The original poster accidentally erased their entire drive without a Windows installation disk and is seeking help. Respondents suggest using the Windows 10 installation tool to create a bootable USB for Windows 10, which could activate with their existing Windows 7 serial number, or utilizing the PC’s recovery partition if available. Overall, the community leans toward creating a bootable USB as the more reliable solution.
