The thread discusses permission and access issues with the D drive on a Windows PC, where the user is unable to open videos, save files, or rename folders, despite successfully changing folder permissions and running disk checks. The user also reports unexpected password prompts and error messages when performing operations on the drive, which do not occur on other drives or USB devices. The responses suggest checking drive health with chkdsk and resetting permissions, but the user continues to experience persistent problems, indicating possible drive corruption or deeper permission issues.
amrosia
hi,
video folder and videos inside d drive were not opening because of permissions.
if pc owner did not give control of his pc to anyone, where did permissions on the video folder come from. I used the internet to change permissions for this folder. permissions changed successfully . but opening video files inside the folder give various kinds of errors .
Also, files are not saving to the d drive.
how to fix this problem, please reply.
thanks.
Then it's very likely that drive is having physical problems, or the file system may be corrupt. I'd suggest running chkdisk on it with the following command
chkdsk D: /F
Neemobeer
Windows Forum Team
Unless you backed up the ACLs there is no rollback on ACLs for any given folder save for re-installing Windows.
If you're referring to the C:\Users\<username>\Videos then just turn on inheritance and the permissions will be what they should be
amrosia
Thread Author #3
@Neemobeer reintalling windows on c drive fixes the problem on c drive and usb drives but not on d drive. i cant even sa ve files to d drives.
Neemobeer
Windows Forum Team
chkdsk D: /F
amrosia
Thread Author #5
i ran chkdsk D: /F
below is result
An image from 'a folder has permissions problems, how to restore to default'. A Windows CHKDSK scan completed with no errors and 25.5 GB free disk space.
amrosia
Thread Author #6
but renaming a folder still wants an administrative password. But previously it didn't want the administrative passwords
plz help..
amrosia
Thread Author #7
when trying to save a file on d drive gives this error message
renaming a folder on this drive gives the following unexpected message, which has never received before.
and deleting a folder on d drive gives the following message
some nice guy on a forum gave/sent me some commands to execute them in elevated command prompt, which i executed successively but the problem remains
theres no such problem on other drives and on usb drives.
plz help.
thanks.
