The user originally experienced difficulty accessing a mapped network drive in Windows XP Mode within Windows 7 when setting up an ODBC connection, as the drive wasn't visible in the database selection window. They later resolved the issue by working with a network specialist to adjust the network drive mapping, which allowed the ODBC setup to succeed. The community responded positively, appreciating the user's update and welcoming them to the forum.
bubu678
I am running virtual XP mode in WIn 7. In XP I am able to map a drive G: that is from Win 7 mapped drive (Microsoft Terminal Services). Great, in Explorer you can see the mapped drive. I need to set up an ODBC connection to a database on that drive. No problem I thought. When I need to select a drive in the Select Database window, I cannot see that drive, only A:, C:, D: , the default drives, G: is not shown.
Is this a bug, or is it normal? Did I do something wrong?
Any help would be appreciated. I have attached a screen print.
Thanks
I finally solved it.
I got a hold of our knowledgeble network person and were able to map network drive. It just needed another format/prefix on the login window. I was then able to setup an ODBC for the Access database.
Looks like virtual XP doesn`t respond well with to tsclient, so had to use normal windows mapping.
Another problem solved!!
bubu678
Thread Author #2
Trouble
Noob Whisperer
Hello and welcome to the forum.
Good to hear that you were able to resolve your issue and thanks for posting back and updating your thread with the solution that worked for you.
Very nice to have those types of knowledgeable folk at your disposal.
Thanks for joining our community and we hope to continue to see you around the forum.
Regards
Randy
