The thread discusses a user experiencing difficulty in configuring dual monitors after upgrading to an EVGA GeForce GTX 650 Ti Boost, primarily due to incompatible DVI connections and monitor types. The original poster seeks advice on connecting an older VGA monitor via DVI-I, but contributors clarify that DVI-D ports only carry digital signals and can't support VGA without the proper DVI-I connection or adapter. The overall sentiment suggests that resolving this issue may require purchasing compatible equipment or reverting to previous hardware, with some advice on BIOS limitations and potential solutions.
seekermeister
Honorable Member
Ever since I upgraded my video card (EVGA GeForce GTX 650 Ti Boost), I haven't been able to get both of my monitors on the desktop to work the way that I want. Nothing is wrong with either monitor, but my secondary monitor is an old Dell VGA LCD, which I've only gotten to work on this card when connected to the upper DVI-I connector, but when connected in that fashion, the BIOS only displays on it, rather than my main monitor.
Since the Dell is VGA, it requires an adapter to connect to the graphics card, but the one that works in the DVI-I doesn't work in the lower DVI-D connector, because the latter doesn't permit insertion of the 4 pins around the single blade. I got one like this:
Which plugs in fine, and to a degree works, because the monitor seems to think it is connected, but the computer doesn't, all I get on it is a black screen. The Device Manager, Nvidia Control panel nor Ultramon see it either.
So I tried finding a DVI-I 24-1 adapter, but what I've found, the picture shows as having the 4 pins around the single blade, that I'm trying to get rid of:
Can someone help clear up my confusion?
Using DVI or VGA in combination with either HDMI or DisplayPort will solve your dual monitor problem. Getting a monitor with HDMI connector will easily solve your problem as there are plenty to choose from. Any HDMI monitor will work. There are not a lot of monitors in the market with DisplayPort (DP). But I think they are more expensive. Most of the time, the DP port is used to run a 3rd monitor using an active displayport to HDMI/DVI adapter. That is exactly how I am running my third monitor. The adapter has to be active. Non-active adapter will not fire up a 3rd monitor.
Josephur
Windows Forum Admin
Go to eBay since you only need a few, look for Rubycon 1000uf 16v.
seekermeister
Honorable Member
Thread Author #63
Another question popped into my head...does this capacitor have polarity? If so, how do you determine which lead is which?
EDIT: I figured out my polarity question, but still another has arisen...the old capacitor's specs are not printed, they are pressed into the cover in extremely small characters, so I missed a line of data, even though I used my magnifying lamp to examine it the first time. This line is 034B, which if I understand, the B indicates a tolerance of .10 percent, but the ad for the capacitors that I ordered said nothing about a tolerance:
Obviously, a proper match is desirable, but how critical is it?
seekermeister
Honorable Member
Thread Author #64
I got a reply from the seller of the caps regarding their tolerance:
I suspect +/- 20% at room temperature, but I don't know for sure. They are YK - you can do a search similar to this:
But this is +85C variant, I suppose the 105C variant would be similar. Keep in mind any electrolytic is for bulk capacitance and should never be used for timing or low impedance (high frequency) filtering. see Link Removed
I pulled three from the batch at room temperature and they read 1060, 1090 and 1185 uF.
But as far as I can see, the old capacitor doesn't have the letters YK on it, and the explanations on the link above, doesn't speak of it as having anything to do with tolerance as the seller suggested...in fact it doesn't say anything about them, even though they appear in some of the pictures. The readings that he obtained from the samples does seem to support that their tolerance is ~20%, but how can I verify that tolerance is acceptable?
Josephur
Windows Forum Admin
I wouldn't worry about 20% so much, if above that then yes. Caps usually have a 10% to 20% tolerance.
seekermeister
Honorable Member
Thread Author #66
Good, then I won't need to order some others. The next challenge for me is to solder them to the board. I always feel as though I need three hands.
Josephur
Windows Forum Admin
it shouldn't be too hard, you will want to remove the board completely and have something hold it while you desolder then solder then new one(s) in place.
seekermeister
Honorable Member
Thread Author #68
The only thing I have to hold it is a Panavice, but I don't have a circuit board attachment for it. I do have the rubber jaws, which might work, if I can find an area I can clamp to without damaging the board.
seekermeister
Honorable Member
Thread Author #69
I believe that I succeeded in soldering the capacitor, but that leaves one problem that I'm struggling with. The little wire that I broke off from the connector on the LCD itself. The connector is a small 3 pin connector, that only the two outer pins are used, one with a red wire and the other with white. It is the white wire that is broken. I pulled the broken piece out of the connector, and as far as I can tell, no solder was used. I think it is one in which the wire is supposed to only be pushed in and caught by an internal locking device. The problem is that I can't seem to even start the wire into the hole, even though I stripped a small length of the insulation. I even tried by using needle nose pliers, so that I could grip the wire up close, but it still bends before going in. Is there a trick to making this work?
Josephur
Windows Forum Admin
Does the connectors solder pins come out the back side of the PCB?
seekermeister
Honorable Member
Thread Author #71
No. The connector is on the wire itself, kind of like a fan connector, only thinner and wider.
seekermeister
Honorable Member
Thread Author #73
Like I said before, I would but every time I try, all I get is a blurry overexposed shot, which I don't think would help. I wish this were some kind of standard connector that I'm familiar with, so I could just buy another, but it isn't, and I don't know what to call it to do a Google.
Josephur
Windows Forum Admin
Most connectors do adhere to some kind of standard however without seeing it....
seekermeister
Honorable Member
Thread Author #75
I have yet to find a picture of the portion of the connector that fits on the cable, but the picture below shows where they fit...the two white connectors on the left edge of the board:
An image from 'Multiple Monitors'. A circuit board with various electronic components on a red surface.
I don't imagine that is enough to indicate what is needed though.
seekermeister
Honorable Member
Thread Author #76
I doubt that it will help any, but since...thanks to Badrobot, I now have a camera that works pretty well for the purpose, and I wanted to try it out, here is a shot of the connector with the broken wire:
An image from 'Multiple Monitors'. White 3-pin electrical connector attached to a pink wire on a gray surface.
I just need to know what to call it, so I might be able to Google a replacement...preferably one with the wires already soldered in place.
