The user reports ongoing issues with Windows Update not functioning properly, despite trying multiple troubleshooting steps, including running fix tools and diagnostic scans. Several contributors suggest clearing update cache and modifying registry settings, which ultimately resolves the problem when the user manually adds a missing registry key per advice. Overall, the thread ends on a positive note with the issue successfully resolved through registry editing.
CDreier
Honorable Member
Windows Updates has stopped working. I've tried everything I can think of, trying to run Update after each of the steps shown below. Needless to say, my Update History is also gone after running these steps.
1) Ran KB947821 v34 x64 and restarted
2) Ran WuReset For Windows 7 & 8 and restarted
3) Ran Microsoft FixIt 50202 and restarted
4) Ran Windows Update Diagnostics (which showed it fixed problems) and restarted
5) Attempted to run KB947821 but got message it was not applicable.
Nothing has worked. Update just sits there but nothing downloads or is indicated even though Task Manager shows Update to be running.
I'm totally out of ideas. Thoughts on how to get this important feature back would be appreciated.
Neemobeer, you ARE the best. Believe it or not there was no registry key for WindowsUpdate! I have no idea why!! Anyway, I added the keys and entries as you suggested and everything is working fine. Solved. Thanks and Merry Christmas!
Neemobeer
Windows Forum Team
I would try clearing out all the Windows Update data and let Windows re-build it.
  • Press Winkey + r
  • Type services.msc
  • Stop Windows Update and Background Intelligent Transfer Service
  • Delete C:\Windows\SoftwareDistribution
  • Restart Windows Update
CDreier
Honorable Member
Thread Author #3
Thanks. I just tried your suggestion but that didn't work. Same problem. In looking at the Diagnostic Report (from 4 above), it shows everything was corrected. However, in Detection Details, it shows ErrorCode 0x80070057 and Collected File Name CheckSURLog.cab.
Neemobeer
Windows Forum Team
Adding or modifying these two registry settings has fixed the issue for some people.
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsUpdate\UX]
"IsConvergedUpdateStackEnabled"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WindowsUpdate\UX\Settings]
"UxOption"=dword:00000000
CDreier
Honorable Member
Thread Author #5
