Texture Transparency Stöds
Texture Wrapping Stöds
Triangle Culling Inget Stöd
Trilinear Filtering Stöds
Two-Sided Stencil Test Stöds
Vertex Alpha Blending Stöds
Vertex Fog Stöds
Vertex Tweening Inget Stöd
W-Based Fog Stöds
W-Buffering Inget Stöd
Z-Based Fog Stöds
Z-Bias Stöds
Z-Test Stöds
Supporterade FourCC Koder:
AI44 Stöds
AIP8 Stöds
ATOC Stöds
AV12 Stöds
AYUV Stöds
NV12 Stöds
NVDB Stöds
NVDP Stöds
NVMD Stöds
PLFF Stöds
R2VB Stöds
SSAA Stöds
UYVY Stöds
YUY2 Stöds
YV12 Stöds
--------[ DirectX ljud ]------------------------------------------------------------------------------------------------
[ Primary Sound Driver ]
DirectSound enhetsegenskaper:
Enhetsbeskrivning Primary Sound Driver
Drivrutinsmodul
Primära buffrar 0
Min / Max sekundära bufferfrekvenser 0 / 0 Hz
Primära bufferns ljudformat Ingen
Sekundära bufferns ljudformat Ingen
Totala / Fria ljudbuffers 0 / 0
Totala / Fria statiska ljudbuffers 0 / 0
Totala / Fria strömmande ljudbuffers 0 / 0
Totala / Fria 3D ljudbuffers 0 / 0
Totalt / Fria 3D statiska ljudbuffers 0 / 0
Totala / Fria 3D strömmande ljudbuffers 0 / 0
DirectSound enhetsfunktioner:
Certifierad drivrutin Nej
Emulerad enhet Nej
Precis samplingfrekvens Inget Stöd
DirectSound3D Inget Stöd
Creative EAX 1.0 Inget Stöd
Creative EAX 2.0 Inget Stöd
Creative EAX 3.0 Inget Stöd
--------[ DirectX musik ]-----------------------------------------------------------------------------------------------
[ Microsoft MIDI Mapper [Emulated] ]
DirectMusic enhetsegenskaper:
Enhetsbeskrivning Microsoft MIDI Mapper [Emulated]
Synthesizertyp Hårdvara
Enhetsklass Utgående Port
Enhetstyp Windows Multimedia
MIDI kanaler 16
DirectMusic enhetsfunktioner:
Inbyggda GM instrument Nej
Inbyggda Roland GS ljuduppsättningar Nej
DirectSound Inget Stöd
DLS L1 samplingssamling Inget Stöd
DLS L2 samplingssamling Inget Stöd
Extern MIDI port Nej
Låst DLS Minnesstorlek Nej
Portdelning Stöds
Köreffekt Inget Stöd
Fördröjningseffekt Inget Stöd
Genljudseffekt Inget Stöd
[ Microsoft GS Wavetable Synth [Emulated] ]
Enhetsbeskrivning Microsoft GS Wavetable Synth [Emulated]
MIDI kanaler 16
Portdelning Stöds
[ Microsoft Synthesizer ]
Enhetsbeskrivning Microsoft Synthesizer
Synthesizertyp Mjukvara
Enhetstyp User-Mode Synthesizer
Ljudkanaler 2
MIDI kanaler 16000
Röster 1000
Tillgängligt minne Systemminne
DirectSound Stöds
DLS L1 samplingssamling Stöds
DLS L2 samplingssamling Stöds
Portdelning Inget Stöd
Genljudseffekt Stöds
--------[ DirectX indata ]----------------------------------------------------------------------------------------------
[ Mus ]
DirectInput enhetsegenskaper:
Enhetsbeskrivning Mus
Enhetstyp Okänd
Enhetsundertyp Okänd
Antal axlar 3
Antal knappar 3
DirectInput enhetsfunktioner:
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Polled Data Format Nej
Attack Force Feedback Inget Stöd
Deadband Force Feedback Inget Stöd
Fade Force Feedback Inget Stöd
Saturation Force Feedback Inget Stöd
+/- Force Feedback Coefficients Inget Stöd
+/- Force Feedback Saturation Inget Stöd
[ Tangentbord ]
Enhetsbeskrivning Tangentbord
Enhetstyp Okänd
Antal knappar 128
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
[ Bluetooth Remote Control Device ]
Enhetsbeskrivning Bluetooth Remote Control Device
Enhetstyp Okänd
Antal knappar 255
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Antal knappar 255
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
[ Saitek Eclipse Keyboard ]
Enhetsbeskrivning Saitek Eclipse Keyboard
Enhetstyp Okänd
Antal knappar 16
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Antal knappar 3
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
Enhetstyp Okänd
Emulerad enhet Ja
Alias Device Nej
Polled Device Nej
--------[ Windows enheter ]---------------------------------------------------------------------------------------------
[ Enheter ]
Bluetooth Radios:
CSR Bluetooth Radio 3.0.0.159
Microsoft Bluetooth Enumerator 6.1.7600.16385
Computer:
ACPI x86-based PC 6.1.7600.16385
Disk drives:
Maxtor 6Y080M0 ATA Device 6.1.7600.16385
ST3120827AS ATA Device 6.1.7600.16385
WDC WD1001FALS-00J7B1 ATA Device 6.1.7600.16385
Display adapters:
NVIDIA GeForce 6500 8.17.11.9562
DVD/CD-ROM drives:
BENQ DVD LS DW1655 ATA Device 6.1.7600.16385
TSSTcorp DVD-ROM SH-D162C ATA Device 6.1.7600.16385
Floppy disk drives:
Floppy disk drive 6.1.7600.16385
Floppy drive controllers:
Standard floppy disk controller 6.1.7600.16385
Human Interface Devices:
Bluetooth HID Device 6.1.7600.16385
Heej!!!! :'D (Remote Control) 3.0.0.183
HID-compliant consumer control device 6.1.7600.16385
HID-compliant device 6.1.7600.16385
Misa ^^ (Remote Control) 3.0.0.183
USB Input Device 6.1.7600.16385
IDE ATA/ATAPI controllers:
ATA Channel 0 6.1.7600.16385
ATA Channel 1 6.1.7600.16385
Intel(R) 82801FB Ultra ATA Storage Controllers - 26516.1.7600.16385
Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F6.1.7600.16385
IEEE 1394 Bus host controllers:
Texas Instruments 1394 OHCI Compliant Host Controller6.1.7600.16385
Keyboards:
HID Keyboard Device 6.1.7600.16385
Mice and other pointing devices:
HID-compliant mouse 6.1.7600.16385
Modems:
Standard Modem over Bluetooth link #3 6.1.7600.16385
Standard Modem over Bluetooth link #4 6.1.7600.16385
Monitors:
Generic PnP Monitor 6.1.7600.16385
Network adapters:
Bluetooth Device (Personal Area Network) #2 6.1.7600.16385
Bluetooth Device (RFCOMM Protocol TDI) #2 6.1.7600.16385
Microsoft ISATAP Adapter #2 6.1.7600.16385
Microsoft ISATAP Adapter #3 6.1.7600.16385
Realtek RTL8139/810x Family Fast Ethernet NIC 6.108.331.2008
Teredo Tunneling Pseudo-Interface 6.1.7600.16385
WAN Miniport (IKEv2) 6.1.7600.16385
WAN Miniport (IP) 6.1.7600.16385
WAN Miniport (IPv6) 6.1.7600.16385
WAN Miniport (L2TP) 6.1.7600.16385
WAN Miniport (Network Monitor) 6.1.7600.16385
WAN Miniport (PPPOE) 6.1.7600.16385
WAN Miniport (PPTP) 6.1.7600.16385
WAN Miniport (SSTP) 6.1.7600.16385
Non-Plug and Play Drivers:
adfs
Ancillary Function Driver for Winsock
AppID Driver
AVG Free AVI Loader Driver x86
AVG Free Network Redirector
Beep
Bitlocker Drive Encryption Filter Driver
CNG
Common Log (CLFS)
Disk Virtual Machine Bus Acceleration Filter Driver
Dynamic Volume Manager
EagleNT
Hardware Policy Driver
HTTP
Kernel Mode Driver Frameworks service
KSecDD
KSecPkg
LDDM Graphics Subsystem
Link-Layer Topology Discovery Mapper I/O Driver
Link-Layer Topology Discovery Responder
Mount Point Manager
msisadrv
NativeWiFi Filter
NDIS System Driver
NDIS Usermode I/O Protocol
NDProxy
NETBT
NetIO Legacy TDI Support Driver
npkcrypt
NSI proxy service driver.
Null
Offline Files Driver
Parvdm
PEAUTH
Performance Counters for Windows Driver
QoS Packet Scheduler
QWAVE driver
RDP Encoder Mirror Driver
RDPCDD
Reflector Display Driver used to gain access to graphics data
Remote Access IPv6 ARP Driver
Security Driver
Security Processor Loader Driver
sptd
Storage volumes
System Attribute Cache
TCP/IP Protocol Driver
TCP/IP Registry Compatibility
TPkd
User Mode Driver Frameworks Platform Driver
WFP Lightweight Filter
VgaSave
Windows Firewall Authorization Driver
Virtual WiFi Filter Driver
Ports (COM & LPT):
Communications Port (COM1) 6.1.7600.16385
Communications Port (COM2) 6.1.7600.16385
Printer Port (LPT1) 6.1.7600.16385
Standard Serial over Bluetooth link (COM10) 6.1.7600.16385
Standard Serial over Bluetooth link (COM11) 6.1.7600.16385
Standard Serial over Bluetooth link (COM12) 6.1.7600.16385
Standard Serial over Bluetooth link (COM9) 6.1.7600.16385
Processors:
Intel(R) Pentium(R) 4 CPU 3.00GHz 6.1.7600.16385
Sound, video and game controllers:
High Definition Audio Device 6.1.7600.16385
Storage controllers:
Microsoft iSCSI Initiator 6.1.7600.16385
Storage volume shadow copies:
Generic volume shadow copy 6.1.7600.16385
Storage Volumes:
Generic volume 6.1.7600.16385
System devices:
ACPI Fixed Feature Button 6.1.7600.16385
ACPI Power Button 6.1.7600.16385
Composite Bus Enumerator 6.1.7600.16385
Direct memory access controller 6.1.7600.16385
Extended IO Bus 6.1.7600.16385
File as Volume Driver 6.1.7600.16385
High Definition Audio Controller 6.1.7600.16385
Intel(R) 82801 PCI Bridge - 244E 6.1.7600.16385
Intel(R) 82801FB LPC Interface Controller - 2640 6.1.7600.16385
Intel(R) 82801FB/FBM SMBus Controller - 266A 6.1.7600.16385
Intel(R) 82802 Firmware Hub Device 6.1.7600.16385
Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 25816.1.7600.16385
Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 25806.1.7600.16385
IPBusEnum Root Enumerator 6.1.7600.16385
Microsoft ACPI-Compliant System 6.1.7600.16385
Microsoft System Management BIOS Driver 6.1.7600.16385
Microsoft Virtual Drive Enumerator Driver 6.1.7600.16385
Motherboard resources 6.1.7600.16385
Numeric data processor 6.1.7600.16385
PCI bus 6.1.7600.16385
Plug and Play Software Device Enumerator 6.1.7600.16385
Printer Port Logical Interface 6.1.7600.16385
Programmable interrupt controller 6.1.7600.16385
Remote Desktop Device Redirector Bus 6.1.7600.16385
System board 6.1.7600.16385
System CMOS/real time clock 6.1.7600.16385
System speaker 6.1.7600.16385
System timer 6.1.7600.16385
Terminal Server Keyboard Driver 6.1.7600.16385
Terminal Server Mouse Driver 6.1.7600.16385
UMBus Enumerator 6.1.7600.16385
UMBus Root Bus Enumerator 6.1.7600.16385
Volume Manager 6.1.7600.16385
Universal Serial Bus controllers:
Intel(R) 82801FB/FBM USB Universal Host Controller - 26586.1.7600.16385
Intel(R) 82801FB/FBM USB Universal Host Controller - 26596.1.7600.16385
Intel(R) 82801FB/FBM USB Universal Host Controller - 265A6.1.7600.16385
Intel(R) 82801FB/FBM USB Universal Host Controller - 265B6.1.7600.16385
Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C6.1.7600.16385
USB Composite Device 6.1.7600.16385
USB Root Hub 6.1.7600.16385
Unknown:
Bluetooth Peripheral Device
[ Bluetooth Radios / CSR Bluetooth Radio ]
Enhetsegenskaper:
Drivrutinsbeskrivning CSR Bluetooth Radio
Drivrutinsdatum 2008-05-19
Drivrutinsversion 3.0.0.159
Drivrutinstillverkare CSR plc
INF Fil oem5.inf
Hårdvaru ID USB\VID_0A12&PID_0001&REV_0525
Location Information Port_#0001.Hub_#0002
[ Bluetooth Radios / Microsoft Bluetooth Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft Bluetooth Enumerator
INF Fil bth.inf
Hårdvaru ID BTH\MS_BTHBRB
[ Computer / ACPI x86-based PC ]
Enhetsegenskaper:
Drivrutinsbeskrivning ACPI x86-based PC
INF Fil hal.inf
Hårdvaru ID acpiapic
[ Disk drives / Maxtor 6Y080M0 ATA Device ]
Enhetsegenskaper:
INF Fil disk.inf
Hårdvaru ID IDE\DiskMaxtor_6Y080M0__________________________YAR51HW0
Location Information Channel 1, Target 1, Lun 0
[ Disk drives / ST3120827AS ATA Device ]
Enhetsegenskaper:
INF Fil disk.inf
Hårdvaru ID IDE\DiskST3120827AS_____________________________3.42____
Location Information Channel 0, Target 1, Lun 0
[ Disk drives / WDC WD1001FALS-00J7B1 ATA Device ]
Enhetsegenskaper:
INF Fil disk.inf
Hårdvaru ID IDE\DiskWDC_WD1001FALS-00J7B1___________________05.00K05
Location Information Channel 1, Target 0, Lun 0
[ Display adapters / NVIDIA GeForce 6500 ]
Enhetsegenskaper:
Drivrutinsbeskrivning NVIDIA GeForce 6500
Drivrutinsdatum 2009-11-20
Drivrutinsversion 8.17.11.9562
Drivrutinstillverkare NVIDIA
INF Fil oem9.inf
Hårdvaru ID PCI\VEN_10DE&DEV_0160&SUBSYS_00000000&REV_A1
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(1,0,0)
PCI enhet nVIDIA NV44 Video Adapter
Enhetsresurser:
IRQ 16
