right now I am having a few problems with my newly built pc on windows 10. first of all, the start menu is not working. whenever I try to open the start menu or settings it just does nothing. my second problem is that the error “you’ll need a new app to open this ms-wpc link” keeps popping up whenever I log into the computer. I can click on the screen to hide it temporarily but it would come back in 30 seconds or so. to be completely honest I don’t know where to start on either of these problems.
The thread discusses a newly built Windows 10 PC experiencing issues with an unresponsive start menu and recurring errors related to “ms-wpc,” identified as Windows Parental Controls. The user seeks help, and Neemobeer suggests a PowerShell command to fix the start menu and explains that the ms-wpc issue is likely linked to parental controls. The original poster confirms that running the suggested command resolved both problems, indicating that the parental controls were causing the issues.
ms-wpc is Windows ParentalControl so it's likely associated to that, so you can try the following command from a powershell prompt.
Get-AppxPackage -Name *parent* | % { Add-AppxPackage -Path "$($_.InstallLocation\AppxManifest.xml)" -Register -DisableDevelopmentMode If it returns nothing than it worked, but if you get any red errors let me know.
- Joined
- Jul 4, 2015
- Messages
- 8,994
This should help you get the start menu working. How to reset the Windows Start Menu
- Joined
- Jul 4, 2015
- Messages
- 8,994
we do have parental controls on this computer, that most likely has something to do with it.ms-wpc is Windows ParentalControl so it's likely associated to that, so you can try the following command from a powershell prompt.
