In this WindowsForum thread, the original poster, Trevor, inquires about why his 1GB USB hard drive does not offer the safe removal option, unlike other devices. Contributors discuss potential causes, including power sources and device settings, with one suggesting that "safe removal required" being set to true typically means safe removal should be necessary; Trevor confirms this setting is enabled. The overall sentiment is that safe removal may not be available or necessary for certain drives, especially if they are hot-swappable or do not require safe removal, leading to some ambiguity about whether the feature should appear in his case.
Trevor Condon
Active Member
With all other devices I am given the option to safely eject before removal. However with my 1G USB hard drive I am not given this option. I'd be grateful if anyone knows a way around this. Thanks.
Yes all good! Apologies Saltgrass, originally I read your post wrong and was looking for Policies on the Device Manager list but not in Disk Drives where I've now found it as per badrobot's pic; sloppy work on my behalf. In details it says Safe Removal - Value - true, but I think I originally checked a box to make it that way (if that makes sense). Yes badrobot I get the same result - Quick removal. Problem solved thanks guys!
Saltgrass
There are two things you might check for the drive in the Device Manager. Look at the properties and the Policies tab. which boxes are checked?
Also look at the Details tab, and select "Safe removal required" from the drop down menu. What does it say?
Saltgrass
Bassfisher: no, it doesn't. Saltgrass: unfortunately those options do not appear in Device Manager.
So you don't have at least the designation shown in the attachment?
Trevor Condon
Active Member
Thread Author #6
Yes I'm sorry there is a 'disk drive' option. But I've checked 'safe removal required' and yet still it will not allow me to do that.
Saltgrass
If it says a Safe Removal is not required, then that is how it works. There are some devices, such as memory cards in a USB reader, if you safe remove them, it messes up the USB port.
Basically it is looking at whether you have data that might be accessed or, as Bassfisher mentions, if it has its own power supply so it doesn't get a power interruption during the disconnect. As you can see, my external drive does not require a safe removal.
badrobot
Not all USB drives needed to be "safely removed" especially if you have hot-swappable drives where once an appropriate software is installed, a user can plug and unplug the component without interruption to the system. You may also want to check this out:
An image from 'Unable to safely eject external hard drive'. Windows Device Manager showing Kingston USB device properties with removal policy options.
Saltgrass
Do you mean you looked at the setting and it shows Safe Removal as true, or you are using some checkbox to all safe removal?
I have checked all of my external drives and they all show safe removal as "false", but I do get the safe removal option in the hidden icons section on the Taskbar.
All of my devices, an external caddy and two externals, show the drive also under the Disk Drives section where it does have Policies tab I mentioned earlier but you stated you did not show any drives in that section.
The only other thing I would check is the USB controllers section in the Device Manager. When you plug something in you may get a Mass Storage entry. Mine just shows the same as the Portable device, but you might check yours.
You might give us the model of your External Drive so we can check.
Trevor Condon
Active Member
Thread Author #11
John Hanson
Banned
I bricked my flash drive once because forgot to safely remove it 😀