Minne 000A0000-000BFFFF
Minne D0000000-DFFFFFFF
Minne F9000000-F9FFFFFF
Minne FA000000-FAFFFFFF
Port 03B0-03BB
Port 03C0-03DF
[ DVD/CD-ROM drives / BENQ DVD LS DW1655 ATA Device ]
Enhetsegenskaper:
INF Fil cdrom.inf
Hårdvaru ID IDE\CdRomBENQ_DVD_LS_DW1655______________________BCHB____
Location Information Channel 0, Target 0, Lun 0
[ DVD/CD-ROM drives / TSSTcorp DVD-ROM SH-D162C ATA Device ]
Enhetsegenskaper:
INF Fil cdrom.inf
Hårdvaru ID IDE\CdRomTSSTcorp_DVD-ROM_SH-D162C_______________TS02____
[ Floppy disk drives / Floppy disk drive ]
Enhetsegenskaper:
Hårdvaru ID FDC\GENERIC_FLOPPY_DRIVE
[ Floppy drive controllers / Standard floppy disk controller ]
Enhetsegenskaper:
INF Fil fdc.inf
Hårdvaru ID ACPI\PNP0700
PnP enhet Floppy Disk Controller
Enhetsresurser:
DMA 02
IRQ 06
Port 03F0-03F5
Port 03F7-03F7
[ Human Interface Devices / Bluetooth HID Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth HID Device
INF Fil hidbth.inf
Hårdvaru ID BTHENUM\{00001124-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Human Interface Devices / Heej!!!! :'D (Remote Control) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Heej!!!! :'D (Remote Control)
Drivrutinsdatum 2008-07-10
Drivrutinsversion 3.0.0.183
INF Fil oem6.inf
Hårdvaru ID BTHENUM\{0000110e-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Human Interface Devices / HID-compliant consumer control device ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID-compliant consumer control device
INF Fil hidserv.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_01&Col01
Enhetsegenskaper:
INF Fil hidserv.inf
Hårdvaru ID HID\BthAvrcpDevice&Col01
Enhetsegenskaper:
INF Fil hidserv.inf
[ Human Interface Devices / HID-compliant device ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID-compliant device
INF Fil input.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_01&Col03
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_01&Col02
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID HID\BthAvrcpDevice&Col02
Enhetsegenskaper:
INF Fil input.inf
[ Human Interface Devices / Misa ^^ (Remote Control) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Misa ^^ (Remote Control)
INF Fil oem6.inf
Hårdvaru ID BTHENUM\{0000110e-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
[ Human Interface Devices / USB Input Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning USB Input Device
INF Fil input.inf
Hårdvaru ID USB\VID_06A3&PID_8020&REV_0130&MI_00
Location Information 0000.001d.0000.002.000.000.000.000.000
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID USB\VID_06A3&PID_8020&REV_0130&MI_01
Enhetsegenskaper:
INF Fil input.inf
Hårdvaru ID USB\VID_04FC&PID_0013&REV_06;0
Location Information Port_#0001.Hub_#0001
[ IDE ATA/ATAPI controllers / ATA Channel 0 ]
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID Intel-266f
Enhetsresurser:
IRQ 14
Port 01F0-01F7
Port 03F6-03F6
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID Intel-2651
[ IDE ATA/ATAPI controllers / ATA Channel 1 ]
Enhetsegenskaper:
INF Fil mshdc.inf
Enhetsresurser:
IRQ 15
Port 0170-0177
Port 0376-0376
Enhetsegenskaper:
INF Fil mshdc.inf
[ IDE ATA/ATAPI controllers / Intel(R) 82801FB Ultra ATA Storage Controllers - 2651 ]
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID PCI\VEN_8086&DEV_2651&SUBSYS_26518086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,2)
PCI enhet Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Enhetsresurser:
IRQ 19
Port C880-C88F
Port CC00-CC03
Port D000-D007
Port D080-D083
Port D400-D407
[ IDE ATA/ATAPI controllers / Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F ]
Enhetsegenskaper:
INF Fil mshdc.inf
Hårdvaru ID PCI\VEN_8086&DEV_266F&SUBSYS_266F8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,1)
PCI enhet Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Enhetsresurser:
Port FFA0-FFAF
[ IEEE 1394 Bus host controllers / Texas Instruments 1394 OHCI Compliant Host Controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Texas Instruments 1394 OHCI Compliant Host Controller
INF Fil 1394.inf
Hårdvaru ID PCI\VEN_104C&DEV_8023&SUBSYS_8026104C&REV_00
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(2,7,0)
PCI enhet Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
Enhetsresurser:
IRQ 19
Minne FBFF8000-FBFFBFFF
Minne FBFFF800-FBFFFFFF
[ Keyboards / HID Keyboard Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID Keyboard Device
INF Fil keyboard.inf
Hårdvaru ID HID\VID_06A3&PID_8020&REV_0130&MI_00
[ Mice and other pointing devices / HID-compliant mouse ]
Enhetsegenskaper:
Drivrutinsbeskrivning HID-compliant mouse
INF Fil msmouse.inf
Hårdvaru ID HID\VID_04FC&PID_0013&REV_06;0
[ Modems / Standard Modem over Bluetooth link #3 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Modem over Bluetooth link #3
INF Fil mdmbtmdm.inf
Hårdvaru ID BTHENUM\{00001103-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Modems / Standard Modem over Bluetooth link #4 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Modem over Bluetooth link #4
Hårdvaru ID BTHENUM\{00001103-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
[ Monitors / Generic PnP Monitor ]
Enhetsegenskaper:
Drivrutinsbeskrivning Generic PnP Monitor
INF Fil monitor.inf
Hårdvaru ID MONITOR\CPQ1435
[ Network adapters / Bluetooth Device (Personal Area Network) #2 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth Device (Personal Area Network) #2
INF Fil bthpan.inf
Hårdvaru ID BTH\MS_BTHPAN
[ Network adapters / Bluetooth Device (RFCOMM Protocol TDI) #2 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth Device (RFCOMM Protocol TDI) #2
INF Fil tdibth.inf
Hårdvaru ID BTH\MS_RFCOMM
[ Network adapters / Microsoft ISATAP Adapter #2 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft ISATAP Adapter #2
INF Fil nettun.inf
Hårdvaru ID *ISATAP
[ Network adapters / Microsoft ISATAP Adapter #3 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft ISATAP Adapter #3
INF Fil nettun.inf
Hårdvaru ID *ISATAP
[ Network adapters / Realtek RTL8139/810x Family Fast Ethernet NIC ]
Enhetsegenskaper:
Drivrutinsbeskrivning Realtek RTL8139/810x Family Fast Ethernet NIC
Drivrutinsdatum 2008-03-31
Drivrutinsversion 6.108.331.2008
Drivrutinstillverkare Realtek Semiconductor Corp.
INF Fil oem8.inf
Hårdvaru ID PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(2,14,0)
PCI enhet Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Enhetsresurser:
IRQ 18
Minne FBFFF400-FBFFF4FF
Port E800-E8FF
[ Network adapters / Teredo Tunneling Pseudo-Interface ]
Enhetsegenskaper:
Drivrutinsbeskrivning Teredo Tunneling Pseudo-Interface
INF Fil nettun.inf
Hårdvaru ID *TEREDO
[ Network adapters / WAN Miniport (IKEv2) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (IKEv2)
INF Fil netavpna.inf
Hårdvaru ID ms_agilevpnminiport
[ Network adapters / WAN Miniport (IP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (IP)
INF Fil netrasa.inf
Hårdvaru ID ms_ndiswanip
[ Network adapters / WAN Miniport (IPv6) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (IPv6)
INF Fil netrasa.inf
Hårdvaru ID ms_ndiswanipv6
[ Network adapters / WAN Miniport (L2TP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (L2TP)
INF Fil netrasa.inf
Hårdvaru ID ms_l2tpminiport
[ Network adapters / WAN Miniport (Network Monitor) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (Network Monitor)
INF Fil netrasa.inf
Hårdvaru ID ms_ndiswanbh
[ Network adapters / WAN Miniport (PPPOE) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (PPPOE)
INF Fil netrasa.inf
Hårdvaru ID ms_pppoeminiport
[ Network adapters / WAN Miniport (PPTP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (PPTP)
INF Fil netrasa.inf
Hårdvaru ID ms_pptpminiport
[ Network adapters / WAN Miniport (SSTP) ]
Enhetsegenskaper:
Drivrutinsbeskrivning WAN Miniport (SSTP)
INF Fil netsstpa.inf
Hårdvaru ID ms_sstpminiport
[ Non-Plug and Play Drivers / adfs ]
Enhetsegenskaper:
Drivrutinsbeskrivning adfs
[ Non-Plug and Play Drivers / Ancillary Function Driver for Winsock ]
Enhetsegenskaper:
Drivrutinsbeskrivning Ancillary Function Driver for Winsock
[ Non-Plug and Play Drivers / AppID Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning AppID Driver
[ Non-Plug and Play Drivers / AVG Free AVI Loader Driver x86 ]
Enhetsegenskaper:
Drivrutinsbeskrivning AVG Free AVI Loader Driver x86
[ Non-Plug and Play Drivers / AVG Free Network Redirector ]
Enhetsegenskaper:
Drivrutinsbeskrivning AVG Free Network Redirector
[ Non-Plug and Play Drivers / Beep ]
Enhetsegenskaper:
Drivrutinsbeskrivning Beep
[ Non-Plug and Play Drivers / Bitlocker Drive Encryption Filter Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bitlocker Drive Encryption Filter Driver
[ Non-Plug and Play Drivers / CNG ]
Enhetsegenskaper:
Drivrutinsbeskrivning CNG
[ Non-Plug and Play Drivers / Common Log (CLFS) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Common Log (CLFS)
[ Non-Plug and Play Drivers / Disk Virtual Machine Bus Acceleration Filter Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Disk Virtual Machine Bus Acceleration Filter Driver
[ Non-Plug and Play Drivers / Dynamic Volume Manager ]
Enhetsegenskaper:
Drivrutinsbeskrivning Dynamic Volume Manager
[ Non-Plug and Play Drivers / EagleNT ]
Enhetsegenskaper:
Drivrutinsbeskrivning EagleNT
[ Non-Plug and Play Drivers / Hardware Policy Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Hardware Policy Driver
[ Non-Plug and Play Drivers / HTTP ]
Enhetsegenskaper:
Drivrutinsbeskrivning HTTP
[ Non-Plug and Play Drivers / Kernel Mode Driver Frameworks service ]
Enhetsegenskaper:
Drivrutinsbeskrivning Kernel Mode Driver Frameworks service
[ Non-Plug and Play Drivers / KSecDD ]
Enhetsegenskaper:
Drivrutinsbeskrivning KSecDD
[ Non-Plug and Play Drivers / KSecPkg ]
Enhetsegenskaper:
Drivrutinsbeskrivning KSecPkg
[ Non-Plug and Play Drivers / LDDM Graphics Subsystem ]
Enhetsegenskaper:
Drivrutinsbeskrivning LDDM Graphics Subsystem
[ Non-Plug and Play Drivers / Link-Layer Topology Discovery Mapper I/O Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Link-Layer Topology Discovery Mapper I/O Driver
[ Non-Plug and Play Drivers / Link-Layer Topology Discovery Responder ]
Enhetsegenskaper:
Drivrutinsbeskrivning Link-Layer Topology Discovery Responder
[ Non-Plug and Play Drivers / Mount Point Manager ]
Enhetsegenskaper:
Drivrutinsbeskrivning Mount Point Manager
[ Non-Plug and Play Drivers / msisadrv ]
Enhetsegenskaper:
Drivrutinsbeskrivning msisadrv
[ Non-Plug and Play Drivers / NativeWiFi Filter ]
Enhetsegenskaper:
Drivrutinsbeskrivning NativeWiFi Filter
[ Non-Plug and Play Drivers / NDIS System Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning NDIS System Driver
[ Non-Plug and Play Drivers / NDIS Usermode I/O Protocol ]
Enhetsegenskaper:
Drivrutinsbeskrivning NDIS Usermode I/O Protocol
[ Non-Plug and Play Drivers / NDProxy ]
Enhetsegenskaper:
Drivrutinsbeskrivning NDProxy
[ Non-Plug and Play Drivers / NETBT ]
Enhetsegenskaper:
Drivrutinsbeskrivning NETBT
[ Non-Plug and Play Drivers / NetIO Legacy TDI Support Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning NetIO Legacy TDI Support Driver
[ Non-Plug and Play Drivers / npkcrypt ]
Enhetsegenskaper:
Drivrutinsbeskrivning npkcrypt
[ Non-Plug and Play Drivers / NSI proxy service driver. ]
Enhetsegenskaper:
Drivrutinsbeskrivning NSI proxy service driver.
