PinkWonderGirl
- Joined
- Sep 6, 2015
- Messages
- 3
Hello,
I am not a techie at all and wanted to see if someone could look at the results of my chkdsk and let me know if there are problems? I had some bad clusters and something called read failures. I'd really appreciate any help or light someone could shed on this. I have read up on this in Google but I keep finding conflicting information.
Thanks!
Checking file system on C:
The type of the file system is NTFS.
Volume label is OS.
A disk check has been scheduled.
Windows will now check the disk.
CHKDSK is verifying files (stage 1 of 5)...
255232 file records processed. File verification completed.
1276 large file records processed. 0 bad file records processed. 0 EA records processed. 47 reparse records processed. CHKDSK is verifying indexes (stage 2 of 5)...
Read failure with status 0xc00000b5 at offset 0x392f2000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x392e4000 for 0x10000 bytes.
The USA check value, 0x1d0, at block 0x1 is incorrect.
The expected value is 0x2a.
The multi-sector header signature for VCN 0x2e of index $I30
in file 0x333c1 is incorrect.
42 41 41 44 28 00 09 00 ee d3 4f 68 10 00 00 00 BAAD(.....Oh....
2d 00 00 00 00 00 00 00 28 00 00 00 f0 07 00 00 -.......(.......
Correcting error in index $I30 for file 209857.
The index bitmap $I30 in file 0x333c1 is incorrect.
The down pointer of current index entry with length 0x18 is invalid.
00 00 00 00 00 00 00 00 18 00 00 00 03 00 00 00 ................
ff ff ff ff ff ff ff ff 8c 63 25 3e 48 93 d0 01 .........c%>H...
8c 63 25 3e 48 93 d0 01 8c 63 25 3e 48 93 d0 01 .c%>H....c%>H...
Sorting index $I30 in file 209857.
335722 index entries processed. Index verification completed.
CHKDSK is scanning unindexed files for reconnect to their original directory.
Recovering orphaned file LOG (1299) into directory file 209857.
Recovering orphaned file 001490.log (3172) into directory file 209857.
Recovering orphaned file LOG.old (22090) into directory file 209857.
Recovering orphaned file 001491.log (66561) into directory file 209857.
Recovering orphaned file 001497.log (72253) into directory file 209857.
Recovering orphaned file 001501.log (73920) into directory file 209857.
Recovering orphaned file 001498.log (85355) into directory file 209857.
Recovering orphaned file 001499.log (122102) into directory file 209857.
Recovering orphaned file 001502.log (125918) into directory file 209857.
Recovering orphaned file 001492.log (143421) into directory file 209857.
Recovering orphaned file 001493.log (144636) into directory file 209857.
Recovering orphaned file MANIFE~2 (158258) into directory file 209857.
Recovering orphaned file MANIFEST-000607 (158258) into directory file 209857.
Recovering orphaned file CURRENT (159811) into directory file 209857.
Recovering orphaned file 001500.log (159821) into directory file 209857.
Recovering orphaned file 001494.log (159967) into directory file 209857.
Recovering orphaned file 001495.log (180068) into directory file 209857.
Recovering orphaned file 001496.log (180072) into directory file 209857.
Recovering orphaned file 001488.log (180277) into directory file 209857.
Recovering orphaned file 001504.log (184153) into directory file 209857.
Recovering orphaned file 001503.log (186426) into directory file 209857.
Recovering orphaned file 001505.log (194748) into directory file 209857.
Recovering orphaned file 001489.log (198046) into directory file 209857.
Recovering orphaned file 001506.log (199921) into directory file 209857.
24 unindexed files scanned. Recovering orphaned file LOCK (209860) into directory file 209857.
0 unindexed files recovered. CHKDSK is verifying security descriptors (stage 3 of 5)...
255232 file SDs/SIDs processed. Cleaning up 186 unused index entries from index $SII of file 0x9.
Cleaning up 186 unused index entries from index $SDH of file 0x9.
Cleaning up 186 unused security descriptors.
Security descriptor verification completed.
40246 data files processed. CHKDSK is verifying Usn Journal...
35893664 USN bytes processed. Usn Journal verification completed.
CHKDSK is verifying file data (stage 4 of 5)...
Read failure with status 0xc00000b5 at offset 0x3f140000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f140000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f141000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f147000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f148000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f149000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f14a000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f14b000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f14c000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f14c000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f14d000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f14d000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f14e000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f151000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f152000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f155000 for 0x1000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f156000 for 0x10000 bytes.
Read failure with status 0xc00000b5 at offset 0x3f156000 for 0x1000 bytes.
Windows replaced bad clusters in file 75419
of name \Users\Lisa\AppData\Local\Google\Chrome\USERDA~1\Default\Cache\data_1.
255216 files processed. File data verification completed.
CHKDSK is verifying free space (stage 5 of 5)...
276914859 free clusters processed. Free space verification is complete.
Adding 10 bad clusters to the Bad Clusters File.
Correcting errors in the Volume Bitmap.
Windows has made corrections to the file system.
1932699647 KB total disk space.
824497360 KB in 192263 files.
125500 KB in 40247 indexes.
40 KB in bad sectors.
417311 KB in use by the system.
65536 KB occupied by the log file.
1107659436 KB available on disk.
4096 bytes in each allocation unit.
483174911 total allocation units on disk.
276914859 allocation units available on disk.
Internal Info:
00 e5 03 00 49 8c 03 00 3f b1 06 00 00 00 00 00 ....I...?.......
43 1e 00 00 2f 00 00 00 00 00 00 00 00 00 00 00 C.../...........
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Windows has finished checking your disk.
Please wait while your computer restarts.
Thanks!
Volume label is OS.
Internal Info:
