The thread discusses issues with achieving the expected 6Gb/sec speeds on a Samsung 850 EVO SSD connected via a Marvell 88SE91xx controller on an older ASUS P7P55D-E LX motherboard with Windows 10, as users note the drive is only reaching around half that speed. The original poster suspects driver compatibility or limitations of the motherboard’s SATA ports, with some suggesting the motherboard's older SATA ports inherently limit speeds, and others mentioning that BIOS or hardware settings like "IO Level Up" could influence performance. Overall, the consensus indicates that hardware age and driver support are likely causing the reduced speeds, with suggestions to consider older OS versions or hardware upgrades for optimal performance.
SvB4EvA
First off, thank you for your post.
This driver installs properly and the disks attached to the controller are working, but not at the 6Gb/s speed that they should.
Any ideas before I have to go back to Win7?
I did some checking and those Marvel controllers do run a little slower, isn't there a Intel port available as you have 6 of those?
Check this post I found via Tomshardware: Link Removed
I also checked your driver support and your board is only supported up to Windows 8.1. so might be worth going back to an earlier os although I still doubt whether you'll get faster speeds unless you use rapid mode via the Samsung Magician app?
could you post some details on your system please. As well as the speeds being reported thank you.
SvB4EvA
Thread Author #3
Core i5 760
ASUS P7P55D-E LX mobo
Windows 10 Home (x64)
Long story short, old SSD died on me. Had it running in same exact system with write speeds @ 700+ MB/sec. (SATA III) That was on Windows 7 though, with the correct drivers from Marvell.
I bought a new SSD (Samsung 850 EVO 500GB), it is only running at 3Gb/sec speeds, @ about 375 MB/sec.
I am thinking that even tho these Marvell 91XX drivers for Win10 installed and are displaying in Device Mgr correctly , they are not working properly and that's why I am stuck at SATAII speeds.
My BIOS indicates the new drive should be operating at 6Gb/sec, as well as Samsung's (useless) SSD software.
The exact name if the Marvell controller I have is "Marvell 88SE91xx Adapter".
Any thoughts or ideas are greatly appreciated. If I can't get the drive up to speed, I will either go back to Win7 or just live with the drive at half the speed it should/could be.
Neemobeer
Windows Forum Team
Looks like the motherboard SATA ports operate at 250MBps unless you enable "IO Level Up" (a little toggle switch) which should bump them up to 500MBps which is close to the max throughput on the 850 evo 540MBps
