The thread discusses how disabling the Recycle Bin’s deletion behavior via properties only affects future deletions, not existing files. The original poster seeks methods to delete all current Recycle Bin contents on an external drive, considering manual removal or smarter options. Respondents confirm this is normal behavior and suggest using methods like unhiding system folders or employing Disk Cleanup to clear all Recycle Bin files across drives.
pstein
Assume I have an external hard disk with one (backup) partition which is currently mounted as drive Q:\
Now I right-click on the Recycle Bin icon on my desktop, then select Properties--->Drive Q: and enable
"Don't move files to the recycleBin. Remoive files immediately when deleted"
Much to my surprise this switch does NOT delete currently existing stuff in RecycleBin of drive Q:\
The toggeling applies only to future deletes.
Can someone confirm this strange behaviour?
How can I tell Win 7 to delete ALL currently existing files in RecycleBin of drive Q: ?
Can I simply unhide "protected folders" in WinExplorer and delete all the files manually?
Or is there a smarter way?
How do I delete all files+folders fom all RECYCLEBINs from all partitions currently mounted?
Peter
This is normal behavior, and yes you can could unhide C:\$Recycle.Bin and delete the content inside, or run the Disk Cleanup utility and check the box next to Recycle Bin will also work.
Neemobeer
Windows Forum Team