[ Non-Plug and Play Drivers / Null ]
Enhetsegenskaper:
Drivrutinsbeskrivning Null
[ Non-Plug and Play Drivers / Offline Files Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Offline Files Driver
[ Non-Plug and Play Drivers / Parvdm ]
Enhetsegenskaper:
Drivrutinsbeskrivning Parvdm
[ Non-Plug and Play Drivers / PEAUTH ]
Enhetsegenskaper:
Drivrutinsbeskrivning PEAUTH
[ Non-Plug and Play Drivers / Performance Counters for Windows Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Performance Counters for Windows Driver
[ Non-Plug and Play Drivers / QoS Packet Scheduler ]
Enhetsegenskaper:
Drivrutinsbeskrivning QoS Packet Scheduler
[ Non-Plug and Play Drivers / QWAVE driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning QWAVE driver
[ Non-Plug and Play Drivers / RDP Encoder Mirror Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning RDP Encoder Mirror Driver
[ Non-Plug and Play Drivers / RDPCDD ]
Enhetsegenskaper:
Drivrutinsbeskrivning RDPCDD
[ Non-Plug and Play Drivers / Reflector Display Driver used to gain access to graphics data ]
Enhetsegenskaper:
Drivrutinsbeskrivning Reflector Display Driver used to gain access to graphics data
[ Non-Plug and Play Drivers / Remote Access IPv6 ARP Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Remote Access IPv6 ARP Driver
[ Non-Plug and Play Drivers / Security Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Security Driver
[ Non-Plug and Play Drivers / Security Processor Loader Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Security Processor Loader Driver
[ Non-Plug and Play Drivers / sptd ]
Enhetsegenskaper:
Drivrutinsbeskrivning sptd
[ Non-Plug and Play Drivers / Storage volumes ]
Enhetsegenskaper:
Drivrutinsbeskrivning Storage volumes
[ Non-Plug and Play Drivers / System Attribute Cache ]
Enhetsegenskaper:
Drivrutinsbeskrivning System Attribute Cache
[ Non-Plug and Play Drivers / TCP/IP Protocol Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning TCP/IP Protocol Driver
[ Non-Plug and Play Drivers / TCP/IP Registry Compatibility ]
Enhetsegenskaper:
Drivrutinsbeskrivning TCP/IP Registry Compatibility
[ Non-Plug and Play Drivers / TPkd ]
Enhetsegenskaper:
Drivrutinsbeskrivning TPkd
[ Non-Plug and Play Drivers / User Mode Driver Frameworks Platform Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning User Mode Driver Frameworks Platform Driver
[ Non-Plug and Play Drivers / WFP Lightweight Filter ]
Enhetsegenskaper:
Drivrutinsbeskrivning WFP Lightweight Filter
[ Non-Plug and Play Drivers / VgaSave ]
Enhetsegenskaper:
Drivrutinsbeskrivning VgaSave
[ Non-Plug and Play Drivers / Windows Firewall Authorization Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Windows Firewall Authorization Driver
[ Non-Plug and Play Drivers / Virtual WiFi Filter Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Virtual WiFi Filter Driver
[ Ports (COM & LPT) / Communications Port (COM1) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Communications Port (COM1)
INF Fil msports.inf
Hårdvaru ID ACPI\PNP0501
PnP enhet 16550A-compatible UART Serial Port
Enhetsresurser:
IRQ 04
Port 03F8-03FF
[ Ports (COM & LPT) / Communications Port (COM2) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Communications Port (COM2)
INF Fil msports.inf
Enhetsresurser:
IRQ 03
Port 02F8-02FF
[ Ports (COM & LPT) / Printer Port (LPT1) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Printer Port (LPT1)
INF Fil msports.inf
Hårdvaru ID ACPI\PNP0400
PnP enhet Parallel Port
Enhetsresurser:
Port 0378-037F
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM10) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM10)
INF Fil bthspp.inf
Hårdvaru ID BTHENUM\{00001101-0000-1000-8000-00805f9b34fb}_LOCALMFG&0000
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM11) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM11)
INF Fil bthspp.inf
Hårdvaru ID BTHENUM\{00001101-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM12) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM12)
INF Fil bthspp.inf
Hårdvaru ID BTHENUM\{00001101-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
[ Ports (COM & LPT) / Standard Serial over Bluetooth link (COM9) ]
Enhetsegenskaper:
Drivrutinsbeskrivning Standard Serial over Bluetooth link (COM9)
INF Fil bthspp.inf
[ Processors / Intel(R) Pentium(R) 4 CPU 3.00GHz ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) Pentium(R) 4 CPU 3.00GHz
INF Fil cpu.inf
Hårdvaru ID ACPI\GenuineIntel_-_x86_Family_15_Model_4
Enhetsegenskaper:
INF Fil cpu.inf
[ Sound, video and game controllers / High Definition Audio Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning High Definition Audio Device
Drivrutinsdatum 2009-07-13
INF Fil hdaudio.inf
Hårdvaru ID HDAUDIO\FUNC_01&VEN_10EC&DEV_0880&SUBSYS_08800000&REV_0905
Location Information Internal High Definition Audio Bus
[ Storage controllers / Microsoft iSCSI Initiator ]
Enhetsegenskaper:
INF Fil iscsi.inf
Hårdvaru ID ROOT\ISCSIPRT
[ Storage volume shadow copies / Generic volume shadow copy ]
Enhetsegenskaper:
Drivrutinsbeskrivning Generic volume shadow copy
INF Fil volsnap.inf
Hårdvaru ID STORAGE\VolumeSnapshot
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
Enhetsegenskaper:
INF Fil volsnap.inf
[ Storage Volumes / Generic volume ]
Enhetsegenskaper:
INF Fil volume.inf
Enhetsegenskaper:
INF Fil volume.inf
Enhetsegenskaper:
INF Fil volume.inf
Enhetsegenskaper:
INF Fil volume.inf
[ System devices / ACPI Fixed Feature Button ]
Enhetsegenskaper:
Drivrutinsbeskrivning ACPI Fixed Feature Button
INF Fil machine.inf
Hårdvaru ID ACPI\FixedButton
[ System devices / ACPI Power Button ]
Enhetsegenskaper:
Drivrutinsbeskrivning ACPI Power Button
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C0C
PnP enhet Power Button
[ System devices / Composite Bus Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Composite Bus Enumerator
INF Fil compositebus.inf
Hårdvaru ID ROOT\CompositeBus
[ System devices / Direct memory access controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Direct memory access controller
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0200
PnP enhet DMA Controller
Enhetsresurser:
DMA 04
Port 0000-000F
Port 0081-0083
Port 0087-0087
Port 0089-008B
Port 008F-008F
Port 00C0-00DF
[ System devices / Extended IO Bus ]
Enhetsegenskaper:
Drivrutinsbeskrivning Extended IO Bus
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0A06
PnP enhet Extended IO Bus
[ System devices / File as Volume Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning File as Volume Driver
INF Fil blbdrive.inf
Hårdvaru ID ROOT\BLBDRIVE
[ System devices / High Definition Audio Controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning High Definition Audio Controller
INF Fil hdaudbus.inf
Hårdvaru ID PCI\VEN_8086&DEV_2668&SUBSYS_58263411&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,27,0)
PCI enhet Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Enhetsresurser:
IRQ 16
Minne F8FFC000-F8FFFFFF
[ System devices / Intel(R) 82801 PCI Bridge - 244E ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801 PCI Bridge - 244E
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_244E&SUBSYS_244E8086&REV_D3
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,30,0)
PCI enhet Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Enhetsresurser:
Minne FBF00000-FBFFFFFF
Port E000-EFFF
[ System devices / Intel(R) 82801FB LPC Interface Controller - 2640 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB LPC Interface Controller - 2640
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_2640&SUBSYS_26408086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,0)
PCI enhet Intel 82801FB ICH6 - LPC Bridge [B-1]
[ System devices / Intel(R) 82801FB/FBM SMBus Controller - 266A ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM SMBus Controller - 266A
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_266A&SUBSYS_266A8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,31,3)
PCI enhet Intel 82801FB ICH6 - SMBus Controller [B-1]
Enhetsresurser:
IRQ 10
Port 0400-041F
[ System devices / Intel(R) 82802 Firmware Hub Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82802 Firmware Hub Device
INF Fil machine.inf
Hårdvaru ID ACPI\INT0800
PnP enhet Intel Flash EEPROM
Enhetsresurser:
Minne FFB80000-FFBFFFFF
Minne FFF80000-FFFFFFFF
[ System devices / Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_2581&SUBSYS_00008086&REV_04
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,1,0)
PCI enhet Intel 82915P PCI Express Root Port [B-1]
Enhetsresurser:
IRQ 16
Minne B8000000-DFFFFFFF
Minne F9000000-FBEFFFFF
Port 03B0-03BB
Port 03C0-03DF
[ System devices / Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 2580 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 915G/P/GV/GL/PL/910GE/GL Processor to I/O Controller - 2580
INF Fil machine.inf
Hårdvaru ID PCI\VEN_8086&DEV_2580&SUBSYS_25808086&REV_04
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,0,0)
PCI enhet Intel 82915P Memory Controller Hub [B-1]
[ System devices / IPBusEnum Root Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning IPBusEnum Root Enumerator
INF Fil umbus.inf
Hårdvaru ID UMB\UMBUS
[ System devices / Microsoft ACPI-Compliant System ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft ACPI-Compliant System
INF Fil acpi.inf
Hårdvaru ID ACPI_HAL\PNP0C08
PnP enhet ACPI Driver/BIOS
Enhetsresurser:
IRQ 100
IRQ 101
IRQ 102
IRQ 103
IRQ 104
IRQ 105
IRQ 106
IRQ 107
IRQ 108
IRQ 109
IRQ 110
IRQ 111
IRQ 112
IRQ 113
IRQ 114
IRQ 115
IRQ 116
IRQ 117
IRQ 118
IRQ 119
IRQ 120
IRQ 121
IRQ 122
IRQ 123
IRQ 124
IRQ 125
IRQ 126
IRQ 127
IRQ 128
IRQ 129
IRQ 130
IRQ 131
IRQ 132
IRQ 133
IRQ 134
IRQ 135
IRQ 136
IRQ 137
IRQ 138
IRQ 139
IRQ 140
IRQ 141
IRQ 142
IRQ 143
IRQ 144
IRQ 145
IRQ 146
IRQ 147
IRQ 148
IRQ 149
IRQ 150
IRQ 151
IRQ 152
IRQ 153
IRQ 154
IRQ 155
IRQ 156
IRQ 157
IRQ 158
IRQ 159
IRQ 160
IRQ 161
IRQ 162
IRQ 163
IRQ 164
IRQ 165
IRQ 166
IRQ 167
IRQ 168
IRQ 169
IRQ 170
IRQ 171
IRQ 172
IRQ 173
IRQ 174
IRQ 175
IRQ 176
IRQ 177
IRQ 178
IRQ 179
IRQ 180
IRQ 181
IRQ 182
IRQ 183
IRQ 184
IRQ 185
IRQ 186
IRQ 187
IRQ 188
IRQ 189
IRQ 190
IRQ 81
IRQ 82
IRQ 83
IRQ 84
IRQ 85
IRQ 86
IRQ 87
IRQ 88
IRQ 89
IRQ 90
IRQ 91
IRQ 92
IRQ 93
IRQ 94
IRQ 95
IRQ 96
IRQ 97
IRQ 98
IRQ 99
[ System devices / Microsoft System Management BIOS Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft System Management BIOS Driver
INF Fil machine.inf
Hårdvaru ID ROOT\mssmbios
[ System devices / Microsoft Virtual Drive Enumerator Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Microsoft Virtual Drive Enumerator Driver
INF Fil machine.inf
Hårdvaru ID ROOT\vdrvroot
[ System devices / Motherboard resources ]
Enhetsegenskaper:
Drivrutinsbeskrivning Motherboard resources
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C02
PnP enhet Motherboard Resources
Enhetsresurser:
Minne E0000000-EFFFFFFF
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FEC00000-FEC00FFF
