The thread discusses a user experiencing communication errors with their Canon MP287 scanner and printer when attempting to scan, which was temporarily fixed by disabling the 'Enhanced host controller' under USB in device manager. However, this workaround significantly reduced transfer speeds for external drives. A suggested solution was to visit the Canon support site and download the appropriate driver for their OS, while another user humorously suggested using Paint as an alternative method. Overall, the thread highlights troubleshooting steps and potential workarounds for hardware communication issues.
Joji90
I have a Canon mp287 printer and scanner, when I press the scan button I get an error saying 'cannot communicate with the scanner' Link Removed (screenshot attached). I found a solution to this problem by disabling 'Enhanced host controller' under USB in device manager. Link Removed(screenshot attached), but after I disable this enhanced host controller USB menu, it affects the whole performance of the transfer to EHDand pendrives (transfer speed of around 700kb/s,when it used to be around 30mbps for my External hard drive) .. Can anybody help me with an alternate solution..? Lots of people have reported this problem but couldn't find a working solution yet.
whs
Try Paint
An image from 'Scanner not working'. The Paint app's file menu shows an option 'From scanner or camera' highlighted but grayed out.
