The original poster is asking if it's possible to grant remote access to only the secondary monitor on a Windows 10 desktop with a dual-monitor setup, so others can work on the secondary while they work on the primary. A responder confirms remote access is possible but clarifies that only one person can control the system at a time, meaning simultaneous independent control of each monitor isn't feasible. Overall, the thread discusses the possibility of partial remote access and clarifies the limitations.
lieiti
I need to allow someone to remotely connect to my windows 10 desktop, and am wondering if this is possible:
I have a dual desktop monitor setup that is extended (not mirrored), and am wondering is it possible to grant someone remote access only to the secondary monitor?
I would like to work on the primary while he works on the secondary remotely.
Please advise if possible and if so how to set it up.
Thanks!
Neemobeer
Windows Forum Team
Yes you can allow someone to remote in, but no you can't have two people controlling it separately at the same time.