Minne FEE00000-FEE00FFF
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FED1C000-FED1FFFF
Minne FED20000-FED8FFFF
Port 0010-001F
Port 0022-003F
Port 0044-005F
Port 0062-0063
Port 0065-006F
Port 0072-007F
Port 0080-0080
Port 0084-0086
Port 0088-0088
Port 008C-008E
Port 0090-009F
Port 00A2-00BF
Port 00E0-00EF
Port 0480-04BF
Port 04D0-04D1
Port 0800-087F
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Port 0290-0297
Port 0680-06FF
Port 0A00-0A7F
Port 0D00-0D7F
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FFC00000-FFF7FFFF
[ System devices / Numeric data processor ]
Enhetsegenskaper:
Drivrutinsbeskrivning Numeric data processor
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C04
PnP enhet Numeric Data Processor
Enhetsresurser:
IRQ 13
Port 00F0-00FF
[ System devices / PCI bus ]
Enhetsegenskaper:
Drivrutinsbeskrivning PCI bus
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0A08
PnP enhet ACPI Three-wire Device Bus
Enhetsresurser:
Minne 000C0000-000DFFFF
Minne A0000000-FFFFFFFF
Port 0000-0CF7
Port 0D00-FFFF
[ System devices / Plug and Play Software Device Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning Plug and Play Software Device Enumerator
INF Fil machine.inf
Hårdvaru ID root\swenum
[ System devices / Printer Port Logical Interface ]
Enhetsegenskaper:
Drivrutinsbeskrivning Printer Port Logical Interface
INF Fil machine.inf
Hårdvaru ID LPTENUM\MicrosoftRawPort958A
Location Information LPT1
[ System devices / Programmable interrupt controller ]
Enhetsegenskaper:
Drivrutinsbeskrivning Programmable interrupt controller
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0000
PnP enhet Programmable Interrupt Controller
Enhetsresurser:
Port 0020-0021
Port 00A0-00A1
[ System devices / Remote Desktop Device Redirector Bus ]
Enhetsegenskaper:
Drivrutinsbeskrivning Remote Desktop Device Redirector Bus
INF Fil rdpbus.inf
Hårdvaru ID ROOT\RDPBUS
[ System devices / System board ]
Enhetsegenskaper:
Drivrutinsbeskrivning System board
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0C01
PnP enhet System Board Extension
Enhetsresurser:
Minne 00000000-0009FFFF
Minne 000E0000-000FFFFF
Minne 00100000-9FFFFFFF
Enhetsegenskaper:
INF Fil machine.inf
Enhetsresurser:
Minne FED13000-FED19FFF
[ System devices / System CMOS/real time clock ]
Enhetsegenskaper:
Drivrutinsbeskrivning System CMOS/real time clock
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0B00
PnP enhet Real-Time Clock
Enhetsresurser:
IRQ 08
Port 0070-0071
[ System devices / System speaker ]
Enhetsegenskaper:
Drivrutinsbeskrivning System speaker
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0800
PnP enhet PC Speaker
Enhetsresurser:
Port 0061-0061
[ System devices / System timer ]
Enhetsegenskaper:
Drivrutinsbeskrivning System timer
INF Fil machine.inf
Hårdvaru ID ACPI\PNP0100
PnP enhet System Timer
Enhetsresurser:
IRQ 00
Port 0040-0043
[ System devices / Terminal Server Keyboard Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Terminal Server Keyboard Driver
INF Fil machine.inf
Hårdvaru ID ROOT\RDP_KBD
[ System devices / Terminal Server Mouse Driver ]
Enhetsegenskaper:
Drivrutinsbeskrivning Terminal Server Mouse Driver
INF Fil machine.inf
Hårdvaru ID ROOT\RDP_MOU
[ System devices / UMBus Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning UMBus Enumerator
INF Fil umbus.inf
[ System devices / UMBus Root Bus Enumerator ]
Enhetsegenskaper:
Drivrutinsbeskrivning UMBus Root Bus Enumerator
INF Fil umbus.inf
Hårdvaru ID root\umbus
[ System devices / Volume Manager ]
Enhetsegenskaper:
Drivrutinsbeskrivning Volume Manager
INF Fil machine.inf
Hårdvaru ID ROOT\VOLMGR
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 2658 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_2658&SUBSYS_26588086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,0)
PCI enhet Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Enhetsresurser:
IRQ 23
Port DC00-DC1F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 2659 ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_2659&SUBSYS_26598086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,1)
Enhetsresurser:
IRQ 19
Port D880-D89F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 265A ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_265A&SUBSYS_265A8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,2)
Enhetsresurser:
IRQ 18
Port D800-D81F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB Universal Host Controller - 265B ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_265B&SUBSYS_265B8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,3)
Enhetsresurser:
IRQ 16
Port D480-D49F
[ Universal Serial Bus controllers / Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C ]
Enhetsegenskaper:
Drivrutinsbeskrivning Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
INF Fil usbport.inf
Hårdvaru ID PCI\VEN_8086&DEV_265C&SUBSYS_265C8086&REV_03
Location Information @system32\DRIVERS\pci.sys,#65536;PCI bus %1, device %2, function %3;(0,29,7)
PCI enhet Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Enhetsresurser:
IRQ 23
Minne F8FFBC00-F8FFBFFF
[ Universal Serial Bus controllers / USB Composite Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning USB Composite Device
INF Fil usb.inf
Location Information Port_#0002.Hub_#0001
[ Universal Serial Bus controllers / USB Root Hub ]
Enhetsegenskaper:
Drivrutinsbeskrivning USB Root Hub
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID2659&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID265B&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID2658&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB&VID8086&PID265A&REV0003
Enhetsegenskaper:
INF Fil usbport.inf
Hårdvaru ID USB\ROOT_HUB20&VID8086&PID265C&REV0003
[ Unknown / Bluetooth Peripheral Device ]
Enhetsegenskaper:
Drivrutinsbeskrivning Bluetooth Peripheral Device
Hårdvaru ID BTHENUM\{00000002-0000-1000-8000-0002ee000002}_VID&00010000_PID&c0f3
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{00000002-0000-1000-8000-0002ee000002}_VID&00010000_PID&c0f5
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771301-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771301-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771401-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f3
Enhetsegenskaper:
Hårdvaru ID BTHENUM\{8e771401-0000-1000-8000-00805f9b34fb}_VID&00010000_PID&c0f5
PCI enheter:
Buss 0, Enhet 30, Funktion 0 Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Buss 0, Enhet 31, Funktion 1 Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Buss 0, Enhet 29, Funktion 7 Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Buss 0, Enhet 27, Funktion 0 Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Buss 0, Enhet 31, Funktion 0 Intel 82801FB ICH6 - LPC Bridge [B-1]
Buss 0, Enhet 31, Funktion 2 Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Buss 0, Enhet 31, Funktion 3 Intel 82801FB ICH6 - SMBus Controller [B-1]
Buss 0, Enhet 29, Funktion 0 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 29, Funktion 1 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 29, Funktion 2 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 29, Funktion 3 Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Buss 0, Enhet 0, Funktion 0 Intel 82915P Memory Controller Hub [B-1]
Buss 0, Enhet 1, Funktion 0 Intel 82915P PCI Express Root Port [B-1]
Buss 1, Enhet 0, Funktion 0 nVIDIA NV44 Video Adapter
Buss 2, Enhet 14, Funktion 0 Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Buss 2, Enhet 7, Funktion 0 Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
PnP enheter:
PNP0501 16550A-compatible UART Serial Port
PNP0C08 ACPI Driver/BIOS
FIXEDBUTTON ACPI Fixed Feature Button
PNP0A08 ACPI Three-wire Device Bus
PNP0200 DMA Controller
PNP0A06 Extended IO Bus
PNP0700 Floppy Disk Controller
INT0800 Intel Flash EEPROM
GENUINEINTEL_-_X86_FAMILY_15_MODEL_4_-_______________INTEL(R)_PENTIUM(R)_4_CPU_3.00GHZIntel(R) Pentium(R) 4 CPU 3.00GHz
ISATAP Microsoft ISATAP Adapter #2
ISATAP Microsoft ISATAP Adapter #3
PNP0C02 Motherboard Resources
PNP0C04 Numeric Data Processor
PNP0400 Parallel Port
PNP0800 PC Speaker
PNP0C0C Power Button
PNP0000 Programmable Interrupt Controller
PNP0B00 Real-Time Clock
PNP0C01 System Board Extension
PNP0100 System Timer
TEREDO Teredo Tunneling Pseudo-Interface
LPT PnP enheter:
MICROSOFTRAWPORT Printer Port Logical Interface
USB enheter:
0A12 0001 CSR Bluetooth Radio
06A3 8020 USB Composite Device
04FC 0013 USB Input Device
06A3 8020 USB Input Device
Portar:
COM1 Communications Port (COM1)
COM10 Standard Serial over Bluetooth link (COM10)
COM11 Standard Serial over Bluetooth link (COM11)
COM12 Standard Serial over Bluetooth link (COM12)
COM2 Communications Port (COM2)
COM9 Standard Serial over Bluetooth link (COM9)
LPT1 Printer Port (LPT1)
--------[ PCI enheter ]-------------------------------------------------------------------------------------------------
[ Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 30 / 0
Enhets ID 8086-244E
Delsystems ID 0000-0000
Enhetsklass 0604 (PCI/PCI Bridge)
Inventering D3
Fast Back-to-Back Transactions Inget Stöd
Enhetens finesser:
66 MHz operation Inget Stöd
Bus Mastering Aktiverad
[ Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 1
Enhets ID 8086-266F
Delsystems ID 8086-266F
Enhetsklass 0101 (IDE Controller)
Inventering 03
Fast Back-to-Back Transactions Stöds, Avaktiverad
Enhetens finesser:
[ Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 7
Enhets ID 8086-265C
Delsystems ID 8086-265C
Enhetsklass 0C03 (USB Controller)
Inventering 03
Enhetens finesser:
[ Intel 82801FB ICH6 - High Definition Audio Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Busstyp PCI Express
Buss / Enhet / Funktioner 0 / 27 / 0
Enhets ID 8086-2668
Delsystems ID 3411-5826
Enhetsklass 0403 (High Definition Audio)
Inventering 03
Enhetens finesser:
[ Intel 82801FB ICH6 - LPC Bridge [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - LPC Bridge [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 0
Enhets ID 8086-2640
Delsystems ID 8086-2640
Enhetsklass 0601 (PCI/ISA Bridge)
Inventering 03
Enhetens finesser:
[ Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 2
Enhets ID 8086-2651
Delsystems ID 8086-2651
Inventering 03
Enhetens finesser:
66 MHz operation Stöds
[ Intel 82801FB ICH6 - SMBus Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - SMBus Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 31 / 3
Enhets ID 8086-266A
Delsystems ID 8086-266A
Enhetsklass 0C05 (Serial Bus Controller)
Inventering 03
Enhetens finesser:
Bus Mastering Avaktiverad
[ Intel 82801FB ICH6 - USB Universal Host Controller [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 0
Enhets ID 8086-2658
Delsystems ID 8086-2658
Inventering 03
Enhetens finesser:
Enhetsegenskaper:
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 1
