A user reports that running and then closing Procmon causes an error when launching privileged programs, suggesting a lingering system monitor or driver remains. Despite others' assurances that Procmon's driver unloads upon exit, the user observes persistent issues and suspects residual kernel-mode components, possibly impacting certain applications like PokerTracker. The discussion highlights uncertainty about whether the problem originates from Procmon or specific software interactions, with some evidence pointing to lingering drivers detected by security tools.
PaulSp
Member
I recently downloaded the procmon tool. I've noticed that after stopping it a subsequent attempt to run a privileged program gets an error dialog saying that a system monitor is running and to remove it. This prevents the privileged program execution. Rebooting cures the problem. The two times that I've run procmon, this has happened. Has anyone else seen this behavior?
Ok. Another data point. I tried running a different program requesting privilege and didn't get the error dialog. So there must be something about the program itself (PokerTracker) that is generating this error. So unless you play poker, you're not likely to encounter this, I suspect. I will report this to the PokerTracker developers and see what they say.
PaulSp
Member
Thread Author #3
Clearly some remnant of procmon has remained after its termination, else I wouldn't get the error that I did.
PaulSp
Member
Thread Author #5
I will experiment a little further. It has occurred to me that perhaps I clicked the "X" to close it rather than using its "exit" function. This could possibly result in procmon not cleaning up as it should. I will post results after I try this.
Neemobeer
Windows Forum Team
Exit and clicking the x have the same result. Procmon consists of a single process and a driver both unload when procmon is closed.
PaulSp
Member
Thread Author #8
Ok, I ran procmon and then performed a File-> Exit. Then when I tried to run a privileged program I got the attached error.
PaulSp
Member
Thread Author #9
PaulSp
Member
Thread Author #10
Searching the internet has provided other users with similar problems. According to some reports, these tools load a "kernel mode driver" which remains after the program (in this case procmon) exits. WinLicense is apparently a tool used by some developers to manage their software distributions. It apparently detects this driver somehow. I'm not sure who should fix this.
Neemobeer
Windows Forum Team
It's likely some anti cheat or drm mechanism. So the fix would be on the developers end.
PaulSp
Member
Thread Author #12
Yes. The PokerTracker folks say that it was done on purpose for "security" reasons. I fail to see what I could obtain from PokerTracker using procmon that would be a security problem.
