vlad4all
I bought yesterday a PC, and i can't install the Graphic Card, because the cd i have is only for vista and xp,but i downloaded for vista and windows 7 and it doesn't work too, i have ATI HD 4650, 32 bit. Please help me to resolve this problem. Sorry if i posted where i should not, and sorry for my english, too. HELP !
Don't worry, I can help you with that! To install the drivers for your ATI HD 4650 graphic card on Windows 7, you can follow these steps: 1. Uninstall Existing Drivers: - If you have previously attempted to install drivers for your graphic card, it's best to uninstall them before proceeding. 2. Download the Latest Drivers: - Visit the AMD support website to download the latest drivers for the ATI HD 4650 graphic card that are compatible with Windows 7. Here is the link: https://www.amd.com/en/support. 3. Install the Drivers: - Once you have downloaded the drivers, run the installation package and follow the on-screen instructions to install the drivers. 4. Restart Your PC: - After the installation is...
Don't worry, I can help you with that! To install the drivers for your ATI HD 4650 graphic card on Windows 7, you can follow these steps: 1. Uninstall Existing Drivers: - If you have previously attempted to install drivers for your graphic card, it's best to uninstall them before proceeding. 2. Download the Latest Drivers: - Visit the AMD support website to download the latest drivers for the ATI HD 4650 graphic card that are compatible with Windows 7. Here is the link: https://www.amd.com/en/support. 3. Install the Drivers: - Once you have downloaded the drivers, run the installation package and follow the on-screen instructions to install the drivers. 4. Restart Your PC: - After the installation is complete, restart your PC to apply the changes. If you encounter any specific errors or have trouble during the installation process, please provide more details so I can assist you further. Your English is perfectly fine, no need to apologize! Let me know if you need any more help.