Enhets ID 8086-2659
Delsystems ID 8086-2659
Inventering 03
Enhetens finesser:
Enhetsegenskaper:
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 2
Enhets ID 8086-265A
Delsystems ID 8086-265A
Inventering 03
Enhetens finesser:
Enhetsegenskaper:
Busstyp PCI
Buss / Enhet / Funktioner 0 / 29 / 3
Enhets ID 8086-265B
Delsystems ID 8086-265B
Inventering 03
Enhetens finesser:
[ Intel 82915P Memory Controller Hub [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82915P Memory Controller Hub [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 0 / 0
Enhets ID 8086-2580
Delsystems ID 8086-2580
Enhetsklass 0600 (Host/PCI Bridge)
Inventering 04
Enhetens finesser:
[ Intel 82915P PCI Express Root Port [B-1] ]
Enhetsegenskaper:
Enhetsbeskrivning Intel 82915P PCI Express Root Port [B-1]
Busstyp PCI
Buss / Enhet / Funktioner 0 / 1 / 0
Enhets ID 8086-2581
Inventering 04
Enhetens finesser:
[ nVIDIA NV44 Video Adapter ]
Enhetsegenskaper:
Enhetsbeskrivning nVIDIA NV44 Video Adapter
Busstyp PCI Express x16
Buss / Enhet / Funktioner 1 / 0 / 0
Enhets ID 10DE-0160
Enhetsklass 0300 (VGA Display Controller)
Inventering A1
Enhetens finesser:
[ Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C] ]
Enhetsegenskaper:
Enhetsbeskrivning Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Busstyp PCI
Buss / Enhet / Funktioner 2 / 14 / 0
Enhets ID 10EC-8139
Delsystems ID 10EC-8139
Enhetsklass 0200 (Ethernet Controller)
Inventering 10
Enhetens finesser:
[ Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller ]
Enhetsegenskaper:
Enhetsbeskrivning Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
Busstyp PCI
Buss / Enhet / Funktioner 2 / 7 / 0
Enhets ID 104C-8023
Delsystems ID 104C-8026
Enhetsklass 0C00 (Firewire Controller)
Inventering 00
Enhetens finesser:
--------[ Enhetsresurser ]----------------------------------------------------------------------------------------------
DMA 02 Exklusiv Standard floppy disk controller
DMA 04 Exklusiv Direct memory access controller
IRQ 00 Exklusiv System timer
IRQ 03 Exklusiv Communications Port (COM2)
IRQ 04 Exklusiv Communications Port (COM1)
IRQ 06 Exklusiv Standard floppy disk controller
IRQ 08 Exklusiv System CMOS/real time clock
IRQ 10 Delad Intel(R) 82801FB/FBM SMBus Controller - 266A
IRQ 100 Exklusiv Microsoft ACPI-Compliant System
IRQ 101 Exklusiv Microsoft ACPI-Compliant System
IRQ 102 Exklusiv Microsoft ACPI-Compliant System
IRQ 103 Exklusiv Microsoft ACPI-Compliant System
IRQ 104 Exklusiv Microsoft ACPI-Compliant System
IRQ 105 Exklusiv Microsoft ACPI-Compliant System
IRQ 106 Exklusiv Microsoft ACPI-Compliant System
IRQ 107 Exklusiv Microsoft ACPI-Compliant System
IRQ 108 Exklusiv Microsoft ACPI-Compliant System
IRQ 109 Exklusiv Microsoft ACPI-Compliant System
IRQ 110 Exklusiv Microsoft ACPI-Compliant System
IRQ 111 Exklusiv Microsoft ACPI-Compliant System
IRQ 112 Exklusiv Microsoft ACPI-Compliant System
IRQ 113 Exklusiv Microsoft ACPI-Compliant System
IRQ 114 Exklusiv Microsoft ACPI-Compliant System
IRQ 115 Exklusiv Microsoft ACPI-Compliant System
IRQ 116 Exklusiv Microsoft ACPI-Compliant System
IRQ 117 Exklusiv Microsoft ACPI-Compliant System
IRQ 118 Exklusiv Microsoft ACPI-Compliant System
IRQ 119 Exklusiv Microsoft ACPI-Compliant System
IRQ 120 Exklusiv Microsoft ACPI-Compliant System
IRQ 121 Exklusiv Microsoft ACPI-Compliant System
IRQ 122 Exklusiv Microsoft ACPI-Compliant System
IRQ 123 Exklusiv Microsoft ACPI-Compliant System
IRQ 124 Exklusiv Microsoft ACPI-Compliant System
IRQ 125 Exklusiv Microsoft ACPI-Compliant System
IRQ 126 Exklusiv Microsoft ACPI-Compliant System
IRQ 127 Exklusiv Microsoft ACPI-Compliant System
IRQ 128 Exklusiv Microsoft ACPI-Compliant System
IRQ 129 Exklusiv Microsoft ACPI-Compliant System
IRQ 13 Exklusiv Numeric data processor
IRQ 130 Exklusiv Microsoft ACPI-Compliant System
IRQ 131 Exklusiv Microsoft ACPI-Compliant System
IRQ 132 Exklusiv Microsoft ACPI-Compliant System
IRQ 133 Exklusiv Microsoft ACPI-Compliant System
IRQ 134 Exklusiv Microsoft ACPI-Compliant System
IRQ 135 Exklusiv Microsoft ACPI-Compliant System
IRQ 136 Exklusiv Microsoft ACPI-Compliant System
IRQ 137 Exklusiv Microsoft ACPI-Compliant System
IRQ 138 Exklusiv Microsoft ACPI-Compliant System
IRQ 139 Exklusiv Microsoft ACPI-Compliant System
IRQ 14 Exklusiv ATA Channel 0
IRQ 140 Exklusiv Microsoft ACPI-Compliant System
IRQ 141 Exklusiv Microsoft ACPI-Compliant System
IRQ 142 Exklusiv Microsoft ACPI-Compliant System
IRQ 143 Exklusiv Microsoft ACPI-Compliant System
IRQ 144 Exklusiv Microsoft ACPI-Compliant System
IRQ 145 Exklusiv Microsoft ACPI-Compliant System
IRQ 146 Exklusiv Microsoft ACPI-Compliant System
IRQ 147 Exklusiv Microsoft ACPI-Compliant System
IRQ 148 Exklusiv Microsoft ACPI-Compliant System
IRQ 149 Exklusiv Microsoft ACPI-Compliant System
IRQ 15 Exklusiv ATA Channel 1
IRQ 150 Exklusiv Microsoft ACPI-Compliant System
IRQ 151 Exklusiv Microsoft ACPI-Compliant System
IRQ 152 Exklusiv Microsoft ACPI-Compliant System
IRQ 153 Exklusiv Microsoft ACPI-Compliant System
IRQ 154 Exklusiv Microsoft ACPI-Compliant System
IRQ 155 Exklusiv Microsoft ACPI-Compliant System
IRQ 156 Exklusiv Microsoft ACPI-Compliant System
IRQ 157 Exklusiv Microsoft ACPI-Compliant System
IRQ 158 Exklusiv Microsoft ACPI-Compliant System
IRQ 159 Exklusiv Microsoft ACPI-Compliant System
IRQ 16 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
IRQ 16 Delad High Definition Audio Controller
IRQ 16 Delad Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
IRQ 16 Delad NVIDIA GeForce 6500
IRQ 160 Exklusiv Microsoft ACPI-Compliant System
IRQ 161 Exklusiv Microsoft ACPI-Compliant System
IRQ 162 Exklusiv Microsoft ACPI-Compliant System
IRQ 163 Exklusiv Microsoft ACPI-Compliant System
IRQ 164 Exklusiv Microsoft ACPI-Compliant System
IRQ 165 Exklusiv Microsoft ACPI-Compliant System
IRQ 166 Exklusiv Microsoft ACPI-Compliant System
IRQ 167 Exklusiv Microsoft ACPI-Compliant System
IRQ 168 Exklusiv Microsoft ACPI-Compliant System
IRQ 169 Exklusiv Microsoft ACPI-Compliant System
IRQ 170 Exklusiv Microsoft ACPI-Compliant System
IRQ 171 Exklusiv Microsoft ACPI-Compliant System
IRQ 172 Exklusiv Microsoft ACPI-Compliant System
IRQ 173 Exklusiv Microsoft ACPI-Compliant System
IRQ 174 Exklusiv Microsoft ACPI-Compliant System
IRQ 175 Exklusiv Microsoft ACPI-Compliant System
IRQ 176 Exklusiv Microsoft ACPI-Compliant System
IRQ 177 Exklusiv Microsoft ACPI-Compliant System
IRQ 178 Exklusiv Microsoft ACPI-Compliant System
IRQ 179 Exklusiv Microsoft ACPI-Compliant System
IRQ 18 Delad Realtek RTL8139/810x Family Fast Ethernet NIC
IRQ 18 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
IRQ 180 Exklusiv Microsoft ACPI-Compliant System
IRQ 181 Exklusiv Microsoft ACPI-Compliant System
IRQ 182 Exklusiv Microsoft ACPI-Compliant System
IRQ 183 Exklusiv Microsoft ACPI-Compliant System
IRQ 184 Exklusiv Microsoft ACPI-Compliant System
IRQ 185 Exklusiv Microsoft ACPI-Compliant System
IRQ 186 Exklusiv Microsoft ACPI-Compliant System
IRQ 187 Exklusiv Microsoft ACPI-Compliant System
IRQ 188 Exklusiv Microsoft ACPI-Compliant System
IRQ 189 Exklusiv Microsoft ACPI-Compliant System
IRQ 19 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
IRQ 19 Delad Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
IRQ 19 Delad Texas Instruments 1394 OHCI Compliant Host Controller
IRQ 190 Exklusiv Microsoft ACPI-Compliant System
IRQ 23 Delad Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
IRQ 23 Delad Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
IRQ 81 Exklusiv Microsoft ACPI-Compliant System
IRQ 82 Exklusiv Microsoft ACPI-Compliant System
IRQ 83 Exklusiv Microsoft ACPI-Compliant System
IRQ 84 Exklusiv Microsoft ACPI-Compliant System
IRQ 85 Exklusiv Microsoft ACPI-Compliant System
IRQ 86 Exklusiv Microsoft ACPI-Compliant System
IRQ 87 Exklusiv Microsoft ACPI-Compliant System
IRQ 88 Exklusiv Microsoft ACPI-Compliant System
IRQ 89 Exklusiv Microsoft ACPI-Compliant System
IRQ 90 Exklusiv Microsoft ACPI-Compliant System
IRQ 91 Exklusiv Microsoft ACPI-Compliant System
IRQ 92 Exklusiv Microsoft ACPI-Compliant System
IRQ 93 Exklusiv Microsoft ACPI-Compliant System
IRQ 94 Exklusiv Microsoft ACPI-Compliant System
IRQ 95 Exklusiv Microsoft ACPI-Compliant System
IRQ 96 Exklusiv Microsoft ACPI-Compliant System
IRQ 97 Exklusiv Microsoft ACPI-Compliant System
IRQ 98 Exklusiv Microsoft ACPI-Compliant System
IRQ 99 Exklusiv Microsoft ACPI-Compliant System
Minne 00000000-0009FFFF Exklusiv System board
Minne 000A0000-000BFFFF Delad PCI bus
Minne 000A0000-000BFFFF Delad NVIDIA GeForce 6500
Minne 000A0000-000BFFFF Ej fastställd Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Minne 000C0000-000DFFFF Delad PCI bus
Minne 000E0000-000FFFFF Exklusiv System board
Minne 00100000-9FFFFFFF Exklusiv System board
Minne A0000000-FFFFFFFF Delad PCI bus
Minne B8000000-DFFFFFFF Exklusiv Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Minne D0000000-DFFFFFFF Exklusiv NVIDIA GeForce 6500
Minne E0000000-EFFFFFFF Exklusiv Motherboard resources
Minne F8FFBC00-F8FFBFFF Exklusiv Intel(R) 82801FB/FBM USB2 Enhanced Host Controller - 265C
Minne F8FFC000-F8FFFFFF Exklusiv High Definition Audio Controller
Minne F9000000-F9FFFFFF Exklusiv NVIDIA GeForce 6500
Minne F9000000-FBEFFFFF Exklusiv Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Minne FA000000-FAFFFFFF Exklusiv NVIDIA GeForce 6500
Minne FBF00000-FBFFFFFF Exklusiv Intel(R) 82801 PCI Bridge - 244E
Minne FBFF8000-FBFFBFFF Exklusiv Texas Instruments 1394 OHCI Compliant Host Controller
Minne FBFFF400-FBFFF4FF Exklusiv Realtek RTL8139/810x Family Fast Ethernet NIC
Minne FBFFF800-FBFFFFFF Exklusiv Texas Instruments 1394 OHCI Compliant Host Controller
Minne FEC00000-FEC00FFF Exklusiv Motherboard resources
Minne FED13000-FED19FFF Exklusiv System board
Minne FED1C000-FED1FFFF Exklusiv Motherboard resources
Minne FED20000-FED8FFFF Exklusiv Motherboard resources
Minne FEE00000-FEE00FFF Exklusiv Motherboard resources
Minne FFB80000-FFBFFFFF Exklusiv Intel(R) 82802 Firmware Hub Device
Minne FFC00000-FFF7FFFF Exklusiv Motherboard resources
Minne FFF80000-FFFFFFFF Exklusiv Intel(R) 82802 Firmware Hub Device
Port 0000-000F Exklusiv Direct memory access controller
Port 0000-0CF7 Delad PCI bus
Port 0010-001F Exklusiv Motherboard resources
Port 0020-0021 Exklusiv Programmable interrupt controller
Port 0022-003F Exklusiv Motherboard resources
Port 0040-0043 Exklusiv System timer
Port 0044-005F Exklusiv Motherboard resources
Port 0061-0061 Exklusiv System speaker
Port 0062-0063 Exklusiv Motherboard resources
Port 0065-006F Exklusiv Motherboard resources
Port 0070-0071 Exklusiv System CMOS/real time clock
Port 0072-007F Exklusiv Motherboard resources
Port 0080-0080 Exklusiv Motherboard resources
Port 0081-0083 Exklusiv Direct memory access controller
Port 0084-0086 Exklusiv Motherboard resources
Port 0087-0087 Exklusiv Direct memory access controller
Port 0088-0088 Exklusiv Motherboard resources
