pahrump808
I just installed Win 7 Ultimate on my system. It was previously Win XP. As long as I leave my wired connection pluged in my system does not hang. There are no hardware conflicts. Eveything else works. If I unplug my wired connection and use just the wireless connection the system hangs, sometimes at boot or shortly after starting. The wireless does work. As long as my wired is connected I can go for ever with no issues. Any suggestion are greatly appreciated. Thankyou.
Version 6.1.7600 Build 7600
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name LAPTOP
System Manufacturer Gateway
System Model S-7310M
System Type X86-based PC
Processor Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz, 2000 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/Date Phoenix Technologies LTD 71.13, 4/26/2007
SMBIOS Version 2.4
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7600.16385"
User Name Laptop\Pahrumo808
Time Zone Hawaiian Standard Time
Installed Physical Memory (RAM) 2.00 GB
Total Physical Memory 1.99 GB
Available Physical Memory 1.03 GB
Total Virtual Memory 3.98 GB
Available Virtual Memory 2.99 GB
Page File Space 1.99 GB
Page File9 C:\pagefile.sys
Intel(R) Pro/1000 PL Nettwork Connection
Intel(R) Pro/Wireless 3945ABG Network Connection
TorrentG
Banned
Hey there...
This should be very simply. Visit Intel's website for the latest wireless adapter and install.
pahrump808
Aloha From Hawaii
Thanks for the info. I did down load the wired driver from intel and still had the problem. Didn't think to do the same with the wireless. Just did and it did not resolve issue.
Thanks
bobalazs
Try removing the current wireless connection and make a new one, also reset your router.
