The original poster seeks a simple command-line method to manually create Windows System Restore Points on Windows 10, akin to third-party tools available on Windows 7. Responses suggest using PowerShell scripts, such as a batch file running the `Checkpoint-Computer` command with administrator privileges, to streamline creating restore points but note some limitations like minimum intervals between restore points and execution policy prompts. Overall, the thread provides practical scripting solutions for easier restore point creation on Windows 10, highlighting a preference for simpler, less click-intensive methods.
pstein
Ok, I can create manually a SRP by navigate with lots of clicks to the Win10 built-in dialog.
But I prefer a much simpler way to do this with as few clicks as possible.
Is there a built-in cmdline command which let me do that? Something like
createsrp.exe -label "my sysrestpoint 123"
On Windows 7 there were a lot of 3rd party SRP tools which ease this function very much.
Since these Win7 tools do not work any more on Win10 may I ask for some similar tools for Win10?
Thank you
Peter
Since it does require elevation one way you could do it is create a .bat file with the following code
powershell -command "& {Checkpoint-Computer -Description 'Script Created Restore Point' -RestorePointType MODIFY_SETTINGS}"
To run it you would simply right click the .bat file and select "Run As Administrator". It is worth noting you can't create restore points less than 24 hours apart.
Neemobeer
Windows Forum Team
Neemobeer
Windows Forum Team
Other way would be create a .ps1 file and have the following code
Start-Process -FilePath "C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe" -Verb RunAs -ArgumentList "-command `"& {Checkpoint-Computer -Description 'Script Created Restore Point' -RestorePointType MODIFY_SETTINGS}`""
To run it you would right click the PowerShell file and select Run with PowerShell.
A couple of caveats would be the PowerShell execution policy is enabled by default so you'd have to accept the prompt every time by pressing 'Y' or you'd need to change the execution policy once with Set-ExecutionPolicy -ExecutionPolicy Unrestricted -Scope LocalMachine