Port 0089-008B Exklusiv Direct memory access controller
Port 008C-008E Exklusiv Motherboard resources
Port 008F-008F Exklusiv Direct memory access controller
Port 0090-009F Exklusiv Motherboard resources
Port 00A0-00A1 Exklusiv Programmable interrupt controller
Port 00A2-00BF Exklusiv Motherboard resources
Port 00C0-00DF Exklusiv Direct memory access controller
Port 00E0-00EF Exklusiv Motherboard resources
Port 00F0-00FF Exklusiv Numeric data processor
Port 0170-0177 Exklusiv ATA Channel 1
Port 01F0-01F7 Exklusiv ATA Channel 0
Port 0290-0297 Exklusiv Motherboard resources
Port 02F8-02FF Exklusiv Communications Port (COM2)
Port 0376-0376 Exklusiv ATA Channel 1
Port 0378-037F Exklusiv Printer Port (LPT1)
Port 03B0-03BB Delad NVIDIA GeForce 6500
Port 03B0-03BB Ej fastställd Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Port 03C0-03DF Delad NVIDIA GeForce 6500
Port 03C0-03DF Ej fastställd Intel(R) 915G/P/GV/GL/PL/910GE/GL PCI Express Root Port - 2581
Port 03F0-03F5 Exklusiv Standard floppy disk controller
Port 03F6-03F6 Exklusiv ATA Channel 0
Port 03F7-03F7 Exklusiv Standard floppy disk controller
Port 03F8-03FF Exklusiv Communications Port (COM1)
Port 0400-041F Exklusiv Intel(R) 82801FB/FBM SMBus Controller - 266A
Port 0480-04BF Exklusiv Motherboard resources
Port 04D0-04D1 Exklusiv Motherboard resources
Port 0680-06FF Exklusiv Motherboard resources
Port 0800-087F Exklusiv Motherboard resources
Port 0A00-0A7F Exklusiv Motherboard resources
Port 0D00-0D7F Exklusiv Motherboard resources
Port 0D00-FFFF Delad PCI bus
Port C880-C88F Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port CC00-CC03 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D000-D007 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D080-D083 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D400-D407 Exklusiv Intel(R) 82801FB Ultra ATA Storage Controllers - 2651
Port D480-D49F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 265B
Port D800-D81F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 265A
Port D880-D89F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 2659
Port DC00-DC1F Exklusiv Intel(R) 82801FB/FBM USB Universal Host Controller - 2658
Port E000-EFFF Exklusiv Intel(R) 82801 PCI Bridge - 244E
Port E800-E8FF Exklusiv Realtek RTL8139/810x Family Fast Ethernet NIC
Port FFA0-FFAF Exklusiv Intel(R) 82801FB/FBM Ultra ATA Storage Controllers - 266F
--------[ Inmatningsenheter ]-------------------------------------------------------------------------------------------
[ HID Keyboard Device ]
Tangentbordsegenskaper:
Tangentbordsnamn HID Keyboard Device
Tangentbordstyp IBM enhanced (101- or 102-key) keyboard
Tangentbordslayout Swedish
ANSI koder 1252 - @%SystemRoot%\system32\mlang.dll,-4612
OEM koder 850
Repetitionsfördröjning 1
Repetitionshastighet 31
[ HID-compliant mouse ]
Musegenskaper:
Musnamn HID-compliant mouse
Musknappar 3
Mushand Höger
Pekarhastighet 1
Dubbelklickningshastighet 500 msec
X / Y tröskelvärde 6 / 10
Antal rader för hjulrullning 3
Musfunktioner:
Spårning av aktivt fönster Avaktiverad
Klicklås Avaktiverad
Göm pekare vid skrivning Aktiverad
Mushjul Närvarande
Flytta pekare till aktiv knapp Avaktiverad
Eftersläpande pekarspår Avaktiverad
Sonar Avaktiverad
--------[ Skrivare ]----------------------------------------------------------------------------------------------------
[ Adobe PDF ]
Skrivaregenskaper:
Skrivarnamn Adobe PDF
Standardskrivare Nej
Delad som Ej delad
Skrivarport Documents\*.pdf
Skrivardrivrutin Adobe PDF Converter (v6.00)
Enhetsnamn Adobe PDF
Skrivarprocessor winprint
Skiljeblad Ingen
Tillgänglighet Alltid
Prioritet 1
Skrivarjobb i kö 0
Status Okänd
Pappersegenskaper:
Pappersstorlek A4, 210 x 297 mm
Orientering Porträtt
Utskriftskvalitet 1200 x 1200 dpi Color
[ Fax ]
Skrivaregenskaper:
Skrivarnamn Fax
Delad som Ej delad
Skrivarport SHRFAX:
Skrivardrivrutin Microsoft Shared Fax Driver (v4.00)
Enhetsnamn Fax
Skiljeblad Ingen
Tillgänglighet 02:00 - 02:00
Prioritet 1
Skrivarjobb i kö 0
Status Okänd
Pappersegenskaper:
Pappersstorlek Letter, 8.5 x 11 in
Utskriftskvalitet 200 x 200 dpi Mono
[ HP LaserJet P2015 PCL6 (Standard) ]
Skrivaregenskaper:
Skrivarnamn HP LaserJet P2015 PCL6
Standardskrivare Ja
Delad som HP LaserJet P2015 PCL6
Skrivarport 192.168.0.105
Skrivardrivrutin HP LaserJet P2015 PCL6 (v6.00)
Enhetsnamn HP LaserJet P2015 PCL6
Skrivarprocessor hpzppwn7
Skiljeblad Ingen
Prioritet 1
Skrivarjobb i kö 0
Status Offline
Pappersegenskaper:
Utskriftskvalitet 600 x 600 dpi Color
Skrivartillverkare:
Företagsnamn Hewlett-Packard Company
Produktinformation Link Removed
[ Microsoft XPS Document Writer ]
Skrivaregenskaper:
Skrivarnamn Microsoft XPS Document Writer
Delad som Ej delad
Skrivarport XPSPort:
Skrivardrivrutin Microsoft XPS Document Writer (v6.00)
Enhetsnamn Microsoft XPS Document Writer
Skiljeblad Ingen
Prioritet 1
Skrivarjobb i kö 0
Status Okänd
Pappersegenskaper:
--------[ Minneshastighet läs ]-----------------------------------------------------------------------------------------
P4EE 3733 MHz MSI P4N Diamond nForce4-SLI-Intel Dual DDR2-667 7630 MB/s
P4EE 3733 MHz Dell Dimension XPS i925XE Dual DDR2-533 6920 MB/s
Pentium EE 840 3200 MHz Intel D955XBK i955X Dual DDR2-667 6100 MB/s
Athlon64 3500+ 2200 MHz MSI K8N Neo2 Platinum nForce3-Ultra Dual PC3200 DDR 6030 MB/s
P4 540 3200 MHz Abit IC7-MAX3 i875P Dual PC3200 DDR 5780 MB/s
P4 560 3600 MHz Intel D925XCV i925X Dual DDR2-533 5570 MB/s
P4 560 3600 MHz Foxconn 915A01-P i915P Dual DDR2-533 5420 MB/s
Athlon64 FX-51 2200 MHz Asus SK8N nForce3Pro-150 Dual PC3200R DDR 5400 MB/s
P4 520 2800 MHz Soltek SL-PT880E-RL PT880 Dual PC3200 DDR 5370 MB/s
Athlon64 X2 4800+ 2400 MHz Asus A8N-SLI Deluxe nForce4-SLI Dual PC3200 DDR 5100 MB/s
P4 3000 MHz Intel D875PBZ i875P Dual PC3200 DDR 4880 MB/s
P4EE 3400 MHz Intel D925XCV i925X Dual DDR2-533 4480 MB/s
P4 2800 MHz Gigabyte GA-8S655TX Ultra SiS655TX Dual PC3200 DDR 4370 MB/s
P4 3000 MHz Intel D865PERL i865PE Dual PC3200 DDR 4070 MB/s
P4 3200 MHz Gigabyte GA-8TRS350MT RS350 Ext. Dual PC3200 DDR 3830 MB/s
Xeon 2800 MHz Asus PC-DL i875P Dual PC2700 DDR 3660 MB/s
P4 2400 MHz Iwill P4GB iE7205 Dual PC2100 DDR 3560 MB/s
P4 2400 MHz Intel D850EMV2 i850E Dual PC1066 RDRAM 3240 MB/s
Athlon64 3000+ 2000 MHz Gigabyte GA-K8N Pro nForce3-150 PC3200 DDR SDRAM 3050 MB/s
Athlon64 3200+ 2000 MHz MSI K8T Neo-FIS2R K8T800 PC3200 DDR SDRAM 2980 MB/s
P4 630 3000 MHz Unknown i915P Dual PC2700 DDR 2897 MB/s
Pentium M 730J 1600 MHz Acer TravelMate 4150 i915PM Dual DDR2-400 2880 MB/s
AthlonXP 3200+ 2200 MHz Shuttle FN45 nForce2-U400 PC3200 DDR SDRAM 2790 MB/s
AthlonXP 3200+ 2200 MHz Asus A7V880 KT880 Dual PC3200 DDR 2590 MB/s
P4 2533 MHz DFI NT72-SC i850E Dual PC800 RDRAM 2560 MB/s
AthlonXP 2700+ 2166 MHz Chaintech 7NJL1 nForce2-SPP Dual PC2700 DDR 2500 MB/s
Pentium M 1500 MHz Acer TravelMate 4500 i855GME Ext. PC2700 DDR SDRAM 2470 MB/s
AthlonXP 2700+ 2166 MHz Asus A7N8X nForce2-SPP Dual PC2700 DDR 2450 MB/s
P4 2533 MHz Gigabyte GA-8PE667 Ultra i845PE PC2700 DDR SDRAM 2450 MB/s
P4 3066 MHz Asus P4PE i845PE PC2700 DDR SDRAM 2400 MB/s
AthlonXP 3200+ 2200 MHz ASRock K7S8XE+ SiS748 PC3200 DDR SDRAM 2370 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2700 DDR SDRAM 2330 MB/s
AthlonXP 2600+ 2100 MHz MSI KT4V KT400 PC2700 DDR SDRAM 2270 MB/s
P4 2400 MHz Gigabyte GA-8GE667 Pro i845GE Int. PC2700 DDR SDRAM 2240 MB/s
Sempron 2600+ 1833 MHz ASRock K7VT4A+ KT400A PC2700 DDR SDRAM 2150 MB/s
P4 1300 MHz Dell Dimension 8100 i850 Dual PC600 RDRAM 2040 MB/s
Celeron 1700 MHz DFI PE21-EC P4X400 PC2100 DDR SDRAM 2020 MB/s
Celeron 2000 MHz Gigabyte GA-8PEMT4 i845PE PC2100 DDR SDRAM 2000 MB/s
AthlonXP 2100+ 1733 MHz Abit NF7 nForce2-SPP Dual PC2100 DDR 1990 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2100 DDR SDRAM 1960 MB/s
P4 1600 MHz Asus P4B266 i845D PC2100 DDR SDRAM 1940 MB/s
P4 1800 MHz MSI 845E Max i845E PC2100 DDR SDRAM 1940 MB/s
P4 2000 MHz Shuttle AV40 P4X266 PC2100 DDR SDRAM 1920 MB/s
AthlonXP 2200+ 1800 MHz Chaintech 7NJL1 nForce2-SPP PC2100 DDR SDRAM 1900 MB/s
Celeron 1700 MHz Asus P4S333-VM SiS650 Ext. PC2100 DDR SDRAM 1870 MB/s
Celeron 1800 MHz TriGem Imperial i845GL Int. PC2100 DDR SDRAM 1870 MB/s
AthlonXP 2000+ 1666 MHz Epox EP-8KHA+ KT266A PC2100 DDR SDRAM 1850 MB/s
P4 1700 MHz ASRock PE Pro SiS645 PC2100 DDR SDRAM 1810 MB/s
AthlonXP 1800+ 1533 MHz Abit AT7-MAX2 KT400 PC2100 DDR SDRAM 1790 MB/s
AthlonXP 2000+ 1666 MHz MSI KT3 Ultra-ARU KT333 PC2100 DDR SDRAM 1770 MB/s
AthlonXP 1800+ 1533 MHz ECS K7S5A SiS735 PC2100 DDR SDRAM 1710 MB/s
Athlon 1200 MHz Abit KG7 AMD760 PC2100 DDR SDRAM 1700 MB/s
Athlon 1200 MHz Asus A7M266 AMD760 PC2100 DDR SDRAM 1560 MB/s
AthlonXP 1500+ 1333 MHz Asus A7V266 KT266 PC2100 DDR SDRAM 1500 MB/s
Celeron 1700 MHz ECS P4S5A/DX+ SiS645DX PC133 SDRAM 1040 MB/s
AthlonXP 1700+ 1466 MHz AOpen AK73A KT133A PC133 SDRAM 990 MB/s
PIII-E 866 MHz Asus CUSL2 i815E Ext. PC133 SDRAM 980 MB/s
P4 1600 MHz Dell Dimension 4300 i845 PC133 SDRAM 950 MB/s
PIII-E 866 MHz ECS P6VAP-A+ ApolloPro133A PC133 SDRAM 840 MB/s
PIII-E 600 MHz Acorp 6V8633A ApolloPro266 PC2100 DDR SDRAM 770 MB/s
PIII-E 866 MHz Intel CC820 i820 PC100 SDRAM 760 MB/s
AthlonXP 1700+ 1466 MHz PCChips M810LR SiS730S Ext. PC133 SDRAM 740 MB/s
Athlon 600 MHz Asus K7M AMD-750 PC100 SDRAM 730 MB/s
Celeron 900 MHz MSI 815EP Pro i815EP PC100 SDRAM 710 MB/s
PIII 600 MHz Asus P2B i440BX PC133 SDRAM 670 MB/s
C3 1333 MHz VIA EPIA SP CN400 Int. PC3200 DDR SDRAM 550 MB/s
Duron 850 MHz Gigabyte GA-7IXE4 AMD750 PC100 SDRAM 460 MB/s
Celeron 466 MHz IBM 628848U i810 Int. PC66 SDRAM 390 MB/s
PII 266 MHz Intel DK440LX i440LX PC66 SDRAM 350 MB/s
K6-III 450 MHz Asus P5A ALADDiN5 PC100 SDRAM 290 MB/s
K6-III 400 MHz Epox EP-MVP3G-M MVP3 PC100 SDRAM 260 MB/s
K6-2 450 MHz Gigabyte GA-5AX ALADDiN5 PC100 SDRAM 260 MB/s
C3 800 MHz VIA EPIA PLE133 PC133 SDRAM 210 MB/s
PentiumMMX 166 MHz Asus TX97-E i430TX PC66 SDRAM 190 MB/s
PentiumPro 200 MHz Intel AP440FX i440FX 66 MHz FPM RAM 160 MB/s
C6 200 MHz M Technology R525 i430FX 66 MHz EDO RAM 60 MB/s
K6 266 MHz Asus SP97-V SiS5598 Int. 66 MHz EDO RAM 60 MB/s
Am5x86 133 MHz Gigabyte GA-5486AL ALi1489 EDO RAM 50 MB/s
--------[ Minneshastighet skriv ]---------------------------------------------------------------------------------------
P4EE 3733 MHz MSI P4N Diamond nForce4-SLI-Intel Dual DDR2-667 2980 MB/s
Athlon64 3500+ 2200 MHz MSI K8N Neo2 Platinum nForce3-Ultra Dual PC3200 DDR 2600 MB/s
Pentium EE 840 3200 MHz Intel D955XBK i955X Dual DDR2-667 2280 MB/s
P4 560 3600 MHz Intel D925XCV i925X Dual DDR2-533 2280 MB/s
P4 560 3600 MHz Foxconn 915A01-P i915P Dual DDR2-533 2200 MB/s
P4EE 3733 MHz Dell Dimension XPS i925XE Dual DDR2-533 2040 MB/s
Athlon64 FX-51 2200 MHz Asus SK8N nForce3Pro-150 Dual PC3200R DDR 1750 MB/s
P4 3000 MHz Intel D875PBZ i875P Dual PC3200 DDR 1750 MB/s
P4 540 3200 MHz Abit IC7-MAX3 i875P Dual PC3200 DDR 1740 MB/s
