LostData
I "successfully" applied SP1 to my W7 system.
Two issues: 1) the hibernate/sleep function is gone. This is a desk top. At the end of the hour, the system shuts down. No USB/mouse wakeup. Pressing power-on does a reboot. The W7 power options seem to be set correctly (unless I am missing something).
2) When I do reboot, the netgear 300 USB receiver can't find the router. If I unplug/replug, all is well. I uploaded the lastest driver - no change.
Be very grateful if someone has a solution -
What do you have programmed to happen at the end of the hour? You may have to reset your options after the update. Have you checked Device Manager to make sure the settings for your Netgear receiver have not been changed or a new drive for it was installed?
Saltgrass
