Chrisao
Good night, friend! I am using a translator to write this, so apologies if there are any errors.
I am having a problem with my computer, a while ago when I turned on the computer the processor COOLER turned on along with the other coolers and then I could get access to windows in 10 seconds, now the processor cooler only turns on a while after all the others have turned on and it takes 20 seconds to turn on. Does anyone know what I can do to fix this? Thanks friends!
This video is to show what is happening on the computer
It seems like there is a delay in the startup of your processor cooler in your computer. Here are some steps you can try to diagnose and potentially resolve this issue: 1. Check BIOS Settings: - Access your computer's BIOS settings (usually by pressing Del, F2, or F10 during startup). - Look for any settings related to fan control or power management. Ensure that the cooler is set to start promptly. 2. Inspect Physical Connections: - Power off and unplug your computer. - Open the case and ensure all the connections to the CPU cooler are secure. - Check for any loose power or fan connections. 3. Update or Reset BIOS: - If the issue persists, consider updating your BIOS to the latest version. - You can also try resetting...
It seems like there is a delay in the startup of your processor cooler in your computer. Here are some steps you can try to diagnose and potentially resolve this issue: 1. Check BIOS Settings: - Access your computer's BIOS settings (usually by pressing Del, F2, or F10 during startup). - Look for any settings related to fan control or power management. Ensure that the cooler is set to start promptly. 2. Inspect Physical Connections: - Power off and unplug your computer. - Open the case and ensure all the connections to the CPU cooler are secure. - Check for any loose power or fan connections. 3. Update or Reset BIOS: - If the issue persists, consider updating your BIOS to the latest version. - You can also try resetting the BIOS settings to default. 4. Check CPU Temperature: - Install software to monitor your CPU temperature. - Ensure that your CPU is not overheating and causing the cooler to delay its startup. 5. Test Fan Speeds: - Use software to test and adjust the fan speeds manually to check if the cooler responds when prompted. 6. Power Supply Check: - If the issue continues, it might be related to power supply irregularities. Check the power supply unit (PSU) and its connections. 7. Consult Manufacturer Support: - If all else fails, consider contacting the manufacturer's technical support for further guidance and assistance. By following these steps, you should be able to diagnose and potentially resolve the delay in your processor cooler startup. Let me know if you need further assistance or have additional questions!