Athlon64 X2 4800+ 2400 MHz Asus A8N-SLI Deluxe nForce4-SLI Dual PC3200 DDR 1650 MB/s
P4EE 3400 MHz Intel D925XCV i925X Dual DDR2-533 1640 MB/s
P4 520 2800 MHz Soltek SL-PT880E-RL PT880 Dual PC3200 DDR 1550 MB/s
Xeon 2800 MHz Asus PC-DL i875P Dual PC2700 DDR 1540 MB/s
P4 2800 MHz Gigabyte GA-8S655TX Ultra SiS655TX Dual PC3200 DDR 1480 MB/s
P4 3000 MHz Intel D865PERL i865PE Dual PC3200 DDR 1440 MB/s
P4 2400 MHz Intel D850EMV2 i850E Dual PC1066 RDRAM 1330 MB/s
P4 630 3000 MHz Unknown i915P Dual PC2700 DDR 1267 MB/s
Athlon64 3200+ 2000 MHz MSI K8T Neo-FIS2R K8T800 PC3200 DDR SDRAM 1220 MB/s
AthlonXP 3200+ 2200 MHz Shuttle FN45 nForce2-U400 PC3200 DDR SDRAM 1120 MB/s
Athlon64 3000+ 2000 MHz Gigabyte GA-K8N Pro nForce3-150 PC3200 DDR SDRAM 1110 MB/s
P4 2533 MHz DFI NT72-SC i850E Dual PC800 RDRAM 1110 MB/s
AthlonXP 2700+ 2166 MHz Chaintech 7NJL1 nForce2-SPP Dual PC2700 DDR 1000 MB/s
AthlonXP 2700+ 2166 MHz Asus A7N8X nForce2-SPP Dual PC2700 DDR 980 MB/s
P4 3200 MHz Gigabyte GA-8TRS350MT RS350 Ext. Dual PC3200 DDR 970 MB/s
P4 2400 MHz Iwill P4GB iE7205 Dual PC2100 DDR 900 MB/s
AthlonXP 3200+ 2200 MHz Asus A7V880 KT880 Dual PC3200 DDR 880 MB/s
P4 2533 MHz Gigabyte GA-8PE667 Ultra i845PE PC2700 DDR SDRAM 860 MB/s
AthlonXP 2100+ 1733 MHz Abit NF7 nForce2-SPP Dual PC2100 DDR 810 MB/s
Pentium M 730J 1600 MHz Acer TravelMate 4150 i915PM Dual DDR2-400 780 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2700 DDR SDRAM 780 MB/s
AthlonXP 2200+ 1800 MHz Chaintech 7NJL1 nForce2-SPP PC2100 DDR SDRAM 760 MB/s
AthlonXP 3200+ 2200 MHz ASRock K7S8XE+ SiS748 PC3200 DDR SDRAM 750 MB/s
Celeron 1700 MHz DFI PE21-EC P4X400 PC2100 DDR SDRAM 750 MB/s
P4 1600 MHz Asus P4B266 i845D PC2100 DDR SDRAM 740 MB/s
AthlonXP 2600+ 2100 MHz MSI KT4V KT400 PC2700 DDR SDRAM 730 MB/s
P4 3066 MHz Asus P4PE i845PE PC2700 DDR SDRAM 700 MB/s
Celeron 1700 MHz Asus P4S333-VM SiS650 Ext. PC2100 DDR SDRAM 700 MB/s
P4 2400 MHz Gigabyte GA-8GE667 Pro i845GE Int. PC2700 DDR SDRAM 690 MB/s
P4 1700 MHz ASRock PE Pro SiS645 PC2100 DDR SDRAM 690 MB/s
Pentium M 1500 MHz Acer TravelMate 4500 i855GME Ext. PC2700 DDR SDRAM 680 MB/s
P4 2400 MHz Asus P4S533-E SiS645DX PC2100 DDR SDRAM 680 MB/s
P4 1800 MHz MSI 845E Max i845E PC2100 DDR SDRAM 660 MB/s
P4 1300 MHz Dell Dimension 8100 i850 Dual PC600 RDRAM 650 MB/s
P4 2000 MHz Shuttle AV40 P4X266 PC2100 DDR SDRAM 650 MB/s
Celeron 1800 MHz TriGem Imperial i845GL Int. PC2100 DDR SDRAM 650 MB/s
Celeron 2000 MHz Gigabyte GA-8PEMT4 i845PE PC2100 DDR SDRAM 640 MB/s
Sempron 2600+ 1833 MHz ASRock K7VT4A+ KT400A PC2700 DDR SDRAM 630 MB/s
AthlonXP 2000+ 1666 MHz MSI KT3 Ultra-ARU KT333 PC2100 DDR SDRAM 590 MB/s
AthlonXP 1800+ 1533 MHz Abit AT7-MAX2 KT400 PC2100 DDR SDRAM 560 MB/s
AthlonXP 2000+ 1666 MHz Epox EP-8KHA+ KT266A PC2100 DDR SDRAM 510 MB/s
AthlonXP 1800+ 1533 MHz ECS K7S5A SiS735 PC2100 DDR SDRAM 510 MB/s
Athlon 1200 MHz Abit KG7 AMD760 PC2100 DDR SDRAM 500 MB/s
Celeron 1700 MHz ECS P4S5A/DX+ SiS645DX PC133 SDRAM 490 MB/s
Athlon 1200 MHz Asus A7M266 AMD760 PC2100 DDR SDRAM 470 MB/s
AthlonXP 1500+ 1333 MHz Asus A7V266 KT266 PC2100 DDR SDRAM 430 MB/s
P4 1600 MHz Dell Dimension 4300 i845 PC133 SDRAM 350 MB/s
AthlonXP 1700+ 1466 MHz PCChips M810LR SiS730S Ext. PC133 SDRAM 350 MB/s
AthlonXP 1700+ 1466 MHz AOpen AK73A KT133A PC133 SDRAM 310 MB/s
Athlon 600 MHz Asus K7M AMD-750 PC100 SDRAM 300 MB/s
PIII 600 MHz Asus P2B i440BX PC133 SDRAM 260 MB/s
PIII-E 866 MHz Asus CUSL2 i815E Ext. PC133 SDRAM 240 MB/s
C3 1333 MHz VIA EPIA SP CN400 Int. PC3200 DDR SDRAM 200 MB/s
Duron 850 MHz Gigabyte GA-7IXE4 AMD750 PC100 SDRAM 200 MB/s
PIII-E 866 MHz ECS P6VAP-A+ ApolloPro133A PC133 SDRAM 190 MB/s
PIII-E 600 MHz Acorp 6V8633A ApolloPro266 PC2100 DDR SDRAM 190 MB/s
Celeron 900 MHz MSI 815EP Pro i815EP PC100 SDRAM 180 MB/s
PIII-E 866 MHz Intel CC820 i820 PC100 SDRAM 140 MB/s
Celeron 466 MHz IBM 628848U i810 Int. PC66 SDRAM 140 MB/s
C3 800 MHz VIA EPIA PLE133 PC133 SDRAM 130 MB/s
PII 266 MHz Intel DK440LX i440LX PC66 SDRAM 120 MB/s
K6-III 450 MHz Asus P5A ALADDiN5 PC100 SDRAM 120 MB/s
K6-III 400 MHz Epox EP-MVP3G-M MVP3 PC100 SDRAM 120 MB/s
PentiumMMX 166 MHz Asus TX97-E i430TX PC66 SDRAM 90 MB/s
K6-2 450 MHz Gigabyte GA-5AX ALADDiN5 PC100 SDRAM 80 MB/s
PentiumPro 200 MHz Intel AP440FX i440FX 66 MHz FPM RAM 80 MB/s
K6 266 MHz Asus SP97-V SiS5598 Int. 66 MHz EDO RAM 40 MB/s
Am5x86 133 MHz Gigabyte GA-5486AL ALi1489 EDO RAM 30 MB/s
--------[ Minnesfördröjning ]-------------------------------------------------------------------------------------------
Athlon64 3500+ 2200 MHz MSI K8N Neo2 Platinum nForce3-Ultra Dual PC3200 DDR 2-2-2-5 45.6 ns
Athlon64 3400+ 2200 MHz Chaintech VNF3-250 nForce3-250 PC3200 DDR SDRAM 2-2-2-5 48.4 ns
Athlon64 3500+ 2200 MHz Asus A8V K8T800Pro Dual PC3200 DDR 2.5-3-3-7 58.8 ns
Athlon64 X2 4800+ 2400 MHz Asus A8N-SLI Deluxe nForce4-SLI Dual PC3200 DDR 2.5-3-3-8 62.2 ns
Athlon64 3800+ 2400 MHz Gigabyte GA-K8NSNXP-939 nForce3-Ultra Dual PC2700 DDR 2-3-3-7 67.8 ns
Opteron 246 2000 MHz Iwill DK8N nForce3Pro-250 Dual PC3200R DDR 2.5-3-3-8 68.0 ns
P4EE 3733 MHz MSI P4N Diamond nForce4-SLI-Intel Dual DDR2-667 4-4-4-15 76.3 ns
P4 3000 MHz Epox EP-4PCA3+ i875P + PAT Dual PC3200 DDR 2.5-3-3-8 78.9 ns
P4 2600 MHz Asus P4P800 i865PE + PAT Dual PC3200 DDR 2.5-3-3-6 79.7 ns
Opteron 248 2200 MHz MSI K8T Master1-FAR K8T800 Dual PC2100R DDR 2-3-3-6 83.1 ns
P4 540 3200 MHz Abit AA8-DuraMAX i925X Dual DDR2-533 3-3-3-8 84.5 ns
Pentium EE 840 3200 MHz Intel D955XBK i955X Dual DDR2-667 4-4-4-11 85.6 ns
P4 540 3200 MHz Epox EP-5EGA+ i915G Ext. Dual PC3200 DDR 2-2-2-5 86.7 ns
Xeon 2800 MHz Asus PC-DL i875P + PAT Dual PC2700 DDR 2-3-3-5 94.9 ns
Pentium M 1500 MHz Acer TravelMate 4500 i855GME Ext. PC2700 DDR SDRAM 2.5-3-3-7 101.0 ns
P4 3000 MHz Intel D865PERL i865PE Dual PC3200 DDR 3-3-3-8 101.4 ns
Pentium M 730J 1600 MHz Acer TravelMate 4150 i915PM Dual DDR2-400 3-3-3-8 101.9 ns
AthlonXP 3100+ 2200 MHz ASRock K7S8XE SiS748 PC3200 DDR SDRAM 2.5-3-3-5 102.2 ns
AthlonXP 2500+ 1833 MHz Asus A7N8X-E nForce2-U400 PC2700 DDR SDRAM 2.5-3-3-7 105.4 ns
P4 3066 MHz MSI 848P Neo-S i848P PC2700 DDR SDRAM 2.5-3-3-7 115.1 ns
P4 2600 MHz Asus P4P800 i865PE Dual PC3200 DDR 2.5-4-4-7 117.8 ns
P4 630 3000 MHz Unknown i915P Dual PC2700 DDR 2.5-4-4-7 119.3 ns
P4 2400 MHz Asus P4T533 i850E Dual PC1066 RDRAM - 121.8 ns
P4 3200 MHz Gigabyte GA-8TRS350MT RS350 Int. Dual PC3200 DDR 3-3-3-8 125.2 ns
Sempron 2600+ 1833 MHz ASRock K7VT4A+ KT400A PC2700 DDR SDRAM 2.5-3-3-7 131.5 ns
P4 2533 MHz DFI NT72-SC i850E Dual PC800 RDRAM - 150.8 ns
C3 1333 MHz VIA EPIA SP CN400 Int. PC3200 DDR SDRAM 2.5-3-3-8 161.3 ns
PIII-E 600 MHz Acorp 6V8633A ApolloPro266 PC2100 DDR SDRAM 2.5-3-3-6 166.8 ns
Celeron 2400 MHz Gigabyte GA-8TRS350MT RS350 Int. Dual PC3200 DDR 3-3-3-8 169.2 ns
C3 800 MHz VIA EPIA PLE133 PC133 SDRAM 3-3-3-6 178.5 ns
Duron 1300 MHz Asus A7V KT133 PC133 SDRAM 3-3-3-6 182.6 ns
AthlonXP 1800+ 1533 MHz Gigabyte GA-7DXE AMD760 PC2100 DDR SDRAM 2.5-3-3-7 191.3 ns
Celeron 2000 MHz Abit TH7II i850 Dual PC600 RDRAM - 191.8 ns
PIII 450 MHz Intel VC820 i820 PC600 RDRAM - 209.0 ns
PIII Xeon 550 MHz IBM Netfinity 8500R Profusion PC100R SDRAM - 221.0 ns
K6-III 400 MHz Epox EP-MVP3G-M MVP3 PC100 SDRAM 2-2-2-5 248.5 ns
PII 266 MHz Intel DK440LX i440LX PC66 SDRAM 3-2-2-6 272.9 ns
K6-2 500 MHz PCChips M577 MVP3 PC100 SDRAM 2-3-3-6 286.8 ns
--------[ Debug - PCI ]-------------------------------------------------------------------------------------------------
B00 D00 F00: Intel 82915P Memory Controller Hub [B-1]
Offset 00: 86 80 80 25 06 00 90 30 04 00 00 06 00 00 00 00
Offset 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 80 25
Offset 30: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 00 90 D1 FE 00 40 D1 FE 00 00 00 E0 00 80 D1 FE
Offset 50: 00 00 00 00 03 00 00 B8 00 00 00 00 00 00 00 00
Offset 60: 01 30 D1 FE 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 10 11 11 00 00 33 33 00 00 00 00 00 A0 0A 38 00
Offset A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
Offset E0: 09 00 09 21 42 B3 9B 88 02 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00
B00 D01 F00: Intel 82915P PCI Express Root Port [B-1]
Offset 00: 86 80 81 25 07 01 10 00 04 00 04 06 08 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 01 01 00 F0 00 00 00
Offset 20: 00 F9 E0 FB 00 B8 F0 DF 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 88 00 00 00 00 00 00 00 10 01 1A 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02
Offset 80: 01 90 02 C8 00 00 00 00 0D 80 00 00 86 80 00 00
Offset 90: 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset A0: 10 00 41 01 00 00 00 00 00 00 00 00 01 2D 01 02
Offset B0: 40 00 01 11 80 25 80 00 C0 01 48 00 00 00 00 00
Offset D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 01 00 00 00 00 00 00 00 04 00 00 00 00 00
B00 D1B F00: Intel 82801FB ICH6 - High Definition Audio Controller [B-1]
Offset 00: 86 80 68 26 06 00 10 00 03 00 03 04 08 00 00 00
Offset 10: 04 C0 FF F8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 11 34 26 58
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00
Offset 40: 03 00 00 00 07 00 00 00 00 00 00 00 00 00 00 00
Offset 50: 01 60 42 C8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 60: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 70: 10 00 91 00 00 00 00 00 00 08 10 00 00 00 00 00
Offset 90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 80 0F 03 00 00 00 00 00
B00 D1D F00: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 58 26 05 00 80 02 03 00 03 0C 00 00 80 00
Offset 20: 01 DC 00 00 00 00 00 00 00 00 00 00 86 80 58 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 17 01 00 00
Offset 60: 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C0: 00 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B00 D1D F01: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 59 26 05 00 80 02 03 00 03 0C 00 00 00 00
Offset 20: 81 D8 00 00 00 00 00 00 00 00 00 00 86 80 59 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 13 02 00 00
B00 D1D F02: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 5A 26 05 00 80 02 03 00 03 0C 00 00 00 00
Offset 20: 01 D8 00 00 00 00 00 00 00 00 00 00 86 80 5A 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 12 03 00 00
B00 D1D F03: Intel 82801FB ICH6 - USB Universal Host Controller [B-1]
Offset 00: 86 80 5B 26 05 00 80 02 03 00 03 0C 00 00 00 00
Offset 20: 81 D4 00 00 00 00 00 00 00 00 00 00 86 80 5B 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 10 04 00 00
B00 D1D F07: Intel 82801FB ICH6 - Enhanced USB2 Controller [B-1]
Offset 00: 86 80 5C 26 06 00 90 02 03 20 03 0C 00 00 00 00
Offset 10: 00 BC FF F8 00 00 00 00 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 5C 26
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00
Offset 50: 01 58 C2 C9 00 80 00 00 0A 00 A0 20 00 00 00 00
Offset 60: 20 20 FF 01 00 00 00 00 01 00 00 00 00 00 00 C0
Offset 70: 00 00 FF 3F 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00
