Aimee
Member
Hello everyone! ♥
I'm facing an incredibly frustrating problem with my laptop. First of all I would like to say that the laptop has been exchanged once for an identical one, and the same problem occurs on the new one. Also a full system recovery does not fix the problem.
The problem is either the mouse buttons or the touchpad; but not all the time, it only happens when I'm clicking and dragging something, ie: scrolling down Google Chrome, changing the size of a window or changing the border size on Microsoft Word.
I really don't know how to describe this, but I'll do my best while trying not to ramble.
Usually when you click and drag something, the process goes:
'click the mouse button, drag the cursor, release the mouse button, done'
Well, mine goes:
'click the mouse button, drag the cursor, release the mouse button, the laptop doesn't register that I've released the mouse button, and whatever I was dragging goes mental on the screen wherever I move my cursor to; and won't let me do anything else.'
When it does this, it's a case of waiting for it to stop. I can't click anything, pressing escape does nothing, only the right click works, not the left. Usually within a minute it's stopped, but sometimes a few seconds later it does it again. It occurs randomly, and only when I'm clicking and dragging something/anything.
I'm getting so tired of this, it's very stressful, can anyone help me please?
Laptop: Acer Aspire E1-572
System: Windows 8.1
Device manager: HID-compliant mouse (updated to latest)
Synaptics PS/2 Port TouchPad (updated to latest)
Screenshots of current mouse settings (if it helps!):
1 -
2 - Link Removed
2 - Link Removed
Thanks in advance ♥
If you're viewing this thread and have the same problem, here is my solution progress. Hope it helps:
Updated drivers (including BIOS) to latest versions Link Removed - didn't work.
Changed some scrolling settings Link Removed - didn't work
Did this: Link Removed - didn't work.
Intel updates: Link Removed - didn't work.
Turned down the setting for Smart Sense - Link Removed - didn't work.
Completely uninstalled all Synaptics software and redownloaded an older version from Acer's website - WORKED!
Issue resolved - thanks everyone who commented, special thanks to Kemical for your persistent help and support here.
strollin
Honorable Member
You might try going into the Device Settings and disabling the Touchpad when a mouse is plugged in. Some people (like me) have problems where they accidentally brush across the touchpad when moving the mouse or using the keyboard and that can cause strange behavior.
I haven't heard of anyone encountering the issue you are experiencing but it's as good a place to start as any.
Aimee
Member
Hi there, thanks for the reply!
I actually use the touchpad and mouse-buttons so disabling them completely wouldn't be useful to me. :(
Anyway, it happens when I'm deliberately trying to click and drag, not if/when I accidentally brush the touchpad.
Thanks anyway though.
Aimee
Member
'Is the behavior the same regardless of where you are dropping the files? In other words, it happens regardless of whether you are dropping on the same drive, different folder or a different drive on your machine or a network drive?'
It doesn't matter what I'm doing on my computer, it does it randomly when I click and drag something, and it's always the same thing. It did it just then when I was trying to scroll down in 'My Photos' and it did it earlier when I was scrolling down Gmail looking for a certain email, and again when I was trying to select some text to copy.
'Is the behavior the same if you use right-click & drag?'
Right click and drag doesn't do anything, it just shows me the standard, available right-click options.
'Just off the top of my head, I would be suspecting some 3rd party software that you have installed or some tweak you may have done. Did you notice this behavior happening from the very beginning of using the computer, before installing any software or making other changes?'
Like I said, it's done it since the moment I first logged into Windows for the first time, a factory reset didn't fix it and neither did an exchange for a different (identical) laptop.
Hope this helps! I feel like getting a desktop just so I have a desk to smack my head against xD
Hi Aimee,
have you checked the machine is fully updated including all drivers and Bios? The support page for your system is here:
I also noticed that the driver versions under windows 7 are of a later date then the versions shown under Windows 8/8.1. It might be worth trying the later versions if possible?
Aimee
Member
Thank you for replying! I'll do that now, I tried updating them before but it said the latest available software is already installed. I'll use the link you've provided though.
Thanks ♥
Aimee
Member
All installed, hopefully it worked! I'll be posting here again if not :)
Thanks a lot!
Aimee
Member
Alas, it just did it to me again :c this time when I was trying to scroll down a Facebook conversation window. Grr.
Hi Aimee,
I did a little Googling and found a post in the Acer support section. The contributor does have several solutions it seems although the outcome seems vague. Have a look anyway:
http://community.acer.com/t5/Notebo...2P-6847-track-pad-scrolling-issue/td-p/215631
I don't want to be the bearer of bad news but i did find a few different links to this machine and this issue.
Aimee
Member
Aww thanks for getting back to me again, I'll take a look.
I looked through those links again and realised they are no help what so ever..Apologies.
More searching led to one user who had a similar issue and his only way round it was to plug in an external mouse... To be honest I'd seriously consider taking it back for either a refund or another model. You've tried updating the drivers and Bios without success. Surely it's time to weigh in on the warranty?
Aimee
Member
Yeah :(
It's a nuisance because I've already had it exchanged once. They won't exchange it anymore either because it's over the 28 day period, they'll just send it off for a repair instead which could be up to six weeks. Eurgh.
I did a little more looking and checked out the Acer support forum. That led me to this troubleshooting page for the Touchpad. It's mainly about changing sensitivity and the like but again it might be worth a look:
Aimee
Member
Yes that was the first thing I did, they politely told me to go away and said that it's a Microsoft issue not an Acer one.
They did what? Sounds like the buck is being passed here. Personally I'd phone them back and stand your ground. You bought something in good faith that it was in working order.
You've tried applying updates but nothing has improved and if it's down to Microsoft how come every other laptop, of the same model, isn't having these issues too? (or are they...)
Aimee
Member
Yeah I know. I can't call them because I only have a cellphone and it would cost a fortune to call them. I actually contacted them the first time via the live web chat.
I've just tried this: Link Removed
If it doesn't work, I'll contact Acer again.
Jimbo22
As Kemical mentioned, do you have the latest BIOS installed? What bit version of 8 do you have....32 or 64? The latest version is: 2.17 for windows 8.1 64 bit.
An image from 'Click and drag fault.'. Acer BIOS updates listed with version, size, date, and caution notice for safe installation.
What drivers did you update? Since this is an intel based system have you tried using the Link Removed?
Aimee
Member
'Do you have the latest BIOS installed?'
I have no idea, when I clicked the link Kemical provided there was a warning that changing the BIOS incorrectly could mess up my laptop even more, so I decided not to try it unless nothing else worked as I don't know what I'm doing properly.
'What bit version of 8 do you have....32 or 64? The latest version is: 2.17 for windows 8.1 64 bit.'
I have Windows 8.1, not sure what version or how to find out, I'm still getting used to it. Link Removed
I performed the Windows updates yesterday, when they finished and my laptop restarted, it wouldn't let me log on to Windows. I had to perform a system restore to get back in. I have not updated since.
'What drivers did you update? Since this is an intel based system have you tried using the Link Removed?'
I updated the two drivers for the touchpad, (and all other drivers) which didn't work. I haven't tried that yet but I'll try it now, thanks.
