Christianplet
Hi
I have
Creative SB Live! 5.1 Sound Card
but i have a echo on my windows ore 3d sound ?
Howe can i get that to gow avay ?
Thx Link Removed Link Removed due to 404 Error
To resolve the echo issue or 3D sound problem you are experiencing with your Creative SB Live! 5.1 Sound Card on Windows, you can try the following steps:
Adjust Sound Settings:​
  • Speaker Configuration:
  • Make sure that the speaker configuration is set correctly to 5.1 (if using a 5.1 speaker setup).
  • Enhancements:
  • Disable any audio enhancements in the sound settings. Right-click on the sound icon in the taskbar, select "Playback devices," locate your sound card, and open its properties. In the enhancements tab, uncheck all options.
Update Drivers:​
  • Driver Update:
  • Ensure that you have the latest drivers installed for your sound card. Visit the official Creative website to download...
  • Enhancements:
Update Drivers:​
  • Driver Update:
  • Ensure that you have the latest drivers installed for your sound card. Visit the official Creative website to download and install the latest drivers for your sound card model.
Additional Steps:​
  • Noise Cancellation:
  • Experiment with noise cancellation or echo cancellation features if available in the sound settings of your sound card.
  • Software Tweaks:
  • Some sound cards have specific software utilities that can help with sound optimization. Explore these options for any advanced settings that might address the echo issue.
Troubleshooting Tips:​
  • Testing:
  • Test your sound card on another system to see if the issue persists. This can help determine if the problem lies with the sound card or the Windows system.
  • Windows Updates:
  • Ensure that Windows is up to date with the latest updates, as sometimes sound issues can be resolved through system updates.
  • Compatibility Mode:
  • Try running the sound card drivers in compatibility mode if you are using an older version of Windows. These steps should help you troubleshoot and potentially resolve the echo or 3D sound issue you are facing. If the issue persists, feel free to provide more details for further assistance.
