vettenut
I am running 2 PC's both with Windows 7 Ultimate 64 bit system. The laptop will not let me modify a home group. What should I do to get past this problem?
I did that with the same result.
Try this: Go to C:\Windows\ServiceProfiles\LocalService\AppData\Roaming\PeerNetworking and delete all of the files in this folder. Now restart the computer.
Go to Services again and you should be able to start 'Peer Networking Grouping' and 'Peer Name Resolution Protocol'. Restart the computer again.
When you log on this time, check the event log again, to ensure no errors concerning the two services are present and also check Services to ensure the two services concerned are running.
You should now have full functionality restored to your homegroup.
vettenut
Another thought
I have been a Microsoft customer since the first release of Windows as well as the first release of Office. I cannot connect to the Internet on my laptop. What can be done to resolve my problem? I am getting weary of trying things that do not help me.
JessicaD
From the sounds of it you might be a victim of malicious software -- you are unable to perform certain administrator tasks and you cannot get on the internet? What type of internet connection do you use?
When you say that your laptop will not let you reinstall Windows -- what do you mean? Which error message do you receive?
