RogerTan
IMG_20110111_143627.webpIMG_20110111_145143.webpIMG_20110111_144808.webpIMG_20110111_143635.webpIMG_20110111_144756.webpIMG_20110111_143544.webpIMG_20110111_143554.webpIMG_20110111_182433.webpIMG_20110111_182453.webpIMG_20110111_181048.webpIMG_20110111_182440.webp
View attachment msinfo 32.txt
What is the problem with my laptop? I have try formating it but it didn't solve the problem. :waah::waah:
I'm able to see Chinese from the web but when i copy n paste it to my laptop it shows boxes. This problem apply on Korea n Japanese Language only.
PLS is there anyone who know how to solve this problem?? :pray:
If you want install a language pack in Windows 7, then it is very easy.
Windows 7 provides around 7100 languages. You can download the languages from Microsoft site.
You have to select ‘Regional and Language Options’ in the ‘Control Panel’.
If you want to install a language, you need to just click the ‘Install or Uninstall Languages’ tab.
pctech33
