The thread discusses issues after upgrading to Windows 11, where users experience connectivity problems with public Wi-Fi and hotspots, often displaying the error "No Internet access." Troubleshooting steps such as disabling random hardware addresses and VPNs like Surfshark are suggested, with some users experiencing their internet breaking completely requiring system restores. Overall, the thread highlights ongoing concerns with network stability and VPN conflicts following the upgrade, with users seeking solutions to resolve their connectivity issues.
Androlyn
Just updated from Windows 10. WiFi works from home but I am unable to connect to a public wifi or personal hotspot. I have tried every troubleshooting guide i can find but the issue persists. In the network & settings section I have the following error:
No Internet access: your device can only access other devices on your local network.
I have googled that exact sentence but nothing shows. I have also tried to turn off firewall and security but it doesn't help.
Anyone have the same issues?
Neemobeer
Windows Forum Team
Many public networks will use your MAC address to allow access. Make sure 'use random hardware addresses' is off in Settings > Network > Wi-Fi
Androlyn
Thread Author #3
Yes that's set to off.
Now my internet is not working at all nor showing in settings.
This is the 2nd time this has happened in a week of installation - I have to do a system restore to fix.
Could the problem be arising by using a VPN? Out of the changes between Windows 10 & 11 - I noticed the VPN settings have been included. I am using Surfshark - could this be causing the conflict?
Neemobeer
Windows Forum Team
Yes it could. You can try removing it and testing
Warfaree
Honorable Member
I use Zen Mate and this VPN also turned off my Internet access.
