The original poster faced an issue on Windows Vista where they couldn't re-enable a setting to prompt before downloads after accidentally disabling it, and their attempts to fix it through Internet Options didn't work. A fellow user asked for the browser details, which the original poster clarified as Internet Explorer 9; eventually, the problem resolved itself, possibly after a restart. The overall tone is informal, and the thread concludes with a suggestion to update Internet Explorer for better performance.
Amb669
Hey guys, i have a prolem on windows vista x64, I accadently clicked off "always ask before downloading" box at the start of a download and now i can't re-enable it.
I tried going to internet options and going to "advanced tab" and clicking reset and clicked "delete personal settings" and it didn't help.
I also tried going to internet options and clicking on "security tab" then clicked on "custom level" and clicked "reset"
I also tried going to internet options and clicking on "security tab" then clicked on "custom level" and looked through the list for "automatic prompting for file downloads" but it doesn't even exist in my list??
Anyone know what is wrong?? i can't imagine reinstalling windows for such a STUPID thing like this.
Thanks.
Good the issue is gone. Still, I would recommend updating IE.
Cheers,
Drew
An image from 'Help, my computer automatically downloads links when clicked'. Windows 8.1 logo with blue icon and text on a white background.
Amb669
Thread Author #3
What browser are you using?
Oh yeah, i guess that might help huh, haha.
I'm using internet explorer 9
EDIT: The issue seems to have resolved itself after some time, (maybe after restarting or something could have fixed this issue?? But i'm not sure what exactly fixed it forsure)
Drew
Banned
Cheers,
Drew
