The thread discusses a computer issue where a popping sound occurs through the speakers after installing a Creative Live! Cam, likely caused by driver problems. The original poster considers driver updates as a solution, with a reply suggesting that installing proper drivers—possibly from a driver disc or Vista-compatible versions—can resolve such issues. Ultimately, the original poster confirms that using the motherboard's original drivers fixed the problem.
1morebogen
After I installed Creative Live! Cam, the computer make a pop sound some times, tru the speakers.
I dont have a sound card, only the bult in.
Ideas?
i believe its a driver issue, my system did the same with the default windows drivers for my soundcard (but different system from yours) until i installed a new driver - is there a driver disc you can use or a maybe a vista driver for your onboard soundcard?
montyuk
1morebogen
Thread Author #3
Thanks. The orginal driver for my MB works perfekt
