I've been having some issues with my battery. I have a Sager X8100 gaming laptop. Specs are i7 Q840, dual Nvidia 285m in SLI, 8gbs RAM, windows 7 64 bit. Its a fairly old rig.. 2009 or 2010 not sure which. I bought it used in 2012. Had a 1 year warranty. I noticed the battery wouldn't keep it running for more than 10 minutes if it was unplugged. I took it back and had them order a battery. They said the battery was dead on arrival. And that they were having to order off of ebay due to the manufacturer not offering them anymore. There werent any more available at the time. They told me they would keep an eye out and call me when they got one ordered. They never called lol.. I honestly wasn't worried about it at the time as this is an 18" laptop that weighs a ton.. Its not something I'd be going to chill at Starbucks with. I knew I'd never care to use it without it plugged in. And Didn't have any plans of ever reselling it. And I didn't know the battery could cause issues with it plugged in at the time. Anyways long story short I'm starting to have some pretty serious issues due to my battery issue. I play a lot of games. When playing something graphically intensive it will randomly and immediately shut down without warning. I don't think anything is overheating.. Gpu temps stay around 50c. Also just recently its gotten to where it will not run off the battery at all. If I unplug the charger it will immediately shutdown without warning. I have a warning in the system tray that always says the same thing... "91% available (plugged in, charging) consider replacing your battery." It never goes above or below 91%.
I googled it and found that some people have had similar issues and it turned out to be a problem or wrong power setting within windows rather than an actual piece of hardware. One thing I found said to put the computer on a portable/laptop power scheme.. I can't find it. All I see is Balanced, High Performance, and Power Saver. The cost of a battery for this thing runs around $150 to $200... I'd rather put that money towards a new pc if the battery is actually bad. But I was wondering if its not the battery since the other one that was ordered turned out to be "DOA". I've recently done a lot of stuff to my computer trying to get SP1 installed that could have something to do with the issues I'm having now. As I don't think it was this bad before hand. One of the things that could have done it was I recently went through and uninstalled every windows update that it would let me uninstall. I've reinstalled all updates that windows has came up with through a "check for updates" or multiple checks. I had 198 updates now I only have 108. And If it matters, no I still haven't got friggin SP1 to install and I'm at wits end with it.
Some things that may or may not matter: I never run both GPU's. I noticed when I first bought this laptop that it gets significantly hotter while running both cards in SLI. So I've kept it disabled to try to prolong the life of it. I've tried every power plan and get the same results. I run MSI afterburner while gaming to UNDERclock my gpu just a little bit to keep it from overheating and to keep from getting other error messages and blue screens I've gotten in the past. It will shutdown with or without MSI afterburner running.
Since the charge level always stays at 91%, I'm wondering if my computer is completely ignoring that it has a battery at all and only shows its charge level. Doesn't charge it.. And doesn't use it.
Any help would be greatly appreciated as I dont have money for a new battery much less a new computer atm.
Sorry for the long winded post.. Just trying to be thorough.
Thanks.
Sent from my LG-H343 using WindowsForum mobile app
Thanks.
People expect "Gaming Laptops" to last just as long as PC desktops like 5-10 years life expectancy. Not going to happen anytime soon.
There are no Laptops on the planet that will handle online Gaming that I've seen, and I've owned several. Not only that, the PC industry keeps selling them with the intention of fooling people into believing they will fulfill that purpose.
As a computer engineer I've been designing computers for 40 years +, and have yet to be able to design a laptop that properly works for that purpose.
A custom-rig is usually the best way to go, and building it yourself lets you do a better job at self-maintenance. You can build solid gaming PC desktops for $500-$2,000 U.S. And if you're interested in recommended build-specs and prices, here's a link to help you out:
