sacarguy
For the longest time i have been battling a horrible slownes in my win 7 64 bit system.
Asus p6t MB
i7 -930 2.81 gig overclocked to 3.85 gigs
6 gigs ddr
Pny Nvidia gtx 470 over clocked as well.
All my games played horribly.. low frame rates etc etc.
well when over clocking my grafics card in a attempt to get more frames per second i ran cpu-z and bang there it was 1 core 1 thread being utilized
checked task manager/performance monitor and same only one cpu clock showing.
brought up msconfig and went to boot advanced and only 1 thread showing no option to select anything else.
updated mb drivers
updated all other drivers
same problem
so I simply uninstalled all 8 cpus from the device manager and ebooted and let windows redownload the drivers.. then on reboot i opend msconfig and sure enough all 8 were available i then clicked the box to use all 8 and now wow my rig is a screamer
batttlefield bad company on 1920x1280 is consistantly 70 to 75 frames per second with every detail seting to max.
i suggest anyone having slow system and poor game performance do a check to make sure you are using all your cores.
just download and run cpu-z abd see how many cores and threads it lists if its not 4 and 8 then you need to do the above.
In my searching across the net no one even recomended this simple fix all were saying a reinstall would be needed etc.
it worked perfect for me and should for anyone else with the same issue.
Mike
Windows Forum Admin
Did you use the Intel Chipset Drivers (Intel INF Update) drivers? This is a weird situation. Possibly motherboard compatibility issue?
sacarguy
asus p6t only allows you to select all or 1 or 2 there is no four option i had all selected..
i updated the bios via the asus updater
nothing would work
When windows loaded it for some reason would only see and use 1 core they were there in bios but NOT in windows msconfig/boot/advanced it simply showed one core as the only option.
unistalling all cores via the device manager reboot and allow windows updater to redownload the drivers fixed the issue.
all four cores are available in the msconfig menu now.
Im thinking some how this was a problem caused during instaltion but the reinstalling of the processor and its drivers in windows fixed it without a need for a full reinstall of the OS.