Offset D0: 00 00 00 00 00 AA FF 00 55 55 FF 00 20 00 00 00
Offset F0: 00 80 00 09 88 8C 40 00 80 0F 03 00 86 17 00 00
B00 D1E F00: Intel 82801FB I/O Controller Hub 6 (ICH6) [B-1]
Offset 00: 86 80 4E 24 07 01 10 48 D3 01 04 06 00 00 01 00
Offset 10: 00 00 00 00 00 00 00 00 00 02 02 20 E0 E0 80 F2
Offset 20: F0 FB F0 FB F1 FF 01 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 FF 00 06 00
Offset 40: 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00
Offset 50: 0D 00 00 00 86 80 4E 24 00 00 00 00 00 00 00 00
B00 D1F F00: Intel 82801FB ICH6 - LPC Bridge [B-1]
Offset 00: 86 80 40 26 07 00 00 02 03 00 01 06 00 00 80 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 86 80 40 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 40: 01 08 00 00 80 00 00 00 81 04 00 00 10 00 00 00
Offset 60: 8A 8A 85 8B D0 00 00 00 80 80 80 85 00 00 00 00
Offset 80: 10 00 0F 14 01 0A 00 00 01 0D 00 00 00 00 00 00
Offset A0: 20 02 00 00 39 00 00 00 00 00 00 00 00 03 00 00
Offset B0: 00 00 00 00 00 00 00 00 00 00 01 08 00 00 00 00
Offset D0: 33 22 11 00 67 45 00 00 C0 80 00 00 00 00 00 00
Offset F0: 01 C0 D1 FE 00 00 00 00 80 0F 03 00 00 00 00 00
B00 D1F F01: Intel 82801FB ICH6 - ATA-100 IDE Controller [B-1]
Offset 00: 86 80 6F 26 05 00 80 02 03 8A 01 01 00 00 00 00
Offset 10: 01 00 00 00 01 00 00 00 01 00 00 00 01 00 00 00
Offset 20: A1 FF 00 00 00 00 00 00 00 00 00 00 86 80 6F 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00
Offset 40: 33 E3 00 80 0B 00 00 00 03 00 22 00 00 00 00 00
Offset C0: 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F02: Intel 82801FB ICH6 - Serial-ATA/150 IDE Controller [B-1]
Offset 00: 86 80 51 26 05 00 B0 02 03 8F 01 01 00 00 00 00
Offset 10: 01 D4 00 00 81 D0 00 00 01 D0 00 00 01 CC 00 00
Offset 20: 81 C8 00 00 00 00 00 00 00 00 00 00 86 80 51 26
Offset 30: 00 00 00 00 70 00 00 00 00 00 00 00 13 02 00 00
Offset 40: 70 C0 77 E3 BB 00 00 00 0E 00 10 11 00 00 00 00
Offset 50: 00 00 00 00 F0 E0 00 00 00 00 00 00 00 00 00 00
Offset 70: 01 00 02 40 00 00 00 00 00 00 00 00 00 00 00 00
Offset 80: 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 90: 00 00 EF 00 82 01 80 00 00 00 00 00 00 00 00 00
Offset C0: 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 00
B00 D1F F03: Intel 82801FB ICH6 - SMBus Controller [B-1]
Offset 00: 86 80 6A 26 01 00 80 02 03 00 05 0C 00 00 00 00
Offset 20: 01 04 00 00 00 00 00 00 00 00 00 00 86 80 6A 26
Offset 30: 00 00 00 00 00 00 00 00 00 00 00 00 0A 02 00 00
Offset 40: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B01 D00 F00: nVIDIA NV44 Video Adapter
Offset 00: DE 10 60 01 07 00 10 00 A1 00 00 03 08 00 00 00
Offset 10: 00 00 00 FA 0C 00 00 D0 00 00 00 00 04 00 00 F9
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 30: 00 00 00 00 60 00 00 00 00 00 00 00 10 01 00 00
Offset 50: 01 00 00 00 01 00 00 00 CE D6 23 00 00 00 00 00
Offset 60: 01 68 02 00 00 00 00 00 05 78 80 00 00 00 00 00
Offset 70: 00 00 00 00 00 00 00 00 10 00 01 00 C0 04 2C 01
Offset 80: 10 28 00 00 01 2D 01 00 48 00 01 11 00 00 00 00
Offset F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B02 D07 F00: Texas Instruments TSB43AB22 1394A-2000 OHCI PHY/Link-Layer Controller
Offset 00: 4C 10 23 80 16 00 10 02 00 10 00 0C 08 40 00 00
Offset 10: 00 F8 FF FB 00 80 FF FB 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 4C 10 26 80
Offset 30: 00 00 00 00 44 00 00 00 00 00 00 00 13 01 02 04
Offset 40: 00 00 00 00 01 00 02 7E 00 80 00 00 00 00 00 00
Offset E0: 00 00 00 00 00 00 00 00 00 00 00 00 88 00 00 00
Offset F0: 10 00 00 00 82 10 00 00 4C 10 26 80 00 00 00 00
B02 D0E F00: Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C]
Offset 00: EC 10 39 81 07 00 90 02 10 00 00 02 00 40 00 00
Offset 10: 01 E8 00 00 00 F4 FF FB 00 00 00 00 00 00 00 00
Offset 20: 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81
Offset 30: 00 00 00 00 50 00 00 00 00 00 00 00 12 01 20 40
Offset 50: 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00
PCI-8086-2580: Intel i910/915/925/945/955/E7221/E7230 MMR
Offset 100: 10 20 28 28 00 00 00 00 44 03 00 00 3F 00 00 00
Offset 110: E8 20 54 86 22 69 70 01 FF 03 00 00 FF 01 FF 03
Offset 120: 05 2A 00 40 00 05 00 C2 F0 01 00 00 00 00 00 00
Offset 130: C4 06 00 00 6D 06 1A 87 10 00 01 02 04 08 00 00
Offset 140: 00 00 00 00 00 00 00 00 01 01 02 06 03 00 00 00
Offset 150: 32 9E 35 D2 76 B6 AB EA 00 25 00 00 00 00 00 00
Offset 160: 00 00 00 00 20 00 00 00 55 AA 00 22 98 87 20 20
Offset 170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset 180: 10 20 28 28 00 00 00 00 44 03 00 00 3F 00 00 00
Offset 190: E8 20 54 86 22 69 70 01 FF 03 00 00 FF 01 FF 03
Offset 1A0: 05 2A 00 40 00 00 00 00 00 00 00 00 00 00 00 00
Offset 200: 02 02 0F 00 00 00 00 00 20 01 02 04 18 00 00 00
Offset 210: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C00: 12 00 00 20 01 01 01 01 00 00 00 00 00 00 00 00
Offset C10: 00 00 00 00 03 00 80 00 00 00 00 00 5A 5A 00 00
Offset C20: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C30: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C40: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C50: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C60: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C70: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset C90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CA0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CB0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CC0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CD0: 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00 00
Offset CE0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Offset CF0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
--------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------
C000:0000 U.w.K7400.L.w.VIDEO ......W...IBM VGA Compatible........08/30/05
C000:0040 .......................................".........PMIDl.o.......
C000:0080 [email protected]...........@...........J!............
C000:00C0 ................................................................
C000:0100 ....PCIR..`.........w.......NVIDIA GeForce 6500 VGA BIOS...VGA B
C000:0140 IOS..........................................Version 5.44.02.41T
C000:0180 3H1....Copyright (C) 1996-2004 NVIDIA Corp......................
C000:01C0 .................................nv44 Board - p280h6 ..........
C000:0200 ....Chip Rev ...........BIT......G2.....B.....C.....D.....I...
C000:0240 ..L.....t.....M.....N.....P.....S.....T.....U.....V.....c.....i.
C000:0280 $.......A.D.........00/00/00..\\.........[X/y\0...(]:]B]b].].]:]
C000:02C0 T................. ..]....f.......I.......BQ.....Pm....(./.!/#..
C000:0300 #.....\.e5H5..A.D..`.6q..>D.]08/05/05..............1.....#.....
C000:0340 E...E.c.I...........Z.......>.......E...j...Z...H.........a.....
C000:0380 .Ye.H.B.B.B.......B.n.4...q.B.B.t.......x.4...T.f`...(].........
C000:03C0 .......u..fa....f`3....fa....C.>....4.......u.........8...t.....
--------[ Debug - Unknown ]---------------------------------------------------------------------------------------------
Motherboard 63-0100-009999-00101111-102604-GrantsD$I501000_BIOS DATE: 10/26/04 18:56:58 VER: 08.00.11 P5I915P(G) BIOS V1.3 OCT.26,2004
Motherboard DMIMOBO: To be filled by O.E.M. To be filled by O.E.M.
Motherboard DMISYS: To Be Filled By O.E.M. To Be Filled By O.E.M.
Motherboard Unknown
Optical BENQ DVD LS DW1655 ATA Device
Those this help?
The names of actual companies and products mentioned herein may be the trademarks of their respective owners.
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,626
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,626
So far I get this:
Link Removed - Invalid URL
So try this link:
Intel® Driver Update Utility for Audio drivers for Intel® Desktop Boards - Check for the latest driver
Intel said:Where do I get an audio driver for my chipset?
If you have an Intel® motherboard, you can download the latest audio driver for your motherboard.
If your computer uses the Intel® integrated graphics controller and has an HDMI port, you can download the latest graphics driver for your Intel chipset; installing the graphics driver will also install the HDMI audio driver.
Note If you are using Microsoft Windows XP*, you may need to first install KB888111.exe, the Microsoft* UAA High Definition Audio Package version 1.0a.
In all other cases, Intel does not provide an audio driver for your chipset. For drivers and technical support, use the following resources.
Intel® High Definition Audio - the driver is a common operating system driver provided by Microsoft*
AC'97 - contact your system or motherboard manufacturer
CNR and AMR sound cards - contact your sound card manufacturer (Note: a CNR card refers to a Communications and Networking Riser card, an AMR card refers to an Audio and Modem Riser card)
PCI sound cards - contact your sound card manufacturer
So try this link:
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,626
1. In Device Manager, right-click your HD audio, and then click Uninstall to remove the device.
2. Restart your computer. After you log on, you should receive a New Hardware Found dialog box with Sound device listed as the description and the Found New Hardware Wizard starts.
3. Click Next to start the wizard.
4. Click search for suitable driver, and then click Next.
5. Click to clear all of the search internet option check boxes, and then click Next.
6. Click Finish when done.
- Thread Author
- #52
Realy?Wow! I think we have a winner for the longest post in Windows7forums.com history..![]()
- Thread Author
- #53
I've tride that several times1. In Device Manager, right-click your HD audio, and then click Uninstall to remove the device.
- Joined
- Aug 28, 2007
- Messages
- 36,160
View attachment 5403 What should i do now?
I'd try running this app: Link Removed
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,626
The problem is that support for you audio card is discontinued. And it looks like Microsoft doesn't have a standard driver for this card either.
What you may want to try is to install HD Audio Vista x64 driver on 7 in Vista compatibility mode.
Everest report shows that you have a notebook pc, so try searching your notebook manufacturer's site.
Your i915p onboard audio is Intel 82801FB ICH6 - High Definition Audio Controller
cybercore
- Joined
- Jul 7, 2009
- Messages
- 15,626
There is no 7 compatible driver for your audio card, so how to fix it ?
1. Buy an external audio card
2. Try to install HD Audio Vista x64 driver (if you have one) on 7 in Vista compatibility mode.
3. Try searching your notebook manufacturer's support site for drivers.
- Joined
- Aug 28, 2007
- Messages
- 36,160
Similar threads
- Article
- Replies
- 0
- Views
- 794
- Article
- Replies
- 0
- Views
- 17K
- Article
- Replies
- 0
- Views
- 1K
- Question
- Replies
- 1
- Views
- 1K
- Replies
- 1
- Views
- 1K
