stereo
Hello everybody.
I changed all the OS fonts from Segoe UI to Arial. Looks much better for me.
But here are still some fonts in the OS which i was unable to change them.
How can i set everything to Arial ?
In this link you'll see that in Everest the fonts are not Arial.
Same when i move arround the mouse cursor over the tray icons ( day,month letters )
Check the pics, please :
Thanks.
Thanks Cybercore.
But i'm sure, you didn't read carefully my first post.
I know about this options from this link.
I'm sure I did, if you already knew or not all or something from that tutorial was not clear. As for EVEREST, I suspect it is something to hack in EVEREST to change its fonts. As for aero colors and fonts, you may want to research on aero.msstyles.
Good luck.
stereo
Thanks Cybercore.
cybercore
Thanks Cybercore.
Good luck.
