The user reports a failed Windows 8.1 installation after downloading content from a torrent, with their Toshiba laptop stuck on a loading screen during a presumed format process interrupted by a power outage. Respondents suggest using a repair or installation media to fix the issue, with one providing links to Microsoft's recovery tool and Toshiba support resources. The overall tone is helpful and encouraging, advising the user to attempt repair options to resolve the stuck installation.
Krazykid
K so here's the story. I downloaded something and restarted my computer. It says windows isn't working correctly and asks if I'd like to format. I clicked yes but during the format my laptop shutoff from lack of power. I turned it on and it's been on the same screen for an hour now. I'm worried that I may have messed something up. Is it still formatting even tho it didn't ask this time? The screen has a loading circle but I'm not sure if it's even doing anything. Any idea how long this should take until it's normal?
Can you give a little more detail on:
What you downloaded and initiated
Which operating system your using
Make and model of your machine.
Krazykid
Thread Author #5
Your very welcome. If this doesn't help or if you encounter any other issues please post back. Oh and I forgot to post this.:
http://support.toshiba.com/support/modelHome?freeText=1200010411
Support page from Toshiba.. Good luck!
