casi
hello everyone.i have a question how can i get winamps equalizer to work,i must ad that i have got srs hd audio lab installed and that program controlles my audio,should i adjust sound on srs hd audio lab controller(HAL) or what:confused:KIND REGARDS CASI.PS. i just thourght it would be fun to use the equalizer.
Hi
Click on "View" check "Equalizer" and the controls will appear at the top of the window.
I have to say that in the new version they are very small!
Mike
MikeHawthorne
Hi
Mike
