The thread discusses concerns about bricking hard drives when enabling the Power-Up Idle Standby (PUIS) setting. The original poster shares their experience of safely changing firmware versions without issues, especially since their WD hard drive had PUIS disabled by default, and later confirms that their issue has been resolved. Overall, the sentiment is positive, indicating successful modifications without problems.
iosman123
Banned
Hello,
I having read on line about bricking hard drives with the puis setting have any other had any problems?
I changed 9841 to 9879 and didn't have any problems was using a WD hard drive which by default puis is not enabled.
thanks
iosman
