SteelForce5
Hi, I am up late at times, and would like to turn my subwoofer off.
I am having trouble doing so. In the Sounds Panel, under Levels, I do not have a subwoofer tab.
Any help is appreciated, Thanks,
John
Post Script. I'm using Windows 7
The first place I would look for something like that would be on the Speaker unit. I cannot read the options on the system volume controller, but check that. Possibly a volume control on the sub woofer itself?
I suppose you have already checked the software that comes with the unit to see if it will control that one speaker, or has an option for setting volume levels for each type of speaker?
Jimbo22
Not much to go on here with out any system specs and what type of peripherals you have connected to the system.
Saltgrass
